Like Tree46Likes
 Old 12-26-2012, 01:55 PM   #121
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Back to the original topic...
I would gum up my spill valve in ~50 miles when trying to run 7.5-8 gal/tank E85 (~E50) when using Walmart SuperTech 5w-30 synthetic. I could reduce the E85 concentration to 6-7 gal/tank and clean the spill valve in place enough to control again.
This was repeatable as it checked it 2-3 times.
I have never had any issues with this oil at E20-E40 during the past 1.5 years.
My daily cld12pk2go tidbit is your use of Walmart Supertech. Obviously, it is working out well for you, but I'm interested to hear if you have had a UOA done.
Note to self: stock pcv system and Walmart Supertech = win.
@atvfreek; would have an interest in this as well.
atvfreek likes this.
atvfreek (12-26-2012), cld12pk2go (12-26-2012)
 Old 12-26-2012, 02:36 PM   #122
I have determined that my spill valve is much more likely to stick when running the engine at high RPM and low load, e.g. when running up to redline slowly in second gear to do a MAF calibration log, or if revving the engine in neutral. This has led me to theorize that the valve sticking is due to fluid coming back into the valve from the pump due to high pump cycling and low fuel flow demand. It brings oil seeping past the seals on the pump piston with it that gum up in the spill valve.
The Following 5 Users Say Thank You to silvapain For This Useful Post:
Enki (12-28-2012), lilred (12-26-2012), metalgear386 (07-30-2013), Nliiitend1 (12-26-2012), rfinkle2 (12-26-2012)
 Old 12-26-2012, 05:28 PM   #123
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
I have been running ST5w-30 synthetic since ~2k miles and changing at 5k intervals after changing the first at 5k on the odo (so all subsequent oil changes would be at 10k, 15k, 20k, etc).
I haven't done an UOA; however, I just received two Blackstone kits and I plan to test my current oil at 4k, and then to switch to Rotella T6 (which will also be checked at 4k).
Going to T6 will increase my operating temp viscosity by ~50%. Also since I am making crazy power and pushing my turbo well off the compressor map, I figured it would probably be smart to not push the oil change frequency like I was still running stockish power levels.
I currently have 82k miles (next oil change at 84k).
 Old 12-28-2012, 01:06 AM   #124
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Yes yes, but how else am I going to get ricers to bite and ultimately commit suicide after they lose?
Eric28243 (03-04-2013), mazdafreak (12-29-2012)
 Old 02-28-2013, 11:11 AM   #125
Enki's Avatar
Groans: 189
So I went back to full e85 after having been on 50/50 and VR1 for over a month, and not even 20 miles in the spill valve stuck. Fortunately, the internals are still holding pressure, but I fear that there might be some black death sneaking around in there as it took a couple of cycles for the car to build any pressure. I'm on about a 25% mix right now (as I had enough foresight to only put 5 gallons of pure in, and filled up a 5 gallon can with 91) and I'm probably going to run that down before I go back to 50/50 or maybe even 3 gallon in preparation for the S3.
It very well could be that the e85 I get is tainted with some kind of additive that just properly fucks oil, I dunno.
Thought you all might like to know.
Dizzy Turbo likes this.
The Following 11 Users Say Thank You to Enki For This Useful Post:
Constantin (06-28-2013), cyber-ms3 (03-01-2013), Dizzy Turbo (02-28-2013), Eric28243 (03-04-2013), GODspeed7 (02-28-2013), jseams (02-28-2013), mazdafreak (02-28-2013), Ms3_Miami (02-28-2013), phate (02-28-2013), silvapain (02-28-2013), Ziggo (02-28-2013)
 Old 02-28-2013, 10:27 PM   #126
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
You should try kendell racing oil next ((the actual full race oil)), i think thats what it is, buddy uses it on his talon ((9sec talon))....I hear its 85 compaitable. Its still too cold for me to test here in IL. And when it was colder out my spill valve stuck all the time on 100%.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 03-01-2013, 07:46 AM   #127
That's disappointing @Enki;.
Have you tried using an oil that is Dexos 1 compliant yet?
 Old 03-01-2013, 09:43 AM   #128
Enki's Avatar
Groans: 189
Not yet; not sure I can handle another failure without cutting myself.
Eric28243 (03-04-2013), phate (03-01-2013), silvapain (03-01-2013)
 Old 06-27-2013, 10:34 PM   #129
Enki's Avatar
Groans: 189
Don't really want to see this die. Anyone have any updates?
@silvapain; @metallemur; @mazdafreak; @GLORIFIEDBOZO; @khopwood77;
Edit:
I'm still rocking 50/50 and hauling much ass doing so, but long for the days of smooth running and lolrape that is full e.
Bucker (06-30-2013), cshunter (06-29-2013), ms3blackmica (07-01-2013)
 Old 06-27-2013, 11:51 PM   #130
mazdafreak's Avatar
Groans: 124
No updates, car is getting the built motor put together right now..... I rly dont want to deal with cleaning the pump anymore, and didnt want to mix anything either. Planned on running 100% Racegas.
Not sure what im gonna do, wish we had a fix for the pump. Or at least last longer than a week and not be worried if ur spill valve will stick lol.
Should try diesel oil ((85 compatible?))
713whp/569wtq!
 Old 06-28-2013, 08:06 AM   #131
I'm on 93 pump gas right now, until I purchase a fif port system and install it. I'm running out of fuel on my setup as it is with just pump gas.
mazdafreak (06-28-2013)
 Old 06-28-2013, 04:58 PM   #132
Enki's Avatar
Groans: 189
Sounds like most have forsaken the corn in favor of big turbos.
 Old 06-28-2013, 06:59 PM   #133
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
I will never forsake the corn. Plus with shitty AZ gas and the heat we get...there is little choice if one wants to run aggressive.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 06-28-2013, 10:08 PM   #134
Enki's Avatar
Groans: 189
I meant full corn. Like your avatar's erection.
86AmishMs3 (06-29-2013), cshunter (06-29-2013), Juyoung (06-29-2013), mazdafreak (06-29-2013)
 Old 06-29-2013, 07:18 AM   #135
86AmishMs3's Avatar
Groans: 338
Wish I could, don't have the moniez for port injection so yeah I'm limited.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 06-29-2013, 09:48 AM   #136
Enki's Avatar
Groans: 189
I'd be interested to see what a pure e car can make with the fuel system maxed out. Fastest stock boost car on the planet?
 Old 06-29-2013, 10:32 AM   #137
stlskater92's Avatar
Posts: 78   (View Stats)
stlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond repute
subbed
White 2009 MS3:
100k mile pig
HTP built
gt3076r powered
6th port fueled
Tuned by Nishan
Black 2008 MS3:
under construction
#700orbust
stlskater92 is offline   Reply With Quote
 Old 06-29-2013, 10:36 AM   #138
86AmishMs3's Avatar
Groans: 338
I think it's just almost everybody is fine with 80% of the benefits with 20% of the work. 80/20 rule.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 06-29-2013, 06:29 PM   #139
speeding3's Avatar
Posts: 118   (View Stats)
speeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond repute
This is a thread I wrote when I had my old Mitsubishi . injectors used to get the black death, this was when I was running 100% E85.
"Alright, I finished my analysis of this stuff, and my finding is very unexpected. I think it will probably surprise everyone else as well. This doesn't appear to be forming because ethanol is "such a good solvent" but because ethanol is a poor solvent. I suppose it should have been obvious when others said that it "washes right off with gasoline". Why would something that ethanol is selectively dissolving wash off with gasoline? If this were something in rubber or from our fuel tanks, wouldn't that imply that gasoline would dissolve it even more readily than E85?
Alright, so what is this stuff? It is a appears to be a very large petroleum based hydrocarbon, similar to Vaseline. There isn't a single hetero-atom in the molecule (ie, the entire molecule is comprised of hydrogens and carbons), but the molecule is very large. It is also completely aliphatic (ie, only single bonds in the structure - no double or triple bonds). Where did it come from? I can only think of two different sources it could be coming from. It is either something that is mixed in with the rubber hoses that is meant to dissolve away in the gasoline, or it is a trace impurity in the 15% gasoline that is in E85 that wasn't separated during the fractional distillation process. Because it is such a large molecule, it wouldn't be very soluble in ethanol and could easily crash out of solution at the injector."
"Well, here is what I did just so everyone is clear. I filled a 40mL vial with E85 and blew it dry with nitrogen gas and mild heating (about 150*F). After there was no fuel left, I placed it under high vacuum to remove any remaining volatiles for about an hour. I was left with a clear sticky residue that smelled bad - like nasty frying oil. I dissolved this sample in the NMR solvent and analyzed it and it IS the same goo that was on the injector. There was smaller amounts of some other stuff in it as well, but the same peaks I saw in the black goo were in this residue. The black goo IS coming from the E85. It isn't naturally black, though. I suspect it just has soot mixed in with it that is giving it the color. Or trace amounts of oil, carbon, etc
I beleive Its caused from some additive they put in E85, some areas have it some dont, but its when the E atomizes out of the end of the injector some of the additive stays behind as this black goo / tar like substance. This may help explain why some of us get the black sticky death, and some don't.
Monotonous ONE and sidekick like this.
speeding3 is offline   Reply With Quote
The Following 9 Users Say Thank You to speeding3 For This Useful Post:
802MS3 (07-09-2013), bob^3 (07-01-2013), Constantin (06-29-2013), cshunter (06-30-2013), Dizzy Turbo (06-29-2013), El_Diablo (06-30-2013), killer-ms3 (07-01-2013), Monotonous ONE (06-29-2013), sidekick (06-29-2013)
 Old 06-29-2013, 06:45 PM   #140
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
That's some really good info, thanks for posting that. So why wouldn't additives be able to break this stuff down like gasoline?
2006 Mazdaspeed6
 Old 06-29-2013, 07:03 PM   #141
speeding3's Avatar
The problems occur when gasoline additives are used in E85 shouldn't be surprising since these additives were never formulated for use in E85
gasoline contains detergent additives to keep critical engine parts clean. Depending on your location. Some e85 contains more or less of these additives. Which may help explain why some get black sticky death and some don't
What is worse, many existing gasoline additives are not fully compatible with E85. While they may appear to mix well with high-level alcohol fuels, the additive may not be completely soluble and could fall out of solution or become trapped on fuel filters, injectors, pump etc.
Modern gasoline additives are formulated to prevent this problem in normal gasoline.
 Old 06-29-2013, 11:23 PM   #142
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
If I'm not mistaken, everybody who ran 100% E85 did have "black death"....Some may be not as often as others...
In any case, you don't think engine oil can be the cause at all?
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
 Old 06-30-2013, 01:25 AM   #143
speeding3's Avatar
I'm sure that the oil plays a factor in the black death. because the E85 is a terrible solvent, the oil gets into the pump and sits after shutdown, and adds to the nasty residue that the additives in the E85 leave, Explains why it is black/brown.
Remember my car was SP not DI so some of the components were different. The only place I experienced Black Death was on the injectors. It's just some food for thought. their are a lot of variables that are involved with E85, location percentage of additives in e85 and gasoline etc. and I'm sure we may never find a completely viable solution on preventing Black Death other than regular cleanings. Even flex fuel vehicles suffer from Black Death.
 Old 06-30-2013, 03:30 AM   #144
Enki's Avatar
Groans: 189
[QUOTE=speeding3;2136857]Words/QUOTE]
I thought this looked familiar.
E85 Discussion - HPFP lubrication and Flow issues
Edit:
So you are this "thiazole" guy from codsm? Still live in Texas?
http://www.codsm.org/forums/showthread.php?t=3965
http://codsm.org/forums/showpost.php?p=29606
Side note: The single nastiest pump I've ever seen came off a CX7 and only ever ran gasoline. Black death infested that pump and I couldn't get all of it out. In fact, it was so nasty I had to pry the internals out of the pump. No joke.
 Old 06-30-2013, 04:07 PM   #145
speeding3's Avatar
[quote=Enki;2137282]
Words/QUOTE]
Edit:
E85 and injectors - Colorado DSM Club Forums
Colorado DSM Club Forums - View Single Post - E85 and injectors
No I was on the VR4 forums. That post has been copied and pasted on forums all over the web lol. Here is some more good reading and was a reply to my original post.
Are you getting your e85 from a station that sells premix, or a blender pump? (one that mixes ethanol with gas from the main station tanks)? What you might be encountering is due to the fact that premixed e85 is often mixed using very low grade gasoline (85 octane or lower - the ethanol largely makes up for it). It's probably sourced from the small amount of gas that is directly extracted from low grade crude oil or natural gas production, as opposed to the majority of gasoline which is processed in some way or another to obtain higher octane mixtures. A number of different processes are used - cracking, alkylation, reforming, etc which all produce slightly different mixtures that will pass the same "octane" rating tests.
What we think of as "gasoline" is really an extremely variable mix of several dozen different liquid hydrocarbons of different types that can pass the combustion and octane tests which allow it to be sold at the pump. (LPG is a similar product). The only real common feature of this mix is that the hydrocarbons all boil around the same (gasoline) temperature when separated from components with higher or lower boiling temperatures during distillation. Before it goes to the pump, it is modified via additives (detergents, ethanol, MTBE, etc) in order to bring it up to various standards.
The feedstock (crude oil) that is used also produces very different mixtures depending on where it came from. "light sweet crude" tends to produce more gasoline with higher octane and light hydrocarbons, where "heavy crude" and "tar sands crude" tend to produce heavier hydrocarbons, and the gasoline that results can contain a lot of heavier tars and waxes. The gasoline from the latter tends to be anywhere from 60-80 octane, and is usually processed in some way to produce consumer gasoline.
E85 blends can be made using cheaper, less processed gasoline when it is available, which leads to many of the problems you are encountering. This is often done to offset the high cost of ethanol, which is not only fairly expensive to produce, but cannot be transported via pipelines because it attracts water, which then contaminates other petroleum products that are also transported through the same pipeline (this is done by inserting a "plug" in between batches of fuel, which keeps the fuels separated). In some cases, lower grades of gasoline are actually required in order to allow the fuel to vaporize more easily, since ethanol does not, especially in colder parts of the country. Recall that the opposite is true - higher octane gasoline vaporizes and burns less easily.
Compounding the problem is that many of the normal gasoline detergents (that prevent the tar buildup that you are seeing) are not compatible with ethanol, and also in ethanol blends, only the gasoline portion contains the EPA required minimum additive levels. (A sidenote - the main difference between cheap gas stations and "top tier" stations that tend to be more expensive is not that the gasoline itself is any different, but that the levels of additives are higher, mainly detergents)
It's such a problem that professional race teams that have switched to e85 have had to source their own blends from manufacturers, which can be blended from a combination of high grade (low water content) ethanol mixed with race gas - the result is much higher quality than the E85 we can get at the pump.
If you have a lot of time, here's a DoE primer on Ethanol fuels: Ethanol
A couple of recommendations if you are having this problem with E85:
1) If your car is still dual-tune, run a tank of 100% gasoline from a "Top Tier" station every now and then (Chevron is my preferred, but there are several. Some independent stations are also certified:Top Tier Stations - You'll probably want premium, but detergent content is unrelated to octane rating)
2) Find a bottle of E85 compatible detergent additive - Chevron's "Techron" is available at many auto parts stores in a bottle. "Seafoam" makes a gas tank additive that is E85 compatible - not to be confused with the popular "spray" product.
After doing looking around a bit at some more DoE and ethanol industry literature, the consensus seems to be that the goo is caused by not just the factors I mentioned above no detergents in the ethanol portion of the blend, and lower quality gasoline with a lot of heavy "gum" hydrocarbons, but also a high level of corrosion inhibitors.
The best bet is probably still to use an appropriate detergent additive, but don't use more than "recommended" by the additive manufacturer, as too much detergent won't dissolve properly in the ethanol, and might cause other problems.
I think the actual ethanol content of the fuel doesn't really matter - it's only dependent on the actual additive.
Here's an excerpt from a whitepaper by the RFA (Renewable Fuels Association)
Detergents/Deposit Control Additives: Recent studies have shown that E85 may, in some
cases, lead to development of fuel injector and/or intake valve deposits. Preliminary work
indicates that this may be a result of no detergents in the ethanol portion of the blend in
combination with high levels of corrosion inhibitor. This can be addressed through the addition
of detergents/deposit control additives. If an additive is used, the blender must rely on
information from the additive manufacturer. In addition to effectiveness, it should be confirmed
that any additive selected will remain soluble in varying blend levels of gasoline and ethanol, and
that the additive meets the “no harm” criteria, meaning it will not interact with other gasoline
additives present in a manner that would cause problems or reduce the effectiveness of other
additives. Common gasoline additives may not be compatible with E85. The recommended treat
rate of any additive should not be exceeded.
The Following 5 Users Say Thank You to speeding3 For This Useful Post:
bob^3 (07-01-2013), Constantin (07-25-2013), El_Diablo (07-01-2013), killer-ms3 (07-01-2013), MattyP617 (06-01-2015)
 Old 06-30-2013, 07:53 PM   #146
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
So what we need is to ditch gasoline all together, and find the proper additive for 100 percent E85...this will require someone who doesn't mind cleaning their spill valve all the time until the right additive is found
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post:
bob^3 (07-01-2013), mazdafreak (07-01-2013)
 Old 07-01-2013, 01:13 AM   #147
mazdafreak's Avatar
Groans: 124
What about buying drums of E85? Instead of going to a pump. Id be down to test this shit once my motor is broken in.
c85
VP Drag Racing Fuels
713whp/569wtq!
 Old 07-01-2013, 02:23 AM   #148
speeding3's Avatar
c85
VP C85 is really good but ur going to pay 50$ for 5 gallons. I pay 17 for 5 gallons of pump E85. Most of us on here don't have pockets that deep to pay 100+ on a fill up lol.
The Following 2 Users Say Thank You to speeding3 For This Useful Post:
mazdafreak (07-01-2013), ms3blackmica (07-01-2013)
 Old 07-01-2013, 03:27 AM   #149
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
c85
Don't mean to go off topic but C85 from VP is some good stuff. Albeit expensive, I tuned a fella who didn't have e85 anywhere near him and 2.5 gallons of that stuff goes a LONG way. More so than pump E85 I would have to say. Might even use the entire 5 gallon drum for track use.
My friend purchased a 55 gallon drum of E98 for his race car so I have dibs on some of it. Been playing with that recently.
www.tunedbynishan.com
 Old 07-01-2013, 03:44 PM   #150
mazdafreak's Avatar
Groans: 124
If it solves my black death problems I wouldn't care at all how much.... $470 for 54 gallons is almost $9 a gallon, which is about the same as racegas at the pumps ((which I was going to use)).
Plus I dont daily my car, only used for like weekends or a random cruise to work.
I have e85 everywhere in IL, suburbs by my house have 2 right down the block from me..... but if this stuff helps with black death im down to order and just try it out. It says 4% hp increase over pumps, but im sure with stock turbo u wont find gains, mine has been maxed out on 100% E. ~25lbs-332whp.
What does @phate; @silvapain; think about c85, think it will help at all with black death? I could order a 30gallon drum, good for 2 full tanks and see what happens.
713whp/569wtq!
mrmonk7663 (07-01-2013)
 Old 07-01-2013, 03:50 PM   #151
Nishan
I have no idea how it reacts in regards to the "black death". I would need to run it in higher concentrations and based off the price, I will never do that.
Just wanted to mention that it is a really good fuel.
 Old 07-01-2013, 04:34 PM   #152
Enki's Avatar
Groans: 189
Again, this might be resolvable simply by keeping the pump cooler. It's possible that some o-ringed thermal gaskets or a return style fuel system could resolve the issue entirely.
dot584 (07-01-2013), El_Diablo (07-01-2013), mazdafreak (07-01-2013), ms3blackmica (07-01-2013)
 Old 07-01-2013, 06:44 PM   #153
dot584's Avatar
Posts: 426   (View Stats)
dot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the world
Groaned at 4 Times in 2 Posts
Is anyone working on a return style setup still?
Sent from my SCH-I545 using Tapatalk 2
CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers!
dot584 is offline   Reply With Quote
 Old 07-02-2013, 02:12 PM   #154
I don't know why you'd want to go through the hassle and cost of purchasing that expensive fuel by the drum, when mixing pump gas and E85 at the station is proven to work and be more cost-effective and less work. The performance gains on full E85 are minimal.
That isn't to say that I'd stay E50 if we figure out a way to safely run full E85. Just that I'm not too upset with our current option.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
cld12pk2go (07-03-2013), ms3blackmica (07-02-2013), MSP6 (07-02-2013), sidekick (07-02-2013)
 Old 07-02-2013, 03:36 PM   #155
Nishan
It is very expensive, I agree 100%.
I've been throwing in a few gallons of E98 from my buddies stash.
It's free so why not
 Old 07-03-2013, 05:11 AM   #156
Eth/Meth Junkie
cld12pk2go's Avatar
I agree that there isn't much reason to try to go full E85...
I have pretty much settled in around 5-5.5 gal E85 per tank. My turbo is maxed out and the difference in airflow capability summer/winter is pretty much offset by the E70/E85 switch such that my IDC stay in the low-mid 90's...
The Following 3 Users Say Thank You to cld12pk2go For This Useful Post:
El_Diablo (07-09-2013), ms3blackmica (07-04-2013), silvapain (07-03-2013)
 Old 07-03-2013, 11:57 AM   #157
Enki's Avatar
Groans: 189
I disagree that there isn't any reason to go full e85. I mean, the fuel carries with it its own oxygen, which makes it like getting a small shot of nitrous on full e.
I had to go from full E with only an intake to bigger intake, intercooler and turboback to reach the same levels of power I was making on full e with only 50/50. Is there a point on the big turbo cars? No, I'll agree there isn't there, but on airflow limited cars at altitude, I do believe there is a reason to go full e.
Hopefully, one day, I'll be able to prove it.
El_Diablo (07-09-2013), mazdafreak (07-03-2013), ms3blackmica (07-04-2013), silvapain (07-03-2013)
 Old 07-03-2013, 11:57 AM   #158
speeding3's Avatar
I just spoke to a rep at VP that dropped by my job. we buy a couple 100 gallons a month of the leaded VP. He said and I quote "VP C85 is nothing more than re-packaged pump E85 in a fancy can, If you want a better fuel try the VP101" so I guess the C85 is a no go as well.
The Following 4 Users Say Thank You to speeding3 For This Useful Post:
El_Diablo (07-09-2013), mazdafreak (07-03-2013), sidekick (07-03-2013), silvapain (07-03-2013)
 Old 07-03-2013, 11:18 PM   #159
sidekick's Avatar
Groans: 47
It is still probably a more consistent mix, if nothing else. Lol.
2006 Mazdaspeed6
The Following User Says Thank You to sidekick For This Useful Post:
mazdafreak (07-04-2013)
 Old 07-09-2013, 11:27 AM   #160
mazdafreak's Avatar
Groans: 124
So what would it take to have a return style fuel system put in....I would love to cure the black death so i can run 100% E85.
713whp/569wtq!
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/kings-corn-hpfp-oil-122082/
2014 Ford Fiesta ST project - Page 9 This thread Refback 08-03-2014 08:28 AM
What happened to the e85 blend thread? - Page 4 This thread Refback 02-15-2014 09:29 PM
What happened to the e85 blend thread? - Page 3 This thread Refback 01-08-2014 09:42 PM
BNR Stage 3 Turbo Upgrade - Page 7 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-01-2013 03:06 PM
Resolving HPFP corn woes (black death/sticking spill valve) Enki MazdaSpeed 3/6 - E85 Fueling 467 10-26-2014 03:50 AM
Another Corn Fed PU trf5000 2010 MS3 - ECU Computer Tuning 73 08-12-2012 09:07 AM
2 gal's of corn + chinacharger dooderek MazdaSpeed 3/6 - ECU Computer Tuning 15 01-10-2012 01:52 AM
Make hate part 10ish. - negative camber kings check in IshiKage MazdaSpeed 3/6 - Suspension & Brakes 30 05-02-2010 11:08 PM
Dale Earnhardt lives on... as 305-foot roller coaster at Kings Dominion?! [w/VIDEO] Haltech Automotive News 0 08-21-2009 09:20 AM
Page generated in 0.61670 seconds with 33 queries
