-   -   E85 Remedy with HPFP Hardware modifications (http://www.mazdaspeedforums.org/forum/f567/e85-remedy-hpfp-hardware-modifications-164812/)
Easter Bunny 10-31-2015 06:51 PM
The interplay between the spray pattern and the piston design is going to have a larger impact on fuel economy and part throttle operation than it will at wot.
Dano 10-31-2015 10:18 PM
Can I get some stir-fry up in here?
Tappin
littleloogy 11-02-2015 09:40 AM
So I will remain quiet while I work on a new thread since @Dano; likes to be all organized and shit. The injector that I have been working with is the FSI RS4 injector the 2.0t guys are reaching over 500hp with these. It is the cheapest option and what appears to be the correct spray pattern. You can get 4 new injectors for under 400 bucks.
I will also keep my eye open for a used 2.3 ecoboost injector for fitment, as they might offer more fuel, but are expensive as fuck.
Edit: Feel free to comment any ideas, problems, or concerns. I will reference these as I begin the journey.
ItsNox 11-02-2015 09:44 AM
Just wow. I came from the 2.0t platform a few years ago and their max was 350hp on a built block at that time. Good shit. There any many of us behind the scenes appreciating the hard work your putting in on this.
ButtholeRedMS3 11-02-2015 09:47 AM
A quick Google search shows those at $350 shipped. Much more feasible than a 5th or 6th port for most people.
Mazdazilla6 11-02-2015 10:20 AM
Had a hunch. Racked my brains for what DI engine puts out the most power.
Be very sure the spray angle is the same. 1800psi of fuel will wash oil off a cylinder wall very fast. If you want any help testing these let me know I have a trashed head I'm already doing some experimenting on.
littleloogy 11-02-2015 10:29 AM
If you want to start looking at the VW forums and find out how the injector controller differs from ours, we will also need a VW to MZR harness adapter. That will save me a shit ton of time.
Edit: I already have my hands full trying to get the injectors to mount to the head and matching them to the rail. Does anyone know the clearance between the IM and the Fuel Rail? Just in case I need to raise the rail.
Mazdazilla6 11-02-2015 10:57 AM
Yea I'll start looking into it tonight. Another big factor we need to take into account is operating voltages. All (to my knowledge) PI injectors operate on 12V, DI injectors operate anywhere between 50-95V so they need to be in a close voltage range too. I think I can find that info pretty easily tho. I'll report back later.
Tokay444 11-02-2015 10:59 AM
The oil control ring gets most of it. There shouldn't be much left to spray off.
Mazdazilla6 11-02-2015 11:03 AM
Got curious about the electrical specs and just looked it up right now.
Our injector resistance: 1.0-1.2ohms
RS4 injector resistance: 12-20ohms (they also operate on 12V, ours are around 100V)
littleloogy 11-02-2015 11:05 AM
Can't we just use their injector controller?
RS4 injector resistance: 12-20ohms (they also operate on 12V, ours are around 50V iirc)
Great we can just throw in some resistors in your harness.
Mazdazilla6 11-02-2015 11:07 AM
I'm not sure. I would imagine it's integral to the ECU like ours is. Edit: ours isn't
Haha yea. I wish our injector harness wasn't so much money.
littleloogy 11-02-2015 11:11 AM
I wish development was free.
Mazdazilla6 11-02-2015 11:13 AM
Just found this for our injector system.
Attachment 215450
I will look for some description of their operation for their injectors.
Dano 11-02-2015 11:20 AM
I recently purchases a 2013 (30K miles) injector harness off e-bay for $125, not sure you'd consider that expensive in the grand scheme of things.
Mazdazilla6 11-02-2015 11:32 AM
No that's not horrible. But comparing it to my buddies who have ecotecs and buy theirs for $30 and that's considered a normal price, it's kinda spendy.
udntknw 11-02-2015 11:35 AM
Attachment 215450
Is this the "caution hot" box mounted to the frame rail in front of the trans mount on the ms3?
Etipp98 11-02-2015 11:41 AM
Yes^
Enki 11-02-2015 11:52 AM
So it might be possible to rig something up to run 12v and skip that box...? Probably throw a code or 10 though.
silvapain 11-02-2015 12:11 PM
No; that's the in-tank fuel pump slow speed resistor. See page 01-14B-20 of the manual for details on it.
Edit: according to page 01-40B-16 of the manual, the injectors are run on ~70VDC?
Enki 11-02-2015 01:04 PM
If noone has a car apart, I'll be willing to document where everything goes in December when mine gets stripped down and re-loomed.
Mazdazilla6 11-02-2015 01:12 PM
I think the big difference is that our injector system is a peak and hold, it uses 70 (or 100V) to open the injector and holds it open with 12V. Versus the RS4 system is a saturated system the uses a flat 12V on the injectors. The biggest telltale is that our injectors are low impedance.
Car Fuel Injector Basics History | Peak and Hold | Saturated How it works
littleloogy 11-02-2015 01:12 PM
Does it peak around 70 volts to open the valve and then a 12volt constant until the valve closes? Or does it simply operate as a 70v valve?
Mazdazilla6 11-02-2015 01:14 PM
Yes. 70 to open. 12 to hold.
littleloogy 11-02-2015 01:26 PM
Edit Never mind,
littleloogy 11-02-2015 01:34 PM
And the RS4 valve operates with just 12volt?
Mazdazilla6 11-02-2015 01:40 PM
That's what I'll be trying to find out later tonight when I'm done with class. My initial thought is yes because it has a much higher resistance spec meaning it's a high impedance injector, which is what is used in saturated systems.
littleloogy 11-02-2015 01:42 PM
Godspeed. Thanks for your help man.
Mazdazilla6 11-02-2015 01:51 PM
I'm not seeing an opening voltage in the FSM. The only reference I can find to it is the image I posted earlier.
littleloogy 11-02-2015 03:45 PM
If that is true and it is only 12 volts then making a controller will not be difficult at all. It would be slick if we can just find a way to eliminate the 70volt jolt out of our stock controller. Rip off the fet controlling the high voltage on the board or something of that sort.
Enki 11-02-2015 05:13 PM
High voltage is probably coming from a cap/inductor boost converter type setup; considering the current requirements, probably something in the 15-20 rated range (not sure if x1000 or x100 microfarad) if they eat a full amp that is.
silvapain 11-02-2015 06:03 PM
It looks like it (peaks at 70, then holds at 12).
The Mazda manual shows example oscilloscope plots for many PCM signals, including the injectors on page 01-40B-16.
ButtholeRedMS3 11-02-2015 06:31 PM
If you guys are interested there's an injector harness on Facebook (I know, bad juju) for 50 + shipping. I asked the dude for pricing and figured I'd pass it onto you guys if you need it. Also has injectors for 150 + shipping IIRC.
MS3Shadow 11-02-2015 08:44 PM
Shipping shouldn't be that much. Maybe $10-15
sent from my Nexus 6P
Mazdazilla6 11-02-2015 09:11 PM
Okay well the first thing we need to address is the resistance in the injector.
Our ECU won't be able to open the injector unless we can decrease the resistance of them, or increase the amperage going to them, but the later might cause them to overheat.
If we can find a way to decrease their resistance we are golden (electrically) and just need to wire the connectors for them onto our harness.
Enki 11-02-2015 09:17 PM
Assuming, of course, that the injectors are driven by the ECU directly and not by a purpose built injector driver box thingie.
If there is a driver box, then a new one can be made and driven directly by the ECU in place of the old one. Timing might still be a factor, though, but that might still be tunable.
Is Dustin's scope data laying around anywhere still?
littleloogy 11-02-2015 09:18 PM
If we can find a way to decrease their resistance we are golden and just need to wire the connectors for them onto our harness.
What about trying to integrate the 2.0t injector controller into ours?
http://images.tapatalk-cdn.com/15/11...417884d926.jpg
Mazdazilla6 11-02-2015 09:20 PM
There should be no need for that, I believe. All an injector is is just a solenoid. Our ECU and inj driver wouldn't change logic and should behave just fine so long as the resistances are the same.
Edit: The only thing I'm not taking into account is the pintle in the injector and the force required to open it since ours *should* be higher than theirs.
I might be looking at this too simply.
davychronic 11-04-2015 11:36 AM
Has anyone thought about ecoboost 3.5 injectors? They displace a little bit more per cylinder and ive seen 500hp taurus sho's on stock injectors. Ive seen the injectors for $120 a pop. Just an idea
https://www.deatschwerks.com/news/pr...t-gdi-injector
Mazdazilla6 11-04-2015 12:57 PM
Okay well I did some more researching. I think our best bet is to use an injector from a car that uses a peak and hold style system. From what I've found all VAG cars use a saturated style system. I've found that GM's LNF and Hyundai's Theta engines use peak and hold like us, their injectors are rated under 2ohms and GM actually states it uses 65V to open the injector and 12V to hold it open. I don't know much about Hyundai's injectors but there's plenty on the LNF. I can't find if Ecoboosts are saturated or peak and hold or any resistance values for the injectors but they would be a great option if they are peak and hold and we can get them to fit, especially since so many companies are making bigger injectors for them.
Some VW guys actually found that LNF injectors fit in their head. So if we can get a VW injector to fit ours I think we can get an LNF one to fit too. What's extra good is that ZZP sells Opel injectors that offer ~15% more fuel over the stock LNF injector. Cobalts already can make ~450ish on their stock injectors so there's a good chance we can make 450+ on the Opel injectors if we can get them to fit.
Also the connectors look pretty similar so we might not have to alter our injector harness to use them.
Page generated in 0.21992 seconds with 11 queries
