Like Tree95Likes
 Old 06-04-2014, 03:02 PM   #161
littleloogy's Avatar
Posts: 4,005   (View Stats)
When ever I get a chance to finish my return system with additive injection I will post up. I wish it was not so damn hot in my shop this time of year. It is like 120 degrees in there by the time I get home from work...
The return line is hooked on a solenoid (no power closed). After I finish my run, I will turn off ignition, flip my solenoid on, and turn ignition back on. Fuel will dump back into my tank as I let the pump, pump.
Any cons to this setup?
Edit: Along the lines of the solenoid being a fire hazard? Or how hot the coil can get when energized for an extended period of time?
Sent From a Galaxy, Far Far Away...
Mauro_Penguin (06-04-2014)
 Old 06-04-2014, 04:01 PM   #162
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
One way to find out....
Easter Bunny (06-04-2014)
 Old 06-04-2014, 05:55 PM   #163
Posts: 9,484   (View Stats)
may give new meaning to zoom zoom boom...
Easter Bunny (06-04-2014), ItsNox (06-08-2014), littleloogy (09-21-2014)
 Old 06-04-2014, 07:17 PM   #164
Scott4957's Avatar
Posts: 171   (View Stats)
Scott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the worldScott4957 is the leader of the world
In for updates, thanks for the hard work on this!
Scott4957 is offline   Reply With Quote
The Following User Says Thank You to Scott4957 For This Useful Post:
 Old 08-13-2014, 08:28 PM   #165
Well I started a new project. We are starting to test it. E-85 Cure With Fuel Additives
 Old 08-13-2014, 09:04 PM   #166
Scott4957's Avatar
Thanks! I have been following that. I was surprised that applying the additive that way lasts so long, that's great! I would have thought it would quickly dissipate.
 Old 08-13-2014, 09:39 PM   #167
I was surprised as well. There also could be other reasoning as to why I am able to go so long.
Either the fuel has changed at my local station and is not reacting to my fuel as it used to.
Or the back death crap is in our tanks, and after over a gallon of Si-1 it has been all cleaned out. Resulting in no death in pump
Time will tell. I know enki is having some of his local guys test this. We will have a better understanding after a while.
The Following 3 Users Say Thank You to littleloogy For This Useful Post:
ItsNox (08-19-2014), Mauro_Penguin (08-27-2014), navyspeed3 (08-14-2014)
 Old 09-10-2014, 01:30 PM   #168
jtms6's Avatar
Posts: 51   (View Stats)
jtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud ofjtms6 has much to be proud of
So i ran SI-1 through the tank for a while when we first started testing this additive. probably 5-6 full fill ups.
went back on 91 for a few months
Now im back on full E - no additive for about 4.5 full fillups thus far.
I drive 60 mi a day = 300 miles a week and for the past month i have yet to see issues in logs or daily driving.
i wanted to see the effects of running without any additive and when or how long till failure, then use the additive to clean and lubricate the pump
my question is, Is the theory of black death coming from the tank still a vaild theory?
I do know Enkei says its only a matter of time but i guess the aforementioned theory kind of makes sense in my case. fluke? luck? maybe i just jinxed myself lol
" THE list " Cobb AP // CPE catback exh w/ resonator // CORKSPORT TMIC // Autotech HPFP // ITV22's // COBB SF+TIH // AWR PMM,TMM // JBR RMM // CPE Rear diff mt // EGAY catless DP // BANJO BOLT // SPC balljoints // speed daddy springs
self tuning journey of fail begins
jtms6 is offline   Reply With Quote
 Old 09-10-2014, 05:58 PM   #169
Fjager's Avatar
Posts: 246   (View Stats)
Fjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the world
I
I believe it was concluded to be due to the heating/boiling of the fuel from shutdown and it mixing with the oil. -sourced from enki's thread on e-85 testing.
2013 White Pearl MS3
JBR SSP/bushings/RMM/EGR delete
Corksport 3ID Intake/Radiator
Cobb APV3/AT Internals
Grimmspeed 3 port EBCS/Matt Damond CC
FMIC W/DIY Sprayer
CPE DP
Fjager is offline   Reply With Quote
The Following 2 Users Say Thank You to Fjager For This Useful Post:
Enki (09-10-2014), PapaSmurf (09-10-2014)
 Old 09-10-2014, 11:50 PM   #170
Enki's Avatar
Groans: 189
It's not just me that says that. Everyone who's been on full E before has a clock between pump cleanings which gets shorter after each. It's possible that the only whole pumps that DON'T have issues are CPE pumps, but there's no real hard data to validate that.
Enkei = wheel mfg
Enki = me
Confirmed. I boiled E in a pan (yes there was an eventual fire) and had no issues whatsoever. Add a little oil, heat it a bit more and sticky over everything.
ArmanRus likes this.
chaser27 (09-11-2014), Easter Bunny (09-11-2014), Fjager (09-11-2014)
 Old 09-11-2014, 07:38 AM   #171
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
@mazdafreak; can confirm that cpe pumps have the same issues with full E85.
-06 MS6
-Corn fed 07 MS3 - Sold
chaser27 (09-11-2014), Constantin (09-12-2014), Easter Bunny (09-11-2014), Enki (09-11-2014), rfinkle2 (09-22-2014)
 Old 09-11-2014, 04:26 PM   #172
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
This is true..... But I do believe I was able to last a lil longer on full E on Cpe pump compared to ppl running just the autotech (internal upgrade)
Been running kendell racing oil with great results (only on a 70/30 mix tho)
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
Enki (09-11-2014), phate (09-11-2014)
 Old 09-18-2014, 04:35 PM   #173
This will be going into the pump tomorrow evening after I change my oil. I'm sure the spring loaded seal will help keeps the oil and E separated.
The Following 13 Users Say Thank You to littleloogy For This Useful Post:
ButtholeRedMS3 (06-09-2015), Cheapspeed (09-18-2014), Easter Bunny (09-18-2014), Enki (09-18-2014), LatinKraze (09-21-2014), manselainen (09-21-2014), Mauro_Penguin (09-20-2014), Mazdazilla6 (09-21-2014), OverBoosted (09-18-2014), Roddiy (09-18-2014), Scott4957 (09-18-2014), SparkySparks (09-18-2014), speed_freak91 (09-22-2014)
 Old 09-18-2014, 04:57 PM   #174
Enki's Avatar
Groans: 189
If this works to keep the pump cleaner than with the chemical method, then we need to find a supplier for the retaining nuts.
littleloogy (09-18-2014), Mauro_Penguin (09-20-2014)
 Old 09-18-2014, 06:37 PM   #175
APR replaces these with their own retaining nut. I need to call them and see if they are willing to sell them to us.
Enki (09-18-2014), Mauro_Penguin (09-20-2014), OverBoosted (09-18-2014)
 Old 09-18-2014, 06:49 PM   #176
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Welcome back from vacation!
I hugged rfinkle2
The Following 4 Users Say Thank You to Easter Bunny For This Useful Post:
Cheapspeed (09-18-2014), Chron (09-18-2014), Mauro_Penguin (09-20-2014), OverBoosted (09-18-2014)
 Old 09-18-2014, 07:16 PM   #177
Enki's Avatar
Groans: 189
If they say no, we can probably arrange to have people randomly call throughout the day, every day, for a month or so asking for them.
That might change their mind.
The Following 9 Users Say Thank You to Enki For This Useful Post:
Constantin (09-18-2014), Easter Bunny (09-18-2014), Fjager (09-22-2014), Jeremy M (09-23-2014), littleloogy (09-18-2014), Mauro_Penguin (09-20-2014), OverBoosted (09-18-2014), SarcasticOne (09-21-2014), speed_freak91 (09-22-2014)
 Old 09-21-2014, 01:28 PM   #178
Holy shit... Fun times
This looks similar as to the last time I took the pump apart. Again, very soft death. Feels like fresh boogers.
Here is the assembly of the audi/vw fastener. It seemed to install the same as our fasteners (retaining nut)
I did not use Si-1 in the installation. This will test this fasteners ability to keep the oil and E85 separate.
Spill valve and button valve were spotless in this run.
The Following 11 Users Say Thank You to littleloogy For This Useful Post:
Cheapspeed (09-22-2014), Constantin (09-21-2014), Dano (09-21-2014), Easter Bunny (09-21-2014), Enki (09-22-2014), Mazdazilla6 (09-21-2014), OverBoosted (09-21-2014), SarcasticOne (09-21-2014), Scott4957 (09-21-2014), speed_freak91 (09-22-2014), wolly6973 (09-21-2014)
 Old 09-21-2014, 01:54 PM   #179
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I'm totally in for this if we can get something that works. Full e fill ups without any further thought would be a dream come true.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
Enki (09-22-2014)
 Old 09-21-2014, 04:32 PM   #180
Here is a fuel pressure log with the new Retaining nut. Pressure seems the same, just like my stock fastener with AT's Attachment 175186
Nothing special, Just Fuel Pressure. I have been driving around a lot Today. Nothing to complain about.... Pure E85 BLISS
PapaSmurf (09-22-2014)
 Old 09-21-2014, 04:46 PM   #181
let the MSF spam team go to work for modification sake for a change instead of the extremely successful trolling.
Enki (09-22-2014), Fjager (09-22-2014), littleloogy (09-21-2014), SarcasticOne (09-21-2014)
 Old 09-21-2014, 04:54 PM   #182
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
SarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the worldSarcasticOne is the leader of the world
Groaned at 8 Times in 4 Posts
Heck, I'd join in from Australia :p
OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPV
NEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP
SarcasticOne is offline   Reply With Quote
The Following User Says Thank You to SarcasticOne For This Useful Post:
 Old 09-21-2014, 05:36 PM   #183
I would prefer to buy them new if I can. I have seen a lot of these o-rings, in different stages of breaking down. The first one I received had a rock hard O-Ring. I am searching for the fasteners (retaining nut) now. It would be nice if we can buy them in bulk and sell them in the MSF store as a key to E85.
Edit: If it works..
The Following 5 Users Say Thank You to littleloogy For This Useful Post:
Constantin (09-21-2014), Easter Bunny (09-21-2014), Enki (09-22-2014), mdl3v8 (09-21-2014), OverBoosted (09-21-2014)
 Old 09-21-2014, 09:12 PM   #184
Raider is mah Homie
Groans: 2,978
Im down for having a reason to be a dick.
I hugged rfinkle2
littleloogy (09-21-2014), UnknownSuperhero (09-22-2014)
 Old 09-21-2014, 10:28 PM   #185
Fuck it. They were discourteous they first time I called them, They deserve it. Telling me no... Who are they? Pieces of shit only dealing with v/w's and Audi's. They are racist is what they are.
Phone:—(800) 680-7921—Local Phone:—+1 (334) 502-5181—Fax:—(334) 502-5180—Address:—APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
I'll give it a shot about fasteners in the morning. When they say no... Fuck em
ButtholeRedMS3 (06-09-2015), chaser27 (09-22-2014), Constantin (09-22-2014), Easter Bunny (09-22-2014), Enki (09-22-2014)
 Old 09-22-2014, 12:03 AM   #186
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
So, what exactly do we have to do? Make them sell us the retaining nut?
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
The Following User Says Thank You to Constantin For This Useful Post:
 Old 09-22-2014, 12:49 AM   #187
Seeing as it's MSF... possibly pics/nudes/phone numbers of any hot family members...
But seeing as they haven't been given troll status yet... Probably settle for them selling us the parts (assuming it works...)
 Old 09-22-2014, 05:17 AM   #188
Raider is mah Homie
Groans: 2,978
Alright, what exactly am I asking for?
I hugged rfinkle2
 Old 09-22-2014, 08:23 AM   #189
That's the goal. If they receive enough demand for the fasteners, maybe they might think about selling them to us, or at least list them on eBay, instead of throwing them away.
Constantin (09-26-2014)
 Old 09-22-2014, 09:46 AM   #190
I called. Talked to a guy named Richard in sales. Asked about what they do with their fasteners. They said "we throw them away."
I then asked if they would be interested in selling the fasteners that they throw away. "We would, but there is too much of a liability, we cant sell a used part"
I asked if someone would sell them on eBay to be rid of the liability "no, we don't do that.
I suggested that he do it personally he said "sorry, I can't, I would loose my job."
What a bunch of pussies...
The Following 6 Users Say Thank You to littleloogy For This Useful Post:
ButtholeRedMS3 (06-09-2015), Constantin (09-26-2014), JSmith (09-22-2014), Koke382 (09-22-2014), PapaSmurf (09-25-2014), pzr2874 (09-22-2014)
 Old 09-22-2014, 10:15 AM   #191
They don't sell new fasteners?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 09-22-2014, 11:11 AM   #192
Their fasteners are designed to work with their internals. The diameter is thicker then ours.
Notice the thickness is the same for the entire length of the piston shaft.
I am curious if we send in a MZR HPFP fuel pump that they can install their internals and fastener. Giving us another option for upgrading our fuel pump.
Constantin (09-27-2014)
 Old 09-22-2014, 11:12 AM   #193
speed_freak91's Avatar
Posts: 1,189   (View Stats)
speed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the world
Groans: 34
Maybe we need Nator AL to go on a mission and do some dumpster diving.
speed_freak91 is offline   Reply With Quote
The Following 8 Users Say Thank You to speed_freak91 For This Useful Post:
ButtholeRedMS3 (06-09-2015), Code Monkey (09-22-2014), Constantin (09-27-2014), dan7225 (09-22-2014), Easter Bunny (09-22-2014), littleloogy (09-22-2014), mdl3v8 (09-22-2014), Scott4957 (09-22-2014)
 Old 09-22-2014, 01:10 PM   #194
Enki's Avatar
Groans: 189
Nope. Exclusivity deal with CPE.
Edit:
At any rate, I'd rather have lower inertia on the internals and a smaller surface area for friction.
 Old 09-22-2014, 02:07 PM   #195
CPE/ APR pumps have been claimed as a 40% volume improvement over stock, At's are claimed to be 50%. In either case getting apr internals would be a step backward. Besides, they fail with E as well.
The Following 2 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (10-16-2014), Enki (09-22-2014)
 Old 09-22-2014, 05:25 PM   #196
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Did you tell them why you were asking about the part?
Bunch of faggots
 Old 09-22-2014, 06:12 PM   #197
Yes. I explained the situation before asking. He claimed nothing can be done to help us.
Constantin (09-27-2014), Easter Bunny (10-16-2014), SarcasticOne (09-22-2014)
 Old 10-16-2014, 03:35 PM   #198
Well this didn't work...
Startup This morning was normal, got one block away from my dwelling and I lost pressure. I pulled over and replaced the spill valve and button valve, but it still would not build pressure. I then dumped some Si-1 in the spill valve and was finally able to build pressure. Got home and found this very familiar black sticky death shit.
This method for controlling back and sticky death is not recommended.
What's next on the drawing board???
The Following 7 Users Say Thank You to littleloogy For This Useful Post:
ButtholeRedMS3 (06-09-2015), Constantin (10-16-2014), Dano (10-17-2014), Easter Bunny (10-16-2014), Mauro_Penguin (10-17-2014), SarcasticOne (10-16-2014), wolly6973 (10-16-2014)
 Old 10-16-2014, 04:07 PM   #199
Enki's Avatar
Groans: 189
This was the Audi retaining nut right? Also, putting SI1 in the spill valve area returned normal function?
 Old 10-16-2014, 05:15 PM   #200
Yes, this was the 2.0t's retaining nut. I was not running any additive in the pump, this was a test of a direct swap of the retaining nut.
After I removed the solenoid I poured a couple of ML's of additive on top of the button valve. After securing the solenoid I restarted my car.
Fuel pressure did not come back right away, It would go from 70psi to 600 psi then watched pressure drop back to in tank pump pressure. It would then spike back up to 1000 psi then taper down to intake pump pressure. After a 1/4 mile of this pressure came back to normal operating pressures.
I also found sticky death in my check valve and on the mouth of my hard line. Wonder how much got in there.
wolly6973 likes this.
ButtholeRedMS3 (06-09-2015), Constantin (10-16-2014), Dano (10-17-2014), Easter Bunny (10-16-2014), Enki (10-16-2014), ItsNox (10-16-2014), jtms6 (10-17-2014), Mauro_Penguin (10-17-2014), Mazdazilla6 (10-22-2014), SarcasticOne (10-16-2014), wolly6973 (10-16-2014)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-remedy-hpfp-hardware-modifications-164812/
speedperf6rmanc3 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #1 Pingback 02-19-2014 05:14 PM
First Modifications for MS3 08' CoolMike Mazdaspeed3/6 General Discussion 10 04-16-2013 02:50 PM
Map modifications suggestions? mrFanel 2010 MS3 - ECU Computer Tuning 37 05-10-2011 05:21 PM
Spring modifications thezfunk MazdaSpeed 3 - Engine, Transmission & Driveline 10 03-19-2010 01:56 PM
New Ace Hardware Coupon Codes - $10 off $50 or $20 off $125 + Free Ship to Store at Ace Hardware Haltech Hot Deals Section 0 04-15-2008 12:10 PM
Page generated in 0.60221 seconds with 34 queries
