Like Tree46Likes
 Old 02-12-2014, 10:46 PM   #441
littleloogy's Avatar
Posts: 4,005   (View Stats)
I just did it in an attempt to make my engine idle smoother. It seemed to help some, so I never changed it back. Saw @Enki; run similar pressures when he was on Full E. I saw no harm in running slightly higher idle pressures.
The point of my comment was to let everyone know I am seeing lower then targeted fuel pressures at idle.
Sent while cleaning my spill valve again...
sidekick (02-12-2014)
 Old 02-12-2014, 11:32 PM   #442
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
I may have to give the higher fuel pressure at idle a shot, my car idles terribly. It may be masking some other issue, but better idle quality is better idle quality. #YOLO
2006 Mazdaspeed6
The Following User Says Thank You to sidekick For This Useful Post:
littleloogy (02-12-2014)
 Old 02-13-2014, 02:21 PM   #443
sidekick's Avatar
Groans: 47
Default Kings of Corn (HPFP + OIL)
I just edited my map, but I started thinking about the higher fuel pressure at idle/low load and I thought of a potential issue. We all know that the DISI has issues with fuel diluting the oil, do you guys think this might make it happen even faster?
@Enki; @littleloogy;
2006 Mazdaspeed6
littleloogy (02-13-2014)
 Old 02-13-2014, 02:28 PM   #444
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
The opposite, really. Higher pressure yields better atomization and less liquid fuel on surfaces.
sidekick likes this.
-06 MS6
-Corn fed 07 MS3 - Sold
Dano (02-19-2014), Easter Bunny (02-14-2014), Enki (02-13-2014), JTMS3 (02-19-2014), littleloogy (02-13-2014), sidekick (02-13-2014), wolly6973 (02-13-2014)
 Old 02-13-2014, 03:57 PM   #445
I have ran Pennzoil Ultra from day 1. Every oil change (3,000 miles) I send a sample of the oil to Blackstone Laboratories. I have never had a problem with fuel dilution before or after I changed my fuel pressure settings. Even with really aggressive timing, my fuel in oil levels were almost non existent.
 Old 02-13-2014, 09:29 PM   #446
sidekick's Avatar
Groans: 47
Well, the car does seem to idle a little smoother with the higher pressure and I don't hear as much popping in the exhaust either.
2006 Mazdaspeed6
 Old 02-13-2014, 10:56 PM   #447
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Cool, good to know it actually does something.
 Old 02-13-2014, 10:59 PM   #448
I knew there was some kind of reason for all your madness... Lol
 Old 02-13-2014, 11:28 PM   #449
Enki's Avatar
Groans: 189
I like to think I put the "Mad" in "Science"
littleloogy (02-14-2014)
 Old 02-14-2014, 09:02 AM   #450
Emergency spill valve replacement kit
Get yours today at WWW.ohshitmyvalvestuckagain.com
The Following 3 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (02-17-2014), Enki (02-14-2014), sidekick (02-14-2014)
 Old 02-15-2014, 01:48 PM   #451
Enki's Avatar
Groans: 189
Originally Posted by littleloogy View Post
There has been a mod for the button valve on the bottom part of the the spill valve. It helps keep the coils of the spring from touching. That's all fine and dandy, but what about the top? How do we keep that damn needle from sticking??? Well I may have finally come up with a fix (trial of course).
The problem we are facing is when the needle gets gummy, it sticks to the collar preventing the button valve from closing causing pressure to not build. To solve this issue, I crimped the spring directly to the needle on the solenoid.
Picture illustrates spring securely attached to solenoid needle.
I then attached the spring to the needle and I am left with this.
Theoretically speaking...
As the solenoid energizes it will have enough power to pull the needle up, and when it is not energized it will push it back down regardless of gummy residue.
I installed this in my pump, and it holds pressure fine. I will see when or if my valve starts to stick.
Thoughts or Comments?
This is potentially too important of a test to be buried deep in a thread about oil, and should get its own thread IMO.
Just sayin.
Dano (02-19-2014), Dizzy Turbo (02-16-2014), littleloogy (02-17-2014), mazdafreak (02-15-2014), wolly6973 (02-15-2014)
 Old 02-18-2014, 08:25 PM   #452
Just sayin.
GTFO would also suffice, therefore I will continue HERE. God, I hope we can figure this out.
Enki (02-18-2014)
 Old 02-18-2014, 11:29 PM   #453
Enki's Avatar
Groans: 189
It's not a GTFO situation; I meant what I said in my prior post.
Easter Bunny (02-19-2014)
 Old 02-18-2014, 11:46 PM   #454
;-) I know, thank you.
Enki (02-18-2014)
 Old 02-20-2014, 08:36 PM   #455
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Hmm, this looks useful.
Sent from my SCH-I535 using Tapatalk
Pickles Tune in progress
littleloogy (02-20-2014)
 Old 02-22-2014, 11:24 AM   #456
Death occurred at 1900 hrs last night...
2,000 miles of E55
480 miles full E85 (winter/spring)
Pennzoil Ultra 5w30
I have restarted my test, we will see how far I can go on round 2.
The Following 6 Users Say Thank You to littleloogy For This Useful Post:
Constantin (02-22-2014), cshunter (02-22-2014), Easter Bunny (02-24-2014), El_Diablo (02-23-2014), Enki (02-22-2014), sidekick (02-24-2014)
 Old 02-22-2014, 11:56 AM   #457
Bratschist's Avatar
Posts: 79   (View Stats)
Bratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud of
My condolences. Are there any hardware change for round 2? If not, what makes you think it will be different?
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  3. CorkSport LED light kit
  4. TWM Performance Shifter
  5. SLS Test Pipe
  6. CorkSport FMIC and SR air intake
  7. SURE Motorsport Torq R6
  8. AccessPort Stage 2+ Map
  9. QTP Electronic Exhaust Cut-Out
  10. KMD HPFP Internals Upgrade
  11. CorkSport Downpipe
Bratschist is offline   Reply With Quote
 Old 02-22-2014, 01:09 PM   #458
Enki's Avatar
Groans: 189
Seals in the retaining nut; should keep more of the oil out.
Def black death there. Was it difficult to extract everything from the retaining nut?
 Old 02-22-2014, 01:40 PM   #459
Nope, it only took a few mins. Shit came right out. I used kerosene.
I need to run this setup one more time. I did not start this test with a clean pump. My results of the oil test were tainted.
This pump has 18,000 miles of e 85 mixes. Who knows how much shit was in there prior to the start of this test.
 Old 02-22-2014, 02:08 PM   #460
Bratschist's Avatar
So no seals yet?
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
The Following User Says Thank You to Bratschist For This Useful Post:
littleloogy (02-22-2014)
 Old 02-23-2014, 09:07 PM   #461
@Enki; I drove 50 miles and pulled my pump again. Black death was beginning to form. Penn Ultra sucks for preventing death. In case you want to update the list of failures.
Easter Bunny (02-24-2014), El_Diablo (02-24-2014), Enki (02-23-2014)
 Old 02-23-2014, 09:33 PM   #462
Enki's Avatar
Groans: 189
What's the exact oil?
Also if you want to verify my findings, try out the Royal Purple listed in the OP; seems to be the best oil I've tested as far as full E85 goes.
Last edited by Enki; 02-23-2014 at 09:33 PM. Reason: MSF Database - Automerged Doublepost
El_Diablo (02-24-2014), littleloogy (02-23-2014)
 Old 02-23-2014, 09:41 PM   #463
Pennzoil Ultra 5w30 full synthetic
The Following 2 Users Say Thank You to littleloogy For This Useful Post:
 Old 02-23-2014, 09:57 PM   #464
You bet. next oil change. I'll try to verify.
 Old 02-23-2014, 10:52 PM   #465
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Once car is up and running, gonna try kendell oil. Says good for e85.
Also saw this...
http://www.mobiloil.com/USA-English/..._Fuel.aspxning
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 02-24-2014, 12:15 AM   #466
sidekick's Avatar
Groans: 47
Also saw this...
Broken link:
Best Motor Oil for Engines Using E85 Fuel
EDIT: Oddly enough, T6 seems to be one of the worst offenders in terms of black death forming, so I'm not sure that is a very good tip. At least in our case. That honda is most likely port injected and doesn't have to deal with the HPFP issues.
2006 Mazdaspeed6
 Old 02-24-2014, 04:28 PM   #467
mazdafreak's Avatar
Groans: 124
Originally Posted by sidekick View Post
Broken link:
Thank you sir.
Yeah I kno its PI. But something to try also.
Ill be on 100% E soon to try some oils.
713whp/569wtq!
littleloogy (02-24-2014)
 Old 03-01-2014, 02:33 PM   #468
Just dumped the Pennzoil ultra... I am going to use Redline 10w30 for this run. I know I did say I was going to confirm royal purple but, was reading a lot about redline and wanted to give this a shot first.
I also cleaned my pump, so I will get some fresh data as to how this oil holds up.
On a personal note, I am about ready to take my engine apart. I have lost a HPFP mounting bolt. I have been searching for the past 5hrs with no luck. I think the speed got hungry. FML
 Old 03-01-2014, 03:41 PM   #469
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
I am glad u are still going at it. I hope u find a good solution. Goodluck
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
The Following User Says Thank You to blackms3_71 For This Useful Post:
littleloogy (03-01-2014)
 Old 03-01-2014, 05:48 PM   #470
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Have you dropped the under tray yet?
I hugged rfinkle2
The Following 3 Users Say Thank You to Easter Bunny For This Useful Post:
86AmishMs3 (03-01-2014), Dano (03-01-2014), Enki (03-01-2014)
 Old 03-01-2014, 06:09 PM   #471
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Guys trying random oils won't help. Only way to test an oil is to put 3/4 e85 and 1/4 oil in a pan and put it on a burner then turned on high.
Obviously.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 3 Users Say Thank You to 86AmishMs3 For This Useful Post:
Enki (03-01-2014), littleloogy (03-01-2014), SloGenpu (05-04-2014)
 Old 03-01-2014, 06:35 PM   #472
Enki's Avatar
Groans: 189
Obviously.
In before
The Following 7 Users Say Thank You to Enki For This Useful Post:
86AmishMs3 (03-01-2014), Constantin (03-01-2014), cshunter (03-02-2014), El_Diablo (03-03-2014), littleloogy (03-01-2014), sidekick (03-03-2014), Spectrix (03-20-2014)
 Old 03-01-2014, 07:20 PM   #473
Bratschist's Avatar
In before
Question, were you drinking wine while doing this test? Nice... Lol
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
 Old 03-01-2014, 08:29 PM   #474
Yeah, I did. It ended up being in my radiator fan shroud standing up on its head (vertical) behind my fan in the corner where the radiator and the shroud meet.
 Old 03-01-2014, 08:43 PM   #475
Enki's Avatar
Groans: 189
No but I had a respiratory infection.
Resolving HPFP corn woes (black death/sticking spill valve)
 Old 03-01-2014, 08:53 PM   #476
Everytime i drop anything thats where it always is so weird
 Old 03-02-2014, 09:20 PM   #477
Just thought I would update you on this God giving Oil. I am at 100 Miles, no Sticky Yet to report. I have been doing 20 miles Runs. Start engine, Drive for 15 miles normal driving, (Freeways, on ramps, stoplights ect...) then for 5 Miles drive it like you stole it, then park it. let Cool and repeat. At the 100 mile mark I decided to take a log. I only see one cell that fell in the high 1500's I am not worried about it.datalog6.csv
Enki (03-02-2014)
 Old 03-02-2014, 09:29 PM   #478
Enki's Avatar
Groans: 189
Do you know if the Redline is a Dexxos oil like the RP is? Honestly, I'd bet RP with your spill valve mod would be fixed totally. Could you post or pm me the details on what you did? I might be able to do this with another local car that could benefit from some full sauce.
 Old 03-02-2014, 11:15 PM   #479
They claim it exceeds GM's Dexos spec. I PMed you about the spill valve...
Enki (03-02-2014)
 Old 03-03-2014, 12:15 AM   #480
sidekick's Avatar
Groans: 47
That shit is such a bitch. IDK how it is on a genpu, but I spent a solid hour trying to get that blue clip from the intake manifold vacuum line out of there on my car. Found some unknown bolt as well. Lol.
2006 Mazdaspeed6
littleloogy (03-03-2014)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/kings-corn-hpfp-oil-122082/
2014 Ford Fiesta ST project - Page 9 This thread Refback 08-03-2014 08:28 AM
What happened to the e85 blend thread? - Page 4 This thread Refback 02-15-2014 09:29 PM
What happened to the e85 blend thread? - Page 3 This thread Refback 01-08-2014 09:42 PM
BNR Stage 3 Turbo Upgrade - Page 7 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-01-2013 03:06 PM
Resolving HPFP corn woes (black death/sticking spill valve) Enki MazdaSpeed 3/6 - E85 Fueling 467 10-26-2014 03:50 AM
Another Corn Fed PU trf5000 2010 MS3 - ECU Computer Tuning 73 08-12-2012 09:07 AM
2 gal's of corn + chinacharger dooderek MazdaSpeed 3/6 - ECU Computer Tuning 15 01-10-2012 01:52 AM
Make hate part 10ish. - negative camber kings check in IshiKage MazdaSpeed 3/6 - Suspension & Brakes 30 05-02-2010 11:08 PM
Dale Earnhardt lives on... as 305-foot roller coaster at Kings Dominion?! [w/VIDEO] Haltech Automotive News 0 08-21-2009 09:20 AM
Page generated in 0.59500 seconds with 30 queries
