![]() | | #601 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score Sent From a Galaxy, Far Far Away... |
![]() | | #602 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score It's probably spray window; you are likely spraying deep into the power stroke. What is your IPW?
__________________ |
![]() | | #603 | ![]() |
| Not Ranked : 0 score |
![]() | | #604 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score IIRC it takes 10 ms for the crank to make a complete revolution at 6k rpm...Meaning you're spraying during/after the spark event. Might have to either adjust phasing slightly or reduce boost or lean it out when you're running into issues.
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #605 | ![]() |
Sent From a Galaxy, Far Far Away... | |
![]() | | #606 | ![]() |
| Not Ranked : 0 score Unproven. Existing injectors dont outflow the aftermarket pumps currently available except at low engine rpms, so in terms of what's holding the DI system back from fueling more power, it is the injectors.
![]() | | #607 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score 130IDC? The car isn't breaking up at all? When I ran 110-115idc the car would break up in the upper rev range....I'm now back down to 95IDC.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #608 | ![]() |
Groans: 189
He's on full e85, and as a result can get away with a LOT more.
__________________ | |
![]() | | #609 | ![]() |
| Not Ranked : 0 score Why does full E85 allow him to get away with more? That is interesting. I was on 50/50 when I was breaking up. Now I'm on a 29 percent blend for the added fuel headroom with this 3076.
![]() | | #610 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Probably has something to do with the burn rate and the tolerance for corn to go lean without issues. I experienced something similar.
| The Following User Says Thank You to Enki For This Useful Post: | mrmonk7663 (12-25-2014) |
![]() | | #611 | ![]() |
![]() Join Date: Apr 2013 Location: Pleasantville, 925
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 589
| Not Ranked : 0 score Does corn combust relatively slower than regular fuel? Would take contribute to favorable results in lean conditions?
__________________ 2012 CWP Speed3 |:| Cobb V3 AP |:| Resonator Delete |:| Magnaflow Exhaust |:| 4" Exhaust Tips |:| CorkSport SRI |:| Autotech Internals |:| SnailPerformance |
![]() | | #612 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I think it might actually burn faster under compression, but I'm sure someone can chime in with the correct answer.
![]() | | #613 | ![]() |
| Not Ranked : 0 score E burns much faster then petrol. E85 has a greater AKI rating which allows us to advance the timing as much as we do. Sent From a Galaxy, Far Far Away... |
![]() | | #614 | ![]() |
Groans: 793
Everything in reading says alcohol burns slower than gas, which would fit with being about to advance timing so much.
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
| The Following 3 Users Say Thank You to Tokay444 For This Useful Post: |
![]() | | #615 | ![]() |
Groans: 793
| Not Ranked : 0 score Up to 60% slower in fact.
| The Following 4 Users Say Thank You to Tokay444 For This Useful Post: |
![]() | | #616 | ![]() |
HORSEPOWER: Because Ethanol contains oxygen, it has a very low power stoichiometric when compared to gasoline fuels (6.5 compared to 12.5). Ethanol must be run at much richer mixtures than gasoline, more than offsetting the lower energy per unit volume. The net energy released per cycle is higher and this results in more horsepower. For example, if a pound of gasoline is burned at its preferred max power air fuel mixture of 12.5/1, it will release approximately 19,000 BTU’s of energy, where ethanol run at its preferred power stoichiometric of 6.5/1 will release approximately 24,400 BTU’s. By comparison, methanol releases slightly more, about 27,650 BTU’s. The more ethanol there is in gasoline, the more powerful it is as a motor fuel. Typically, you can expect at least 5% more horsepower at the rear wheels of a vehicle running on E-85 than one burning gasoline only. INCREASED ENGINE LIFE: Ethanol has a very high MON octane rating, allowing engine builders to run higher compression ratios without fears of destructive detonation. It also has a very high Latent Heat of Vaporization, so the engine is cooled far better than one running on gasoline. This lowers bottom end and oiling system temperatures substantially. REDUCED EMISSIONS: Although reducing emissions usually will not directly affect the ontrack performance of a race car, engine parts like pistons and valves tend to stay cleaner. More importantly, there are serious health concerns with many of the octane boosting additives that must be added to racing gasoline in order for them to be compatible with higher compression racing engines. Ethanol fumes are also non-toxic. Sent From a Galaxy, Far Far Away... | |
| The Following 3 Users Say Thank You to littleloogy For This Useful Post: |
![]() | | #617 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score As if there wasn't another reason to use the RP oil: http://www.mazdaspeedforums.org/foru...kstone-lol.png >6200 miles and nearly 9 months on this OCI and they recommend extending AGAIN.
| The Following 4 Users Say Thank You to Enki For This Useful Post: |
![]() | | #618 | ![]() |
Groans: 111
| Not Ranked : 0 score They recommend 8k miles which is getting closer to the 9200 miles oil change interval recommended by mazda. Not bad...
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI |
![]() | | #619 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Not on their horse piss oil I wouldn't.
| The Following User Says Thank You to Enki For This Useful Post: | Mauro_Penguin (01-17-2015) |
![]() | | #620 | ![]() |
![]() Join Date: Dec 2014 Location: Tucson AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score So now that the end is nigh, time to start playing with various dexos oils. Enki's running the RP pretty successfully so far soit's toime to test if it's indeed the dexos standards that make it booze friendly or something with the RP. There's a bunch of different dexos spec oils out there. I think I'll start with castrol edge 5-30. Or QS ultimate durability, whichever one is easier to find locally. I'm going to be running full booze so issues should pop up quickly I imagine. Couple thousand miles. |
![]() | | #621 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I think you should stay on the RP at least for one more oil change, since there's T6 in there right now, and I never really *fully* tested the RP.
![]() | | #622 | ![]() |
| Not Ranked : 0 score My idea is that with a good drain and a freshly cleaned pump that the traces of T6 shouldn't affect the replacement oil. |
![]() | | #623 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Considering most of the time I couldn't get out of the driveway before I had pump issues, I'm gonna have to say that even traces of it in the engine are going to pose a problem.
![]() | | #624 | ![]() |
| Not Ranked : 0 score Hmm :/ Well I guess we'll have to see. Correct me if I'm wrong but it seems that the pump issues aren't consistent either. Only in the respect that it will gunk up, but in terms of how long seems to vary pretty wildly. |
![]() | | #625 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Depends on the oil you use and the quality of the E85 (which you will be getting from the same place I do probably).
![]() | | #626 | ![]() |
| Not Ranked : 0 score The super slow pump @ valencia and houghton. The one at irvington and houghton is too expensve. |
![]() | | #627 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Yep. BTW Blackstone is telling me to extend my OCI to 8k+ miles...I won't be changing my oil until next year per them. Food for thought.
![]() | | #628 | ![]() |
| Not Ranked : 0 score You're running 50/50 though, right? As it stands, I'm projecting to only put on ~8k on the racecar per year. I just figured out testing others could again help determine if its the dexos or the RP that is playing nice with the booze. |
![]() | | #629 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score ...And if you have to rebuild the pump every time you go out in it? Let's confirm that RP works here too first, esp since I left four quarts of it at your place. Also no, I'm on E29.
![]() | | #630 | ![]() |
| Not Ranked : 0 score Well if that's the case then I guess we're all back to square one. E85 will be the test for this. You'll need to show me the pump cleaning procedure when we pop that transmission back in and I'll carry the kit with me at all times. |
![]() | | #631 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score OK guess next time I'm down there I'll pick up that oil I left there too then. Edit: I just think cheaping out on oil is the wrong way to go about this, esp since we have so few validated results on this oil. Whatever man.
![]() | | #632 | ![]() |
| Not Ranked : 0 score Nono, I forgot before that you weren't running E85, so I thought you'd had vetted the RP already on it. I'm more than happy to put it through it's paces with the strong drink and see where it stands. If RP checks out then I'd like to try different dexos oils. Not for being cheap, but for choice. Afterall, perhaps some people can't get their hands on RP easily, but maybe something else could work. |
![]() | | #633 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Ahh ok. Yeah only like 3-5 people have tried RP including myself, but my test was fresh off of T6, and I wasn't doing the redline mod.
![]() | | #634 | ![]() |
![]() Join Date: May 2009 Location: Memphis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,249
| Not Ranked : 0 score I feel like i may have a freek motor/HPFP, I ran 50/50 mix for 1+ year on t6 and never experienced black death. Never took apart my HPFP after I upgraded to AT internals. Since I've mixed it up with some Chevron Delo oil, ran Mobil 0w40 Euro, and 5w30 Castrol Edge Tit. I normally run a bottle of b12 through the tank every oil change, but that's out of habit and from most of the people on this forum no tank additive prevents or fixes BD once it occurs. This is the first winter that I've decided to run straight 93 for a few months, since I've started a 50/50 mix several years ago. I'm too lazy, and afraid to open up my HPFP so long as I'm not having issues. Don't want to jinx the shit How many people on here have consistently ran a 50/50 mix without BD for 2+ years? I started running E in Aug of 2012 50/50 mix for the past 30k+ miles
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with |
![]() | | #635 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score You don't get issues on 50/50 or below. That's pretty well established.
| The Following User Says Thank You to Enki For This Useful Post: | Mfinlay04 (02-01-2015) |
![]() | | #636 | ![]() |
| Not Ranked : 0 score I've seen a few people on here running less than 50/50 open their HPFP and have some black shit in there. IDK if it was causing any real issues... or if they did it for clean sake. I'd love to make the jump to e85 but I work 12 hr days and 4-5 days a week and don't have time for the BS of the car not running randomly.
![]() | | #637 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Car still runs, just not very well. I had my pump crap out at the start of a trip to another city once, drove it 200 miles with 60 PSI. Took about a solid 3 minutes to get to 80 mph, but there was just enough fuel to do it.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Mauro_Penguin (02-15-2015), Mfinlay04 (02-01-2015) |
![]() | | #638 | ![]() |
![]() Join Date: Oct 2013 Location: Saint Simons Island, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 313
| Not Ranked : 0 score I have 99 Quattro buna-n seals if anyone local to me needs one lol.
__________________ Slow for now... Cobb ApV3///Cobb SRI+TIP///JBR Solid Shift Bushings///JBR 88 RMM///JBR SSP/// JBR Shift Knob///Cobb EBCM///MSR 045 18x8 +35///Nitto Nt05 235/40/18///CS Batt Box///CS Catted DP///ITV22's///Autotech Internals///TR8 FMIC///Koni FSD's/// CS springs Freek Tuning Meow |
| The Following User Says Thank You to BlackFlag For This Useful Post: | Enki (05-28-2015) |
![]() | | #639 | ![]() |
![]() Join Date: Oct 2013 Location: Fort Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 976
Groans: 438
| Neutral : -1 score
I was just as worried the first time I filled up with some e85, after that first start, and it gets going, all the worries go away.
__________________ All good things must come to an end... | |
| The Following User Says Thank You to g00s3y For This Useful Post: | Enki (05-29-2015) |
![]() | | #640 | ![]() |
Groans: 189
There's pics somewhere I think. At any rate, the black death is a systemic issue that derives from the design of our pumps, and affects *all* of our pumps, regardless of mod or corn level.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Easter Bunny (06-01-2015), Mauro_Penguin (05-29-2015) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/kings-corn-hpfp-oil-122082/ | ||||
| 2014 Ford Fiesta ST project - Page 9 | This thread | Refback | 08-03-2014 08:28 AM | |
| What happened to the e85 blend thread? - Page 4 | This thread | Refback | 02-15-2014 09:29 PM | |
| What happened to the e85 blend thread? - Page 3 | This thread | Refback | 01-08-2014 09:42 PM | |
| BNR Stage 3 Turbo Upgrade - Page 7 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-01-2013 03:06 PM | |
| Resolving HPFP corn woes (black death/sticking spill valve) | Enki | MazdaSpeed 3/6 - E85 Fueling | 467 | 10-26-2014 03:50 AM |
| Another Corn Fed PU | trf5000 | 2010 MS3 - ECU Computer Tuning | 73 | 08-12-2012 09:07 AM |
| 2 gal's of corn + chinacharger | dooderek | MazdaSpeed 3/6 - ECU Computer Tuning | 15 | 01-10-2012 01:52 AM |
| Make hate part 10ish. - negative camber kings check in | IshiKage | MazdaSpeed 3/6 - Suspension & Brakes | 30 | 05-02-2010 11:08 PM |
| Dale Earnhardt lives on... as 305-foot roller coaster at Kings Dominion?! [w/VIDEO] | Haltech | Automotive News | 0 | 08-21-2009 09:20 AM |
