Like Tree95Likes
 Old 10-22-2014, 10:24 AM   #201
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Damn. I really want to see a permanent hardware solution come about for the people who would like to daily on E. Additive solutions seem to be working great but I feel like that's more added maintenance which I (and probably a good amount of others) would rather not deal with.
I'm going to look over the patent info for our pump and see if anything sticks out to me.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 10-22-2014, 10:28 AM   #202
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Edit: Wrong thread.
 Old 10-29-2014, 04:20 PM   #203
Ok so I read through the patent for our fuel pump, found here: Patent US20030017069 - High pressure fuel pump for internal combustion engine - Google Patents
And I've come up with the following for solutions (or at least help) with high Ethanol concentrations:
1. Coat the retaining nut and spill valve threading in a resin coating which would insulate the parts and keep heat from spreading.
2. Replacing seals with O, X, or K rings of superior sealing ability, or possibly adding additional seals.
3. Increasing the seal between the cylinder and the pump body. This could be done in couple of ways.
.......A. Increase the torque on the retaining nut to press the cylinder harder against the pump body.
.......B. Surface harden the cylinder so it can press into pump body to seal better. Possibly in combination with A.
.......C. Put some sort of deformable material such as part 70 between the cylinder and pump body to create a seal. Possibly in combination with A and ...........B.
4. Improving part 30, the seal between the cylinder and retaining nut could be improved.
Not all of these may work but that's what I came up with after going over the patent. If our pump isn't that different from the LNF pump then I think it's very possible to run full E85. The patent goes over the seals pretty extensively so I would definitely recommend taking a read of it.
Here is a picture to get a good idea of what I mean by sealing the cylinder to the pump body.
As well as a picture of seal 30 and 70.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
The Following 6 Users Say Thank You to Mazdazilla6 For This Useful Post:
Constantin (10-29-2014), Easter Bunny (10-30-2014), ItsNox (10-29-2014), Mauro_Penguin (11-05-2014), pzr2874 (11-01-2014), TiGraySpeed6 (10-29-2014)
 Old 10-29-2014, 05:27 PM   #204
Enki's Avatar
Groans: 189
Counter arguments for each; not trying to shit on your rainbow but I've thought about the pump design at great length as well.
The internals themselves have direct contact with super hot engine oil as well as a set of lobes on the camshaft; heat conduction will happen regardless.
Our pumps actually have *two* seals/oil control surfaces already. One is an X shaped buna ruing on the narrow end of the retaining nut, and the other is a little plastic scraper backed by a regular shaped o-ring on the fat end. I had my gunsmith drill this part out and plug it with a piece of PTFE that was also center drilled, but the tolerances are so fucking tight that when tightening the last couple of threads on the nut, the drilled hole in the PTFE was off just enough to seize the internals and prevent actuation, so that idea was scrapped. Yes, he used a drill press and lined it all up while installed in the retaining nut.
If you're going to increase the seal anywhere, it should be on the narrow end of the retaining nut. Closing off the internals from allowing fuel to flow around/through them will result in metal on metal contact and a hardware failure; I'm pretty (~99%) sure that the cause of the issue is oil entering the pump.
See 3.
Our best bet right now (both cost and effort wise) is oil + additive, which so far has been promising to a remarkable degree.
Mauro_Penguin (11-05-2014), Mazdazilla6 (10-29-2014)
 Old 11-01-2014, 06:53 AM   #205
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
At what point (*) is this happening though? I know oil coolers assist in this but too cool of oil isn't good either. I'm sure someone has thought of this, just didn't see it.
 Old 11-01-2014, 11:09 AM   #206
Enki's Avatar
Groans: 189
It probably happens at a lower temperature with a hot pump due to the innate 40-60 psi the pump will see at resting preventing the e from boiling and removing heat.
 Old 11-06-2014, 07:46 PM   #207
cletusb's Avatar
Posts: 488   (View Stats)
cletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the world
Just found these fuel pump internals that I don't think have ever been tried on a MS
Integrated Engineering
Seems to come with a retaining nut?
cletusb is offline   Reply With Quote
The Following 8 Users Say Thank You to cletusb For This Useful Post:
Code Monkey (11-06-2014), Constantin (11-09-2014), Easter Bunny (11-08-2014), jtday (11-06-2014), mrmonk7663 (11-07-2014), phate (11-06-2014), SarcasticOne (11-06-2014), wolly6973 (11-06-2014)
 Old 11-06-2014, 09:57 PM   #208
littleloogy's Avatar
Posts: 4,005   (View Stats)
Wonder if they can service a mzr pump. They appear to be like APR, requiring you to send in the pump to be rebuilt. Its nice that I have a spare pump here, just need the money to send it in. I love new testing opportunities.
Sent From a Galaxy, Far Far Away...
 Old 11-06-2014, 09:59 PM   #209
cletusb's Avatar
They offer a self install kit
Pump internal kit only- This is the entry-level HPFP kit for builders who prefer to assemble their HPFP themselves. Each kit includes all necessary components and a detailed install sheet to get the job done.
 Old 11-06-2014, 10:04 PM   #210
You're right, my mistake. I skimmed through the article failing to look at the top.
$500... Fuck.
 Old 11-06-2014, 10:13 PM   #211
cletusb's Avatar
Yeah the price is the first catch, might be worth calling them? See if they know anything about e85 compatibility etc
I would but in Australia :-)
 Old 11-07-2014, 07:37 PM   #212
I'm selling my internals. Going to be on my stock fp internals for a while. My stock clutch is gone so I can't really go fast anyway. My next internal set will be these. I have to try them out.
The Following 4 Users Say Thank You to littleloogy For This Useful Post:
cletusb (11-07-2014), Constantin (11-09-2014), Easter Bunny (11-08-2014), OverBoosted (11-07-2014)
 Old 11-07-2014, 07:54 PM   #213
Enki's Avatar
Groans: 189
Upgrade the flywheel while you're at it.
Easter Bunny (11-08-2014), littleloogy (11-07-2014)
 Old 11-07-2014, 07:59 PM   #214
Which option are you going with? Have you contacted them yet about ethanol compatibility?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 11-07-2014, 09:12 PM   #215
I'm asking Santa for a new clutch. I'm debating on a few.
I'll call them after I lean all I can about them. If they don't work out I'll just pick up another set of at's or CS internals.
In the meantime... I'll be running the stock fuel pump on full E. I won't be putting a lot of load on the engine, fuel pressure "should" be OK.
 Old 11-07-2014, 09:27 PM   #216
Enki's Avatar
Groans: 189
Zero your VVT, drop the boost. You'll be fine.
 Old 11-07-2014, 10:34 PM   #217
This sucks not only am I a slow fuck, my RV is failing too. 10 months of straight E is taking its toll on my fuel system. I'm going to have to run a few tanks on petrol to clean it out.
Normally after shutdown, my fuel pressure would climb to 1875psi then the RV would open. Now after shut down it immediately starts to loose pressure without climbing. Joy
 Old 11-08-2014, 12:06 AM   #218
Enki's Avatar
Groans: 189
Is the engine hot? If it's not hot, it may not build pressure because there's no heat in the injectors/rail to cause it to increase in pressure.
 Old 11-08-2014, 12:46 AM   #219
I ran it for a good 20 mins... I take it for a longer drive tomorrow to Make sure
 Old 11-08-2014, 06:00 AM   #220
MSP6's Avatar
Posts: 1,246   (View Stats)
MSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the world
Did you dial your hpfp pressure settings in to keep em below the RV crack limit? If you just leave them all at 1700+ psi or whatever your RV will be constantly opening/closing throughout any WOT pull. Mine is set to 1700 or so for only a short window then tapers down at redline to prevent pressure from running away. Usually only one blip above 1800 or so for a 4th gear pull. Rest is mid-high 1700's.... Good pressure AND happy RV!
Speed 6 Gone for 3+ years and still not happy about it
2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP
Enki - "High mixes of corn = all the wastegate all the time for great justice."
MSP6 is offline   Reply With Quote
The Following 4 Users Say Thank You to MSP6 For This Useful Post:
Constantin (11-09-2014), Fjager (11-10-2014), littleloogy (11-08-2014), OverBoosted (11-08-2014)
 Old 04-07-2015, 06:32 PM   #221
Well, I decided to get back to testing e85 death solutions. Last week I ordered Integrated Engineering's internal kit and it finally came it. This kit is beautiful. Check it out!
These internals come pre broken in, literally install and WOT (according to IE). Everything was individually wrapped in sealed plastic soaking in assembly lube. I can't wait to get them installed.
I have searched high and low on the audi/vw forums looking for a failure. There was none. I don't know of any Mazdaspeeds currently or ever using this Fuel Pump internal. So should be interesting.
Sent from my iPhone 6
Mauro_Penguin likes this.
The Following 19 Users Say Thank You to littleloogy For This Useful Post:
ButtholeRedMS3 (06-09-2015), chaser27 (04-08-2015), cletusb (04-07-2015), Code Monkey (04-07-2015), Constantin (04-07-2015), Dano (04-08-2015), Easter Bunny (04-07-2015), Enki (04-07-2015), ItsNox (04-08-2015), jack_hammer (04-10-2015), JSM3377 (04-07-2015), JSmith (04-07-2015), Mauro_Penguin (04-07-2015), Mazdazilla6 (04-08-2015), Sandman978 (04-08-2015), speed_freak91 (04-09-2015), tegxsi (04-08-2015), TiGraySpeed6 (04-07-2015), wolly6973 (04-07-2015)
 Old 04-07-2015, 06:37 PM   #222
And a million thanks to @cletusb; for bringing this pump kit to my attention. I'd buy you a beer if you were not so god damn far away.
The Following 3 Users Say Thank You to littleloogy For This Useful Post:
jack_hammer (04-10-2015), Mauro_Penguin (04-07-2015), TiGraySpeed6 (04-07-2015)
 Old 04-07-2015, 06:42 PM   #223
cletusb's Avatar
Thanks for being the guinea pig on the IE fuel pump internals. Looking forward to the the results
The Following 2 Users Say Thank You to cletusb For This Useful Post:
littleloogy (04-07-2015), Mauro_Penguin (04-07-2015)
 Old 04-07-2015, 07:23 PM   #224
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Have you heard of PayPal?
I hugged rfinkle2
The Following 4 Users Say Thank You to Easter Bunny For This Useful Post:
ButtholeRedMS3 (06-09-2015), chaser27 (04-08-2015), littleloogy (04-07-2015), Mauro_Penguin (04-07-2015)
 Old 04-07-2015, 07:35 PM   #225
Enki's Avatar
Groans: 189
Sprung replaceable scraper. Interesting.
Easter Bunny (04-08-2015), littleloogy (04-07-2015), Mauro_Penguin (04-07-2015)
 Old 04-07-2015, 07:40 PM   #226
I just like that the retaining nuts like the vw/Audi guys have is now available to us.
The Following 2 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (04-08-2015), Enki (04-07-2015)
 Old 04-07-2015, 08:47 PM   #227
Wow, these things are quiet. Sounds like I have stock internals. Throttle tip in sound is not Audible. I wish I had a way to monitor fuel pressure.
Assembly was simple, much like the autotechs except for getting the piston through the seal. The seal was tighter the a 16 year old virgin.
The Following 12 Users Say Thank You to littleloogy For This Useful Post:
chaser27 (04-08-2015), cletusb (04-07-2015), Code Monkey (04-08-2015), Easter Bunny (04-08-2015), Enki (04-07-2015), g00s3y (04-08-2015), Jarods7920 (04-08-2015), jdmage_mx5 (04-07-2015), JgamB (04-08-2015), Mauro_Penguin (04-07-2015), tegxsi (04-08-2015), TiGraySpeed6 (04-08-2015)
 Old 04-08-2015, 09:00 AM   #228
JgamB's Avatar
Posts: 2,566   (View Stats)
While it hasn't been a problem for us, cam follower fail has been a serious issue for the VW/Audi 2.0TFSI. I'm not saying it will be for you, but please take a look at your bucket now and watch for signs of wear. I know we don't have the oiling holes, but I also don't know if this is going to increase friction / resistance to the point it damages our cam follower. Just an FYI.
TiGraySpeed6 likes this.
The Following 9 Users Say Thank You to JgamB For This Useful Post:
ButtholeRedMS3 (06-09-2015), chaser27 (04-08-2015), Code Monkey (04-08-2015), Easter Bunny (04-08-2015), JSmith (04-08-2015), littleloogy (04-08-2015), Mauro_Penguin (04-08-2015), TiGraySpeed6 (04-08-2015), wolly6973 (04-08-2015)
 Old 04-08-2015, 11:40 AM   #229
These internals were said to reduce cam follower wear on the 2.0t. I am sure I'll be okay. Besides, ran my pump for 400 miles with sticky internals. My cam follower still looks fine. I'll keep an eye on it, it's good to be cautious.
The Following 5 Users Say Thank You to littleloogy For This Useful Post:
ButtholeRedMS3 (06-09-2015), Easter Bunny (04-08-2015), Enki (04-08-2015), JgamB (04-08-2015), Mauro_Penguin (04-09-2015)
 Old 04-08-2015, 12:10 PM   #230
ItsNox's Avatar
Posts: 3,076   (View Stats)
ItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the world
I came from the 2.0T platform and the cam follower fail is very real in their world. Some vendors/manufacturers have gone so far as to offer reinforced cam followers. Replacing the camshaft in an Audi is EXPENSIVE and thats what this leads to. Interesting enough, the Audi community absolutely swears by Welcome | HPFPUpgrade.com and we dont hear a mention of them in ours.
Curious to see your experience with these loogie.
Edit: Just opened hpfpupgrade.com and they even have injector seals.
'06 Mazdaspeed 6 GT
Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella
Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings
Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s
Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth
- Miltuned
On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.
Georgia Motherfucking Nator
Originally Posted by Ziggylittles View Post
I hate that you can sleep on suckas and then make rape with your family sedan
ItsNox is offline   Reply With Quote
The Following 3 Users Say Thank You to ItsNox For This Useful Post:
Easter Bunny (04-08-2015), JgamB (04-08-2015), Mauro_Penguin (04-09-2015)
 Old 04-08-2015, 12:13 PM   #231
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Ohhhhh we hear mention of John/PTP/HPFPUpgrade/DFDD and whatever other name he's selling under these days....
Typically results in name calling, rock throwing, long shouting matches then he gets banned.
340hp / 371tq
The Following 8 Users Say Thank You to TiGraySpeed6 For This Useful Post:
Dano (04-08-2015), Easter Bunny (04-08-2015), ItsNox (04-08-2015), JgamB (04-08-2015), Mauro_Penguin (04-09-2015), Mizzle (06-13-2015), OverBoosted (04-08-2015), UnknownSuperhero (04-16-2015)
 Old 04-08-2015, 12:16 PM   #232
ItsNox's Avatar
Musta been before my time. I missed all the good shit.
JgamB likes this.
'06 Mazdaspeed 6 GT
- Miltuned
The Following User Says Thank You to ItsNox For This Useful Post:
 Old 04-08-2015, 12:42 PM   #233
Enki's Avatar
Groans: 189
TLDR is he's a shady faggot and you and everyone else should avoid him like he's a leper.
The Following 6 Users Say Thank You to Enki For This Useful Post:
Easter Bunny (04-08-2015), ItsNox (04-08-2015), littleloogy (04-08-2015), Mauro_Penguin (04-09-2015), TiGraySpeed6 (04-08-2015), udntknw (04-16-2015)
 Old 04-08-2015, 12:42 PM   #234
Posts: 9,484   (View Stats)
In the collective eyes of MSF there is only a marginal difference between:
Ptp/dfdd/john
Cullen/streetunit
Rapebuilt
Oh and what was the guys name that was PCing rims or more correctly stealing them?
Lol.
Tappin
The Following 6 Users Say Thank You to Dano For This Useful Post:
Easter Bunny (04-08-2015), Enki (04-08-2015), ItsNox (04-08-2015), littleloogy (04-08-2015), Mauro_Penguin (04-09-2015), TiGraySpeed6 (04-08-2015)
 Old 04-08-2015, 02:02 PM   #235
Raider is mah Homie
Groans: 2,978
Shawn shreeve.
I hugged rfinkle2
The Following 3 Users Say Thank You to Easter Bunny For This Useful Post:
Dano (04-08-2015), littleloogy (04-08-2015), Mauro_Penguin (04-09-2015)
 Old 04-08-2015, 02:14 PM   #236
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Curious to see how these do on e85
2008 MazdaSpeed 3 AWD big turbo...blah blah blah
Jarods7920 is offline   Reply With Quote
The Following 2 Users Say Thank You to Jarods7920 For This Useful Post:
Enki (04-08-2015), littleloogy (04-08-2015)
 Old 04-08-2015, 03:00 PM   #237
Default E85 Remedy with HPFP Hardware modifications
Me too. Waiting on @CorkSport; to send my new AP. $22 for 2 day priority shipping. I ordered Monday, it still does not show that it shipped. I am thinking about getting a refund on shipping because of slowness.
Easter Bunny (04-09-2015)
 Old 04-08-2015, 03:07 PM   #238
Enki's Avatar
Groans: 189
Edge drop ships them from Cobb directly with overnight shipping, if memory serves.
Easter Bunny (04-09-2015), littleloogy (04-08-2015), Mauro_Penguin (04-09-2015)
 Old 04-08-2015, 04:09 PM   #239
reading fail or typing fail...he ordered from corksport.
lol at Shawn Shreeve...he was raping guys on many forums if memory serves...
 Old 04-08-2015, 04:17 PM   #240
Yes, corksport. They are close to me. I figured I would be "smart" and order through them to get the product quickly.
I ordered the IE internals in the afternoon, they shipped same day. I was very impressed how fast they were.
jdspeed (04-20-2015)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/e85-remedy-hpfp-hardware-modifications-164812/
speedperf6rmanc3 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #1 Pingback 02-19-2014 05:14 PM
First Modifications for MS3 08' CoolMike Mazdaspeed3/6 General Discussion 10 04-16-2013 02:50 PM
Map modifications suggestions? mrFanel 2010 MS3 - ECU Computer Tuning 37 05-10-2011 05:21 PM
Spring modifications thezfunk MazdaSpeed 3 - Engine, Transmission & Driveline 10 03-19-2010 01:56 PM
New Ace Hardware Coupon Codes - $10 off $50 or $20 off $125 + Free Ship to Store at Ace Hardware Haltech Hot Deals Section 0 04-15-2008 12:10 PM
Page generated in 0.59343 seconds with 32 queries
