-   -   The E85 and E85 Mix *Ignition Timing* Database (http://www.mazdaspeedforums.org/forum/f567/e85-e85-mix-ignition-timing-database-100743/)
phate 09-28-2012 12:14 PM
Thanks for posting. Good to see more verification falling in line with the others.
Compared to your street tune, how did it change? I remember talking about this in another thread, but don't remember the timing curve.
I'll add the curve to the op when I'm at a computer.
RichieRichness 09-28-2012 12:27 PM
I was only 1.5* away from MBT with the e-tune.:fingersx:
cld12pk2go 01-05-2013 05:34 PM
Here are all 6 pulls from my last dyno session running an ~E20 Blend with about ~15% of my total fueling from Meth:
http://i77.photobucket.com/albums/j6...ps088540e2.jpg
Here is my breakdown of the benefit I obtained from the extra timing:
http://i77.photobucket.com/albums/j6...psaa806230.jpg
Basically, I normalized the power gain based upon hp per g/s to try to remove the impact of changes in MAF flow per pull, which can influence the end result. Per this analysis, I continued to gain power per g/s of MAF flow all the way up to my final timing (never found MBT)…It would appear that the diff between pulls 2-3 were somewhat anomalous in the 6000-6500 RPM range...
Familyguy427 01-10-2013 05:21 AM
subbed
ABSpeed3 01-23-2013 11:34 AM
So I've read through this thread and the only person I saw that posted a 2.5gal mix timing curve was @Lex. His peak timing numbers are about in line with what I am running, but I was wondering where could I improve? Can I add more up top? I'm going to smooth the mid-range a bit to get my torque curve looking better. Here is my timing as it sits now. My number one goal is not to blow my motor so nothing too aggressive but a bit more power up top would be nice.
Thanks for any help
http://imageshack.us/a/img593/1530/49566647.jpg
warlord 01-23-2013 11:42 AM
Let knock be your guide. Pretty sure you can't hit MBT on a 2.5 mix so find knock in each rpm column along your load curve and then back off a bit. Advancing timing in .5* increments is a safe way to do it. A knock decay rate of 150 will ensure that knock is localized to the area it's happening and doesn't perpetuate itself though out the run.
phate 01-23-2013 11:58 AM
DO NOT let knock be your guide when running e85. Be safe, get on a dyno if you want to dial things in further than what is seen in some of these timing curves. Every car is different.
ABSpeed3 01-23-2013 12:11 PM
I guess what I'm asking is I've seen other mixes as low as 3 gals with timing around 16-17 in the upper regions. As e85 tuners, would you say I have any room to hit 15 or 16 degrees? Or should I just stay put where I am until I can dyno verify? Thanks again
phate 01-23-2013 12:15 PM
I'd be comfortable going a little further if you think you were still gaining power. If you don't feel comfortable, a couple hundred bucks for dyno time could save you thousands on a new engine.
Edit: only on the top end. That mid range looks like a good bit of timing already.
Familyguy427 01-23-2013 12:28 PM
I'll share my timing numbers. I'm running 31% though. From 4500...
12.50 16.00 18.00 20.00 21.00 19.00
Listen to @phate; He's good peeps!
Sent while eating rice
ABSpeed3 01-23-2013 12:32 PM
Ill bump her up a little bit and bring it down a cunt hair in the middle regions. Phate and Silva are the reason I run e85 lol
cld12pk2go 01-23-2013 04:41 PM
I am pretty sure you can hit MBT with a 2.5 gallon mix, but YMMV.
One thing of note is that one of the guys I tuned (GT3076 at ~26 PSI) didn't gain any power at 6500RPM beyond 14° (dyno verified) so I would certainly urge caution when taking timing up too far without some detailed feedback on MBT.
I keep gaining power up to at least 20.5° at 6500RPMs (haven't clearly found MBT yet)...
warlord 01-23-2013 04:55 PM
Duly noted. I didn't see BT in his sig and his present timing looked like 93 timing so I figured he had a ways to go up top with timing. I was knock limited to 18* at 6k on a three gal mix. I don't want to see anyone vent their block so I'll refrain from posting in these types of threads where destruction may be lurking just around the corner.
ABSpeed3 01-25-2013 07:39 AM
Is that because he's on a bigger turbo that the timing doesn't net him any greater power? I'm pretty sure I could squeeze a few extra horses from timing considering I'm running stock ko4 still
Ziggo 01-25-2013 08:01 AM
A denser charge requires less timing to reach MBT. The flame front will move faster. Typically you can't run as much timing on a smaller turbo as you can with a large one though because the smaller turbo will generate higher BATs, but due to the magic of E85 BATs don't matter so much.
Zigatapatalka
ABSpeed3 01-25-2013 12:52 PM
oh how I love the magic of e85 :slomo:
cld12pk2go 01-25-2013 03:57 PM
I am running a similarly sized turbo at similar boost/flow, yet I keep gaining power for at least another 6° compared to him...
The point is that every car is different and that assuming otherwise can be a very expensive mistake...
silvapain 01-26-2013 10:09 AM
The moral of the story is DON'T PUSH TIMING ON E85 WITHOUT A PROPER DYNO TUNE. Don't assume that your engine can use the same timing as others posted in this thread.
Dano 01-26-2013 11:21 AM
Another thing to consider is the potential variance in each motors mechanical timing as well as the mounting of the Crank sensor. 1-2* variance is certainly possible and I have tuned a guy who's sensor was improperly aligned making his actual advance higher than commanded/logged.
This lead to KR with very minimal timing and some head scratching for a few map revs until I had him re-align his crank to sensor setup.
Tappin
atvfreek 01-26-2013 01:44 PM
I had a speed 6 on the dyno recently and we didn't gain hardly any power above 14* at 6k. It's very important to keep run conditions and road the same if street tuning an aggressive timing curve, and I would still stay a little conservative.
Sent from your couch
sidekick 01-29-2013 10:17 AM
What mix was that on?
atvfreek 01-29-2013 11:01 AM
That wasn't even with e85 in the tank. Just running 100% meth, d07 nozzle and obviously zero kr.
Edit: Another note that is an important detail on this tune, is that he had a warranty engine replacement a few months ago, and it's likely the crank sensor is slightly off.
ABSpeed3 02-02-2013 10:40 AM
Originally Posted by ABSpeed3 (Post 1853904)
so I followed the advice from you guys..made timing 15* @ RL and changed the 3500 and 4000 values to 6 and 8 respectively. Is there room for more boost on a 2.5gal mix? This is my vdyno from last night, weight is 400 because both myself and friend were in the car as well as a 5 gal tank of e85 and a subwoofer box that takes up my entire trunk.
https://sphotos-a.xx.fbcdn.net/hphot...83348607_o.jpg
Familyguy427 02-14-2013 02:27 PM
Occ. Weight 400lbs??????????????????
Enki 02-14-2013 03:09 PM
RCP.
Familyguy427 02-14-2013 04:10 PM
I totally missed that part. LMFAO!!!!!!!! :buttkick:
ABSpeed3 02-14-2013 08:00 PM
i never got around to getting a different setup I just pulled it straight out of my truck thing is no joke ha
http://imageshack.us/a/img809/2661/dsc00061e.jpg
superdave2335 05-15-2013 12:36 PM
so being as this is mostly about timing is anyone against discussing timing on meth since i dont have access to e85 up here in anchorage alaska...i will be jumping on a dyno very soon. using VD as my help i was actually able to hit Phates timing and still showed power being made. my timing is exactly as Phates is in OP up top. im running 90oct (the highest avail in alaska) along with 50/50 meth. i run a 1gal/hr nozzle pre turbo and 6gal/hr pre throttle body. vd numbers showed 325hp/410 iirc. im going to drop timing back down since yall fuckers making me nervous and go up all over again on the dyno.
since im at work ill post this log just to tide yall over until i can post a vd
if this is not ok to post here feel free to delete.
Lex 05-15-2013 01:01 PM
That is quite aggressive. More aggressive than what I feel comfortable with especially not being on a real dyno.
superdave2335 05-15-2013 01:07 PM
I completely understand as well that's why I'm gonna drop it down some until u get back on a dyno. I don't get how I don't knock though. Motor is built and I'm sure ambient temps along with being at sea level has an effect on this. We just recently got a decent dyno in anchorage though and guy said I can make as many pulls for 100$ so I'm gonna take that deal and see what I come up with. Vd pisses me off these days.
Thanks for chiming in as well lex
superdave2335 05-15-2013 02:09 PM
Backed off about 4* through whole range and dropped boost as well. Gonna get on the dyno this weekend. How are you guys finding your power points? Are you adding a degree on top of baseline run to find benefits and then adjusting accordingly? Just want to have some tips and tricks to use when I go this weekend. Thanks guys
phate 05-15-2013 02:12 PM
You can add timing until power plateaus (sans knock). That last point where you pick up power is MBT.
superdave2335 05-15-2013 02:14 PM
Ok roger that. Then back off a degree or so from what I've seen. I've got too much damn money in this bus to fuck it up. I appreciate the help lex/phate/dj. I still don't know how to tag ppl in this shit. I know. I'm such a brownie!!!
atvfreek 05-15-2013 02:43 PM
Something is going crazy with your maf g/s and volts. Make sure you don't have a meth leak spraying at your air filter. Seen that a few times.
superdave2335 05-15-2013 02:48 PM
I actually run a blow thru maf and pre turbo meth. But will remove it tonight because I seen the fluctuating maf as well. Even before pre turbo meth I can seem to get the damn afr's to flatline. Figured it was because I was boost based. Would you recommend going maf based instead? Come on at around 3.4-3.5 volts and go max around 4.3-4.4?
atvfreek 05-15-2013 04:27 PM
Ahhh the meth spray is hitting the maf because the pre turbo meth. If you go back to a standard maf setup, that should clean it up. Or pull the pre turbo meth nozzle
rfinkle2 05-15-2013 04:39 PM
at in front of the username, semi colon afterwards.
@ superdave2335 ;
@superdave2335;
Take it easy on those forged internals man. You are running some big timing down low.
superdave2335 05-15-2013 05:25 PM
Thanks @rfinkle2; I turned the timing down. Wayyyy down. Gonna hit the dyno next weekend and do it correctly and accurately. Thanks for the heads up guys.
Shitty part about going back to standard draw thru is the fact that my JBR intake dosent have the recirc tube. My blow thru works well and I haven't had any issues with it. Even before when I was draw thru my meth would skew afr's. just want to find a more accurate approach to spray and keep afr's straight. That's why I mentioned trying maf based setup
Mfinlay04 05-17-2013 11:38 PM
Well spraying meth before the MAF sensor is basically throwing that sensor off. Wiki how a MAF sensor works if you don't know yet but the meth droplets won't play nice with the hot wire. I'm kinda surprised youve never had any cuts with this setup.
Try spraying post MAF
superdave2335 05-17-2013 11:52 PM
I actually spray both. Ended removing this setup for the risk. Never had issues but just wanted to be cautious. If I was not blow thru I would smash meth down the turbos throat!
seshomaru7 06-12-2013 04:37 PM
How is that blow thru MAF working out? I've read the sensor doesn't respond consistently to that setup.
superdave2335 06-12-2013 09:38 PM
It can be a little tricky the maf can seem to act finicky but as long as you take your time on maf cal it works just fine. And vta is always fun. I got a jbr wp intake with out recirc so that's another reason I opted to do it.
seshomaru7 06-13-2013 08:07 AM
Wow. I've also heard something like people only using the MAP with no MAF or something like that. Any idea what I am talking about?
Dano 06-13-2013 09:26 AM
Its called Speed Density and we dont yet have the ECU logic to run it.
Tappin
mrmonk7663 06-13-2013 10:02 AM
Speed Density is a little advanced :) Factory speed density vs factory mass air....speed desnsity makes more power generally....start modding and the car goes to shit without a custom tune.....I converted cars from speed density to mass air simply for the ease of tuning and forgiveness of the mass air system. Speed density + mods is a game for the big power guys!!!
seshomaru7 06-13-2013 03:52 PM
That's what it was! Now what vehicles were those? Subies?
superdave2335 06-13-2013 04:08 PM
Speed density from what I have seen here in Alaska is difficult when the weather changes and it goes from 80* outside to 0* lol.
Dano 06-13-2013 05:09 PM
Topic for another thread but yes as VE changes so to must the tune if it expands beyond the table limits.
MAF is much easier and more forgiving to hardware changes.
SD is Robbing Peter to pay Paul IMO.
Tappin
mrmonk7663 06-13-2013 07:26 PM
Old fox body mustangs....87 and 88 had speed density from the factory...except the California models...they got mass air in 88 I believe. Anyway, back on topic :)
silvapain 06-15-2013 02:03 PM
Actually MAF is newer and more advanced than speed density.
Lex 06-15-2013 02:20 PM
But in recent turbocharged cars such as the Ecoboost they went back to speed density with some very advanced modelling techniques.
Why? Speed density response is faster than MAF especially if the MAF sensor is so far upstream from the throttle plate.
All the speed density does is it translates pressure into airflow for the engine. You can run a simple table translator such as this:
MAP-ECU3 - Performance Motor Research : Performance Motor Research
Plug it into your MAF harness instead of the MAF and make sure you map the VE table correctly.
mrmonk7663 06-15-2013 07:48 PM
By Advanced, I meant to tune...not the technology. The typical armchair tuner would have quite a bit to learn tuning a modified speed denisity setup.
Enki 06-15-2013 10:28 PM
Don't you have to retune for changes in altitude on SD?
mrmonk7663 06-15-2013 10:49 PM
You have to retune for everything with SD. Stock for stock a speed density car tends to make more power than a Maf Car. This is seen by numerous dynos with the 88 Mustang GT...this is my reference and experience with speed density. Anyway, as soon as you started modding the speed density system, car would react negatively. In order to reel it back in you had to piggyback the ECU and custom tune it. On the other end, the mustang with a MAF was much more forgiving. Heads/cams/intakes/headers/exhaust/superchargers...and the only thing that was needed to change were fuel pumps, fuel injectors, and maf housing...the maf housing was needed to be changed not for size but to complement the injectors.....these kinds of mods were not possible without extensive piggyback ecu tuning on a speed density setup.
BuddySpeed3 04-12-2016 12:59 PM
Are there any dyno proven values for in tank methanol? I'm running 1 gallon and was able to get away with 16* at 6k rpm holding 18.5 psi on k04. I tuned for what was in the tank and used WMI for more safety and consistency. Weird thing though, I recently turned off the WMI to verify my tune doesn't knock and I started seeing knock values at 5K. Idk why it would suddenly start doing that when it didn't when I was tuning for it. Also I've always been putting a full gallon in every fill up at empty, so there would always be residual meth in tank so I was usually just slightly over 1 gallon.
phate 04-12-2016 09:49 PM
Not really, but I suspect that once you have sufficient octane with any fuel type, that MBT values on a given engine will be within a degree or two. The big takeaway from this thread, to me, is that there is HUGE variance in MBT curves between engines. I would take the lowest values and use them as a guideline until you are able to tune on a dyno and sufficiently quantify what a degree or two of timing does for power. Street tuning is not accurate enough for that fine of tuning.
I would go back and have a look at those data logs for comparison, specifically temperatures. Agreed with Enki, this part of your post is best found in a new thread.
Thanks @SofaKingAwesome!
SofaKingAwesome 04-13-2016 06:27 AM
http://www.mazdaspeedforums.org/foru...g-woes-200845/
Page generated in 0.23394 seconds with 11 queries
