![]() | | #201 | ![]() |
![]() Join Date: Mar 2012 Location: Warrenville, IL/Big Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,349
| Not Ranked : 0 score I'm going to look over the patent info for our pump and see if anything sticks out to me.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings |
![]() | | #202 | ![]() |
Groans: 189
| Not Ranked : 0 score Edit: Wrong thread.
__________________ |
![]() | | #203 | ![]() |
| Not Ranked : 0 score Ok so I read through the patent for our fuel pump, found here: Patent US20030017069 - High pressure fuel pump for internal combustion engine - Google Patents And I've come up with the following for solutions (or at least help) with high Ethanol concentrations: 1. Coat the retaining nut and spill valve threading in a resin coating which would insulate the parts and keep heat from spreading. 2. Replacing seals with O, X, or K rings of superior sealing ability, or possibly adding additional seals. 3. Increasing the seal between the cylinder and the pump body. This could be done in couple of ways. .......A. Increase the torque on the retaining nut to press the cylinder harder against the pump body. .......B. Surface harden the cylinder so it can press into pump body to seal better. Possibly in combination with A. .......C. Put some sort of deformable material such as part 70 between the cylinder and pump body to create a seal. Possibly in combination with A and ...........B. 4. Improving part 30, the seal between the cylinder and retaining nut could be improved. Not all of these may work but that's what I came up with after going over the patent. If our pump isn't that different from the LNF pump then I think it's very possible to run full E85. The patent goes over the seals pretty extensively so I would definitely recommend taking a read of it. Here is a picture to get a good idea of what I mean by sealing the cylinder to the pump body. ![]() As well as a picture of seal 30 and 70.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings Last edited by Mazdazilla6; 10-29-2014 at 04:37 PM. |
| The Following 6 Users Say Thank You to Mazdazilla6 For This Useful Post: | Constantin (10-29-2014), Easter Bunny (10-30-2014), ItsNox (10-29-2014), Mauro_Penguin (11-05-2014), pzr2874 (11-01-2014), TiGraySpeed6 (10-29-2014) |
![]() | | #204 | ![]() |
Groans: 189
| Not Ranked : 0 score Counter arguments for each; not trying to shit on your rainbow but I've thought about the pump design at great length as well.
Our best bet right now (both cost and effort wise) is oil + additive, which so far has been promising to a remarkable degree.
__________________ | ||||
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Mauro_Penguin (11-05-2014), Mazdazilla6 (10-29-2014) |
![]() | | #205 | ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5051 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
| Not Ranked : 0 score At what point (*) is this happening though? I know oil coolers assist in this but too cool of oil isn't good either. I'm sure someone has thought of this, just didn't see it. |
![]() | | #206 | ![]() |
Groans: 189
| Not Ranked : 0 score It probably happens at a lower temperature with a hot pump due to the innate 40-60 psi the pump will see at resting preventing the e from boiling and removing heat.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Mauro_Penguin (11-05-2014), pzr2874 (11-01-2014) |
![]() | | #207 | ![]() |
![]() Join Date: Nov 2009 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
| Not Ranked : 0 score Just found these fuel pump internals that I don't think have ever been tried on a MS Integrated Engineering Seems to come with a retaining nut? |
| The Following 8 Users Say Thank You to cletusb For This Useful Post: | Code Monkey (11-06-2014), Constantin (11-09-2014), Easter Bunny (11-08-2014), jtday (11-06-2014), mrmonk7663 (11-07-2014), phate (11-06-2014), SarcasticOne (11-06-2014), wolly6973 (11-06-2014) |
![]() | | #208 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
(Thread Starter) | Not Ranked : 0 score Wonder if they can service a mzr pump. They appear to be like APR, requiring you to send in the pump to be rebuilt. Its nice that I have a spare pump here, just need the money to send it in. I love new testing opportunities. Sent From a Galaxy, Far Far Away... |
![]() | | #209 | ![]() |
| Not Ranked : 0 score They offer a self install kit Pump internal kit only- This is the entry-level HPFP kit for builders who prefer to assemble their HPFP themselves. Each kit includes all necessary components and a detailed install sheet to get the job done. |
![]() | | #210 | ![]() |
(Thread Starter) | Not Ranked : 0 score You're right, my mistake. I skimmed through the article failing to look at the top. $500... Fuck. Sent From a Galaxy, Far Far Away... |
![]() | | #211 | ![]() |
| Not Ranked : 0 score Yeah the price is the first catch, might be worth calling them? See if they know anything about e85 compatibility etc I would but in Australia :-) |
![]() | | #212 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm selling my internals. Going to be on my stock fp internals for a while. My stock clutch is gone so I can't really go fast anyway. My next internal set will be these. I have to try them out. Sent From a Galaxy, Far Far Away... |
| The Following 4 Users Say Thank You to littleloogy For This Useful Post: |
![]() | | #213 | ![]() |
Groans: 189
| Not Ranked : 0 score Upgrade the flywheel while you're at it.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Easter Bunny (11-08-2014), littleloogy (11-07-2014) |
![]() | | #214 | ![]() |
| Not Ranked : 0 score Which option are you going with? Have you contacted them yet about ethanol compatibility?
![]() | | #215 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm asking Santa for a new clutch. I'm debating on a few. I'll call them after I lean all I can about them. If they don't work out I'll just pick up another set of at's or CS internals. In the meantime... I'll be running the stock fuel pump on full E. I won't be putting a lot of load on the engine, fuel pressure "should" be OK. Sent From a Galaxy, Far Far Away... |
| The Following User Says Thank You to littleloogy For This Useful Post: | Easter Bunny (11-08-2014) |
![]() | | #216 | ![]() |
Groans: 189
| Not Ranked : 0 score Zero your VVT, drop the boost. You'll be fine.
![]() | | #217 | ![]() |
(Thread Starter) | Not Ranked : 0 score This sucks not only am I a slow fuck, my RV is failing too. 10 months of straight E is taking its toll on my fuel system. I'm going to have to run a few tanks on petrol to clean it out. Normally after shutdown, my fuel pressure would climb to 1875psi then the RV would open. Now after shut down it immediately starts to loose pressure without climbing. Joy Sent From a Galaxy, Far Far Away... |
![]() | | #218 | ![]() |
Groans: 189
| Not Ranked : 0 score Is the engine hot? If it's not hot, it may not build pressure because there's no heat in the injectors/rail to cause it to increase in pressure.
![]() | | #219 | ![]() |
(Thread Starter) | Not Ranked : 0 score I ran it for a good 20 mins... I take it for a longer drive tomorrow to Make sure Sent From a Galaxy, Far Far Away... |
![]() | | #220 | ![]() |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score Did you dial your hpfp pressure settings in to keep em below the RV crack limit? If you just leave them all at 1700+ psi or whatever your RV will be constantly opening/closing throughout any WOT pull. Mine is set to 1700 or so for only a short window then tapers down at redline to prevent pressure from running away. Usually only one blip above 1800 or so for a 4th gear pull. Rest is mid-high 1700's.... Good pressure AND happy RV!
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
| The Following 4 Users Say Thank You to MSP6 For This Useful Post: |
![]() | | #221 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, I decided to get back to testing e85 death solutions. Last week I ordered Integrated Engineering's internal kit and it finally came it. This kit is beautiful. Check it out! ![]() ![]() ![]() ![]() ![]() ![]() These internals come pre broken in, literally install and WOT (according to IE). Everything was individually wrapped in sealed plastic soaking in assembly lube. I can't wait to get them installed. I have searched high and low on the audi/vw forums looking for a failure. There was none. I don't know of any Mazdaspeeds currently or ever using this Fuel Pump internal. So should be interesting. Sent from my iPhone 6 |
| The Following 19 Users Say Thank You to littleloogy For This Useful Post: | ButtholeRedMS3 (06-09-2015), chaser27 (04-08-2015), cletusb (04-07-2015), Code Monkey (04-07-2015), Constantin (04-07-2015), Dano (04-08-2015), Easter Bunny (04-07-2015), Enki (04-07-2015), ItsNox (04-08-2015), jack_hammer (04-10-2015), JSM3377 (04-07-2015), JSmith (04-07-2015), Mauro_Penguin (04-07-2015), Mazdazilla6 (04-08-2015), Sandman978 (04-08-2015), speed_freak91 (04-09-2015), tegxsi (04-08-2015), TiGraySpeed6 (04-07-2015), wolly6973 (04-07-2015) |
![]() | | #222 | ![]() |
(Thread Starter) | Not Ranked : 0 score And a million thanks to @cletusb; for bringing this pump kit to my attention. I'd buy you a beer if you were not so god damn far away. Sent from my iPhone 6 |
| The Following 3 Users Say Thank You to littleloogy For This Useful Post: |
![]() | | #223 | ![]() |
| Not Ranked : 0 score Thanks for being the guinea pig on the IE fuel pump internals. Looking forward to the the results |
| The Following 2 Users Say Thank You to cletusb For This Useful Post: | littleloogy (04-07-2015), Mauro_Penguin (04-07-2015) |
![]() | | #224 | ![]() |
| Raider is mah Homie ![]() Join Date: Jan 2011 Location: Towson, Maryland
Rep Power: 7524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54,831
Groans: 2,978
__________________ ![]() I hugged rfinkle2 | |
| The Following 4 Users Say Thank You to Easter Bunny For This Useful Post: | ButtholeRedMS3 (06-09-2015), chaser27 (04-08-2015), littleloogy (04-07-2015), Mauro_Penguin (04-07-2015) |
![]() | | #225 | ![]() |
Groans: 189
| Not Ranked : 0 score Sprung replaceable scraper. Interesting.
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #226 | ![]() |
(Thread Starter) | Not Ranked : 0 score I just like that the retaining nuts like the vw/Audi guys have is now available to us. Sent from my iPhone 6 |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | Easter Bunny (04-08-2015), Enki (04-07-2015) |
![]() | | #227 | ![]() |
(Thread Starter) | Not Ranked : 0 score Wow, these things are quiet. Sounds like I have stock internals. Throttle tip in sound is not Audible. I wish I had a way to monitor fuel pressure. Assembly was simple, much like the autotechs except for getting the piston through the seal. The seal was tighter the a 16 year old virgin. ![]() ![]() ![]() Sent from my iPhone 6 |
| The Following 12 Users Say Thank You to littleloogy For This Useful Post: | chaser27 (04-08-2015), cletusb (04-07-2015), Code Monkey (04-08-2015), Easter Bunny (04-08-2015), Enki (04-07-2015), g00s3y (04-08-2015), Jarods7920 (04-08-2015), jdmage_mx5 (04-07-2015), JgamB (04-08-2015), Mauro_Penguin (04-07-2015), tegxsi (04-08-2015), TiGraySpeed6 (04-08-2015) |
![]() | | #228 | ![]() |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score While it hasn't been a problem for us, cam follower fail has been a serious issue for the VW/Audi 2.0TFSI. I'm not saying it will be for you, but please take a look at your bucket now and watch for signs of wear. I know we don't have the oiling holes, but I also don't know if this is going to increase friction / resistance to the point it damages our cam follower. Just an FYI.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
| The Following 9 Users Say Thank You to JgamB For This Useful Post: | ButtholeRedMS3 (06-09-2015), chaser27 (04-08-2015), Code Monkey (04-08-2015), Easter Bunny (04-08-2015), JSmith (04-08-2015), littleloogy (04-08-2015), Mauro_Penguin (04-08-2015), TiGraySpeed6 (04-08-2015), wolly6973 (04-08-2015) |
![]() | | #229 | ![]() |
(Thread Starter) | Not Ranked : 0 score These internals were said to reduce cam follower wear on the 2.0t. I am sure I'll be okay. Besides, ran my pump for 400 miles with sticky internals. My cam follower still looks fine. I'll keep an eye on it, it's good to be cautious. Sent from my iPhone 6 |
| The Following 5 Users Say Thank You to littleloogy For This Useful Post: | ButtholeRedMS3 (06-09-2015), Easter Bunny (04-08-2015), Enki (04-08-2015), JgamB (04-08-2015), Mauro_Penguin (04-09-2015) |
![]() | | #230 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
Curious to see your experience with these loogie. Edit: Just opened hpfpupgrade.com and they even have injector seals.
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
| The Following 3 Users Say Thank You to ItsNox For This Useful Post: |
![]() | | #231 | ![]() |
![]() Join Date: Jun 2009 Location: Tally, FL
Rep Power: 3058 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,683
| Not Ranked : 0 score Ohhhhh we hear mention of John/PTP/HPFPUpgrade/DFDD and whatever other name he's selling under these days.... Typically results in name calling, rock throwing, long shouting matches then he gets banned.
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq |
| The Following 8 Users Say Thank You to TiGraySpeed6 For This Useful Post: | Dano (04-08-2015), Easter Bunny (04-08-2015), ItsNox (04-08-2015), JgamB (04-08-2015), Mauro_Penguin (04-09-2015), Mizzle (06-13-2015), OverBoosted (04-08-2015), UnknownSuperhero (04-16-2015) |
![]() | | #232 | ![]() |
| Not Ranked : 0 score Musta been before my time. I missed all the good shit.
| The Following User Says Thank You to ItsNox For This Useful Post: | OverBoosted (04-08-2015) |
![]() | | #233 | ![]() |
Groans: 189
| Not Ranked : 0 score TLDR is he's a shady faggot and you and everyone else should avoid him like he's a leper.
| The Following 6 Users Say Thank You to Enki For This Useful Post: | Easter Bunny (04-08-2015), ItsNox (04-08-2015), littleloogy (04-08-2015), Mauro_Penguin (04-09-2015), TiGraySpeed6 (04-08-2015), udntknw (04-16-2015) |
![]() | | #234 | ![]() |
| Not Ranked : 0 score In the collective eyes of MSF there is only a marginal difference between: Ptp/dfdd/john Cullen/streetunit Rapebuilt Oh and what was the guys name that was PCing rims or more correctly stealing them? Lol. Tappin
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 04-08-2015 at 12:44 PM. Reason: 8 |
| The Following 6 Users Say Thank You to Dano For This Useful Post: | Easter Bunny (04-08-2015), Enki (04-08-2015), ItsNox (04-08-2015), littleloogy (04-08-2015), Mauro_Penguin (04-09-2015), TiGraySpeed6 (04-08-2015) |
![]() | | #235 | ![]() |
Groans: 2,978
| Not Ranked : 0 score Shawn shreeve.
| The Following 3 Users Say Thank You to Easter Bunny For This Useful Post: |
![]() | | #236 | ![]() |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 582 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score Curious to see how these do on e85
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
| The Following 2 Users Say Thank You to Jarods7920 For This Useful Post: | Enki (04-08-2015), littleloogy (04-08-2015) |
![]() | | #237 | ![]() |
(Thread Starter) | Not Ranked : 0 score Me too. Waiting on @CorkSport; to send my new AP. $22 for 2 day priority shipping. I ordered Monday, it still does not show that it shipped. I am thinking about getting a refund on shipping because of slowness. Sent from my iPhone 6 |
| The Following User Says Thank You to littleloogy For This Useful Post: | Easter Bunny (04-09-2015) |
![]() | | #238 | ![]() |
Groans: 189
| Not Ranked : 0 score Edge drop ships them from Cobb directly with overnight shipping, if memory serves.
![]() | | #239 | ![]() |
| Not Ranked : 0 score reading fail or typing fail...he ordered from corksport. lol at Shawn Shreeve...he was raping guys on many forums if memory serves...
| The Following User Says Thank You to Dano For This Useful Post: | Easter Bunny (04-09-2015) |
![]() | | #240 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes, corksport. They are close to me. I figured I would be "smart" and order through them to get the product quickly. I ordered the IE internals in the afternoon, they shipped same day. I was very impressed how fast they were. Sent from my iPhone 6 |
| The Following User Says Thank You to littleloogy For This Useful Post: | jdspeed (04-20-2015) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-remedy-hpfp-hardware-modifications-164812/ | ||||
| speedperf6rmanc3 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | Post #1 | Pingback | 02-19-2014 05:14 PM | |
| First Modifications for MS3 08' | CoolMike | Mazdaspeed3/6 General Discussion | 10 | 04-16-2013 02:50 PM |
| Map modifications suggestions? | mrFanel | 2010 MS3 - ECU Computer Tuning | 37 | 05-10-2011 05:21 PM |
| Spring modifications | thezfunk | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 03-19-2010 01:56 PM |
| New Ace Hardware Coupon Codes - $10 off $50 or $20 off $125 + Free Ship to Store at Ace Hardware | Haltech | Hot Deals Section | 0 | 04-15-2008 12:10 PM |
