I just did it in an attempt to make my engine idle smoother. It seemed to help some, so I never changed it back. Saw @Enki; run similar pressures when he was on Full E. I saw no harm in running slightly higher idle pressures. The point of my comment was to let everyone know I am seeing lower then targeted fuel pressures at idle. Sent while cleaning my spill valve again... |
I may have to give the higher fuel pressure at idle a shot, my car idles terribly. It may be masking some other issue, but better idle quality is better idle quality. #YOLO :D |
Kings of Corn (HPFP + OIL) I just edited my map, but I started thinking about the higher fuel pressure at idle/low load and I thought of a potential issue. We all know that the DISI has issues with fuel diluting the oil, do you guys think this might make it happen even faster? @Enki; @littleloogy; |
The opposite, really. Higher pressure yields better atomization and less liquid fuel on surfaces. |
I have ran Pennzoil Ultra from day 1. Every oil change (3,000 miles) I send a sample of the oil to Blackstone Laboratories. I have never had a problem with fuel dilution before or after I changed my fuel pressure settings. Even with really aggressive timing, my fuel in oil levels were almost non existent. Sent while cleaning my spill valve again... |
Well, the car does seem to idle a little smoother with the higher pressure and I don't hear as much popping in the exhaust either. |
Cool, good to know it actually does something. |
I knew there was some kind of reason for all your madness... Lol Sent while cleaning my spill valve again... |
I like to think I put the "Mad" in "Science" |
Emergency spill valve replacement kit Get yours today at WWW.ohshitmyvalvestuckagain.com http://img.tapatalk.com/d/14/02/14/7a4azyvu.jpg Sent while cleaning my spill valve again... |
Just sayin. |
Sent from my SCH-I535 using Tapatalk |
Death occurred at 1900 hrs last night... 2,000 miles of E55 480 miles full E85 (winter/spring) Pennzoil Ultra 5w30 I have restarted my test, we will see how far I can go on round 2. http://img.tapatalk.com/d/14/02/23/temyruda.jpghttp://img.tapatalk.com/d/14/02/23/zematu2y.jpghttp://img.tapatalk.com/d/14/02/23/u8e4a6yb.jpghttp://img.tapatalk.com/d/14/02/23/he3y9ere.jpg Sent while cleaning my spill valve again... |
My condolences. Are there any hardware change for round 2? If not, what makes you think it will be different? Sent from my iPhone using Tapatalk |
Seals in the retaining nut; should keep more of the oil out. Def black death there. Was it difficult to extract everything from the retaining nut? |
Nope, it only took a few mins. Shit came right out. I used kerosene. I need to run this setup one more time. I did not start this test with a clean pump. My results of the oil test were tainted. This pump has 18,000 miles of e 85 mixes. Who knows how much shit was in there prior to the start of this test. Sent while cleaning my spill valve again... |
So no seals yet? Sent from my iPhone using Tapatalk |
@Enki; I drove 50 miles and pulled my pump again. Black death was beginning to form. Penn Ultra sucks for preventing death. In case you want to update the list of failures. Sent while cleaning my spill valve again... |
What's the exact oil? Also if you want to verify my findings, try out the Royal Purple listed in the OP; seems to be the best oil I've tested as far as full E85 goes. |
Pennzoil Ultra 5w30 full synthetichttp://img.tapatalk.com/d/14/02/24/qa9equby.jpg Sent while cleaning my spill valve again... |
Once car is up and running, gonna try kendell oil. Says good for e85. Also saw this... http://www.mobiloil.com/USA-English/..._Fuel.aspxning |
Best Motor Oil for Engines Using E85 Fuel EDIT: Oddly enough, T6 seems to be one of the worst offenders in terms of black death forming, so I'm not sure that is a very good tip. At least in our case. That honda is most likely port injected and doesn't have to deal with the HPFP issues. |
Thank you sir. Yeah I kno its PI. But something to try also. Ill be on 100% E soon to try some oils. |
Just dumped the Pennzoil ultra... I am going to use Redline 10w30 for this run. I know I did say I was going to confirm royal purple but, was reading a lot about redline and wanted to give this a shot first. I also cleaned my pump, so I will get some fresh data as to how this oil holds up. On a personal note, I am about ready to take my engine apart. I have lost a HPFP mounting bolt. I have been searching for the past 5hrs with no luck. I think the speed got hungry. FML Sent while cleaning my spill valve again... |
Guys trying random oils won't help. Only way to test an oil is to put 3/4 e85 and 1/4 oil in a pan and put it on a burner then turned on high. Obviously. |
1 Attachment(s) Quote:
http://www.mazdaspeedforums.org/foru...1&d=1393724121 |
Question, were you drinking wine while doing this test? Nice... Lol Sent from my iPhone using Tapatalk |
http://www.mazdaspeedforums.org/foru...ml#post1324983 |
1 Attachment(s) Just thought I would update you on this God giving Oil. I am at 100 Miles, no Sticky Yet to report. I have been doing 20 miles Runs. Start engine, Drive for 15 miles normal driving, (Freeways, on ramps, stoplights ect...) then for 5 Miles drive it like you stole it, then park it. let Cool and repeat. At the 100 mile mark I decided to take a log. I only see one cell that fell in the high 1500's I am not worried about it.Attachment 149786 |
Do you know if the Redline is a Dexxos oil like the RP is? Honestly, I'd bet RP with your spill valve mod would be fixed totally. Could you post or pm me the details on what you did? I might be able to do this with another local car that could benefit from some full sauce. |
They claim it exceeds GM's Dexos spec. I PMed you about the spill valve... Sent while cleaning my spill valve again... |
| All times are GMT -7. The time now is 11:35 AM. |
