![]() | | #2281 | ![]() |
| Not Ranked : 0 score Trouble is you will not really know where MBT is without a dyno So once you go past MBT you over stress the rods which can lead to failure but you still don't get any knock. you can however make much more power very safely by running a mix and say add a degree or so more than you were on 91/93 and knock limited. This is why Phate put together the database so you can see what others are making on dynos with varying E mixes and hardware.
| The Following 5 Users Say Thank You to Dano For This Useful Post: | Boost_creep (12-30-2011), djuosnteisn (01-03-2012), Nataphen (12-29-2011), phate (12-29-2011), SJP0tato (12-29-2011) |
![]() | | #2282 | ![]() |
![]() Join Date: Dec 2010 Location: St. Louis
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,169
Groaned at 25 Times in 25 Posts
| Not Ranked : 0 score for the love of god......all i can tell you guys.....tune your knock sensor on 93/91 and then copy it over to your e85 map...DO NOT tune out "ENGINE NOISE" when on your e85 map... Knock you get while on e85 should raise some alarm to you if you do this all right....My be a good time to back timing down and or get on a dyno and actually tune your shit.
__________________ EWG K04...GETSUM! A journey to make people cry like babies when loosing to a wagon. |
| The Following User Says Thank You to bewsted For This Useful Post: | Nataphen (12-29-2011) |
![]() | | #2283 | ![]() |
| Not Ranked : 0 score Dunno, I am still knock limited on a 3/9 mix, and there is no way I am running my 93oct timing +1/2deg. I was knock limited at 9* peak on pump @ 11.2AFR, and the mix allowed me to gain over 80whp through 8* more timing and 12AFR. Note though, I am using a load tune with the express purpose of keeping cylinder pressures manageable over varying temps. It's only hitting ~16-17psi in the 3-4k range now to maintain ~400wtq with the extra timing and 50deg ambients. Past MBT or not, the extra timing plus a boost tune thats just going for 22psi would be headed towards 500wtq quickly. Even running at MBT significantly increases cylinder pressures while having a small effect on power.
![]() | | #2284 | ![]() |
| Not Ranked : 0 score Just some sketches done from memory to illustrate my point. Even reaching MBT significantly increases cylinder pressure. First up your basic cycle using instantaneous combustion. ImageUploadedByTapatalk1325212150.954953.jpg Now a couple figures for non-instant combustion ImageUploadedByTapatalk1325212165.537341.jpg The key is you never achieve peak pressure directly at TDC when at MBT; you lose more power by having combustion going on while compressing (hogher pressure at point 2) than gained so you stop adding timing. However going past MBT moves point 3 closer to TDC and up that exponential cylinder pressure curve.
| The Following 7 Users Say Thank You to Ziggo For This Useful Post: | 86AmishMs3 (12-29-2011), djuosnteisn (01-03-2012), kritz (12-30-2011), Nataphen (12-29-2011), Nliiitend1 (01-03-2012), rfinkle2 (12-30-2011), SJP0tato (12-30-2011) |
![]() | | #2285 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold | |
![]() | | #2286 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
| Not Ranked : 0 score ^Agreed. @Ziggo, just because I thank you doesn't mean that I have the slightest clue what you're sketching, but I appreciate your effort to explain things to the simple folk here (me). |
![]() | | #2287 | ![]() |
| Not Ranked : 0 score It all always comes back to thermodynamics!
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | 86AmishMs3 (12-30-2011), cld12pk2go (12-29-2011) |
![]() | | #2288 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
| Not Ranked : 0 score Oh YEAH. Thermo FTMFW!
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | rfinkle2 (12-30-2011) |
![]() | | #2289 | ![]() |
![]() Join Date: May 2011 Location: Phoenix
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30,524
Groans: 156
| Not Ranked : 0 score speaking of thermodynamics... |
| The Following 4 Users Say Thank You to josurr For This Useful Post: |
![]() | | #2290 | ![]() |
Groans: 338
| Not Ranked : 0 score as a chem-e thermo was probably my least favorite....along with process control. I was all about transer, whether it was fluid, mass, or momentum.
| The Following User Says Thank You to 86AmishMs3 For This Useful Post: | rfinkle2 (12-30-2011) |
![]() | | #2291 | ![]() |
| Not Ranked : 0 score P-V diagrams and Otto cycles make me wet. Tapadatass
__________________ |
| The Following 2 Users Say Thank You to silvapain For This Useful Post: | cld12pk2go (12-30-2011), kritz (12-31-2011) |
![]() | | #2292 | ![]() |
![]() Join Date: Oct 2009 Location: Gilbert, Az
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 347
You can push down on the pedal when it's parallel with the ground, and get good power, but if you push down earlier you can get more work out of your weight up to a point. At some point the force you're exerting is putting much more stress on the pedals/cranks than is being transferred into the chain to propel you forward. Ever earlier in the cycle almost all your weight is going directly into the crank arm for awhile before it gets around, and it bends/snaps. | |
| The Following 4 Users Say Thank You to SJP0tato For This Useful Post: |
![]() | | #2293 | ![]() |
(Thread Starter) | Not Ranked : 0 score As I mentioned in the other thread, but this seems an appropriate place to repost:
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| The Following 4 Users Say Thank You to phate For This Useful Post: |
![]() | | #2294 | ![]() |
| Not Ranked : 0 score WTF are you engineers talking about??? i put corn into my car and I go faster...nuf said?? I could throw up a DJ MS paint drawing to illustrate what I mean but I think its clear and besides....I've had too much to drink...
| The Following 6 Users Say Thank You to Dano For This Useful Post: | djuosnteisn (01-03-2012), Fatguy729 (01-01-2012), JacksonMS30 (01-10-2012), Nataphen (12-31-2011), phate (12-31-2011), rfinkle2 (01-01-2012) |
![]() | | #2295 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score I went with 4 gallons of E85 today, and topped it off with premium (~E25). I added about 13% fuel up top on my maf curve, and staggered it down to 5% around 125 g/s or so. I've only driven about 12 miles on the new map, and went wot from 2nd-3rd near my house. My wot afrs weren't that bad... a little rich, but not that far off. Once the map settles, I'll do a maf g/s and cal the lower part of the maf, flash that map, then do some 4th pulls. I could only run 11* timing up top before with 0 kr, but I bumped it to 14* timing for my base map. It hit 14 NP, and no kr, so that's a good place to start. I'll have her leaned back out to 12.0 afrs, and I'm hoping I can run 16-18* timing up top. I'm pushing about 25psi, and I may squeak it up to 26psi. Too rich/soon to feel any big sotp gains, but I'm hoping once she's dialed that she can break 400whp SAE. We'll see... dyno is less than 3 weeks away, and I need to get tweaking! Also, my IDC% is right around 100% now, and the E85 skewed my maf about up by 30g/s up top. EDIT: Added a 3rd gear pull from 2,800 rpms to redline. Looks solid, just rich and needs more timing.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] Last edited by dougefresh_; 01-02-2012 at 12:52 PM. |
| The Following 7 Users Say Thank You to dougefresh_ For This Useful Post: | cld12pk2go (01-02-2012), Dano (01-03-2012), djuosnteisn (01-03-2012), Enki (01-02-2012), Nataphen (01-02-2012), phate (01-02-2012), rfinkle2 (01-03-2012) |
![]() | | #2296 | ![]() |
![]() Join Date: Jun 2009 Location: placerville, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 52
Groaned at 27 Times in 8 Posts
| Not Ranked : 0 score looks like some good air ingestion goin on there.
__________________ https://www.facebook.com/NorCalTintZone instagram: sharpdetails |
| The Following User Says Thank You to GoSpeed3Go For This Useful Post: | dougefresh_ (01-02-2012) |
![]() | | #2297 | ![]() |
Groans: 79
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following 6 Users Say Thank You to djuosnteisn For This Useful Post: | Alpha (01-03-2012), cld12pk2go (01-04-2012), Dano (01-03-2012), dougefresh_ (01-03-2012), rfinkle2 (01-05-2012), Todd98SE (01-05-2012) |
![]() | | #2298 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score Yes I agree with DJ to an extent. I think you can make more power with the e85/timing combo vs the added 1-2psi and less e85 like he is suggesting. If you can keep your 4g to 8g mixture I think you can make 400whp NO problem. I dont suggest running 4g to a top off. eventually your mixture will be off. When filling next time do 4g to 8g. Make sense? You should be able to go all the way to 19-20 degrees timing without any knock and from the 11 degrees you were at before you will make about 40-50whp more. Id try keeping boost around 24psi and start timing around 16-17 degrees on the dyno and add 1 degree at a time until you stop making power. If you are still around 100% idc I would suggest leaning out some more to around 12.4-12.5 afr to give yourself a lil room on idc. This is still a very safe afr on your setup and will give you that lil bit of breathing room. Good luck and keep us posted. Im excited for your results.
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
| The Following 6 Users Say Thank You to driver311 For This Useful Post: | Alpha (01-03-2012), cld12pk2go (01-04-2012), Dano (01-03-2012), dougefresh_ (01-03-2012), rfinkle2 (01-03-2012), Todd98SE (01-05-2012) |
![]() | | #2299 | ![]() |
| Not Ranked : 0 score I concur with pulling boost to 24psi and then push timing. Here are your tradeoffs: The more boost, the more power. The more boost, the more fuel needed. The more boost the more heat, the more knock. The more heat, the less timing. The more timing, the more power. The more fuel (richer) the more cooling. The more E85, the higher the octane, the less knock. The more E85, the more fuel needed.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 01-03-2012 at 02:57 PM. |
| The Following 7 Users Say Thank You to Lex For This Useful Post: | dougefresh_ (01-05-2012), mazdaspeed916 (08-20-2012), mrmonk7663 (01-03-2012), Nliiitend1 (01-04-2012), phate (01-05-2012), rfinkle2 (01-05-2012), Todd98SE (01-05-2012) |
![]() | | #2300 | ![]() |
| Not Ranked : 0 score just think of the things some you could accomplish if we all werent fuel limited.
| The Following User Says Thank You to GoSpeed3Go For This Useful Post: | phate (01-05-2012) |
![]() | | #2301 | ![]() |
![]() Join Date: Feb 2010 Location: NoVA/ Norfolk
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,285
Groans: 133
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score So has anyone figured out the size of the o-ring that seals around the pump piston? Mine is wearing and I need a new one.
__________________ 08.5 CWP MS3 GT PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC |
![]() | | #2302 | ![]() |
I'll try to get an answer on the size this weekend. Tapadatass
__________________ | |
| The Following 7 Users Say Thank You to silvapain For This Useful Post: | ABSpeed3 (01-05-2012), djuosnteisn (01-05-2012), Nliiitend1 (01-05-2012), phate (01-05-2012), rfinkle2 (01-05-2012), SWAY (01-05-2012), wolly6973 (01-06-2012) |
![]() | | #2303 | ![]() |
Groans: 133
__________________ 08.5 CWP MS3 GT PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC | |
![]() | | #2304 | ![]() |
Groans: 298
| Not Ranked : 0 score I'm reading more and more evidence that it may be best to go to a 2 step colder plug rather than back to the stock heat range if running high eth mixtures. I know many of you guys read as much as I do, but it seems that ethanol is particularly sensitive to preignition. I think cld12pk2go ran itv24's for a long time on his eth mixes with good luck. |
![]() | | #2305 | ![]() |
![]() | | #2306 | ![]() |
(Thread Starter) | Not Ranked : 0 score My car has run better on stock heat range plugs compared to ITV22's. When I was running 22's, the car ran shitty at idle and WOT, with some hesitations here and there. The 20's work great until around 35° ambient temp. I would actually like to try ITV16's (1 step hotter than stock) to see how they work in winter. Quick google search for auto ignition temps of various hydrocarbons, including ethanol and gasoline: http://www.engineeringtoolbox.com/fu...res-d_171.html And here's an SAE paper if anyone wants to pay for it: http://papers.sae.org/2008-01-0321/ Edit: I think my intercooler delete testing shows just how damn awesome E85 is. back to back to back runs with 230°+ BAT's with full boost and full timing and my shit didn't go nuclear. I really don't think it's a concern, lol.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. Last edited by phate; 01-05-2012 at 02:17 PM. |
![]() | | #2307 | ![]() |
Groans: 298
| Not Ranked : 0 score Alrighty guys, just saying I'm reading over and over again some of the more experienced tuners for many of the platforms quoting various sources, that preignition is an issue with ethanol. I understand on paper, things can be debunked, but we all know that things don't always behave in nature as they do on paper. Last edited by rfinkle2; 01-05-2012 at 02:24 PM. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | phate (01-05-2012) |
![]() | | #2308 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here we go:
| The Following User Says Thank You to phate For This Useful Post: | rfinkle2 (01-05-2012) |
![]() | | #2309 | ![]() |
Groans: 298
| Not Ranked : 0 score Phate, you posted that to show bat's< temperatures listed for auotignition in the link you provided? |
![]() | | #2310 | ![]() |
| Not Ranked : 0 score FYI, i have had zero issues with the ITV24's with up to E50. I am currently in the E35 range without any issues down to 18°F ambient temp so far. Of course I am now pushing close to 350 g/s actual, which might require something quite different from a K04 at similar ethanol concentration.
| The Following 3 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #2311 | ![]() |
(Thread Starter) | Not Ranked : 0 score Consider post-compression temps of the same mass of air between a 100° pre-compression charge and a 250° pre-compression charge. Someone want to run some numbers for us???
![]() | | #2312 | ![]() |
Groans: 298
I didn't intend to debunk your science, I'm simply stating what I am reading from some pretty experienced ethanol tuners, as well as some of what I've read from various sources. | |
![]() | | #2313 | ![]() |
![]() | | #2314 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
Groans: 24
Firsthand/Frontline empirical data is ALWAYS the best data! Keep doin your thing playa!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() Last edited by Alpha; 01-05-2012 at 04:09 PM. | |
![]() | | #2315 | ![]() |
Groans: 298
I didn't mean to challenge your intelligence, nor your findings, just participating with some of what I read. It is a commonly excepted issue that ethanol's only weakness is its predisposition to preignition. Just to show you that I read something I thought was of interest from a credible source concerning plug heat range, the following is from ngk's website: Fuel Type / Quality When using an ethanol blend fuel with high ethanol content in high performance applications, a colder heat range may be necessary. The spark timing can be advanced further because ethanol blend fuel has a higher resistance to knock (higher octane). Due to the decreased knock, there will be less audible “warning” from knock before the spark plug overheats and pre-ignites. Some types of fuel additives in lower quality fuels can cause spark plug deposits that can lead to misfires, pre-ignition, etc. | |
![]() | | #2316 | ![]() |
(Thread Starter) | Not Ranked : 0 score I just downloaded the SAE paper. Gonna take a few minutes to read, lol.
![]() | | #2317 | ![]() |
Groans: 298
| Not Ranked : 0 score |
![]() | | #2318 | ![]() |
Groans: 79
| Not Ranked : 0 score Have you guys been checking your plugs much? I'd be real curious to see how yours looked after that IC delete test Clint.
![]() | | #2319 | ![]() |
| Not Ranked : 0 score Pre-ignition would result in some pretty hefty holes in pistons pretty fast. Anyone had this show up? ![]() Is this the paper. I think I will buy this since I'm a member of SAE. Pre-Ignition Characteristics of Ethanol and E85 in a Spark Ignition Engine
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Lex; 01-05-2012 at 04:17 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | Nliiitend1 (01-05-2012), rfinkle2 (01-05-2012) |
![]() | | #2320 | ![]() |
Groans: 298
From what I can tell, you can throw traditional plug reading out the window.
Last edited by rfinkle2; 01-05-2012 at 04:31 PM. Reason: MSF Database - Automerged Doublepost | ||
| Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. | 08Anamoly | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 03-04-2010 01:07 PM |
| Discussion | Race Roots | Mazdaspeed3/6 General Discussion | 3 | 01-24-2010 07:52 PM |
| Toyota ponders new pedals, lubrication as fixes in latest recall | Haltech | Automotive News | 0 | 01-22-2010 10:10 PM |
| Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? | Wenis Prinkle | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 07-27-2009 01:47 AM |
| HPFP flow mods, should support 550 WHP | ptperformance | Mazdaspeed3/6 General Discussion | 20 | 01-04-2009 01:56 AM |
