Like Tree95Likes
 Old 05-03-2015, 04:11 PM   #361
Sandman978's Avatar
Posts: 1,441   (View Stats)
Sandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the worldSandman978 is the leader of the world
What's soldered on there? Gold plated tab?
Fapped over pics of Laguna Seca
2012 CWP Speed3 |:| Cobb V3 AP |:| Resonator Delete |:| Magnaflow Exhaust |:| 4" Exhaust Tips |:| CorkSport SRI |:| Autotech Internals |:| SnailPerformance
Sandman978 is offline   Reply With Quote
 Old 05-03-2015, 04:42 PM   #362
littleloogy's Avatar
Posts: 4,005   (View Stats)
I'm burning some fuel up, verifying that my gauge is not stuck at 3/4 full. After I see it drop and register full after I fillip I'll give details.
But In short, solder ball with a point in it, and a piece of a paper clip lol
Sent from my iPhone 6
The Following 3 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (05-03-2015), ItsNox (05-04-2015), Mauro_Penguin (05-04-2015)
 Old 05-03-2015, 04:42 PM   #363
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Could you just solder over the whole thing and prevent issues?
Easter Bunny (05-03-2015), Mauro_Penguin (05-04-2015)
 Old 05-03-2015, 04:53 PM   #364
Default E85 Remedy with HPFP Hardware modifications
No, the black you see on the left side is a special coating that solder will not adhere to. I then tried to scrape off the coating looking for s trace to solder to. Unfortunately there was none under it.
Easter Bunny (05-03-2015), Enki (05-03-2015), Mauro_Penguin (05-04-2015)
 Old 05-03-2015, 05:07 PM   #365
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Whatever magic you have done, I am 150% interested. Being able to know my fuel level is something I do like.
Also yeah I did finish the same day I started that fun. I'll definitely be pulling it tomorrow to look at it, and hopefully fix it with your magic.
Last edited by g00s3y; 05-03-2015 at 05:07 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to g00s3y For This Useful Post:
 Old 05-03-2015, 05:19 PM   #366
It's on a need to know basis. IIRC you are on petrol, you trader.
The Following 2 Users Say Thank You to littleloogy For This Useful Post:
 Old 05-03-2015, 05:49 PM   #367
g00s3y's Avatar
Groans: 438
Originally Posted by littleloogy View Post
It's on a need to know basis. IIRC you are on petrol, you traitor.
This is true, but that was only to try and "fix" the fuel level sender problem without having to open it up again. But that isn't working, plus another e85 station opened up (makes 2 stations within 10 miles of me). So if there is a possibility of a permanent fix, I will gladly let the ethanol gods bless my car again.
The Following 3 Users Say Thank You to g00s3y For This Useful Post:
Easter Bunny (05-03-2015), littleloogy (05-03-2015), Mauro_Penguin (05-04-2015)
 Old 05-03-2015, 05:49 PM   #368
It's working and Looks good. I'll write how to do it now since I got a 12 pack of XX and a copy of "The Love Bug" (a 1968 classic) to watch.
The Following 4 Users Say Thank You to littleloogy For This Useful Post:
Enki (05-03-2015), g00s3y (05-03-2015), ItsNox (05-04-2015), Mauro_Penguin (05-04-2015)
 Old 05-03-2015, 06:02 PM   #369
nindoja's Avatar
Posts: 2,395   (View Stats)
@littleloogy; any chance you can post up the logs from the aluminum foil coverage tests?
@chaser27;
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
The Following User Says Thank You to nindoja For This Useful Post:
 Old 05-03-2015, 06:30 PM   #370
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
*traitor
I hugged rfinkle2
 Old 05-03-2015, 06:31 PM   #371
*traitor
Dam auto correct...
 Old 05-03-2015, 07:53 PM   #372
All you need to get you fuel level sensor working again is a solder pencil, some steel wool, and some WD-40.
First the obvious, you need to either drop your fuel tank or make your access hole bigger to get to to your ITFP which is where your fuel sender unit is. Remove your pump and place it on your work bench and take a look at your problem child.
Remove the fuel level sending unit from the housing by sliding it upwards and unplugging the connector. Place the fuel pump aside.
What I did was take some WD-40 and a toothbrush to clean everything up. WD-40 will clean up everything that has been corroding. (Used this when I did Amplifier repair and it worked great!)
The next thing you will want to do is grab your ohm meter and check connectivity. Like so...
in my case I was reading an open circuit which was caused by a bad connection between the terminal and the plate.
So what I did was I took the corroded terminal off and used some 00 steel wool soaked in WD-40 to clean the terminal. I then took some Q-tips with wd 40 on the plate to clean it up so there will be a solid connection.
To prevent any future corrosion I soldered a solder ball on the tip of the terminal with some silver bearing solder
Put it back together, verify connectivity, and you should be golden. Make sure you use as much clamping force as possible when reattaching the terminal to the plate.
If anyone needs more detail or questions feel free to ask.
The Following 6 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (05-03-2015), g00s3y (05-04-2015), Hush (05-04-2015), ItsNox (05-04-2015), JgamB (05-03-2015), Mauro_Penguin (05-04-2015)
 Old 05-03-2015, 07:54 PM   #373
Raider is mah Homie
Groans: 2,978
Dam auto correct...
What the duck you talking about.
I hugged rfinkle2
JgamB (05-03-2015), littleloogy (05-03-2015)
 Old 05-03-2015, 08:54 PM   #374
Enki's Avatar
Groans: 189
So how long does it normally take for the sender to take a shit once full corn touches it?
 Old 05-03-2015, 08:56 PM   #375
Couple weeks in my case. I was on 50/50 with no problems. When I switched to full E... Went out, quick!
 Old 05-03-2015, 09:01 PM   #376
Enki's Avatar
Groans: 189
How quick is quick?
 Old 05-03-2015, 09:02 PM   #377
Few weeks compadre
 Old 05-03-2015, 09:18 PM   #378
Enki's Avatar
Groans: 189
So there's a bit of time that needs to pass before this can be signed off as 100% fixed then...? Or did you already do this weeks ago?
 Old 05-03-2015, 10:35 PM   #379
Here everyone. I makes for you.
The Following 5 Users Say Thank You to littleloogy For This Useful Post:
Hush (05-04-2015), ItsNox (05-04-2015), Micha (06-10-2015), Sandman978 (05-03-2015), Spectrix (05-04-2015)
 Old 05-03-2015, 10:49 PM   #380
Enki's Avatar
Groans: 189
Filmed with advanced potato 2.0 pro.
 Old 05-03-2015, 10:49 PM   #381
Wait, who signs off on my work?
I have not said that this was a 100%, Cure all. I was asked me to post up how I did it, so I did. Usually wait a good while before posting how I did something to prevent some jerkoff copying shit prematurely
chaser27 (05-05-2015), Easter Bunny (05-05-2015), Enki (05-03-2015), Mauro_Penguin (05-04-2015), Sandman978 (05-03-2015)
 Old 05-03-2015, 11:16 PM   #382
Enki's Avatar
Groans: 189
I was only asking for clarification. I wasn't sure if you had tested this as being 100% fixed on full corn yet or not.
littleloogy (05-04-2015)
 Old 05-03-2015, 11:53 PM   #383
Alright, fine. It is in HD now...
Easter Bunny (05-05-2015), Enki (05-04-2015)
 Old 05-04-2015, 12:28 AM   #384
@chaser27;
sure Brownie...
base no coverage.csv
30%coverage wot.csv
60% wot.csv
80% wot.csv
I will be collecting some more data This week.
I should really start to think about sorting out this thread. I have 3 projects going on at the moment, even I cant keep it straight.
MSP6 likes this.
The Following 7 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (05-05-2015), Enki (05-04-2015), g00s3y (05-04-2015), ItsNox (05-04-2015), Mauro_Penguin (05-04-2015), MSP6 (05-04-2015), nindoja (05-04-2015)
 Old 05-04-2015, 10:11 PM   #385
Well, I did it again, But this time I wanted to put my timing back to how I normally Run. I also wanted to try no coverage VS 100% Coverage. the results this time were completely Backwards from my last attempt. BAT's sure can climb fast
100% coverage 1st run.csv
100% coverage 2nd run.csv
Uncovered 1st Run.csv
Uncovered 2nd run.csv
Mauro_Penguin (05-06-2015)
 Old 05-04-2015, 10:37 PM   #386
I fear that running this much timing with high BAT's is pushing me past MBT. My next test will be running 1/2 the timing That I am currently running.
If you look at my 80 WOT log from my post from yesterday, notice my timing at the higher RPM range when my BAT's are at their highest compared to the uncovered run. The timing is much lower (I screwed up a timing table on accident) yet I am making more power then the uncovered runs.
 Old 05-14-2015, 11:39 AM   #387
Back to the fuel level sender problem:
Update...
I have yet to experience any problems with my okie rigged level sender. I ran my tank down to where it said I had 7 miles left in tank. It then took 14 gallons to top it off. So if anyone is wondering, the range is still accurate.
Cheers!
biscuit003 (05-14-2015), Easter Bunny (05-14-2015), Enki (05-14-2015), ItsNox (05-14-2015), Sandman978 (05-14-2015)
 Old 05-14-2015, 01:37 PM   #388
Enki's Avatar
Groans: 189
Level sender would have normally gone out by now right?
 Old 05-14-2015, 01:42 PM   #389
Fuck if I know. Mine went out years ago when I first started putting on SI-1 in the tank. With the 1oz to 1 gallons ratio. Maybe @g00s3y; can give us a better understanding of how fast his went out. I remember it being pretty fast. @Dano; you have a Pu, any input?
Enki (05-14-2015)
 Old 05-14-2015, 02:08 PM   #390
g00s3y's Avatar
Groans: 438
My first sender went out at about 53k, bought the car with 37k. That was about 8k miles on pump, 8k miles on e42.5 mix, then about 500 miles on full e before it started going.
When I replaced it the first time, it lasted through about 2 tanks of 50/50 and 3 tanks of e85. After soldering it, I'm about halfway through my second tank of e with no problems. Sender was a bit wonky with the first tank, but that was to be expected as it was "calibrating" i'm sure.
Easter Bunny (05-14-2015), Enki (05-14-2015), littleloogy (05-14-2015)
 Old 05-14-2015, 02:17 PM   #391
Glad it's working @g00s3y; I appreciate the feed back. Please let us know if you run into a problem. we are the only ones doing this, that I know of.
Enki (05-14-2015), g00s3y (05-14-2015)
 Old 05-14-2015, 02:17 PM   #392
Raider is mah Homie
Groans: 2,978
@Dano; has a Juan.
I hugged rfinkle2
 Old 05-14-2015, 02:18 PM   #393
@Dano; has a Juan.
Well shit... @Dano; why you no have Pu?
 Old 05-14-2015, 02:19 PM   #394
Posts: 9,484   (View Stats)
no sir...I have a gen 1
edit: and have no intention of getting a PU. Maybe a gen 3 but more likely a Focus RS in 2017.
Enki (05-14-2015), littleloogy (05-14-2015), Nliiitend1 (05-15-2015), silvapain (05-14-2015)
 Old 05-19-2015, 12:37 PM   #395
snailD's Avatar
Posts: 3,039   (View Stats)
Speaking of the focus RS, i saw one yesterday ripping around, the guy wouldn't stop to talk tho he was taunting us and then weaved through traffic and took some backroad
The Following User Says Thank You to snailD For This Useful Post:
littleloogy (05-19-2015)
 Old 05-19-2015, 03:56 PM   #396
g00s3y's Avatar
Groans: 438
You mean Focus ST right? I don't think the RS was released yet.
On topic though, 500+ miles on e85 after soldering and fuel level sender still working correctly.
Dano (05-19-2015), Enki (05-19-2015), Micha (06-10-2015)
 Old 05-19-2015, 04:45 PM   #397
as goosey said, it's unlikely you saw an RS.....won't be here till 2017...and there is a HUGE difference between the ST and RS. Not even close to the same car.
 Old 05-19-2015, 04:53 PM   #398
snailD's Avatar
nope it was the RS. I live at 10,000 FT ASL and they test cars up here all the time. I live right by the highest town in the US. Here is the best pic we could get. Michigan plates....
The Following 2 Users Say Thank You to snailD For This Useful Post:
Dano (05-20-2015), Micha (06-10-2015)
 Old 05-19-2015, 06:27 PM   #399
g00s3y's Avatar
Groans: 438
Shit that's awesome. Look at that single pipe sticking out the back, were you able to get a look at the front? Is that just blurry, or do they really have a Chevy emblem on the back lol.
 Old 05-20-2015, 09:01 AM   #400
a pic is worth a thousand words as they say...certainly looks like an RS. Wing, rear diffuser, sculpted sides of rear bumper and wheels are def not OEM ST and look like the RS package.
better place to discuss this here. post up your pic.
http://www.mazdaspeedforums.org/foru...cus-rs-183726/
Easter Bunny (05-21-2015), ItsNox (05-20-2015), littleloogy (05-20-2015)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-remedy-hpfp-hardware-modifications-164812/
speedperf6rmanc3 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #1 Pingback 02-19-2014 05:14 PM
First Modifications for MS3 08' CoolMike Mazdaspeed3/6 General Discussion 10 04-16-2013 02:50 PM
Map modifications suggestions? mrFanel 2010 MS3 - ECU Computer Tuning 37 05-10-2011 05:21 PM
Spring modifications thezfunk MazdaSpeed 3 - Engine, Transmission & Driveline 10 03-19-2010 01:56 PM
New Ace Hardware Coupon Codes - $10 off $50 or $20 off $125 + Free Ship to Store at Ace Hardware Haltech Hot Deals Section 0 04-15-2008 12:10 PM
Page generated in 0.59226 seconds with 28 queries
