![]() | | #161 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score It's probably worth noting that black death forming as a result of heat is significantly more likely to happen with a hot shutoff over time, seeing as how no fluids will be circulating anywhere.
__________________ |
![]() | | #162 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score Has anyone tested if pre-cooling the fuel has any effect? Could line routing close to the block be pre-heating the fuel system? With a modified length plunger could we put a thermal insolating gasket and have any worth while results? Another option may be to directly cool the HPFP by creating a heatsink or some other cooling setup.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
![]() | | #163 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score It would probably be easier to mill the pump/hat and have a tig made there than extending the piston. Ideally, we should have a crank driven pump, like a reworked diesel pump or something. THAT would be awesome.
![]() | | #164 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Just talked to my gunsmith, he's on board to produce a new drive housing for the hpfp which would relocate it to either drive directly from the crank or off the serpentine belt. Anyone with some engineering knowledge care to draw it up? Sadly, I have no skills. @phate; @silvapain; @djuosnteisn;
| The Following 6 Users Say Thank You to Enki For This Useful Post: | Constantin (07-25-2013), mazdafreak (07-09-2013), mrmonk7663 (07-10-2013), Roddiy (07-20-2013), sidekick (07-10-2013), stlskater92 (07-13-2013) |
![]() | | #165 | ![]() |
![]() Join Date: Oct 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score That's the sketchiest idea I've ever heard............it made my wiener wiggle and I want one........
__________________ White 2009 MS3: 100k mile pig HTP built gt3076r powered 6th port fueled Tuned by Nishan Black 2008 MS3: under construction #700orbust |
| The Following User Says Thank You to stlskater92 For This Useful Post: | mazdafreak (07-13-2013) |
![]() | | #166 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I've thought about it a bit more and it probably wouldn't work too well if utilizing the stock control circuitry. The reasoning is that normally the fuel pump is driven off the intake cam, which has VVT. The pulses to the spill valve are (I assume) timed and compensated for the fact that VVT can relocate any of the three lobes 30+ degrees in either direction. We would probably need something else to control pressure, unless the engine can run with 1800+ PSI at idle.
![]() | | #167 | ![]() |
| Not Ranked : 0 score The CMP is also on the intake cam, so the ECU knows the actual location of the HPFP cam lobes. I don't know how the ECU determines when to pulse the spill valve though.
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #168 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I'd wager it's in relation to the lobe angle. This can probably be scoped and if correct, the pulse location will change with VVT, thus confirming a requirement for a tertiary control system. Now that I think about it, a custom controller could probably be done with an Arduino; base off of MAF and RPM and it wouldn't be too hard to pulse through a mosfet to kick the spill valve. Not really the cheapest alternative to fueling but if effective...oh boy. Hell, you could make a housing with two HPFP to kick the volume up even higher. Shit, they could even be stock pumps (140% volume per stroke single with internals or 200% with stock twins). Hmm.... Giggity.
| The Following 4 Users Say Thank You to Enki For This Useful Post: |
![]() | | #169 | ![]() |
| Not Ranked : 0 score I dont know that anyone has ever scoped the HPFP spill valve signal. I know if it was me designing it I wouldn't attempt to time it at all, I would just make it have a check valve before the spill valve that wouldn't allow fuel to flow the wrong way past the spill valve, and then have the duty cycle variable on the spill valve, so when its full bore, the spill valve is just open 100% of the time, relying on the check valve to prevent back flow. But I don't trust SW for anything. We just redesigned an entire mechanism to have a spring loaded failsafe because they kept crashing stuff into a focusing optic because they were supposed to check that the focus cell was clear before commanding the other mechanism to move.
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | Enki (07-13-2013), mazdafreak (07-14-2013) |
![]() | | #170 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score The only problem with that though is that the spill valve is what controls the pressure. Without it, we would likely see full pressure at idle (due to check valve not allowing pressure bleed), which may not work too well with injector pulse width (might not be low enough). I've had my afrs at idle in the 8 range (mafcal shifted a couple boxes), and although it sounds awesome (like a cammed v8), it's probably not good for the motor.
| The Following User Says Thank You to Enki For This Useful Post: | mazdafreak (07-14-2013) |
![]() | | #171 | ![]() |
![]() Join Date: Jul 2011 Location: Elk Grove Village, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,411
Groans: 124
| Not Ranked : 0 score I am going to be testing diesel oil with 100% E85. Mobil 1 recommonds their full synthetic diesel oil to be ran with E85....And oil has high zinc, which is good for our motors (the head).....If black death occurs after week or two ill just be running ~50/50 or a tad higher E. Whenever clint is free to send me a base map for it tho lol.
__________________ DBB Gen2 Pte6266, kozmic pte top mount manifold kit, Kozmic 4'' Intake, kozmic hood exit Dp+Dump, 11:1 Custom Wiesco Pistons + Monlar rods, Freek PnP head w/Supertech springs&retainers, L19 Head Studs, JMF PI Intake Manifold W/ custom single Walbro 450+ Fuelab Inline Pump, HKS BOV, Cp-e Stage2 RMM, Trz Tranny Mount, MD PMM, JBR Egr Block Off Plate, Cp-e Fuel Pump, Sheepey Built Fmic Core, 3.5 Bar Map Sensor, Precision Wastegate, TWM Shifter bushings, Freak Tuned! 713whp/569wtq! FIRST MS3 IN 10s! 10.963 @ 136.79 (8/12/2015) 10.72 @ 139.44! (10/1/2015) 10.43 @ 140.95! 10/9/2015 10.35 @ 140.86 (10/30/2015) New Time! Fastest Ms3 to date 10.27 @ 141.55 (5/22/2016) |
![]() | | #172 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Which oil?
![]() | | #173 | ![]() |
Groans: 124
| Not Ranked : 0 score I run rotella diesel oil now for the high zinc on a freshly new 11:1 motor. But I saw mobil 1 recommonds their full synthetic diesel oil with E85.
![]() | | #174 | ![]() |
![]() Join Date: Apr 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 234
Groaned at 53 Times in 17 Posts
| Not Ranked : 0 score I still wonder what role does the oil play since it has no contact with the FP? Is there another car that is DISI and is approved for E85 so we can compare the FPs? |
![]() | | #175 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score If you seriously think there is no oil in/around the fuel pump, you should probably re-read this thread and a few other threads in this section.
__________________ Last edited by Enki; 07-17-2013 at 08:00 PM. |
| The Following 10 Users Say Thank You to Enki For This Useful Post: | aaron_-01 (07-26-2013), cyber-ms3 (07-17-2013), Dizzy Turbo (07-17-2013), El_Diablo (07-17-2013), mazdafreak (07-17-2013), ms3blackmica (07-20-2013), phate (07-17-2013), Roddiy (07-20-2013), silvapain (07-22-2013), udntknw (07-17-2013) |
![]() | | #176 | ![]() |
![]() Join Date: Jan 2011 Location: vancouver,WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
| Not Ranked : 0 score Can't you add some kind of lubricating additive to the e85, seems like this would help with the sticking issue, ethanol likes to attract water and tends to dry rot any kind of seals, I ASSUME black death is a byproduct from the deterioration of said seals
__________________ 425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel |
![]() | | #177 | ![]() |
Groans: 769
| Not Ranked : 0 score If you would have read over the last 2 pages you wouldn't have to incorrectly assume.
| The Following 3 Users Say Thank You to El_Diablo For This Useful Post: |
![]() | | #178 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Next person to post in this thread without reading it first is going to get raped in every face hole.
| The Following 10 Users Say Thank You to Enki For This Useful Post: | aaron_-01 (07-26-2013), Dano (07-20-2013), Easter Bunny (07-25-2013), El_Diablo (07-21-2013), GODspeed7 (07-20-2013), Kyle Undefined (07-25-2013), mazdafreak (07-20-2013), ms3blackmica (07-20-2013), Roddiy (07-20-2013), silvapain (07-22-2013) |
![]() | | #179 | ![]() |
![]() Join Date: Jun 2008 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 752
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score How much E can I run with using Rotella T6? just tappa it in...
__________________ Wiseco OTS pistons, Eagle Rods, ARP mainstuds, JBR BSD w/ baffle,GT2871R, 51R battery, JBR V1 3.5 aluminum widepath, CP-e Catted DP, custom 3in cat-back, Treadstone TR8L core w/ COBB piping, Damond OCC, HKS SSQV3 (full VTA), autotech HPFP internals, Self tune 33% E85, Grimmspeed EBCS (3port), JBR TM & PM, TRZ Rmm, COBB short shifter, COBB Front/Rear swaybars, Koni STR.T struts, AXIS Circuits 18x8.5 45offset **Old Motor** Best 1/4 -13.19 Stock Turbo/ street tires Best trap speed - 112mph **New Motor** Best 1/4 - 13.35 Stock turbo/ street tires Best trap speed - 112.5 |
![]() | | #180 | ![]() |
Groans: 124
| Not Ranked : 0 score 1 gallon of E.
![]() | | #181 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
| Not Ranked : 0 score @Enki; this guy requests said face hole raping. Please oblige him.... Sent from my iBro 5 using tapatalk, Bro!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. |
| The Following 3 Users Say Thank You to GODspeed7 For This Useful Post: |
![]() | | #182 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score Read faggot.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
![]() | | #183 | ![]() |
![]() Join Date: Apr 2011 Location: Allentown, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,504
| Not Ranked : 0 score When's the rape? |
![]() | | #184 | ![]() |
| Not Ranked : 0 score im hoping tonight... @Enki; can we cuddle afterwards?
![]() | | #185 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score No cuddling. Rest of you fucks just got trolled.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Easter Bunny (07-25-2013), udntknw (07-20-2013) |
![]() | | #186 | ![]() |
Groans: 124
| Not Ranked : 0 score I didnt get trolled, since his mod list shows self tune 25% e85, so I would think he was trolling lol
![]() | | #187 | ![]() |
| Not Ranked : 0 score Hey noobs. Read before posting. Every question you can think of has already been answered. Tappin
| The Following User Says Thank You to Dano For This Useful Post: | phate (07-20-2013) |
![]() | | #188 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Not everyone has sigs turned on or reads mod lists.
| The Following User Says Thank You to Enki For This Useful Post: | mazdafreak (07-20-2013) |
![]() | | #189 | ![]() |
Groans: 47
![]() | | #190 | ![]() |
| Not Ranked : 0 score I just edited my sig for e85 a little bit ago, realized it wasn't on there. No intent of trolling, other than James. just tappa it in...
| The Following User Says Thank You to udntknw For This Useful Post: | mazdafreak (07-20-2013) |
![]() | | #191 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| Not Ranked : 0 score Or they could just be on tapatalk ...
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress |
| The Following User Says Thank You to himurax13 For This Useful Post: | silvapain (07-25-2013) |
![]() | | #192 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
| Not Ranked : 0 score Something > than 6 gal of E per full tank... At least my last two fill ups were 6.3 and 6.0 Gal E85 with balance 93...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
![]() | | #193 | ![]() |
| Not Ranked : 0 score I regularly run E50 (7 gallons E85 + 6 gallons E10 93 octane pump gas) on T6 will no spill valve issues. Sent from my iPhone using Tapatalk 2
| The Following User Says Thank You to silvapain For This Useful Post: | ms3blackmica (07-25-2013) |
![]() | | #194 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Just do 50/50 mix (1 gallon e to 1 gallon pump gas) and never worry about it again.
![]() | | #195 | ![]() |
![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 50
| Not Ranked : 0 score I currently run 5 gallons e85 NP. I believe it's good practice to clean your spill valve every so often 3-6months it's very easy and it just offers piece of mind. I'm wondering if anyone on here is running e85 with the new kmd aviva instruments internals they say they have a different coating on them Piston surface treatment is a proprietary coating applied by PVD. Refined for lower μ than traditional DLC coatings. I'm wondering if maybe this is a little bit more resistant to the Black Death. Just some food for thought. |
![]() | | #196 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score The black death does not discriminate. It will fill your internals, and gum them up so bad the piston won't cycle. The only way to avoid the problems associated with the black death is to prevent it from building up in the first place.
| The Following User Says Thank You to Enki For This Useful Post: | Tokay444 (07-26-2013) |
![]() | | #197 | ![]() |
| Not Ranked : 0 score For craps and laughs... What if a higher rate spring was used for the return? Could there be a point that it doesn't get stuck from the sticky icky? just tappa it in...
![]() | | #198 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Wouldn't matter; the spill valve would still stick (and I'm already running a 5x spring in that).
![]() | | #199 | ![]() |
| Not Ranked : 0 score I wonder if maybe we can run some kind of inline filter, not that shity one in the tank, like a inline 70-140 micron stainless mesh filter pre hpfp, and after the in tank pump. I think some of this may be from the station tanks. It would be easy enough to install an in line filter and it may work. I mean the Black Death effects every pump, but I'm wondering if you can filter the shit out of it, then maybe you can significantly reduce the amount of deposits. |
| The Following User Says NO Thank You to speeding3 For This Un-useful Post: | Easter Bunny (07-26-2013) |
![]() | | #200 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score It isn't. It doesn't. It won't. Read the entire section please. Every thread. Every page. Every post.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/kings-corn-hpfp-oil-122082/ | ||||
| 2014 Ford Fiesta ST project - Page 9 | This thread | Refback | 08-03-2014 08:28 AM | |
| What happened to the e85 blend thread? - Page 4 | This thread | Refback | 02-15-2014 09:29 PM | |
| What happened to the e85 blend thread? - Page 3 | This thread | Refback | 01-08-2014 09:42 PM | |
| BNR Stage 3 Turbo Upgrade - Page 7 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-01-2013 03:06 PM | |
| Resolving HPFP corn woes (black death/sticking spill valve) | Enki | MazdaSpeed 3/6 - E85 Fueling | 467 | 10-26-2014 03:50 AM |
| Another Corn Fed PU | trf5000 | 2010 MS3 - ECU Computer Tuning | 73 | 08-12-2012 09:07 AM |
| 2 gal's of corn + chinacharger | dooderek | MazdaSpeed 3/6 - ECU Computer Tuning | 15 | 01-10-2012 01:52 AM |
| Make hate part 10ish. - negative camber kings check in | IshiKage | MazdaSpeed 3/6 - Suspension & Brakes | 30 | 05-02-2010 11:08 PM |
| Dale Earnhardt lives on... as 305-foot roller coaster at Kings Dominion?! [w/VIDEO] | Haltech | Automotive News | 0 | 08-21-2009 09:20 AM |
