Like Tree46Likes
 Old 09-25-2013, 12:16 AM   #281
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Honestly I'm not too terribly worried about a 5% (maximum) content drop. It's still enough to cause issues with pumps as it is. Normally, I don't even flash a new map with changed scalars; I let the LTFTs soak it up.
 Old 10-19-2013, 07:38 PM   #282
Enki's Avatar
Groans: 189
Oil is out of the car, to be replaced tomorrow.
*Que dramatic music*
mazdafreak likes this.
The Following 9 Users Say Thank You to Enki For This Useful Post:
Constantin (10-19-2013), cshunter (10-21-2013), Easter Bunny (10-20-2013), El_Diablo (10-20-2013), killer-ms3 (10-21-2013), lilred (10-19-2013), littleloogy (10-19-2013), mazdafreak (10-19-2013), udntknw (10-19-2013)
 Old 10-20-2013, 05:50 PM   #283
Enki's Avatar
Groans: 189
Car not going anywhere for a bit while I figure shit out:
Enki's EFR Ordeal...
TLDR: Car on jack stands, no manifold or turbo installed; unable to proceed due to lack of parts/proper configuration on turbo and vague instructions.
Constantin (10-20-2013), cshunter (10-21-2013), El_Diablo (10-20-2013), littleloogy (10-22-2013)
 Old 10-21-2013, 04:10 PM   #284
Enki's Avatar
Groans: 189
Baseline UOA on the RP oil has been mailed today...somewhere around 1k miles on it but should give me an idea of where it sits.
Constantin (10-22-2013), El_Diablo (10-21-2013), littleloogy (10-22-2013), Mauro_Penguin (11-01-2013), wolly6973 (10-21-2013)
 Old 10-22-2013, 05:36 PM   #285
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
Not trying to thread jack, or post in the wrong place, but I had a random thought today at work and I want to get it out before I forget it because I'm about to leave the house in like five minutes.
There's probably some way to isolate the pump area, including the end of the cam from engine oil. This way no engine oil ever reaches the fuel pump in the first place.
The parts could then bathe in some OTHER type of lubricant, one that wouldn't react the same way as typical engine oil would. (if such a lubricant exists) A type of closed loop, splash lubrication system perhaps.
Maybe the pump isnt the place to prevent black goo, but rather the pump's mounting base itself.
If this has been ruled out before or doesn't make sense, disregard this post.
'06 Mazdaspeed 6
timjs is offline   Reply With Quote
 Old 10-22-2013, 05:40 PM   #286
Enki's Avatar
Groans: 189
Unfortunately the cam follower has to have oil all the way around it, and without the vent holes for oil to drain out, at some point whatever lubricant is in the follower will be forced into the pump proper. Also, you'd want whatever lubricant is there to cycle through and get filtered/cooled at some point.
Sadly, it doesn't really seem viable to fully isolate the pump like that without spending huge amounts of time/money on modifications to the pump when I might prove in the coming weeks that a simple change of oil can resolve the issues with E.
Constantin (10-25-2013)
 Old 10-22-2013, 06:27 PM   #287
timjs's Avatar
Excellent feedback, thanks!
'06 Mazdaspeed 6
 Old 10-28-2013, 03:08 PM   #288
Enki's Avatar
Groans: 189
Baseline oil test came back...Low mileage, so nothing to see really.
Next test in 3 months or so.
Mazdaspeed 3/6 UOA Results
El_Diablo (10-28-2013), Mauro_Penguin (11-01-2013), Roddiy (10-28-2013), wolly6973 (10-29-2013)
 Old 11-01-2013, 12:23 PM   #289
Enki's Avatar
Groans: 189
Might be testing e74 (full e85 spring/fall blend, which is southern AZ's winter blend) as soon as tonight. I'm still running the pump as it was the last time I tested, and the only thing that's been done to it since the last full breakdown is the reported 2 spill valve cleanings. I'm curious to see how it goes.
Updates to follow.
The Following 8 Users Say Thank You to Enki For This Useful Post:
Constantin (11-01-2013), DSIT995 (11-01-2013), Easter Bunny (11-01-2013), El_Diablo (11-01-2013), JeffroMS3 (11-02-2013), silvapain (11-04-2013), WetzMS3 (11-01-2013), wolly6973 (11-01-2013)
 Old 11-01-2013, 06:14 PM   #290
Enki's Avatar
Groans: 189
Made it home with no issues. Might go for another little drive tonight and see how it does, or I might just wait till tomorrow morning and go meet up with some locals for a stockout (not me stocking out).
Pretty promising, considering I've not cleaned the pump since the last time.
Constantin (11-01-2013), El_Diablo (11-01-2013), timjs (11-01-2013), WetzMS3 (11-01-2013), wolly6973 (11-01-2013)
 Old 11-01-2013, 07:55 PM   #291
littleloogy's Avatar
Posts: 4,005   (View Stats)
How many miles was your drive? God I hope we figure this out!
 Old 11-01-2013, 08:57 PM   #292
Enki's Avatar
Groans: 189
About 12, but it doesn't really matter, seeing as how the past two times I've tried full corn I've not made it home without issues.
Tonight, however, marks a change.
The pump has still not been cleaned, and I've put another 20-23 hard flogging miles on it.
ZERO ISSUES SO FAR!
If there is hope, it comes in a purple bottle...
The Following 6 Users Say Thank You to Enki For This Useful Post:
bladerunner10121 (11-02-2013), DSIT995 (11-02-2013), El_Diablo (11-02-2013), littleloogy (11-01-2013), Ms3_Miami (11-02-2013), silvapain (11-04-2013)
 Old 11-02-2013, 07:46 AM   #293
bladerunner10121's Avatar
Posts: 83   (View Stats)
bladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the world
Wow. I hope people realize what a great achievement this is if it turns out to have fixed the black death issue. Its one more thing that would let us push this platform even further. Enki, thank you for all your hard work. Can't wait to see your numbers with that EFR turbo on full corn juice.
Sent from my SGH-M919 using Tapatalk
2012 CWP MS3
  • AP V3
  • Autotech HPFP Internals
  • JBR Tru3" WP Aluminum intake
  • Damond Motorsports RMM
  • M2 Full cat-less Downpipe
  • NGK 1 step colder plugs @.028'
  • Stratified E85 Flash Tune
bladerunner10121 is offline   Reply With Quote
The Following User Says Thank You to bladerunner10121 For This Useful Post:
Enki (11-02-2013)
 Old 11-02-2013, 08:29 AM   #294
mtosofsky's Avatar
Posts: 543   (View Stats)
mtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the world
Threads like these are why i love MSF. Great to see that something is potentially working. myself and I'm sure many other members really appreciate all the time, money, and risk you've taken by using your vehicle for this process.
2008 MS3 GT GTX//Relentless Customs//Voltron Approved//Nishan Tuned
mtosofsky is offline   Reply With Quote
The Following 2 Users Say Thank You to mtosofsky For This Useful Post:
Enki (11-02-2013), littleloogy (11-02-2013)
 Old 11-02-2013, 04:01 PM   #295
Enki's Avatar
Groans: 189
Pressure dropped out; pulling pump tomorrow for full cleaning (first time in a long time). Details here:
El_Diablo (11-03-2013)
 Old 11-02-2013, 04:18 PM   #296
timjs's Avatar
Damn. So if this doesn't work out, do you have another plan?
'06 Mazdaspeed 6
 Old 11-02-2013, 04:42 PM   #297
Enki's Avatar
Groans: 189
Yeah, gunsmith has stuff to mill specialty scraper for the HPFP.
El_Diablo (11-03-2013), mazdafreak (11-02-2013), timjs (11-02-2013)
 Old 11-03-2013, 03:08 PM   #298
Enki's Avatar
Groans: 189
OK so cleaned the pump out, found some nasty shit in there but no black death. It was pretty sticky but that's likely because I didn't clean the spill valve all that well last time and Ski used T6 to re-lube the spill valve o-ring.
Anywho, the first thing I noticed when I pulled the pump was that I could actuate the internals by hand without too much issue. It was squishy, but not really sticky; not really sure if it was becoming an issue or not. The spill valve was definitely sticking though.
At any rate, I'm below half a tank from being topped off with full E, so things look pretty decent. I'd like to see how long it goes on a full clean from here, but I'm not sure if I'm potentially having some ITFP issues or not. Time will tell, updates will follow.
Constantin (11-03-2013), Easter Bunny (11-04-2013), El_Diablo (11-04-2013), Ms3_Miami (11-05-2013)
 Old 11-03-2013, 04:37 PM   #299
Enki's Avatar
Groans: 189
Pressure dropped out again after 50 ish miles. Went back to 50/50 for now until I think this through a little further and get the car running stable.
So far, though, all the issues I've hit have been spill valve related, which is much easier to deal with than black death on the internals.
At any rate, it doesn't look like I'll be able to run stock boost with the EFR due to fueling window limitations, so further involvement on my part may be short lived here on out.
El_Diablo (11-04-2013), silvapain (11-04-2013)
 Old 11-03-2013, 04:50 PM   #300
Do you know how to create the sticky substance that we get in our SVs? I have some fresh/wild ideas in my head to keep the SV clean however I need a specimen. I quit running straight E85 because of reliability (daily driver). Now I wish I would have saved all the gunk funk
 Old 11-03-2013, 04:51 PM   #301
Enki's Avatar
Groans: 189
Yes. Boil E85 + oil in a saucepan on really high heat. E alone won't do it.
Edit:
It might be possible to slightly mill the spill valve so it will accept a tiny PTFE washer between the needle and the actual channel/button thingie. That is where it sticks, and where the spill valve issue will likely be solved.
It might also be possible to simply polish part of it so there's very little seating contact between needle and channel/button thingie. That would also probably work rather well and be easier most likely.
El_Diablo (11-04-2013), mazdafreak (11-03-2013), Ms3_Miami (11-05-2013)
 Old 11-03-2013, 05:02 PM   #302
Agreed, Thanks for the recipe. I'll use FP hardware mod attempts as a last resort.
Enki (11-03-2013)
 Old 11-04-2013, 06:35 AM   #303
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Be very careful when heating fuel. The vapor is extremely volatile and doesn't take much to go off.
2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather
2004 Mazdaspeed Miata #3142- Stock, but not for long.
Equal rights for all, special privileges for none. ~ Thomas Jefferson
The Following 4 Users Say Thank You to El_Diablo For This Useful Post:
Enki (11-04-2013), killer-ms3 (11-04-2013), Ms3_Miami (11-05-2013), timjs (11-04-2013)
 Old 11-04-2013, 08:22 AM   #304
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
@Enki; knows this from experience...
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
udntknw is offline   Reply With Quote
The Following 2 Users Say Thank You to udntknw For This Useful Post:
Enki (11-04-2013), Spectrix (11-05-2013)
 Old 11-04-2013, 08:39 AM   #305
El_Diablo's Avatar
Groans: 769
That’s exactly why I posted that, lol.
It’s best to do it in an open environment with a good breeze. Next best thing would be in the garage with a fan blowing out of the garage.
The Following User Says Thank You to El_Diablo For This Useful Post:
Enki (11-04-2013)
 Old 11-04-2013, 09:32 AM   #306
Enki's Avatar
Groans: 189
Best with no breeze and DEF not in an enclosed environment. Open space for sure.
Keep in mind the only time I was able to replicate the sticky was when the e85 auto ignited. Food for thought.
 Old 11-04-2013, 09:34 AM   #307
So much for cooking this on my stove next to my dinner tonight. Thanks for the heads up guys... May have saved my eyebrows
 Old 11-04-2013, 09:42 AM   #308
JgamB's Avatar
Posts: 2,566   (View Stats)
This is interesting. The fueling stations themselves get black death it appears, complete with cavitating pumps and clogged filters.
The Following 3 Users Say Thank You to JgamB For This Useful Post:
Easter Bunny (11-04-2013), El_Diablo (11-04-2013), Tokay444 (11-05-2013)
 Old 11-04-2013, 10:09 AM   #309
El_Diablo's Avatar
Groans: 769
The reason I suggested a breeze is to quickly disapate the volatile vapor "cloud".
Keep in mind, the vapor is heavier than air so if you have a gas fired water heater or anything with a pilot light anywhere near where you're working you have a highly explosive situation.
 Old 11-04-2013, 10:11 AM   #310
Enki's Avatar
Groans: 189
I did my testing in the driveway on an electric hotplate and it still burst into flames.
No spark or open flames within 100 feet of it.
atvfreek (11-04-2013), Tokay444 (11-05-2013)
 Old 11-04-2013, 10:18 AM   #311
El_Diablo's Avatar
Groans: 769
A slow simmer would probably be better. The rest of the comment was focused towards @littleloogy;
The Following 2 Users Say Thank You to El_Diablo For This Useful Post:
Enki (11-04-2013), littleloogy (11-04-2013)
 Old 11-04-2013, 10:43 AM   #312
All joking aside I will be heading to my lab to create the substance and do my testing. Now I have an excuse to wear my flame suit.
The Following 4 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (11-05-2013), El_Diablo (11-04-2013), Enki (11-04-2013), Roddiy (11-04-2013)
 Old 11-04-2013, 11:00 AM   #313
Enki's Avatar
Groans: 189
You can't do a slow simmer. Not with full E85. 5 seconds after I would take it off of the hotplate (boiling) it would be cool enough to touch the bottom. It *HAS* to have *EXTREMELY* high heat in order to get the oil hot enough to do the breakdown thing; normally in the pump it would be 160+ degrees and under pressure so the fuel wouldn't boil.
You might be able to keep it in a sealed metal container and replicate though, without risk of fire.
Pretty sure @phate; already sent in some sticky/black death to be tested and found it to be compounds normally found in oil.
Last edited by Enki; 11-04-2013 at 11:00 AM. Reason: MSF Database - Automerged Doublepost
Easter Bunny (11-05-2013), El_Diablo (11-04-2013), littleloogy (11-04-2013), phate (11-04-2013), Tokay444 (11-05-2013)
 Old 11-04-2013, 11:36 AM   #314
timjs's Avatar
A bomb?
'06 Mazdaspeed 6
The Following 4 Users Say Thank You to timjs For This Useful Post:
Easter Bunny (11-05-2013), Enki (11-04-2013), littleloogy (11-04-2013), Tokay444 (11-05-2013)
 Old 11-04-2013, 11:40 AM   #315
Enki's Avatar
Groans: 189
I said there wouldn't be risk of fire, didn't say anything about explosion.
El_Diablo (11-04-2013), timjs (11-04-2013), Tokay444 (11-05-2013), udntknw (11-04-2013)
 Old 11-04-2013, 05:11 PM   #316
biscuit003's Avatar
biscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond repute
If you've got a set of brass balls, perhaps you could try this in a pressure cooker.
2013 Mazdaspeed 3 Liquid Silver
AT internals / Cobb AP / CS SRI + TIP / CS TMIC / CS Race Pipe / JBR 88a RMM / JBR 80a TMM / JBR 80a PMM / JBR RSB / JBR OCC
biscuit003 is offline   Reply With Quote
The Following 3 Users Say Thank You to biscuit003 For This Useful Post:
Easter Bunny (11-05-2013), killer-ms3 (11-06-2013), littleloogy (11-04-2013)
 Old 11-04-2013, 05:30 PM   #317
Enki's Avatar
Groans: 189
FYI, I used a portable laser thermometer to take temp readings off the fuel pump after going out for lunch today; parts where the fuel was boiling (I.E. the spill valve area) were about 140 Fahrenheit, while lower down and closer to the head read between 160 and 165.
Easter Bunny (11-05-2013), littleloogy (11-05-2013), Spectrix (11-05-2013)
 Old 11-05-2013, 07:23 AM   #318
Spectrix's Avatar
Posts: 332   (View Stats)
Spectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the world
Groaned at 7 Times in 3 Posts
Not sure if this has been suggested / dismissed already; the idea of a phenolic spacer to reduce heat transfer to the HPFP?
2008 Gen1 MS3
Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires.
Self tuned on E85
Spectrix is offline   Reply With Quote
 Old 11-05-2013, 07:35 AM   #319
mtosofsky's Avatar
But then if something like that was possible, wouldn't the internals assembly be too short if we are essentially spacing the pump off of the head slightly?
 Old 11-05-2013, 08:33 AM   #320
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Hmm I wonder how much an effect a gasket would make. I would think we would see a reduction in volume due to the shorter stroke of the piston. Most internals seem to like to run away up top if all the gasket did was stop this from happening it might not be a bad thing
Sent from my XT1080 using Tapatalk
Damond Built Speed 6
Deldran is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/kings-corn-hpfp-oil-122082/
2014 Ford Fiesta ST project - Page 9 This thread Refback 08-03-2014 08:28 AM
What happened to the e85 blend thread? - Page 4 This thread Refback 02-15-2014 09:29 PM
What happened to the e85 blend thread? - Page 3 This thread Refback 01-08-2014 09:42 PM
BNR Stage 3 Turbo Upgrade - Page 7 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-01-2013 03:06 PM
Resolving HPFP corn woes (black death/sticking spill valve) Enki MazdaSpeed 3/6 - E85 Fueling 467 10-26-2014 03:50 AM
Another Corn Fed PU trf5000 2010 MS3 - ECU Computer Tuning 73 08-12-2012 09:07 AM
2 gal's of corn + chinacharger dooderek MazdaSpeed 3/6 - ECU Computer Tuning 15 01-10-2012 01:52 AM
Make hate part 10ish. - negative camber kings check in IshiKage MazdaSpeed 3/6 - Suspension & Brakes 30 05-02-2010 11:08 PM
Dale Earnhardt lives on... as 305-foot roller coaster at Kings Dominion?! [w/VIDEO] Haltech Automotive News 0 08-21-2009 09:20 AM
Page generated in 0.56245 seconds with 31 queries
