Like Tree247Likes
 Old 03-30-2012, 07:48 PM   #2441
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Another 2nd gen with fuel level sensor issues! Solution: Buy a first gen.
The stuttering and whatnot is probably from the spill valve getting gunked up. I'd pull it first thing!
-06 MS6
-Corn fed 07 MS3 - Sold
Dano (03-30-2012), Nliiitend1 (03-30-2012), RichieRichness (04-03-2012), silvapain (03-30-2012), wolly6973 (03-30-2012)
 Old 03-30-2012, 07:56 PM   #2442
VitViper's Avatar
Posts: 293   (View Stats)
VitViper is the leader of the worldVitViper is the leader of the worldVitViper is the leader of the worldVitViper is the leader of the worldVitViper is the leader of the worldVitViper is the leader of the worldVitViper is the leader of the worldVitViper is the leader of the worldVitViper is the leader of the worldVitViper is the leader of the worldVitViper is the leader of the world
That's odd... I've been on 50/50 with my GenPu with no issues so far. It's also unusual for 100% E85 to corrode anything in the tank in a week... Even on my 8th gen which is notorious for the fuel level sender to corrode with high ethanol content it doesn't happen for a couple months (before the fuel level gauge never lights up).
2008 Honda Civic Si - 11.494 @ 134.18
2012 MS3 w/ Tech - 12.8 @ 110
VitViper is offline   Reply With Quote
The Following 3 Users Say Thank You to VitViper For This Useful Post:
Bucker (04-02-2012), phate (03-30-2012), wolly6973 (03-30-2012)
 Old 03-30-2012, 08:11 PM   #2443
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Sticky on the level sender.
 Old 03-30-2012, 08:20 PM   #2444
My money is on the fuel level potentiometer shorting out due to the hygroscopic nature of Ethanol.
The Following 5 Users Say Thank You to silvapain For This Useful Post:
adlpb (04-02-2012), Bucker (04-02-2012), Dano (03-30-2012), phate (03-30-2012), wolly6973 (03-30-2012)
 Old 03-30-2012, 09:24 PM   #2445
VitViper's Avatar
If that's the case, just coat it with epoxy.
The Following User Says Thank You to VitViper For This Useful Post:
Bucker (04-02-2012)
 Old 03-30-2012, 09:29 PM   #2446
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
The sputtering stopped as soon as I added gas and FP has been fine. Doesn't a stuck spill valve show up as low FP?
I only added about a half gallon from the can since the station is basically across the street.
Sent from my SAMSUNG-SGH-I777 using Tapatalk
 Old 03-30-2012, 09:40 PM   #2447
Posts: 9,484   (View Stats)
a few of the genpu guys have reported issues with the fuel level gauge and 100% E. sounds the same. IDK what the resolution is.
edit: @phate beat me to it ...get a genwan
mazdafreak (04-22-2012), wolly6973 (03-31-2012)
 Old 03-30-2012, 09:52 PM   #2448
Enki's Avatar
Groans: 189
If the car was warm when you added gas, no dice.
@ 140 degrees ECT, e85 runs smooth.
 Old 03-31-2012, 04:23 AM   #2449
wolly6973's Avatar
Groans: 386
Car had been on for 10 seconds and it was about 40 degrees out. My garage is not insulated or heated either.
 Old 03-31-2012, 06:45 AM   #2450
Eth Fiend
phate's Avatar
If it was that early on in the switch when it was stuttering, it may simply be because there was still your old mix in the lines, and you had already flashed to the E85 map. How's the car running now?
-06 MS6
 Old 03-31-2012, 09:08 AM   #2451
wolly6973's Avatar
Groans: 386
Here is the timeline for everyone...
Monday evening - fill up with 100% e85, drive 1/2 block home
Tuesday morning - drive to work (10 mins)
Tuesday afternoon - flash map before driving home
Wed & Thursday - drive to and from work, no probs
Friday morning - car is whack
I have only driven to and from work since topping back off, and it has been fine.
I did notice that Friday am when it was stuttering that FP was dropping to 90 psi before I added gas.
The Following User Says Thank You to wolly6973 For This Useful Post:
rfinkle2 (04-03-2012)
 Old 03-31-2012, 09:09 AM   #2452
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
spill valve.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 03-31-2012, 11:26 AM   #2453
wolly6973's Avatar
Groans: 386
Just went out for a spin after putting on the pmm. Fuel gauge shows empty, but everything else was good.
 Old 03-31-2012, 12:45 PM   #2454
event's Avatar
Posts: 521   (View Stats)
event is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the world
You filling up at the Thorton's on Ogden between Eola and 75th?
***sold*** 06 MS6 Cobb SRI 3.5" ETS TMIC Cobb AP Sure RMM JBR SSP EBay Catless DP Autotech HPFP Magnaflow
2013 Scion FR-S 6MT
1993 Mazda Miata with shocks, springs, fsb, GT2560r, Megasquirt
event is offline   Reply With Quote
 Old 03-31-2012, 01:56 PM   #2455
wolly6973's Avatar
Groans: 386
yup
 Old 04-02-2012, 08:24 AM   #2456
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
Originally Posted by wolly6973 View Post
I just switched to 100% E85 this week, after being on a 30% blend for the last year or so. Some wierd shit went down this morning though.
I started the car to go to work and it was stuttering and wanting to die. The fuel gauge showed no bars and the fuel light was on. I am 99.999% positive I had almost a half tank when I parked it in my garage last night.
So I jump out and dump some regular gas in from the can sitting there for the mower. Everything smooths out immediately and I head out to the gas station. FP is normal on the way there. When I get to 5 gallons the pump clicks off. I figured no biggie, it happens, and I restarted. Clicked off again. Started again slowly and I could hear it coming up the fill tube as it does when it is almost full and it clicked off. 5.5 gallons got in the tank.
Get back in the car and the gauge now shows 1/2 full. FP is just fine and I have no idea what is going on. I had flashed a new map the day before, so I re-flashed back to the previous map just to rule out a variable, since that is the only thing that has been changed/touched recently.
WTF!?!
Welcome to the "fucked fuel level sensor" club
That makes 3 of us
I suggest you reset your trip meter every time you fill up. Fill up your tank all the way. Repeat after 180-200 miles. Do not go more than 200 miles (ask me how I know)...well this is with 100% city driving. You might get away with a few more miles if you drive highway, but I wouldn't risk it.
I am going to eventually fill up with 93 and take it to the dealer, but I know that the issue is probably going to come back if using E85
The Following User Says Thank You to adlpb For This Useful Post:
wolly6973 (04-03-2012)
 Old 04-03-2012, 05:08 AM   #2457
wolly6973's Avatar
Groans: 386
Do u trigger a CEL about the fuel level sensor as well?
 Old 04-03-2012, 07:41 AM   #2458
adlpb's Avatar
Groans: 669
Yes sir. Two actually:
P0460 Fuel Level Sensor Circuit
P0463 Fuel Level Sensor Circuit High Output
E85 - fucking your fuel level sensor, one genpu at a time.
The Following 3 Users Say Thank You to adlpb For This Useful Post:
BigJimMs3 (04-12-2012), MSFer87 (04-04-2012), wolly6973 (04-03-2012)
 Old 04-03-2012, 01:50 PM   #2459
VitViper's Avatar
Pull the fuel pump hanger out of the tank and look at what's corroded... You can coat that in E85 proof epoxy and call it a day.
 Old 04-03-2012, 02:48 PM   #2460
adlpb's Avatar
Groans: 669
It's most likely not corrosion. Ethanol is naturally more conductive than gasoline. This will tend to short out the circuit.
 Old 04-03-2012, 03:01 PM   #2461
VitViper's Avatar
My point is pull the hanger out and look! Coating the circuit that is shorting in E85 proof epoxy will protect that circuit as it will have no contact with the E. If this had happened on my GenPu I'd rip the hanger out and take a look. We've already tested the epoxy trick on our shitty non-ethanol friendly level sender/circuit in the 8th gen's, so it does work.
Bucker (04-03-2012), Nataphen (04-04-2012), silvapain (04-03-2012)
 Old 04-03-2012, 03:12 PM   #2462
adlpb's Avatar
Groans: 669
I see this as a good preventative measure for a sensor which is in good working order.
I am not sure if this would help mine since it sends no signal whatsoever. I'm no electrical expert, but I would assume that a sensor which has shorted out would need to be replaced.
 Old 04-03-2012, 03:13 PM   #2463
VitViper's Avatar
I was looking at the mazda parts catalog and the fuel level sender is like $43 or so. I doubt you'll be able to replace just the circuit, generally they sell the whole level sender assembly as one piece (it has the circuit on it). Lucky yours is so cheap, it's $100 for my 8th gen... lol.
You should pull it and take pics... it's extremely valuable research.
 Old 04-03-2012, 03:28 PM   #2464
adlpb's Avatar
Groans: 669
Yes, you are correct on the price. I definitely plan on taking a look at the sensor before taking it in to the dealer (if I even will do that). Wouldn't be a bad idea to buy an extra one and cover it with epoxy/goop (both meth resistant).
 Old 04-03-2012, 07:38 PM   #2465
wolly6973's Avatar
Groans: 386
If only it was so easy to pull the tank. It is a pita and requires a special tool from Mazda iirc.
 Old 04-03-2012, 07:54 PM   #2466
VitViper's Avatar
Do you really have to drop the tank to get to the pump? All the cars I've owned have had access to the pump from the back seat/trunk area. Yes, still a PITA, but nothing that special. No special tools required either... just a hammer and screw driver to get the ring off.
 Old 04-03-2012, 07:55 PM   #2467
josurr's Avatar
Posts: 954   (View Stats)
josurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the worldjosurr is the leader of the world
Groans: 156
lol, go take the back seat out of your speed, take off the access cover, and then see why you need to drop the tank...
josurr is offline   Reply With Quote
 Old 04-03-2012, 08:06 PM   #2468
VitViper's Avatar
Is there no big round hole back there? lol
 Old 04-03-2012, 08:17 PM   #2469
josurr's Avatar
Groans: 156
its about half the size it should be to allow for in-tank fuel pump access without dropping the tank... just ask @phate
The Following User Says Thank You to josurr For This Useful Post:
 Old 04-03-2012, 08:37 PM   #2470
adlpb's Avatar
Groans: 669
True, but I thought this had changed for genpus. I've read around here that the diameter of access was larger than genjuans.
triphop631 (07-17-2012)
 Old 04-04-2012, 09:39 AM   #2471
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
Nope, it isn't. I've checked the wife's 2010 myself.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
The Following 2 Users Say Thank You to Nataphen For This Useful Post:
adlpb (04-04-2012), wolly6973 (04-04-2012)
 Old 04-12-2012, 08:38 AM   #2472
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
does anyone have any clue where around MBT is for these engines?
mrQQ is offline   Reply With Quote
 Old 04-12-2012, 08:42 AM   #2473
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Dizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the world
I wouldn't push past twenty. But that would vary between cars so your not gonna get the definitive answer that your looking for. Especially if you ask in the wrong dam section
Sent from my Desire HD using Tapatalk
Dizzy Turbo is offline   Reply With Quote
 Old 04-12-2012, 08:44 AM   #2474
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
I try not to go past 1700* F EGT but as far as timing, each car is different.
 Old 04-12-2012, 09:26 AM   #2475
Eth Fiend
phate's Avatar
Pretty sure we already went over this. Fuel has a pretty significant effect on where MBT lies for these engines. Search, we have dyno proven results.
-06 MS6
RichieRichness (04-12-2012), silvapain (04-12-2012), wolly6973 (04-13-2012)
 Old 04-15-2012, 03:14 PM   #2476
sleepyspeed6's Avatar
Posts: 288   (View Stats)
sleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the worldsleepyspeed6 is the leader of the world
Alright so went to the dyno yesterday, this is my car with 19° timing 4.5gal of e85
Hx35 sold
New sc6266
sleepyspeed6 is offline   Reply With Quote
The Following 3 Users Say Thank You to sleepyspeed6 For This Useful Post:
Enki (04-15-2012), mazdafreak (05-04-2012), Nataphen (04-15-2012)
 Old 04-15-2012, 04:17 PM   #2477
Nataphen's Avatar
Groans: 31
This probably won't help, but I was looking at Lucas ethanol additive in the store today. Would that help at all with black death, or is it more for lubrication and moisture protection?
triphop631 likes this.
13 5.0
Wife's 13 Focus ST
The Following User Says Thank You to Nataphen For This Useful Post:
rfinkle2 (05-04-2012)
 Old 04-15-2012, 05:56 PM   #2478
Enki's Avatar
Groans: 189
Probably not, sadly. I think the best bet is just simply keeping the oil out of the pump in the first place.
Nataphen (04-16-2012)
 Old 05-04-2012, 06:15 PM   #2479
zspalm1's Avatar
Posts: 16   (View Stats)
zspalm1 is infamous around these parts
Groaned at 20 Times in 5 Posts
i have had a problem just once with my stock fuel pump deciding it didnt want to supply fuel like you the car just didnt want to accel even while i was to the metal the problem was so speratic too i was driving parked for maybe 20 min came back tried to drive away and the car barely moved parked again came back like hour and a half later was fine i figured my car has 115k miles on it and i did through some seafoam in there so eh idk but i have been reading up on this E85 so im going to give it a shot this weekend i dont have any fuel mods just the intake test pide and mounts
zspalm1 is offline   Reply With Quote
 Old 05-04-2012, 07:45 PM   #2480
FYI: Nobody's going to bother reading this shit. Use capitalization, punctuation, and proper spelling.
The Following 9 Users Say Thank You to silvapain For This Useful Post:
Enki (05-04-2012), GrumpyMPS (05-17-2014), jdeves (05-04-2012), josurr (05-04-2012), jracer (05-06-2012), mazdafreak (05-04-2012), phate (05-05-2012), Pu Manchu (05-04-2012), Vinnie (05-04-2012)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Discussion Race Roots Mazdaspeed3/6 General Discussion 3 01-24-2010 07:52 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.59885 seconds with 36 queries
