Like Tree63Likes
 Old 05-30-2015, 05:33 PM   #121
littleloogy's Avatar
Posts: 4,005   (View Stats)
Originally Posted by g00s3y View Post
12.05 AFR. I was leaning it out to 12.2, but didn't notice any difference, and didn't want to go any leaner. I know we can go above 100, but with mine, above ~105 it starts to stutter a bit, and above 110 quite a bit more (plugs are good, gapped correctly, etc...).
Plus, with most of my driving being city/town driving, FL heat so A/C on all the time, MPG's were horrible. So 50/50 helps with that some also (read MPG tooning thread, modified cruise load afr's/timing, still sucky). When it starts getting cooler I'll probably go back full corn, just because I can now.
I will probably go back to my tune and try again, just not now here in summer. I step out into the sun and instantly become unmotivated to do almost anything.
Okay. You make some valid points. You do what makes you happy and what you feel comfortable with. I just don't want you to give up on 100% E85 if that what you truly want to run. James and I are here to assist if you run into problems.
Something to think about: before I knew how to tune correctly and was fucking around I beat the living shit out of my car. I leaned to 12.4 targeting 20 Psi at redline. Car bucked like it was a nut tied bull. Calculated load was at 2.5 at 3500 RPMs. Drove that way for a while trying to get as much power out of it as I could. I still have the same compression I did when the car was new. So, I don't think you will hurt anything. There are reasons I run E like @Enki; said, It can protect your engine. When you start running mixes, that shield goes away.
Sent from my iPhone 6
The Following 6 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (05-30-2015), Enki (05-30-2015), g00s3y (05-30-2015), impossible (05-23-2016), Koke382 (07-17-2015), Micha (09-26-2015)
 Old 05-30-2015, 05:45 PM   #122
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
We just don't know at what % you lose that bombproof feeling full corn gives; 50/50 might be just as good, and I might wind up going back to 50/50 for reasons of power as well. Time will tell, however.
g00s3y (05-30-2015), littleloogy (05-30-2015)
 Old 05-30-2015, 05:59 PM   #123
Off topic but nice view...
The Following 4 Users Say Thank You to littleloogy For This Useful Post:
Koke382 (07-17-2015), Mochi (05-30-2015), speedfreak44 (05-30-2015), WetzMS3 (06-02-2015)
 Old 06-02-2015, 03:31 PM   #124
Car made it to south Tahoe, and back. I am so glad I fixed my fuel level sender, makes driving the car on long road trips much more enjoyable.
I lost track of my mileage do to my turbo upgrade. I'll have to read through my notes and find my stating mileage. I know I am getting close to 3000 miles. No problems... Having a great time playing with my mid sized Air compressor. Up to 320whp with fuel headroom.
Easter Bunny (06-02-2015), Enki (06-02-2015), Mauro_Penguin (06-02-2015), WetzMS3 (06-02-2015)
 Old 06-02-2015, 04:58 PM   #125
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Puppy sized.
I hugged rfinkle2
littleloogy (06-02-2015)
 Old 06-03-2015, 10:35 AM   #126
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Both you @littleloogy; and @Enki; have definitely helped already, and I thank both of you for that.
I went and filled up full corn today, said fuck it and going to try this out. Aiming for 20mpg & 300hp just to start (300hp easy, 20mpg will be tough with my "conditions"). I've done some more re-reading in the MPG Tooning thread, changed up some things in the tune, and will be seeing how that works. If I didn't have to use the A/C so much, I'm sure 20mpg would be easily attainable.
Also, fuel level sender still works. Was acting a bit weird when around the empty level, and then stopped 1 bar short of full after filling up, MID range at 326. Then drove away from the pump, and about 15 seconds later that last bar filled and MID changed to 349. It may not be 100% accurate, but it works well enough, and that's good for me.
The Following 2 Users Say Thank You to g00s3y For This Useful Post:
biscuit003 (06-04-2015), littleloogy (06-03-2015)
 Old 06-13-2015, 02:36 PM   #127
MSP611's Avatar
Posts: 2,291   (View Stats)
so these internals seem to be the fix for full E... looks like im selling my autotechs lol
In progress:
 Old 06-13-2015, 02:43 PM   #128
Enki's Avatar
Groans: 189
For now, sure. If the seals wear enough, that might change.
Mauro_Penguin (06-13-2015)
 Old 06-13-2015, 03:22 PM   #129
Love these internals. Group buy?
Cheapspeed (06-13-2015), impossible (05-23-2016), ItsNox (06-13-2015), Koke382 (07-17-2015), Mauro_Penguin (06-13-2015), MD1032 (06-13-2015)
 Old 06-13-2015, 09:29 PM   #130
MSP611's Avatar
Can't u just buy extra seals? Or do they not sell them seperately?
In progress:
 Old 06-13-2015, 09:31 PM   #131
Nope. They won't sell a la cart
Enki (06-13-2015)
 Old 06-13-2015, 10:02 PM   #132
Enki's Avatar
Groans: 189
I can attest that Redline is at worst a near permanent fix.
littleloogy (06-13-2015), Mauro_Penguin (06-18-2015)
 Old 06-14-2015, 02:39 PM   #133
Default IE HPFP Internals For E85
Log Time
Fuel Pump untouched and am at the 3,500 Mile mark. I need a 3 BAR MAP sensor upgrade... then Some Eth injection, i keep running out of Fuel
datalog64.csv
Fuel Pressure WOT target 1669.6 (I never hear my RV go off)
AFR target .823 Lambda
I start Running Lean as MY IDC hits over 120
I am happy that the Puppy was able to suck more air then my fuel system can accommodate and that I did not waste money on expensive intakes.
redneck4Christ likes this.
The Following 3 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (06-14-2015), Enki (06-14-2015), Mauro_Penguin (06-18-2015)
 Old 06-16-2015, 07:28 PM   #134
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Got my IE internals in the mail today...can't wait to install and see the results. I am reluctant to remove the kmd v3 internals that have about 50k on them though been working flawlessly.
Etipp98 is offline   Reply With Quote
The Following 7 Users Say Thank You to Etipp98 For This Useful Post:
Easter Bunny (06-16-2015), impossible (05-23-2016), ItsNox (06-17-2015), littleloogy (06-16-2015), Mauro_Penguin (06-18-2015), Putin 2.3T (06-16-2015), sho (06-17-2015)
 Old 06-16-2015, 08:58 PM   #135
JgamB's Avatar
Posts: 2,566   (View Stats)
Originally Posted by littleloogy View Post
Log Time
Attachment 203395
Barely tickle 21 psi
Hit 1850+ multiple times during the pull
... put some of that normal people fuel in the tank, like 8 or 9 gallons of it - THEN you need a 3 bar *and* a 3" intake.
Although I am curious how you intend to spray Eth - none of the meth pumps are compliant, so carry on.
 Old 06-16-2015, 09:47 PM   #136
I almost went to a mix today actually, but I ended up leaving the pump on and walked into the gas station and buying some skittles. Maybe next time.
I have my eyes open for a 3 BAR with PNP harness, but the Warden saw my turbo bill and flipped the fuck out. So I must tread lightly on my car spending.
In the HPFP mod thread I'll be doing something funky with the HPFP. My goal is to modify the HPFP pump in a way that will allow a secondary fuel supply where I will be able to control injection with a valve set to open at a certain boost pressure. That's the plan anyway.
ItsNox (06-17-2015), JgamB (06-16-2015), Mauro_Penguin (06-18-2015)
 Old 06-16-2015, 09:52 PM   #137
Take your time on the install. You only get one seal. Mine was really tight. I worked it in ever so gently.
 Old 06-21-2015, 12:43 AM   #138
Etipp98's Avatar
Well, didn't even last 100 miles with 2 gallons 93 and 8 gallons e85. This is of course with no SI-1, nor the fancy RP oil. This was just with rotella.. Ill be taking the pump apart tomorrow to see what it looks like.
The Following 5 Users Say Thank You to Etipp98 For This Useful Post:
Easter Bunny (06-21-2015), JgamB (06-21-2015), Mauro_Penguin (06-21-2015), Micha (06-23-2015), TJM216 (06-21-2015)
 Old 06-21-2015, 12:44 AM   #139
With the IE internals?
Edit: Rotella and e DO NOT MIX
 Old 06-21-2015, 12:45 AM   #140
Etipp98's Avatar
Yes @littleloogy;
 Old 06-21-2015, 12:48 AM   #141
Fuck!
You might have to put on this sticker for it to work.
Koke382 likes this.
Last edited by littleloogy; 06-21-2015 at 12:48 AM. Reason: MSF Database - Automerged Doublepost
Koke382 (06-24-2015), Mauro_Penguin (06-21-2015), Micha (06-23-2015)
 Old 06-21-2015, 12:57 AM   #142
Etipp98's Avatar
I sure hope not!!! pics will come tomorrow after i wake up. its 3 am :/
The Following 2 Users Say Thank You to Etipp98 For This Useful Post:
 Old 06-21-2015, 01:01 AM   #143
Good luck.
 Old 06-21-2015, 09:44 AM   #144
MSP6's Avatar
Posts: 1,246   (View Stats)
MSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the world
Damn, that blows. That RP dexos is some tough shit it seems.
Speed 6 Gone for 3+ years and still not happy about it
2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP
Enki - "High mixes of corn = all the wastegate all the time for great justice."
MSP6 is offline   Reply With Quote
The Following User Says Thank You to MSP6 For This Useful Post:
Enki (06-21-2015)
 Old 06-21-2015, 10:13 AM   #145
Raider is mah Homie
Groans: 2,978
Did you use rotella to lune the internals during assembly?
I hugged rfinkle2
 Old 06-22-2015, 10:20 AM   #146
I doubt he did. The kit comes with a piston pre lubricated with assembly lube. I did run these internals on gas for a few hundred miles before making the switch to E85. Maybe the assembly lube is what caused the failure?
 Old 06-22-2015, 02:35 PM   #147
Etipp98's Avatar
Sooo. To answer your question @Easter Bunny; I used the supplied grease to lube the piston. Took the pump apart, no black death. Pulled everything apart to find the piston and the inside of the cylinder lightly marred. Happens to be right where the hole is on the cylinder. I cleaned everything up real good before the install so I doubt anything metal was left on any of the parts. Only thing I can think of is if maybe the inside of the hole had a very small burr on it from being drilled from the machining process? Im going to email IE and see what they have to say. Hopefully they take care of me. I can run my fingernail over the piston and feel where it is marked up.
MD1032 likes this.
The Following 4 Users Say Thank You to Etipp98 For This Useful Post:
Easter Bunny (06-22-2015), littleloogy (06-22-2015), Micha (09-26-2015), SarcasticOne (06-22-2015)
 Old 06-22-2015, 02:39 PM   #148
@Etipp98; please verify with IE that every internal is tested before boxing. This pisses me off as I was told each kit was tested before boxed.
The Following 8 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (06-22-2015), Enki (06-22-2015), impossible (05-23-2016), Koke382 (07-17-2015), Mauro_Penguin (06-24-2015), MD1032 (06-22-2015), Mizzle (06-28-2015), SarcasticOne (06-22-2015)
 Old 06-22-2015, 03:29 PM   #149
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Groans: 29
Installer error.
littleloogy likes this.
The Following User Says Thank You to Cheapspeed For This Useful Post:
 Old 06-22-2015, 03:37 PM   #150
Etipp98's Avatar
Originally Posted by Cheapspeed View Post
Installer error.
Could very well be. I've only installed about 20 sets of internals for all the locals. Maybe I need to do some more so I know what I am doing
Realgib3 and Koke382 like this.
Easter Bunny (06-22-2015), Mauro_Penguin (06-24-2015), Micha (06-23-2015), sho (06-23-2015)
 Old 06-22-2015, 04:02 PM   #151
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
SuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond repute
I am interested in this big time. I only run 25% e85 right now but if I can up it, I certainly want to!
2013 Genpu GT, 245/40 Direzzas, CS SRI+TIP,CS TP+CB, CS TMIC, CS FP Internals, CS 80a RMM, CS BPV, Accessport V3, Tuned by Nishan
SuckSqueezBangBlow is offline   Reply With Quote
 Old 06-22-2015, 04:48 PM   #152
Raider is mah Homie
Groans: 2,978
Well thanks for clearing that up. We have identified the problem which it is good to know was not black death. However for you its a much worse problem. Hopefully you are taken care of.
littleloogy and MD1032 like this.
I hugged rfinkle2
Micha (06-23-2015)
 Old 06-22-2015, 04:50 PM   #153
Cheapspeed's Avatar
Groans: 29
I ran 50/50 for over a year with no issues. Gen1 so no fuel level sensor issues.
 Old 06-23-2015, 07:12 PM   #154
Etipp98's Avatar
Little Update:
IE just got back to me a few moments ago. They want me to ship the internals back to them so they can check the tolerances of the piston and barrel.
The Following 10 Users Say Thank You to Etipp98 For This Useful Post:
Easter Bunny (06-23-2015), Enki (06-23-2015), littleloogy (06-23-2015), Mauro_Penguin (06-24-2015), MD1032 (06-23-2015), Micha (06-23-2015), Mochi (07-06-2015), Realgib3 (06-25-2015), SarcasticOne (06-23-2015), sho (06-27-2015)
 Old 06-23-2015, 08:43 PM   #155
Enki's Avatar
Groans: 189
It's something.
Micha (06-23-2015), sho (06-24-2015)
 Old 07-14-2015, 03:46 PM   #156
Etipp98's Avatar
Update, Just got this email.
"Hi Jake,
We received your pump a few days ago and were able to inspect it. It appears that the problem was associated with a tolerance inside the stainless nut being slightly out of spec, which caused the cylinder to move around, causing wear on the piston and cylinder. This is not a common point of failure and the first of its kind with our fuel pumps. We have been able to measure other nuts that we have here and they are all within specification, leading me to believe that this will be the only one.
We have gone through each and every component in your kit and replaced all items necessary, including the nut, seal, piston, and cylinder. We should have it boxed up and shipped back out to you no later than tomorrow.
Thanks for bearing with us on this and I'm sure you will be happy with the performance to come in the future with your IE HPFP!
Thank you,
Cassidy Williams
Integrated Engineering"
Koke382 and Mauro_Penguin like this.
The Following 21 Users Say Thank You to Etipp98 For This Useful Post:
aackthpt (07-14-2015), acousticdefbot (07-14-2015), Cheapspeed (07-15-2015), cocoanton (12-04-2015), Code Monkey (07-14-2015), Dano (07-14-2015), davychronic (07-14-2015), Easter Bunny (07-14-2015), Enki (07-14-2015), g00s3y (07-14-2015), impossible (05-23-2016), JgamB (10-20-2015), Koke382 (07-15-2015), littleloogy (07-14-2015), Mauro_Penguin (07-14-2015), Mazdazilla6 (07-19-2015), MD1032 (07-14-2015), Micha (09-26-2015), Nliiitend1 (07-14-2015), SarcasticOne (07-14-2015), TJM216 (07-18-2015)
 Old 07-14-2015, 04:09 PM   #157
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Holy shit, now that's some goddamn customer service.
Sent from my A0001 using Tapatalk
Koke382 likes this.
2007 Mazdaspeed3 GT
The Following 2 Users Say Thank You to MD1032 For This Useful Post:
Koke382 (07-15-2015), Micha (09-26-2015)
 Old 07-14-2015, 04:44 PM   #158
That's great that they took care of you. Hope your journey from this point fourth is as smooth as mine has been. I'm at 4700 miles on the fuel pump internals, 4200 miles of which are on full Corn with no problems to speak of.
Koke382 likes this.
The Following 2 Users Say Thank You to littleloogy For This Useful Post:
davychronic (07-14-2015), Koke382 (07-15-2015)
 Old 07-14-2015, 05:53 PM   #159
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I knew it!
Koke382 and littleloogy like this.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 07-14-2015, 06:03 PM   #160
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
So we possibly have a permafix for corn? Have you inspected these internals for sticky at all?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Koke382 likes this.
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
The Following User Says Thank You to davychronic For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/ie-hpfp-internals-e85-188283/
E85 map build - Page 3 This thread Pingback 05-21-2015 03:25 PM
First log with HPFP internals oOfactoryOo 2010 MS3 - ECU Computer Tuning 11 03-23-2014 12:12 PM
HPFP internals or new HPFP? JAGspeed6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 11-26-2011 02:34 PM
Page generated in 0.58664 seconds with 33 queries
