Like Tree95Likes
 Old 10-31-2015, 12:01 AM   #561
littleloogy's Avatar
Posts: 4,005   (View Stats)
4. Petrol.
1700cc at what PSI? I have seen threads like that as well. The problem that I have is where did the information come from? Did they take a 5 BAR standard flow test and then multiply that number to get the CC? Because if they did then the numbers are not correct.
 Old 10-31-2015, 12:19 AM   #562
MSP611's Avatar
Posts: 2,291   (View Stats)
i wonder if these would work... fuckin mustangs gettin all the shit.
DeatschWerks 1700cc Fuel Injectors 2015 Mustang Ecoboost Set of 4
Koke382 likes this.
In progress:
The Following 2 Users Say Thank You to MSP611 For This Useful Post:
Koke382 (11-04-2015), MD1032 (10-31-2015)
 Old 10-31-2015, 12:22 AM   #563
Oh baby. Go to fine me a OEM one for possible fitment.
 Old 10-31-2015, 12:29 AM   #564
MSP611's Avatar
ill have my boys at ford keep a look out if they get a broken one and ill have em send it ur way... doubt they will get on tho, cuz i dont think theyd be failin already...
In progress:
 Old 10-31-2015, 12:35 AM   #565
What kind of power are those mustangs putting out anyway?
 Old 10-31-2015, 12:40 AM   #566
MSP611's Avatar
stock?? or modded?
In progress:
 Old 10-31-2015, 12:41 AM   #567
stock?? or modded?
Modded of course. I wonder if anyone has taxed their fuel system yet.
 Old 10-31-2015, 12:45 AM   #568
MSP611's Avatar
uhhh i know there is a couple big turbo ones pushin 500hp on stock blocks... im pretty sure tht was stock fuel system but not 100%
littleloogy likes this.
In progress:
 Old 10-31-2015, 12:50 AM   #569
Good to know. These look like the HDEV 5.2. I'll order one and see if it will somewhat fit out head.
 Old 10-31-2015, 01:00 AM   #570
MSP611's Avatar
ur gunna order a stock one or the new deatchwerks one?
In progress:
 Old 10-31-2015, 01:16 AM   #571
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Dustin Jones, gearhead. Not sure what method he used, but I'm sure it factored in full spray window (without factoring timing).
Mauro_Penguin (11-01-2015), Micha (10-31-2015)
 Old 10-31-2015, 05:49 AM   #572
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Looking forward to seeing the results...thanks for your work here.
2007 Mazdaspeed3 GT
 Old 10-31-2015, 09:31 AM   #573
Gearheads... What do they know? No offense.
The Following 3 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (10-31-2015), Enki (10-31-2015), Mauro_Penguin (11-01-2015)
 Old 10-31-2015, 09:44 AM   #574
Enki's Avatar
Groans: 189
He's the guy that drove around with a full size O-Scope on his dashboard and a trunk of wiring going to under his hood for measuring injector PW and shit like that.
littleloogy (10-31-2015), Mauro_Penguin (11-01-2015), Micha (10-31-2015), silvapain (11-02-2015)
 Old 10-31-2015, 10:04 AM   #575
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
Fuel system on ecoboost mustang supports 500whp on pump gas, just fyi. Excited that you are working on this, i have a million diesel shops around me and ive been looking for some used injectors to see what they flow and if anything can be done to improve them. Im getting tired of running out of fuel at 20psi on the cs turbo on e30.
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
 Old 10-31-2015, 10:06 AM   #576
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
PS Mountune makes bigger DI injectors for the 2.3 EB
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 10-31-2015, 10:14 AM   #577
The injectors and head design are completely different tho
Even looks like the bucket they use for the cdfp has a roller on it, interesting that this design hasnt come out sooner with all the problems vw had with cam follower wear
The Following User Says Thank You to davychronic For This Useful Post:
ItsNox (10-31-2015)
 Old 10-31-2015, 10:32 AM   #578
Posts: 9,484   (View Stats)
EB market >>>> MZR DISI (MZR DISI is dead after all)
jussayin.
retrofit is our only hope
 Old 10-31-2015, 10:46 AM   #579
jussayin.
Amen. That's what this is all about...
ItsNox likes this.
The Following 2 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (10-31-2015), TiGraySpeed6 (11-02-2015)
 Old 10-31-2015, 10:48 AM   #580
SpeedRebirth's Avatar
Posts: 685   (View Stats)
SpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the world
Groans: 33
It is unknown. 550bhp worth. What is the max our injectors will do?
Power output can very alot between cars. Variables like perfectly seating rings, CC venting, fuel quality, timing used and amount of exhaust backpressure (to mention a few) dictates what power that specific engine makes. And IDC can be taken well beyond 130% on some cars where they cause fuel cut very quickly on others when exceeding 100%.
My car made 360-380awhp from 5400 to 6500 rpm on 25% E85 and stock fueling system (VD numbers though but they are quite accurate) at 11 AFR. This equals 450-475bhp on 20% drivetrain loss. Probably close to maxing the injectors out but it ran quite well, no fuel cuts.
So 550bhp is almost 100bhp more
Mazdaspeed6 -06
Tuned with by Alex@Stratified
CP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP
Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation
Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit
JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2
Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025
Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp
Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter
Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
SpeedRebirth is offline   Reply With Quote
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
Easter Bunny (10-31-2015), littleloogy (10-31-2015)
 Old 10-31-2015, 11:11 AM   #581
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
I assume the statement was more along the lines of how much fuel can it flow, how much potential energy is stored in this amount of fuel and how much power could that be? Hell just a degree of timing could be 15+ Hp on some setups
@littleloogy; did you mean 550 each or for four?
I hugged rfinkle2
 Old 10-31-2015, 11:16 AM   #582
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Mountune doesn't make injectors. They just rebrand other ford injectors from a Jaguar I believe.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-31-2015, 11:31 AM   #583
I wish. 550/4
 Old 10-31-2015, 11:44 AM   #584
They kinda look like VAG/TSI injectors. It looks like you bored out the injector bore to make it fit.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 10-31-2015, 11:53 AM   #585
what do any of the last two dozen posts have to do with the HPFP.
see why we need a new thread loogy?
doo eeeet already. We'll get Raider to clean it up.
 Old 10-31-2015, 11:57 AM   #586
Groans: 33
Exactly! And I would think that when they state "550bhp capable", that would be on a more normal setup, with "normal" timing and boost. What we do to our cars is optimizing it as much as possible. So if timing on a normal setup is 10*, then we could gain ALOT by bringing it up to ~18*. So possibly 600+? *dreaming a little*
Mazdaspeed6 -06
290 AWHP / K04
 Old 10-31-2015, 12:59 PM   #587
Enki's Avatar
Groans: 189
So long as our ECU can drive them, I'm willing to test bigger injectors on full corn....Kind of in a good spot to do it anyways.
ItsNox (10-31-2015)
 Old 10-31-2015, 03:09 PM   #588
Raider is mah Homie
Groans: 2,978
I wish. 550/4
Wheel or crank?
I hugged rfinkle2
 Old 10-31-2015, 03:12 PM   #589
Wheel or crank?
Bhp.
 Old 10-31-2015, 03:13 PM   #590
Enki's Avatar
Groans: 189
So probably close to what we have already.
 Old 10-31-2015, 03:47 PM   #591
Groans: 33
Have you ever seen a stock fueling mazdaspeed with 495whp / 440awhp? Me neither
Mazdaspeed6 -06
290 AWHP / K04
 Old 10-31-2015, 03:55 PM   #592
Enki's Avatar
Groans: 189
He said 550 brake; you mean to tell me that our drivetrain loss is around 10%?
Mauro_Penguin (11-01-2015), Tokay444 (10-31-2015)
 Old 10-31-2015, 03:57 PM   #593
ButtholeRedMS3's Avatar
Posts: 784   (View Stats)
ButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the world
I'm here to tell you I'm excited about possible injectors. Been lurking on all your threads for awhile. I knew there was a reason why.
2007 BM MS6 - Sold
2010 VRM MS3 Tech - Sold
ButtholeRedMS3 is offline   Reply With Quote
 Old 10-31-2015, 04:25 PM   #594
Raider is mah Homie
Groans: 2,978
More like 460 on a 3 which is probably around an 80-100 Hp increase over stock. More importantly it would be enough to cover 95% of builds.
Edit: all of the above is ricer math I pulled out of my ass.
littleloogy, ItsNox and ms3gt08 like this.
I hugged rfinkle2
The Following 4 Users Say Thank You to Easter Bunny For This Useful Post:
ButtholeRedMS3 (10-31-2015), Dano (10-31-2015), ItsNox (10-31-2015), littleloogy (10-31-2015)
 Old 10-31-2015, 05:57 PM   #595
Groans: 33
Read my post again
550 * 0,9 = 495
550 * 0,8 = 440
whp = two wheel drive = ms3
awhp = four wheel drive = ms6
Mazdaspeed6 -06
290 AWHP / K04
 Old 10-31-2015, 06:18 PM   #596
Enki's Avatar
Groans: 189
Yeah, you're saying that MS3 drivetrain loss is only 10%? Always thought it was a bit higher.
 Old 10-31-2015, 06:26 PM   #597
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
SarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the world
Groaned at 8 Times in 4 Posts
Here in Australia we've seen stock 3's dyno 150-155kw stock (190kw crank) which is about 15% loss...
6's usual around 130kw (low 20's loss)
OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPV
NEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP
SarcasticOne is offline   Reply With Quote
The Following 3 Users Say Thank You to SarcasticOne For This Useful Post:
Dano (10-31-2015), Easter Bunny (10-31-2015), Enki (10-31-2015)
 Old 10-31-2015, 06:32 PM   #598
Raider is mah Homie
Groans: 2,978
Standerd internet drivetrain losses are
15% fwd
20% rwd
20-25% awd
Stock ms3 s dyno 220-230 so right at 15%
I hugged rfinkle2
littleloogy (10-31-2015), silvapain (11-02-2015)
 Old 10-31-2015, 06:35 PM   #599
Enki's Avatar
Groans: 189
Yeah that's what I was thinking too; 15% seems more reasonable.
That would put 400 WHP cars at about 470 crank...So 550 BHP injectors are about 17% larger, and would see 60-65 WHP gain (roughly)....Or close to 350 WHP on full E85 (assuming 300 WHP is all that can be attained; I forget exactly how much I was able to make).
One other thing that needs to be considered is spray pattern and piston top design to match. I'd assume that the Ford injectors would have a superior spray pattern, but I'm not sure.
 Old 10-31-2015, 06:49 PM   #600
Tokay444's Avatar
Groans: 793
It's definitely higher than 10%.
This is a heavy duty tranny. All you need to do is listen to it to know that. I wouldn't doubt it's closer to 20% on the 3.
Demodded.
The Seals
The Following 4 Users Say Thank You to Tokay444 For This Useful Post:
Easter Bunny (11-01-2015), Enki (10-31-2015), ItsNox (11-01-2015), Mauro_Penguin (11-01-2015)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-remedy-hpfp-hardware-modifications-164812/
speedperf6rmanc3 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #1 Pingback 02-19-2014 05:14 PM
First Modifications for MS3 08' CoolMike Mazdaspeed3/6 General Discussion 10 04-16-2013 02:50 PM
Map modifications suggestions? mrFanel 2010 MS3 - ECU Computer Tuning 37 05-10-2011 05:21 PM
Spring modifications thezfunk MazdaSpeed 3 - Engine, Transmission & Driveline 10 03-19-2010 01:56 PM
New Ace Hardware Coupon Codes - $10 off $50 or $20 off $125 + Free Ship to Store at Ace Hardware Haltech Hot Deals Section 0 04-15-2008 12:10 PM
Page generated in 0.56241 seconds with 32 queries
