![]() | | #521 | ![]() |
| Not Ranked : 0 score touche'
![]() | | #522 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
(Thread Starter) | Not Ranked : 0 score Luckily, I don't think this thread has had any cats... Sent from my iPhone 6 |
![]() | | #523 | ![]() |
Groans: 189
| Not Ranked : 0 score I'll be doing this on my true racecar build, automated of course (cause lazy). Not on the Mazda though, bit of a pain in the ass getting it set up right for that unless extra holes drilled and tapped into the filter housing or plate or whatever. Falcon will be dry sump though, so no worries there.
__________________ |
![]() | | #524 | ![]() |
![]() Join Date: Feb 2015 Location: Palmer, Iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
| Not Ranked : 0 score Im also curious about what draining the fp housing will do. That plug makes me curious like it was designed for the drain and changed after production maybe? If you do it, im interested if the lobe sees increased wear. Sent from my SAMSUNG-SM-N910A using Tapatalk
__________________ 06 MS6 GT Titanium Gray II Metallic |
| The Following User Says Thank You to davychronic For This Useful Post: | littleloogy (10-02-2015) |
![]() | | #525 | ![]() |
uploadfromtaptalk1443798025791.jpg ![]() sorry for my shitty pictures, i can get better ones if you need
__________________ 06 MS6 GT Titanium Gray II Metallic | |
| The Following 2 Users Say Thank You to davychronic For This Useful Post: | Easter Bunny (10-02-2015), Tokay444 (10-03-2015) |
![]() | | #526 | ![]() |
![]() Join Date: Mar 2012 Location: Warrenville, IL/Big Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,349
Patent US20030017069 - High pressure fuel pump for internal combustion engine - Google Patents
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
![]() | | #527 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks, I have that document already, I was looking for the engine docs Sent from my iPhone 6 |
| The Following User Says Thank You to littleloogy For This Useful Post: | Mazdazilla6 (10-02-2015) |
![]() | | #528 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
Groans: 52
| Not Ranked : 0 score I am not sure what is being discussed here at this point, last I checked things were being modified in the pump to help keep it clean now you guys are talking about draining oil. Me personally do not believe I would modify anything to do with the oil system for the pump as noone has ever had issues with the stock setup and Mazda engineers know a fuck of allot more than we ever will. With that said I cant read through all this banter, were there any conclusions made on your physical modifications, last I had seen you were doing many things and tearing the pump down almost daily. |
![]() | | #529 | ![]() |
(Thread Starter) | Not Ranked : 0 score So, what your saying is you want more fuel pump mods that no one will ever use? I almost blew @Enki;'/s fuel rail with some of these mods... We all figured out a better way to run 100%E without fucking with the fuel pump. This thread is now about Waco ideas that will benefit our platform. But we do have something fuel related in the works... But for now, oil drain and why that's there is a head scratcher... Sent from my iPhone 6 |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | ButtholeRedMS3 (10-02-2015), Easter Bunny (10-02-2015) |
![]() | | #530 | ![]() |
Groans: 52
| Not Ranked : 0 score No that's not what I said. You basically answered my question, which is where are we on this project and you just said basically fuel pump mods have been abandoned and you have another solution? I was trying to catch up from where I left off, but there is allot of random talking going on(hence oil drain). Please link me to the other solution. |
![]() | | #531 | ![]() |
Groans: 52
In the FSM you will find this in the pump housing removal steps. EDIT: I rather clean up the mess instead of dealing with a potential leaking plug after removal Last edited by Nitr0EngiE; 10-02-2015 at 05:58 PM. | |
| The Following 3 Users Say Thank You to Nitr0EngiE For This Useful Post: |
![]() | | #532 | ![]() |
(Thread Starter) | Not Ranked : 0 score Buzz kill. Sent from my iPhone 6 |
| The Following 4 Users Say Thank You to littleloogy For This Useful Post: |
![]() | | #533 | ![]() |
http://www.mazdaspeedforums.org/foru...-steps-186427/
| The Following 5 Users Say Thank You to Dano For This Useful Post: | Easter Bunny (10-02-2015), Enki (10-02-2015), littleloogy (10-02-2015), Mauro_Penguin (10-03-2015), Nitr0EngiE (10-02-2015) |
![]() | | #534 | ![]() |
Groans: 52
![]() | | #535 | ![]() |
| Not Ranked : 0 score doin good, nothing exciting going on.
![]() | | #536 | ![]() |
(Thread Starter) | Not Ranked : 0 score Maybe you can teach us something about phantom ghost in our engine bay... You ever find it? D? Sent from my iPhone 6 |
![]() | | #537 | ![]() |
| Not Ranked : 0 score I don't even want to answer that...
![]() | | #538 | ![]() |
(Thread Starter) | Not Ranked : 0 score If it makes you feel any better I have started getting some random knock, bad thing is I'm still running lots of E I first noticed it a few months ago. I was seeing less then 2 KR. Now it is in the 6's. It's so random, I have not been able to catch it on the data log yet. Sent from my iPhone 6 |
![]() | | #539 | ![]() |
| Raider is mah Homie ![]() Join Date: Jan 2011 Location: Towson, Maryland
Rep Power: 7524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54,831
Groans: 2,978
__________________ ![]() I hugged rfinkle2 | |
| The Following User Says Thank You to Easter Bunny For This Useful Post: | littleloogy (10-05-2015) |
![]() | | #540 | ![]() |
(Thread Starter) | Not Ranked : 0 score I was thinking that at first as well. But now I am leaning towards a VVT failure. I tried zeroing out the table thinking my VTT could be causing the noise. But I still get 10 degrees of registered advancement. I assume something loose? I am all game for a build, but I need to ask for educational reasons. If this was a ZZB What would cause a such a random knock? I am talking about one episode during a 2 hr drive... I assumed a engine on its way out would knock more frequently. Sent from my iPhone 6 |
![]() | | #541 | ![]() |
Groans: 2,978
| Not Ranked : 0 score Cracked ringland could do any number of weird things.
![]() | | #542 | ![]() |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score I would stop expecting the worst and check small stuff first. My intercooler shroud was causing me random kr up to about 3.5*
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
![]() | | #543 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hope for the best, plan for the worst. Either way, it's been a few years since I have done any leak down/compression tests. Should do one anyway. Who knows, maybe 30,000 miles on E has finally taken its toll. Sent from my iPhone 6 |
![]() | | #544 | ![]() |
| Not Ranked : 0 score That's likely something external causing the registered knock. You can run a leak test to confirm good rings and lands. Tappin
| The Following 2 Users Say Thank You to Dano For This Useful Post: | littleloogy (10-05-2015), MS3Shadow (10-06-2015) |
![]() | | #545 | ![]() |
(Thread Starter) | Not Ranked : 0 score Went over my engine bay, possible mount issue again. Thinking about getting new Passenger, Transmission, and Rear motor mounts. . Tired of this shit. Sent from my iPhone 6 |
| The Following 3 Users Say Thank You to littleloogy For This Useful Post: |
![]() | | #546 | ![]() |
| Not Ranked : 0 score Nice, thatll do it. Bet you were happy to see that. Sent from my SAMSUNG-SM-N910A using Tapatalk
| The Following 2 Users Say Thank You to davychronic For This Useful Post: | Easter Bunny (10-06-2015), littleloogy (10-06-2015) |
![]() | | #547 | ![]() |
![]() Join Date: Oct 2013 Location: Fort Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 976
Groans: 438
| Not Ranked : 0 score Get the DM mounts, 100% worth it in every way.
__________________ All good things must come to an end... |
| The Following 5 Users Say Thank You to g00s3y For This Useful Post: | ButtholeRedMS3 (10-06-2015), Enki (10-06-2015), JgamB (10-06-2015), Mauro_Penguin (10-06-2015), MS3Shadow (10-06-2015) |
![]() | | #548 | ![]() |
Groans: 189
| Not Ranked : 0 score Can't be QFT enough.
![]() | | #549 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score wat mounts do u have?
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
| The Following User Says Thank You to MSP611 For This Useful Post: | Easter Bunny (10-06-2015) |
![]() | | #550 | ![]() |
Groans: 189
| Not Ranked : 0 score Looks like Corksport rear at the least. I'd get that thing warrantied.
![]() | | #551 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
Groans: 67
| Not Ranked : 0 score That rear mount itself doesn't really appear to have a problem. If anything, it looks like it's the eye bushing in the OEM aluminum bracket that is allowing movement/noise (in the video, at least)...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | Easter Bunny (10-06-2015) |
![]() | | #552 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well here is a close up of the mount torqued to max CS spec of 66lb/lbs. yuck... Looks to me that running the stock TMM for as long as I did cause lateral pressure which has been wearing out the sides of the mount. ![]() ![]() So I searched my tool box, junk box, and garage floor for something the use as a shim. I ended up using a few spark plug indexing shims and a thing-a-am-jig. All better. Sent from my iPhone 6 |
![]() | | #553 | ![]() |
(Thread Starter) | Not Ranked : 0 score Finally got some head... |
![]() | | #554 | ![]() |
| Not Ranked : 0 score mmmmm head lol
![]() | | #555 | ![]() |
(Thread Starter) | Not Ranked : 0 score Little teaser...progress is my middle name. ![]() |
| The Following 11 Users Say Thank You to littleloogy For This Useful Post: | aackthpt (11-01-2015), ButtholeRedMS3 (10-31-2015), Code Monkey (10-31-2015), Dano (10-30-2015), Easter Bunny (10-31-2015), Enki (10-30-2015), ItsNox (10-31-2015), Mauro_Penguin (11-01-2015), Mazdazilla6 (10-31-2015), MD1032 (10-31-2015), speedfreak44 (10-30-2015) |
![]() | | #556 | ![]() |
| Not Ranked : 0 score Needs own thread. linky here.
| The Following 4 Users Say Thank You to Dano For This Useful Post: |
![]() | | #557 | ![]() |
| The Following 5 Users Say Thank You to littleloogy For This Useful Post: | ButtholeRedMS3 (10-31-2015), Easter Bunny (10-31-2015), ItsNox (10-31-2015), Koke382 (11-04-2015), Mauro_Penguin (11-01-2015) |
![]() | | #558 | ![]() |
| Not Ranked : 0 score what size injector?
| The Following User Says Thank You to Dano For This Useful Post: | Easter Bunny (10-31-2015) |
![]() | | #559 | ![]() |
| The Following User Says Thank You to littleloogy For This Useful Post: | Easter Bunny (10-31-2015) |
![]() | | #560 | ![]() |
Groans: 189
| Not Ranked : 0 score 550 times how many? And on what fuel? I've found ancient threads that suggest ours are 1700 CC.
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-remedy-hpfp-hardware-modifications-164812/ | ||||
| speedperf6rmanc3 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | Post #1 | Pingback | 02-19-2014 05:14 PM | |
| First Modifications for MS3 08' | CoolMike | Mazdaspeed3/6 General Discussion | 10 | 04-16-2013 02:50 PM |
| Map modifications suggestions? | mrFanel | 2010 MS3 - ECU Computer Tuning | 37 | 05-10-2011 05:21 PM |
| Spring modifications | thezfunk | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 03-19-2010 01:56 PM |
| New Ace Hardware Coupon Codes - $10 off $50 or $20 off $125 + Free Ship to Store at Ace Hardware | Haltech | Hot Deals Section | 0 | 04-15-2008 12:10 PM |
