Like Tree247Likes
 Old 01-29-2012, 05:37 PM   #2401
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Originally Posted by Zbrit00x View Post
im looking to get an e85 tune with a 3 or 4 gallon blend of e85, 10 gallon 91. After my tune I was looking to run just 91 again because of availability of e85 and only use it when I crave more from my dd. Anyone think I would be seeing any specific problems when swapping out tunes and gas from e85 to 91 intermittently.
other than your maf curve being off no....You will need to add about 5% to maf with 3 gallons.
 Old 01-29-2012, 07:02 PM   #2402
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Or if you really wanted you could just dial your AFRs .5 richer to hit target with no MAF cal like I did, and be able to run both fuels without too much issue (other than possibly too much timing on the e mix tune).
 Old 01-30-2012, 04:15 PM   #2403
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Well i took apart the pump the other day...i havent touched/cleaned the pump in months and ran a good couple full 85 tanks of gas, and well....it was completely spotless....not one thing of gunk or anything.
I think, starting full 85 with way lower miles than what bozo and phate had on the car at the time, is why i havent gotten any gunk build up yet.....i started 85 with around 32,xxx miles, and they started it with 50K+. could be a factor.
Im going to seafoam the tank soon, before i go back on 85 once it starts to warm up....see if pump gets dirty or anything.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
atvfreek (01-30-2012), phate (01-30-2012)
 Old 01-30-2012, 04:46 PM   #2404
Enki's Avatar
Groans: 189
You're on a timer, son. The clock has started, and when cleaning the spill valve doesn't cut it anymore, you'll start eyeing the pumps with the non yellow handles while fondly remembering the good ole days.
J-Liss (03-01-2012), mazdafreak (01-30-2012)
 Old 01-30-2012, 04:55 PM   #2405
mazdafreak's Avatar
Groans: 124
haha.....i kno.....matter of time, but i havent had the gunk buildup like they had...i figured i would have saw something, but nothing just yet.
Is there a fuel line etc that is 85 compatable that could be installed on the speed that could help with future problems???
@forcedinduktion said there is a new pump out, 265 or something for the tank that is 85 compatable....which could help for the intake pump i guess.
713whp/569wtq!
 Old 01-30-2012, 04:56 PM   #2406
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Nope!
403whp/451ft/lb Dry Shot
 Old 01-30-2012, 05:13 PM   #2407
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Details on said pump and how it could help our overall fueling capabilities, if any?
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 01-30-2012, 05:41 PM   #2408
mazdafreak's Avatar
Groans: 124
Well i kno, @phate changed his intake pump, but said it could have been just the filter clogged or something.....I would think the intake pump would help longer term since its 85 compatable....but dont quote me on that.
((Im just giving advise of the pump that came out being 85 compatable...which i would say would help down the road with one less problem u would have to worry about....but idk lol))
Once a fuel system upgrade is finally produce for our cars, i would love to run full 85 on bt....and im guessing that intake pump would help....but would like to kno, if there is any fuel line etc, upgrades that is 85 compatable....cause i kno no one has cut open a fuel line to see if any corrision etc is happening in the lines without us knowing till something happens.
713whp/569wtq!
 Old 01-30-2012, 06:54 PM   #2409
Enki's Avatar
Groans: 189
Phate's initial problems were due to both spill valve and ITP getting gummed up. The problem of which I speak currently has no solution, but both myself and I think Bucks are working on it from different angles.
 Old 01-30-2012, 07:23 PM   #2410
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Deatschwerks DW65 Series 265lph Drop-in Compact Fuel Pump (Mazdaspeed 3 & 6) - Modern Automotive Performance
The Following 2 Users Say Thank You to forcedinduktion For This Useful Post:
J-Liss (01-30-2012), mrmonk7663 (01-30-2012)
 Old 01-30-2012, 11:55 PM   #2411
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
One solution to the fuel lines which i just purchased is to convert to steel braided teflon lines which are ethanol compatiable.
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
The Following 2 Users Say Thank You to J-Liss For This Useful Post:
rfinkle2 (01-31-2012), wolly6973 (01-31-2012)
 Old 01-31-2012, 12:17 AM   #2412
Enki's Avatar
Groans: 189
Is that even needed? Doesn't seem to be to me.
 Old 01-31-2012, 12:22 AM   #2413
J-Liss's Avatar
Groans: 81
We dont know yet need to see the longevity effect of e on our cars. I know on the n.a. 3 when boosted on e it eats the lines
2004 mazda 3-Daily
2008 mazda 6-Wife
The Following User Says Thank You to J-Liss For This Useful Post:
mazdafreak (01-31-2012)
 Old 01-31-2012, 05:36 AM   #2414
mrmonk7663's Avatar
Links and pricing information for the lines please. Did you have to buy additional fittings to attach to stock lines?
 Old 01-31-2012, 11:12 AM   #2415
mazdafreak's Avatar
Groans: 124
That's why I asked too.....cause we can't see anything happening in the fuel lines....unless someone wanted to cut the line open and see. Running new lines+85 compatable itp, I would feel a lil better about.running 85 all the time ((besides winter))
713whp/569wtq!
J-Liss (01-31-2012)
 Old 01-31-2012, 04:49 PM   #2416
Groans: 35
Question for those who have fully tuned on e85 mixes. What power gains are you seeing between a 3 gallon mix and 50/50 mix? Because it looks like most people are only pushing a couple extra degrees of timing between these two mixes. I ask because I'm tuning a couple cars on 3 gal e85 mixes and vd numbers are avg 315hp 350 tq corrected @ 20 psi. One of my tunee's wants to go 50/50 mix but I don't see people making massive gains beyond a 3 gal mix. I haven't gone 50/50 on my own car because I like getting 20+mpg.
The Following User Says Thank You to RichieRichness For This Useful Post:
 Old 01-31-2012, 04:53 PM   #2417
Enki's Avatar
Groans: 189
If any gains are to be had, it's likely from airflow and not timing.
RichieRichness (01-31-2012)
 Old 01-31-2012, 04:55 PM   #2418
Groans: 35
I'm currently seeing 340 g/s at 12.1 afr
 Old 01-31-2012, 05:11 PM   #2419
i would say theres no gains after 5050 and its easier to fill up
 Old 01-31-2012, 05:35 PM   #2420
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I wouldn't say there are no gains, but I think the gains would probably be no more than 10-15hp. We need better testing, not just random vd samples....meaning we need proper dyno testing.
-06 MS6
-Corn fed 07 MS3 - Sold
Nliiitend1 (01-31-2012)
 Old 01-31-2012, 05:47 PM   #2421
Groans: 35
I'll have actual dyno results on both cars by next weekend.
Nataphen (01-31-2012)
 Old 01-31-2012, 05:52 PM   #2422
Eth Fiend
phate's Avatar
They won't be comparable results, so they are just numbers in the air. What I meant was we need to take a full E85 car (like mine) tune it on a dyno (like mine), then fill with 50/50 or whatever mix and redo the dyno tuning. Then we will have comparable results.
-06 MS6
J-Liss (01-31-2012), Nataphen (01-31-2012), wolly6973 (02-01-2012)
 Old 01-31-2012, 06:03 PM   #2423
Enki's Avatar
Groans: 189
I had .1 volts more airflow at the MAF on pure e from where I am now, with only 2 degrees more timing. Pretty sure 2 degrees isn't gonna net me that much more airflow. Oh, and that was when it was hotter.
 Old 02-13-2012, 09:17 PM   #2424
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
So here are the results from a guy I recently tuned:
The mods were:
2008 MS3
- K04
- COBB AP
- CorkSport TMIC
- Denso ITV22 (Gapped .28)
- HPFP Internals
- HKS Hi-Power CBE
- SURE Areos SRI
- StreetUnit Test Pipe
- Turboxs Downpipe
- Turbosmart Dual Port BOV (set to 50/50)
Using Cali 91 octane cat urine for fueling.
The baseline was using the OTS Stage2+SUR2+TIH+IC 91 v210 tune.
The 91 octane log was the most I could squeeze out without KR with the sucktastic Cali "premium" fuel.
The E85 log was just with 2 gal of E85 added per tank (the guy is an hour away from the nearest E85 pump so the minimal required to allow for extra timing is desired to minimize trips for E85), which allowed 3.5-6° additional timing from 4000+ and another 1.5-2° down low.
I was quite impressed with how much extra timing was allowed by the 2 gal of E85.
OTS timing:
Best 91 octane timing:
2 gal E85 timing:
I probably could have pushed another 1-2° from 3000-3500 and 5500-7000 RPMs, but wanted to play conservative. I did get small hits of KR in the 4000-5000 range intermittently at the current timing, but nothing overly concerning.
Bucker likes this.
The Following 15 Users Say Thank You to cld12pk2go For This Useful Post:
BigjohnB20 (02-13-2012), Boost_creep (02-27-2012), Bucker (02-14-2012), charlesfist (02-20-2012), ChimmyChong (02-22-2012), Dano (02-13-2012), dereeek (02-13-2012), djuosnteisn (02-14-2012), JacksonMS30 (04-02-2012), Nataphen (02-14-2012), Nliiitend1 (02-13-2012), phate (02-13-2012), Pseud0logik (03-30-2012), Pu Manchu (02-14-2012), SJP0tato (02-13-2012)
 Old 02-20-2012, 11:23 AM   #2425
09speedaddict's Avatar
Posts: 223   (View Stats)
09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute09speedaddict has a reputation beyond repute
Groans: 28
Lots of great info in this. Thanks phate
09speedaddict is offline   Reply With Quote
The Following User Says Thank You to 09speedaddict For This Useful Post:
phate (02-20-2012)
 Old 02-25-2012, 02:58 PM   #2426
sleepyspeed6's Avatar
Posts: 288   (View Stats)
sleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the world
Alright so I thought I would post this here. My car wont hold boost, thats the reason for it falling off so bad
My mods are intake, TIP, AP, injector seals, 3 gal of E85, 16* timing.
EDIT: This is vs my 91 tune
I just ordered a down pipe, fuel pump, and a frontmount, bpv.
Hx35 sold
New sc6266
sleepyspeed6 is offline   Reply With Quote
 Old 02-25-2012, 03:05 PM   #2427
Wait, you're running an E85 mix with no internals?
Can I have your injector seals when you blow your engine?
Bucker (03-06-2012), josurr (02-25-2012), mazdafreak (02-25-2012)
 Old 02-25-2012, 03:09 PM   #2428
Eth Fiend
phate's Avatar
He's likely at high elevation and can get away with it. Less air ftl.
-06 MS6
Bucker (03-06-2012), sleepyspeed6 (02-25-2012)
 Old 02-25-2012, 03:15 PM   #2429
Damn. I really wanted those injector seals.
sleepyspeed6 likes this.
josurr (02-25-2012), mazdafreak (02-26-2012)
 Old 02-25-2012, 03:15 PM   #2430
I don't have a fueling issue. I am at a higher elevation like phate said, also why I am runing such high psi.
I just ordered a autotech pump last thursday
Hx35 sold
New sc6266
 Old 02-26-2012, 10:48 AM   #2431
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
I have similar mods as sleepyspeed6 and occasionally run a 2.5/10 E85/91 mix with OEM internals. The map I run with the E is not really much more aggressive than my 91 map. I mostly run it in the summer when it gets hot and I almost need it to just run very moderate timing.
Anyway, I monitor my FP pretty religiously and I have never seen it drop to dangerous levels. Even at low elevation and 18psi tappering. I do have internals already that I need to get in, but for now the stockers seem to be doing fine for me.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
The Following User Says Thank You to BigjohnB20 For This Useful Post:
 Old 02-28-2012, 12:35 PM   #2432
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
E85 Beta, now live on ATR
and thanks to Enki:
Fuel mix cheat sheets
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
cld12pk2go (02-28-2012), Enki (02-28-2012), Nataphen (02-28-2012), Nliiitend1 (03-03-2012), wolly6973 (03-01-2012)
 Old 03-06-2012, 07:21 AM   #2433
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
Is anyone else experiencing Fuel Level Sensor problems? I started having the issue below, and I think E85 might be playing a role in it...
Fuel Level Sensor issues
The Following User Says Thank You to adlpb For This Useful Post:
rfinkle2 (03-06-2012)
 Old 03-06-2012, 09:28 AM   #2434
Eth Fiend
phate's Avatar
When I pulled and replaced my in-tank pump, the fuel level float assembly looked fine, just like the rest of the assembly (minus the filter). I don't remember that the 2nd gen's had a different part # for that stuff, but I could check for you if you are interested.
-06 MS6
adlpb (03-06-2012)
 Old 03-06-2012, 05:09 PM   #2435
adlpb's Avatar
Groans: 669
Thanks phate, that would be nice. For some reason, both cars having this issue are genpus. And for an even stranger reason, we both live in the same city and most likely get E85 from the same station...
The Following 2 Users Say Thank You to adlpb For This Useful Post:
phate (03-06-2012), rfinkle2 (03-06-2012)
 Old 03-06-2012, 06:34 PM   #2436
Eth Fiend
phate's Avatar
Definitely different part #'s, and not of the supersession type:
2007-2009 Fuel Level - B37F-60-960A
2010-2011 Fuel Level - BBN6-60-960
I can't tell what changed, though :/
-06 MS6
rfinkle2 (03-23-2012)
 Old 03-23-2012, 11:45 AM   #2437
Eth Fiend
phate's Avatar
Sadly, my second set of fuel pump internals has gone downhill. These were my warrantied KMD's, and they were scarred very badly. I've run straight E85, straight gas, and a few mixes with them. I am currently on 5050.
Autotech's have been ordered. I think I'll order a whole new pump so I can have a brand new housing and whatnot to run them in. This might also give us a better idea if it's the seal condition causing the gunk.
Many thanks to @JP@edgeautosport.com for getting those internals and other random parts to my door so quickly.
-06 MS6
Enki (03-23-2012), JP@edgeautosport.com (03-27-2012), Nataphen (03-23-2012), Nliiitend1 (03-24-2012), Pseud0logik (03-23-2012), rfinkle2 (03-23-2012), RichieRichness (03-23-2012)
 Old 03-23-2012, 12:14 PM   #2438
Enki's Avatar
Groans: 189
Should warrantee the KMDs and sell the new set to pay for the Autotechs.
BTW, last I looked I had minor scoring in the collar on mine. Piston looked brand new though.
bewsted (03-23-2012), Nataphen (03-23-2012), phate (03-23-2012), silvapain (03-23-2012)
 Old 03-23-2012, 03:46 PM   #2439
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Groaned at 25 Times in 25 Posts
autotech or gtfo
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
 Old 03-30-2012, 07:44 PM   #2440
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
I just switched to 100% E85 this week, after being on a 30% blend for the last year or so. Some wierd shit went down this morning though.
I started the car to go to work and it was stuttering and wanting to die. The fuel gauge showed no bars and the fuel light was on. I am 99.999% positive I had almost a half tank when I parked it in my garage last night.
So I jump out and dump some regular gas in from the can sitting there for the mower. Everything smooths out immediately and I head out to the gas station. FP is normal on the way there. When I get to 5 gallons the pump clicks off. I figured no biggie, it happens, and I restarted. Clicked off again. Started again slowly and I could hear it coming up the fill tube as it does when it is almost full and it clicked off. 5.5 gallons got in the tank.
Get back in the car and the gauge now shows 1/2 full. FP is just fine and I have no idea what is going on. I had flashed a new map the day before, so I re-flashed back to the previous map just to rule out a variable, since that is the only thing that has been changed/touched recently.
WTF!?!
The Following User Says Thank You to wolly6973 For This Useful Post:
adlpb (04-02-2012)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.60355 seconds with 38 queries
