This really needs its own thread. |
Nah that's crazy talk. Tappin |
New thread, old thread, all I know is my body is ready. EDIT: @Raider; please move the injector posts from the past few pages of this thread to the following: http://www.mazdaspeedforums.org/foru...1/#post2977171 kthx xoxoxoxo |
Whatever. You guys go off and do your own thing, I'll stay here. |
Technically, this thread IS for hardware fixes for running full corn. I'd be happy to give you OP in the other thread, or if you make your own mine can be merged into yours. |
E85 Remedy with HPFP Hardware modifications Quote:
No worries. You're better at keeping track of everything anyway. |
Seriously, I just want the fucking injectors. Lol |
The real question I have is how are them IE internals holding up? Once I get a bigger turbo I def want to run full corn, plus all the kids on campus are doing it and I want to be cool just like them :bandwagon: |
IE internals have not given me any problems. Running Stock fuel pressure with a CS turbo gives me a nice vdyno at 350/375. Everyone loves corn, except for those who don't. |
Do you think the deaths are related to ash content in the oil? One of the big trends I've seen is that dexos oils are mostly very low ash oils (plus low ash oils cause less build up on valves, which is always nice). I'm a big fan of Shell products so I'd love to keep running Pennzoil Ultra if I make the switch to IE. |
As much as your fuel system/Rods can handle. I ran 21 psi for many years with the K04 and stock MAP sensors. With my upgraded MAP sensor I now hit +\- 23psi peak tapering to 18 at redline. My advice... Do not hit anything over 400 ft/lbs of torque on a stock block. Upgraded rods and Pistons with 6th port fueling... Sky is the limit. |
Oh Full E I hit 23 psi, and taper down to about 18psi @redline with 125 IDC. Anytime I go over 125 IDC I start to run lean. Oh, and I target 12.1 AFR. Sometimes because of my shitty self tune and some cold mornings I will lean out close to 13.0 AFR redline. [emoji57] |
Ive been able to get away with 12 afr up til about 5k rpm then i have to taper it to 11.7ish but i havent pushed passed 107%. It gets cold as balls here. Ofcourse on e30. Thanks for the info, wanted to make the switch but i guess oversized valves and some port work took me out on full e85. I grow ethanol for a living and love that its so popular and you guys are working so hard to use more of it. |
I don't know how much I can push these stock injectors, where is the limit?. Got up to 139 IDC this time. 17 hp gain from the last set of logs that i did. Attachment 219219 |
Sent from my Nexus 7 using Tapatalk |
Hmmm now u have me thinkin.. Fuck permits lol Sent from my Nexus 7 using Tapatalk |
There's more to it than that as well. You need an ATF permit to brew your own fuel, of which you are limited in quantity, and it has to be denatured, and the ATF has to have access to your brewery at all times. There's plans and fees and all kinds of bullshit you have to do to get it done, which takes forever and has some fees associated with it. |
I'll post up the log when I get home @Enki; I tried posting earlier but I screwed something up. Made 367whp though. Sent from my iPhone using Tapatalk |
Full corn? Edit: Any mods to injector phasing? |
U don't think u could get away with a personal brew? I mean I will be living in the cuts as well.. Just a thought I had since I do have land and the space Sent from my Nexus 7 using Tapatalk |
No, phasing went back to 1.00. I am still on full Corn, yes. Edit: I am only running 18 degrees of timing up top Sent from my iPhone using Tapatalk |
Trust me when I say you want no part of the ATF kicking in your door and finding a high capacity still setup. Quote:
It can be, but your car needs to be set up to make it efficient. It is possible to get the same or better mileage vs gasoline, but again, you need to set the engine up for that and after it's done you won't be able to run pump gas any longer. |
E85 Remedy with HPFP Hardware modifications Injector duty cycle must be calculated, similar to calculated load. MAF calibration could effect IDC Sent from my iPhone using Tapatalk |
Just get it from the pump man. Trust me. Quote:
I will be getting it from the pump for the short for seeable future becuz I still live in Cali... It does suck tho cuz closest pump is like 45mims away... And only other ones are in the deep inner city of san Francisco and east bay. I will not be traveling far on it thts for sure. Sent from my Nexus 7 using Tapatalk |
2 Attachment(s) |
Oh, that's dynojet numbers, so you're hitting normal limits on full corn then. |
Would the IE fuel pump internals have anything to do with his high IDC capacity? |
Jesus christ guys, if you're going to make hooch you don't do it from something as expensive as corn; you use the proper strong yeast with something akin to sugar water. It's the sugar source that will be the most expensive. |
Growing enough corn to produce ethanol, without selling it or raising livestock will have someone looking at you; pot farmers grow in between rows to hide it, you will have the DEA and the ATF looking in your general direction. Before you add the denaturant, it might proved to be a tasty beverage as well :) |
| All times are GMT -7. The time now is 11:55 AM. |
