Like Tree7Likes
 Old 11-11-2011, 10:24 AM   #81
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Ok Dustin...
I apologize for the confusion.
Please see my post above.
Haha, not a big deal. I just like to stop conspiracy theories before they start.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
rfinkle2 (11-11-2011)
 Old 11-13-2011, 03:34 PM   #82
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
specvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the world
Groaned at 54 Times in 27 Posts
By your description of the noise it might be what I heard today from my spill valve.
With the car idling and the HPFP chirping, disconnect the electrical connector from the spill valve. If the noise goes away, you should pull the valve and see if there is debris on it.
What tool do you use to remove the spill valve? Before looking at it I went and bought a 32mm socket but the plug to the connector is in the way. I think it needs a crowsfoot wrench.
specvspeedfreak is offline   Reply With Quote
 Old 11-13-2011, 04:04 PM   #83
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
E85 Discussion - HPFP lubrication and Flow issues
hyperlink to post concerning removal^
djuosnteisn (11-14-2011), specvspeedfreak (11-13-2011)
 Old 11-13-2011, 04:14 PM   #84
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
Personally I've always used a cresent wrench
The Following User Says Thank You to GLORIFIEDBOZO For This Useful Post:
rfinkle2 (11-13-2011)
 Old 11-13-2011, 04:52 PM   #85
yeah that's what I am going to do. thanks
 Old 11-13-2011, 05:23 PM   #86
took the spill valve off. Didn't want to take the parts from it out to check since everything looked clean.. I guess my car will keep chugging E85 till I see something is wrong... Just need to figure out if I should go 100% or stick with 50%
 Old 11-13-2011, 06:22 PM   #87
I bought a 32mm combination wrench from Sears for ~$25. Works great.
Sears: Online department store featuring appliances, tools, fitness equipment and more
Here's the link to my new thread on removing and partially disassembling the spill valve:
HOW TO: Remove & Disassemble HPFP Spill Valve
The Following 4 Users Say Thank You to silvapain For This Useful Post:
djuosnteisn (11-14-2011), Enki (11-13-2011), rfinkle2 (11-15-2011), specvspeedfreak (11-13-2011)
 Old 11-13-2011, 09:57 PM   #88
I am going to try 1.07 lambda at <3500RPM and <0.56 load for fuel economy. I got an average of 22 MPG on the highway on my trip to St. Louis for the NATOR MO meat on Saturday.
I'm now targeting 0.81 lambda at WOT, by the way.
djuosnteisn (11-14-2011), phate (11-13-2011), wolly6973 (11-14-2011)
 Old 11-13-2011, 10:26 PM   #89
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
If anyone is curious that's 15.729 gas AFR and 10.449 on e85.
Mizzle (07-26-2013), phate (11-13-2011), rfinkle2 (11-15-2011), silvapain (11-13-2011), wolly6973 (11-14-2011)
 Old 11-13-2011, 10:29 PM   #90
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
If only we had straight gas and perfect E85 But yes, 15.7 targeted in ATR.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 11-14-2011, 09:05 AM   #91
I noticed this morning that even with all my fuel tables targeting 1.07 lambda at low loads, the ECU was still targeting 1.00 lambda when idle at stop lights. I wonder if it has something to do with the clutch tables...
 Old 11-14-2011, 09:09 AM   #92
Enki's Avatar
Groans: 189
I noticed this too, but I doubt it has anything to do with the clutch tables, as they appear to be a ratio. There is probably another table or two Cobb has to unlock.
silvapain (11-14-2011), wolly6973 (11-14-2011)
 Old 11-14-2011, 11:14 AM   #93
Eth Fiend
phate's Avatar
Yeah, this is what I was alluding to when I didn't want to switch all of the tables to the desired E85 AFR. The ecu still seems to want that 14.68 no matter what. I think we have a LOT of closed loop tables to be released for our use. Fueling and timing for sure, and probably others that control other closed loop functions.
-06 MS6
Enki (11-14-2011), rfinkle2 (11-16-2011), silvapain (11-14-2011), wolly6973 (11-14-2011)
 Old 11-14-2011, 11:45 AM   #94
Captain
Groans: 79
Are you guys trying to maximize gas mileage or something?
IMO, maximizing the timing in the PT / cruise load regions will probably net a better increase in gas mileage than simply leaning out the AFR. Has anyone tried to find MBT in the part throttle regions?
www.permtuning.com
 Old 11-14-2011, 11:58 AM   #95
Enki's Avatar
Groans: 189
Probably need to steady state load the car via dyno for that.
rfinkle2 (11-14-2011), silvapain (11-14-2011)
 Old 11-14-2011, 11:59 AM   #96
Surprisingly, based on the prior research I've found on the internet, E85 provides the best fuel economy on lower timing advance than pump gas. The flame speed at lambda in the 1.0-1.1 range is much higher than with regular petrol:
Information Bridge: DOE Scientific and Technical Information - Sponsored by OSTI
Spark Advance vs. Fuel Efficiency & Gasoline vs. E85
I have already done some timing limiting, but I haven't had the time lately to do any solid comparison testing.
Exactly.
@phate, do you think this is something we could do at A-spec on Saturday?
Last edited by silvapain; 11-14-2011 at 11:59 AM. Reason: MSF Database - Automerged Doublepost
djuosnteisn (11-14-2011), Enki (11-14-2011), wolly6973 (11-14-2011)
 Old 11-14-2011, 12:43 PM   #97
Captain
Groans: 79
Good info. So you did pull timing across the board in the PT area? Considering the e has nearly twice as fast a flame speed, i seriously doubt you'd want to be running the super advanced factory timing table.
Maybe pull like 6 degrees or something, and just see if it makes a difference over a couple tanks of gas.
www.permtuning.com
 Old 11-14-2011, 12:48 PM   #98
I'll have to look at my tune and get back to you on what values I'm actually running.
 Old 11-14-2011, 01:16 PM   #99
Eth Fiend
phate's Avatar
Sort of. It seems we don't have much control over the PT closed loop timing. I have been doing some testing with this in my car, and it is still running more than 20° over what I'm commanding, and what is in the Max A/B ignition tables. The car does whatever it feels like.
This is the best way to do it.
Yes, the dynojet we are using is pretty awesome. We can load the car and hold rpms if you want to. I think this will be EXTREMELY time consuming, and something we may want to try later on. We need to figure out how exactly we would quantify the results, and how we would actually go about testing it. We know the fuel injection amount/injector pulsewidth are not accurate, so we can't rely on them for any sort of efficiency calculations. I think if we don't come up with a serious plan, it'll be a lot of cash wasted. I could probably spend days on a dyno doing this, lol.
Tried that. I'm commanding like 20° in my driving range, but the car still runs 40°++. It's frustrating, and a little scary.
-06 MS6
djuosnteisn (11-14-2011), rfinkle2 (11-14-2011), wolly6973 (11-14-2011)
 Old 11-15-2011, 04:55 AM   #100
i wouldent do any testing till cobb releases the rest of the fuel tables. all in do time.........
 Old 11-15-2011, 05:35 AM   #101
There's no harm right now in playing with timing and fuel at low loads. It's just annoying that the ECU isn't running exactly what we're commanding.
However, until COBB can uncover all the fuel tables we won't be able to tune for E85 using fuel instead of MAF scaling. That's just too risky at this point.
phate (11-15-2011), wolly6973 (11-15-2011)
 Old 11-15-2011, 08:36 AM   #102
Upped the load values I target 1.07 lambda and lowered Max timing. I'm holding between 20-40 degrees of advance cruising around town now at 1.07 lambda. The car definitely feels less responsive; I may bump advance up a bit to see the affects.
 Old 11-15-2011, 09:45 PM   #103
I've decided that I am trying to test two things at once, which never works.
I put my old timing tables back in, and I'm just going to run the higher cruise lambda values for now. The car is back to feeling more responsive with the old timing values back. It's obvious I also was too drastic with my timing changes.
My timing values before (what I've gone back to now):
What I tried that felt sluggish:
I tried to get some clean WOT datalogs to put up to show where I'm at, but it's around 45°F right now, and my tires can't grip. I spin in 4th at ~4000 RPM every time.
Last edited by silvapain; 11-15-2011 at 09:45 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-16-2011, 06:38 AM   #104
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
What tires are you on and what size?
 Old 11-16-2011, 07:27 AM   #105
Hankook Ventus V12 K110 215/45 R18.
wolly6973 (11-16-2011)
 Old 11-16-2011, 07:50 AM   #106
wolly6973's Avatar
Groans: 386
This is why I need to get on the dyno saturday.
I don't even spin the tires in 3rd usually, let alone 4th. I am on the V12s also, except I have 225/40/18, and my v-dyno shows that I am making about 310 hp & 350 ft-lbs. Butt dyno also says that it is not that fast.
 Old 11-16-2011, 08:01 AM   #107
I'm spinning the clutch on occasion too. Ugh. Looks like a clutch swap is on my schedule for this winter.
 Old 11-16-2011, 09:03 AM   #108
Eth Fiend
phate's Avatar
Is that with 1.09CF or lower? Cause if that's at 1.0 or 1.01, that's solid power.
-06 MS6
 Old 11-16-2011, 09:17 AM   #109
rfinkle2's Avatar
Groans: 298
I think Wolly6973 is getting used to having that much hp.
It never ends. LOL.
The Following 4 Users Say Thank You to rfinkle2 For This Useful Post:
Dano (11-16-2011), kritz (11-16-2011), phate (11-16-2011), wolly6973 (11-16-2011)
 Old 11-16-2011, 09:24 AM   #110
wolly6973's Avatar
Groans: 386
CF = 1
It never ends. LOL.
That is what I am hoping for, but I am definitely not spinning the tires like everyone else.
The Following User Says Thank You to wolly6973 For This Useful Post:
 Old 11-16-2011, 09:39 AM   #111
Posts: 9,484   (View Stats)
It never ends. LOL.
every once in awhile...i flash an OE map and drive around for a day to see just how far I have come....when you flash back to the power map its violently different lol.
of course I haven't been able to do this with the corn juice but you get the point. Its good to go back and get some perspective once in awhile...keeps you grounded and can keep you from going too far.
just my .02 worth
kritz likes this.
rfinkle2 (11-16-2011), wolly6973 (11-16-2011)
 Old 11-16-2011, 10:31 AM   #112
rfinkle2's Avatar
Groans: 298
CF = 1
I just barely spin and third also.
It "slips" ocassionally.
Maybe you have particularly clean / grippy roads where you live.
Are you going to dyno your car soon Nate?
 Old 11-16-2011, 11:48 AM   #113
wolly6973's Avatar
Groans: 386
Hopefully on Saturday. That is pending weather and closing on my house/wife don't clean my bank account.
 Old 11-16-2011, 12:22 PM   #114
Enki's Avatar
Groans: 189
At least she will be cleaning SOMETHING.
 Old 11-17-2011, 06:37 AM   #115
wolly6973's Avatar
Groans: 386
Sorry for threadjack silvapain, back on the topic of 100% e85 goodness!
 Old 11-17-2011, 07:07 AM   #116
No problem.
I had to increase my WOT lambda from .81 to .84 to give me some injector headroom. I was hitting 103% IDC above 5500 RPM. Now at .84 lambda I'm at 96% IDC max.
I'm still running pretty conservative timing at 18.5 degrees advance at RL.
Dano (11-17-2011), phate (11-17-2011), wolly6973 (11-17-2011)
 Old 11-17-2011, 10:17 AM   #117
Think my clutch and/or tires are slipping? Number seem VERY high, but consistent...
 Old 05-06-2012, 12:32 PM   #118
Spectrum24x's Avatar
Posts: 276   (View Stats)
Spectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond repute
Groaned at 20 Times in 7 Posts
So to the OP, or even to @phate, after this experiment, would you advise against running e-85 on a stock hpfp even if I only had intake with a ap and stock downpipe and exhaust? I live down the street from a Cobb so getting a protune on e-85 wouldn't be a problem.
2007 TRUE RED MS3 GT
RX-8 WHEELS/DRILLED & SLOTTED ROTORS
KONI YELLOW/COBB SPRINGS/JBR RSB/HOTCHKIS FSB
COBB OTS STAGE 2 MAP
RMM/COBB INTAKE/COBB TIH/ETS TMIC
OBX TEST PIPE/AUTOTECH INTERNALS/FORGE BPV V2
Spectrum24x is offline   Reply With Quote
 Old 05-06-2012, 01:56 PM   #119
100% E85 is unadvisable with the stock fuel pump internals.
 Old 05-06-2012, 09:25 PM   #120
Is the drive able with 5xx+ trq to the front wheels?
HPFP vs Stock Tuning sheldonross Gen2 MS3 General Discussion 47 02-17-2012 10:34 AM
Upgraded HPFP on stock tune Meder MazdaSpeed 3/6 - ECU Computer Tuning 21 02-01-2011 04:05 PM
CPE HPFP out of stock mo4130 MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-22-2010 04:43 PM
Stock HPFP can rattle too dougefresh_ MazdaSpeed 6 - Engine, Transmission & Driveline 10 11-20-2010 07:58 PM
Page generated in 0.59314 seconds with 31 queries
