![]() | | #281 | ![]() |
| Raider is mah Homie ![]() Join Date: Jan 2011 Location: Towson, Maryland
Rep Power: 7524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54,831
Groans: 2,978
| Not Ranked : 0 score
__________________ ![]() I hugged rfinkle2 | |
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Mauro_Penguin (01-14-2016) |
![]() | | #282 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
That would be ideal for them to have a "E85 ready" FP internal kit. Unfortunately I doubt people are not ready to give up their T6 which accelerates death buildup. Even if the death would not stick to the piston, it will stick to everything else that is not coated in the pump and eventually cause a failure, like in the Spill Valve. Sent from my iPhone using Tapatalk | |
| The Following 5 Users Say Thank You to littleloogy For This Useful Post: | Easter Bunny (01-13-2016), ItsNox (01-14-2016), Mauro_Penguin (01-14-2016), Mazdazilla6 (01-13-2016), WetzMS3 (01-22-2016) |
![]() | | #283 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score I believe i seen a stock fp for about $100 in the fs section
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
![]() | | #284 | ![]() |
![]() Join Date: Oct 2013 Location: Fort Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 976
Groans: 438
Some guy on failbook was seling a stock pump (not sure if stock internals or none) for $125 I believe. The connector was cracked and CPe wouldn't take it as a core. I can't remember what page it was, I'll try and find it later.
__________________ All good things must come to an end... | |
| The Following 2 Users Say Thank You to g00s3y For This Useful Post: | littleloogy (01-13-2016), Mauro_Penguin (01-14-2016) |
![]() | | #285 | ![]() |
![]() Join Date: Mar 2012 Location: Warrenville, IL/Big Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,349
| Not Ranked : 0 score I've got 2. Shoot me an address to ship to.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings |
| The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post: |
![]() | | #286 | ![]() |
Edit: Okay so after some quick research it seems that DLC is a coating. It adds thickness to the metal unlike nitriding which alters the metal composition at the surface. With that said, I won't be nitriding my autotechs because in order for it to work properly there can't be a surface coating and I don't want to strip the coating because the tolerances are designed with the coating taken into account. When the time comes I'll sell my autotechs and probably pick up a set of IE internals or just run S1. http://www.northeastcoating.com/products/dlc-coating
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings Last edited by Mazdazilla6; 01-13-2016 at 11:51 AM. | |
![]() | | #287 | ![]() |
![]() Join Date: Dec 2012 Location: Irvine, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
__________________ 2013 Mazdaspeed 3 Liquid Silver AT internals / Cobb AP / CS SRI + TIP / CS TMIC / CS Race Pipe / JBR 88a RMM / JBR 80a TMM / JBR 80a PMM / JBR RSB / JBR OCC | |
| The Following User Says Thank You to biscuit003 For This Useful Post: | Mauro_Penguin (01-14-2016) |
![]() | | #288 | ![]() |
Groans: 189
| Not Ranked : 0 score I would avoid the IE internals for now as they seem to be causing mushrooming on the HPFP follower. Maybe see if Corksport will do it on theirs? Also oil + Redline seems like a good long term solution to me personally.
__________________ |
| The Following 4 Users Say Thank You to Enki For This Useful Post: |
![]() | | #289 | ![]() |
(Thread Starter) | Not Ranked : 0 score I sent an email to Pete @ integrated engineering this afternoon. I have not heard back from him. Went back to petrol, holy fuck balls my pump feels like it's on its last leg. Rattling like it ain't no body's business. It's amazing how quiet E85 operates, even with a damaged follower. Has me baffled as to why. Sent from my iPhone using Tapatalk |
| The Following 5 Users Say Thank You to littleloogy For This Useful Post: | Easter Bunny (01-14-2016), ItsNox (01-14-2016), Mauro_Penguin (01-14-2016), Mazdazilla6 (01-14-2016), WetzMS3 (01-22-2016) |
![]() | | #290 | ![]() |
Groans: 189
| Not Ranked : 0 score Requires more flow, thus less overall pressure is dumped.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | ItsNox (01-14-2016), Mauro_Penguin (01-14-2016) |
![]() | | #291 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
![]() | | #292 | ![]() |
Groans: 189
| Not Ranked : 0 score Probably just the mass of the internals and extra drag from seal area, maybe the spring if it's heavier too.
| The Following User Says Thank You to Enki For This Useful Post: | ItsNox (01-15-2016) |
![]() | | #293 | ![]() |
(Thread Starter) | Not Ranked : 0 score The kit does not come with a spring, but everything else could be true. You all have to remember, I may have fatigued the cam follower with all my episodes of death testing in the past. Sent from my iPhone using Tapatalk |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | ItsNox (01-15-2016), Mauro_Penguin (01-14-2016) |
![]() | | #294 | ![]() |
Groans: 189
| Not Ranked : 0 score You forget, I've got ~50k miles of death testing as well (sorta).
| The Following 2 Users Say Thank You to Enki For This Useful Post: | ItsNox (01-15-2016), Mauro_Penguin (01-14-2016) |
![]() | | #295 | ![]() |
(Thread Starter) | Not Ranked : 0 score Oh hush... Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to littleloogy For This Useful Post: | ItsNox (01-15-2016) |
![]() | | #296 | ![]() |
(Thread Starter) | Not Ranked : 0 score That's interesting. I've never seen the mazda cam follower in person- the VW one is just flat on the inside. The VW ones wear through from the outside before anything happens to the inside. They are too small diameter and they break through the oil film on the cam and just get torn up, despite being coated. One day I might order a mazda follower and just see if anything can be done to make the tip of our pump any more compatible with it. What sort of rail pressure are you running? Rail pressure pretty much determines the force from the pin to the bucket, and at least, in our application - controls how fast we tear up the buckets. On our big turbo cars we run 150 bar of rail pressure and ya, the buckets don't last forever like that. On the gunk- I'd be interested to see what temperature your pumps run at. I say that because while E85 use is rare with us, because we're limited by fuel injection pulsewidth- I've never seen that same gunk build up in the pumps, and as you know, it's the same pump internally. I somewhat suspect the mazda application could be running the pump at a hotter temperature just because of its location or similar factor- and this is causing the ethanol to break down in areas where it does not circulate well. The outside of that barrel is only fuel which leaked past the pin inside the cylinder and is being returned to the LPFP inlet side as it comes out. So a good pump, is not flowing much fuel down there. Perhaps a k type thermocouple stuck to the pump body and ran around to the inside of the vehicle could yield some interesting data- I could probably compare to our application. Maybe something can be done about it if we can understand the real cause. Cheers, Peter Blais Director of Engineering Sent from my iPhone using Tapatalk |
| The Following 4 Users Say Thank You to littleloogy For This Useful Post: | Easter Bunny (01-16-2016), Mauro_Penguin (01-17-2016), Mazdazilla6 (01-16-2016), WetzMS3 (01-22-2016) |
![]() | | #297 | ![]() |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score Have the temperature measurements of the pump and surrounding area been measured before? I have a calibrated 3 port logger with a 5 second recording interval that I could volunteer. |
| The Following User Says Thank You to JSmith For This Useful Post: | Mauro_Penguin (01-17-2016) |
![]() | | #298 | ![]() |
Groans: 2,978
| Not Ranked : 0 score Nice that they seem interested in finding a solution.
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Mauro_Penguin (01-17-2016) |
![]() | | #299 | ![]() |
Groans: 189
| Not Ranked : 0 score They have not but his understanding of the issue is a bit skewed. It's not the E85 that's breaking down here, but rather, the oil in the presence of alcohol.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Mauro_Penguin (01-17-2016), MD1032 (01-16-2016) |
![]() | | #300 | ![]() |
(Thread Starter) | Not Ranked : 0 score @JSmith; Why would death develop in the pump but leave the SV completely clean If it was the fuel alone? Normally the Spill valve is the first thing to go. Stupid theory: the carbon coating in ATs is changing the molecular properties of E85 and creating sticky death... Ha ha. A pump for testing the stock internal idea should be here soon. I still need to get a Tappet. I have one more tank of petrol to burn, then I'll be switching the pump and getting back on the sauce. Sent from my iPhone using Tapatalk |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | Easter Bunny (01-17-2016), Mauro_Penguin (01-17-2016) |
![]() | | #301 | ![]() |
Groans: 189
__________________ | |
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Easter Bunny (01-17-2016), Mauro_Penguin (01-17-2016) |
![]() | | #302 | ![]() |
Groans: 106
| Not Ranked : 0 score Can more data hurt? Forgive me if this has been determined before, but are we assuming that the black death occurs at shutdown and not while in use? |
![]() | | #303 | ![]() |
Groans: 189
| Not Ranked : 0 score It happens in use. This too, I've experienced first hand by removing the double seals off the internals (the scraper x ring on the retaining nut) and just idling in the driveway (cold start). After it came up to temp, it failed very, VERY quickly. By all means, test the stock internals, but expect to be out of fuel on very low boost and expect to see little to no change in death production. Remember that I tested (and found the cause of) death by boiling fuel and oil in a stove pot which was raw metal. Death also stuck to the coated sample strip I had in the pot as well.
__________________ Last edited by Enki; 01-20-2016 at 06:51 PM. Reason: Typo |
| The Following 5 Users Say Thank You to Enki For This Useful Post: | Code Monkey (01-22-2016), Easter Bunny (01-17-2016), Mauro_Penguin (01-17-2016), Micha (01-18-2016), Mochi (01-20-2016) |
![]() | | #304 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ooo Pretty. ![]() Stock internals along with this will be going in tonight when I get off work. Driving with a stock pump will suck, but I can tune around it. Let's see. Zero out VVT Zero boost Zero Wategate tables Adjust waste gate preload & Bam Good to go. Sent from a Galaxy far, far away... Special shout out to @Mazdazilla6; for allowing me to play with his pump while he works on his build. Sent from a Galaxy far, far away... Last edited by littleloogy; 01-22-2016 at 02:24 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 6 Users Say Thank You to littleloogy For This Useful Post: | Easter Bunny (01-24-2016), Enki (01-22-2016), Mauro_Penguin (01-23-2016), Mazdazilla6 (01-22-2016), monkey.bones.007 (01-24-2016), WetzMS3 (01-22-2016) |
![]() | | #305 | ![]() |
| Not Ranked : 0 score Good luck! Look forward to your results.
| The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post: | Mauro_Penguin (01-23-2016), monkey.bones.007 (01-24-2016) |
![]() | | #306 | ![]() |
Sent from my SM-N910T using Tapatalk
![]() | | #307 | ![]() |
Groans: 189
| Not Ranked : 0 score Billet forged. Nah probably just new. If new factory, then I should probably get one as well as mine is kinda dimpled a bit as well.
| The Following User Says Thank You to Enki For This Useful Post: | Mazdazilla6 (01-24-2016) |
![]() | | #308 | ![]() |
Groans: 2,978
| Not Ranked : 0 score Looks dimpled? Also are you looking at growing your own corn?
__________________ ![]() I hugged rfinkle2 Last edited by Easter Bunny; 01-24-2016 at 03:57 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #309 | ![]() |
![]() Join Date: Feb 2015 Location: Palmer, Iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
| Not Ranked : 0 score Pssh why grow it, ill sell you up to 50,000 bushel at the chicago board of trade price if you come to Iowa to pick it up. Make all the ethanol youll need for a years.
__________________ 06 MS6 GT Titanium Gray II Metallic |
![]() | | #310 | ![]() |
(Thread Starter) | Not Ranked : 0 score Corn price is really taking a shit this year. Apparently all the corn that we exported did not get used because of the higher price last year. So, naturally the supply to demand ratio is now fucked thus we have a lower cost of corn. @Enki; The follower is OEM Sent from a Galaxy far, far away... |
![]() | | #311 | ![]() |
Groans: 189
| Not Ranked : 0 score How much was it and where did you order it from? I might as well get a new one.
![]() | | #312 | ![]() |
(Thread Starter) | Not Ranked : 0 score My local dealer. 68.00. My ass still hurts from the rape. Sent from a Galaxy far, far away... |
| The Following 2 Users Say Thank You to littleloogy For This Useful Post: | blackms3_71 (01-24-2016), Enki (01-24-2016) |
![]() | | #313 | ![]() |
Its more the brazilian reel crashed and our dollar is too strong. Its cheaper to buy imported brazilian corn than to buy our own. Price of corn crashed 2 years ago and since then its been dropping lower and lower. Lowest ive seen in a long time was right after the Paris attacks and since then its recovered almost to October 1st price.
__________________ 06 MS6 GT Titanium Gray II Metallic | |
| The Following User Says Thank You to davychronic For This Useful Post: | Easter Bunny (02-05-2016) |
![]() | | #314 | ![]() |
Well, 250miles/ 10 heat cycles in with the stock FP internals and sticky death has stated to take its toll on the spill valve. The pump sounds like it is still pumping fine, but the Spill valve functions are becoming problematic under low RPM higher loads, I.E. 6th gear @ 2300 RPM cruise. Here is the "Spring Tensioner" as Mazda calls it. Part number L3K9-12-615 ![]() Sent from a Galaxy far, far away... | |
| The Following 3 Users Say Thank You to littleloogy For This Useful Post: |
![]() | | #315 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay, well results are in and I am not going to test this further because I don't see a point. When Installed the stock pump internals I inserted Royal Purple oil to try to create death in the pump quickly. Although I did gets few sticky death failures in my spill valve (which was anticipated) there was not any signs of death sticking to the stock piston. There was however death developing inside the retaining nut and outside of the barrel, but this was also expected as these parts are not nitride coated. ![]() ![]() ![]() ![]() Sent from a Galaxy far, far away... |
![]() | | #316 | ![]() |
| Not Ranked : 0 score Awesome. So +1 for nitriding. Maybe we should get ahold of AT or CS and see if they'll consider revising their internals. I think I might have my AT's get nitrided while I've got the engine out. It doesn't change thickness of the part so it should be fine.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | littleloogy (02-07-2016) |
![]() | | #317 | ![]() |
(Thread Starter) | Not Ranked : 0 score Might as well do this https://en.m.wikipedia.org/wiki/Titanium_nitride Internals will be fit for a king. Sent from a Galaxy far, far away... |
![]() | | #318 | ![]() |
Groans: 2,978
| Not Ranked : 0 score It would be nice if @CorkSport; would revise their internals to include an upgraded retaining nut and to nitride coat everything.
![]() | | #319 | ![]() |
All they have to do is get their hands on Vw/Audi's OEM retaining nut and include it with their redesigned FP internal. Sent from a Galaxy far, far away... | |
| The Following User Says Thank You to littleloogy For This Useful Post: | Easter Bunny (02-07-2016) |
![]() | | #320 | ![]() |
Groans: 2,978
| Not Ranked : 0 score So all the designing has already been done? Seems like a slam dunk.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/ie-hpfp-internals-e85-188283/ | ||||
| E85 map build - Page 3 | This thread | Pingback | 05-21-2015 03:25 PM | |
| First log with HPFP internals | oOfactoryOo | 2010 MS3 - ECU Computer Tuning | 11 | 03-23-2014 12:12 PM |
| HPFP internals or new HPFP? | JAGspeed6 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 11 | 11-26-2011 02:34 PM |
