Like Tree46Likes
 Old 11-05-2013, 08:39 AM   #321
robry's Avatar
Posts: 862   (View Stats)
robry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the world
Groans: 27
Groaned at 9 Times in 7 Posts
Originally Posted by mtosofsky View Post
But then if something like that was possible, wouldn't the internals assembly be too short if we are essentially spacing the pump off of the head slightly?
yes you would need to make a spacer for the top of the internals as well, or make a longer set of internals.
2014 Mustang GT Premium 6MT - GT Track Pack/Leather Recaros/Glass roof in Sterling Grey Metallic | Barton SS/2 Post | J&M LCA | Steeda Street UCA | JBA 3" O/R X | GT500 ABs | JLT plastic CAI | SCT xcal with AED HP custom tune
SOLD2011 Mazdaspeed3 Celestial Blue Mica
robry is offline   Reply With Quote
 Old 11-05-2013, 09:02 AM   #322
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Originally Posted by Spectrix View Post
Not sure if this has been suggested / dismissed already; the idea of a phenolic spacer to reduce heat transfer to the HPFP?
I suggested a TIG for the pump could potentially help much earlier in this very thread, but recanted considering hot ass engine oil splashes all over the pump. I've also suggested converting to a return style fuel system, but that would only allow cooling for as much thermal mass as there is fuel before heatsoaking.
You could have the pump or pump mount milled a little to account for the spacer and keep everything in check; I have a spare pump to head mounting assembly that this could be tested with, but I'm not too sure this would work anyways.
Originally Posted by Deldran View Post
Hmm I wonder how much an effect a gasket would make. I would think we would see a reduction in volume due to the shorter stroke of the piston. Most internals seem to like to run away up top if all the gasket did was stop this from happening it might not be a bad thing
I don't really think it would be a good idea to use a reduction in effective fuel flow volume via displacement changes in the pump to control the runaway pressure when you can simply modify the HPFP commanded tables to achieve the same result. My table, for example, is attached (I should note that I'm still fucking with this to get the result I want). I run a 2100 rail valve so if I let pressure run away, I hit fuel cut almost immediately.
Or you could mill the pump mount to the head, or the pump, or have a custom follower bucket made. Milling the pump mount to the head is probably the best option, because there's tons of thread on the three bolts and taking 1mm off of it probably wouldn't hurt it any. There'd still probably be a fair bit of heat transmission through the bolts and via ambient air, though, so it would really be a matter of time before the pump got hot again; I just think it would take longer.
 Old 11-05-2013, 09:22 AM   #323
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I didn't think it was the best solution I would just be curious to see the effect it had
Sent from my XT1080 using Tapatalk
Damond Built Speed 6
Deldran is offline   Reply With Quote
 Old 11-05-2013, 09:36 AM   #324
Enki's Avatar
Groans: 189
I think someone needs to get their hands on an SRT4 fuel pump for analysis...last I heard, they don't have the issues we have.
 Old 11-05-2013, 09:49 AM   #325
littleloogy's Avatar
Posts: 4,005   (View Stats)
Interesting. I'll run by my buddies wrecking yard after work and see if i can't locate one.
Enki (11-05-2013)
 Old 11-05-2013, 09:56 AM   #326
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
....Um I am confused. The dart srt4 isn't really out...and the caliber erm...well doesn't have a hpfp.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
Enki (11-05-2013)
 Old 11-05-2013, 10:06 AM   #327
Enki's Avatar
Groans: 189
Guess I'm mistaken on the SRT4 part, but I am pretty sure that there's something out there with a hpfp that doesn't have issues on full corn.
86AmishMs3 (11-05-2013)
 Old 11-05-2013, 10:26 AM   #328
Ms3_Miami's Avatar
Posts: 3,185   (View Stats)
Ms3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the world
Groans: 55
335i?
Sent from my Samsung Galaxy SIII
08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold
NATOR FL
Ms3_Miami is offline   Reply With Quote
 Old 11-05-2013, 10:39 AM   #329
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
cobalt ss turbocharged
I hugged rfinkle2
The Following 3 Users Say Thank You to Easter Bunny For This Useful Post:
Deldran (11-05-2013), El_Diablo (11-05-2013), Enki (11-05-2013)
 Old 11-05-2013, 10:50 AM   #330
Enki's Avatar
Groans: 189
Skittle, SRT, Cobalt, they all look the same to me. Lol
Constantin (11-05-2013), littleloogy (11-05-2013)
 Old 11-05-2013, 11:38 AM   #331
mtosofsky's Avatar
Posts: 543   (View Stats)
mtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the world
I've read numerous cobalt forums and people are running 100% E on the stock HPFP with no issues at all. It's the only DI car I've seen run full e85 without fuel pressure issues. Even 335i's can't do it. I had a friend running 70% E with a 400lph e85 compatible lpfp and it still didnt work. His logs showed drops in fuel pressure especially between shifts.
2008 MS3 GT GTX//Relentless Customs//Voltron Approved//Nishan Tuned
mtosofsky is offline   Reply With Quote
The Following 5 Users Say Thank You to mtosofsky For This Useful Post:
Constantin (11-05-2013), El_Diablo (11-05-2013), Enki (11-05-2013), Ms3_Miami (11-05-2013), Ziggo (11-05-2013)
 Old 11-05-2013, 11:40 AM   #332
Enki's Avatar
Groans: 189
Then we need to dissect a Cobalt pump.
El_Diablo (11-05-2013), mtosofsky (11-05-2013), Tokay444 (11-05-2013)
 Old 11-05-2013, 11:40 AM   #333
Noted.
Enki (11-05-2013)
 Old 11-05-2013, 12:29 PM   #334
mtosofsky's Avatar
Been thinking this for a really long time. I've seen them making 340-350whp and 400+trq. But we all know our stock rods can't take that much torque.
Edit: just looked up some info. What trifecta tuning has done for the cobalt to run full E was to crank up fuel rail pressure and change the starting window for the injectors. Some people had experienced low fuel pressure because the lpfp wasn't providing the hpfp with enough fuel to compensate for needing a higher volume of E than compared to gas. So some people upgrade their lpfp and then are good to go. ZZP also created a stock profile camshaft that has a larger lobe for the hpfp. I've seen some of them have a roller follower on their hpfpand some have the same interal setup that we do. I don't know too much about the inner workings of these pumps so I can't speak as to why the LNF platform can support full E, but I'm hoping it can give us some insight.
The Following User Says Thank You to mtosofsky For This Useful Post:
 Old 11-05-2013, 12:59 PM   #335
Enki's Avatar
Groans: 189
We will probably have to actually take one apart to find out more; our major issue with e85 is the fact that nasty shit builds up inside and causes all sorts of mayhem. If they aren't reporting similar issues, it's probably because of a fundamental design difference in the pump.
Easter Bunny (11-06-2013)
 Old 11-05-2013, 01:08 PM   #336
mtosofsky's Avatar
Agreed. Luckily their hpfp can be had really cheap compared to ours. So it might pay to get one and rip it apart.
Cobalt SS LNF Turbo Buick Regal Direct Injection Pump 2 0 Eng | eBay
The Following 2 Users Say Thank You to mtosofsky For This Useful Post:
 Old 11-05-2013, 01:13 PM   #337
I will see if I can't get one for free first. If so, i will get it over to ENKI so he can take a look at it. No sense of spending money for no reason.
The Following 3 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (11-06-2013), El_Diablo (11-05-2013), Enki (11-05-2013)
 Old 11-05-2013, 02:10 PM   #338
Enki's Avatar
Groans: 189
That would be pretty cool. If you can get one free, let me know what shipping is and I should be able to get you that much at least. Kind of in debt up to my ass due to EFR purchase at the moment, though so buying a new one just to destroy doesn't make financial sense to me right now.
 Old 11-06-2013, 10:28 AM   #339
Raider is mah Homie
Groans: 2,978
All you see are headlights in your rearview mirror?
I hugged rfinkle2
Enki (11-06-2013), littleloogy (11-06-2013)
 Old 11-06-2013, 11:11 AM   #340
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
I'll cheap in for the pump as well if you guys can't find a free one.
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
The Following 2 Users Say Thank You to Constantin For This Useful Post:
 Old 11-06-2013, 11:13 AM   #341
mtosofsky's Avatar
This!! I'm sure we could get a few people together who are willing to chip in for the cause.
Enki (11-06-2013)
 Old 11-06-2013, 11:29 AM   #342
Enki's Avatar
Groans: 189
If it comes to that, let's not spend a whole bunch on a new pump that's only going to get destroyed.
 Old 11-06-2013, 11:35 AM   #343
My buddy sold the only cobalt block with the pump still installed. I am going to try one more place. Then its off to eBay we go...
Constantin (11-06-2013), El_Diablo (11-06-2013), Enki (11-06-2013)
 Old 11-06-2013, 08:47 PM   #344
No luck. Is the pump that what's his face posted earlier the correct one? I will hit buy it now and get it on its way.
 Old 11-06-2013, 09:17 PM   #345
Enki's Avatar
Groans: 189
Edit:
This may not be the right one.
 Old 11-16-2013, 11:21 AM   #346
I've been researching these and it seems these pumps are used in a lot of flex fuel applications. Do you know who actually makes the fuel pump for our engines? Is it bosch, denso, or maybe another company that does DGI? I am hitting a wall...
Blind people don’t see blackness, they see nothing.
 Old 11-16-2013, 12:51 PM   #347
Hitachi.
Easter Bunny (11-17-2013), El_Diablo (11-18-2013), littleloogy (11-16-2013)
 Old 11-16-2013, 06:52 PM   #348
Enki's Avatar
Groans: 189
I pulled my pump apart today to clean it due to some pressure drop I was seeing and looking at the spill valve (the only thing that appears to be having issues with full corn at the moment), it should be really feasible to have the seat milled (the part where the needle contacts that gets pried off of the spill valve assembly) and have a little tiny ptfe washer made for right there. I'm pretty sure the needle assembly doesn't see much, if any flow, and that all of it goes through the seat and button area itself (out the sides).
I'll talk to my gunsmith, but unfortunately I won't be able to test much of this stuff going forward.
El_Diablo (11-18-2013), mazdafreak (11-16-2013)
 Old 11-16-2013, 07:28 PM   #349
You still interested in seeing the SS pump?
 Old 11-16-2013, 08:40 PM   #350
Enki's Avatar
Groans: 189
Hell yeah, there's always room for analysis, and I'm sure we can locate a test car.
 Old 11-16-2013, 09:06 PM   #351
udntknw's Avatar
Posts: 1,062   (View Stats)
Maybe... Maybe we can....
just tappa it in...
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
udntknw is offline   Reply With Quote
The Following User Says Thank You to udntknw For This Useful Post:
Enki (11-17-2013)
 Old 11-16-2013, 10:06 PM   #352
I don't like using my DD for testing. But I will help fund the project. PM me your address @Enki; I. Get you the pump.
Roddiy likes this.
The Following 4 Users Say Thank You to littleloogy For This Useful Post:
Easter Bunny (11-17-2013), Enki (11-17-2013), Roddiy (11-17-2013), Spectrix (11-17-2013)
 Old 11-17-2013, 10:26 AM   #353
Spectrix's Avatar
Posts: 332   (View Stats)
Spectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the world
Groaned at 7 Times in 3 Posts
Does anyone happen to have a bit of 1/16th phenolic spacer material to cut a gasket for Enki too?
2008 Gen1 MS3
Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires.
Self tuned on E85
Spectrix is offline   Reply With Quote
 Old 11-17-2013, 11:03 AM   #354
NCspecV81's Avatar
Posts: 2,867   (View Stats)
NCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the worldNCspecV81 is the leader of the world
Groaned at 32 Times in 17 Posts
This may sound a little ghetto, but what about getting a cheap cutting board at a dollar store?
NCspecV81 is offline   Reply With Quote
 Old 11-17-2013, 11:07 AM   #355
Phenolic Material is chemical resistant. I would not want dollar store crap breaking down and getting in my fuel or oil. Why don't you try it and let us know how it goes ;-)
 Old 11-17-2013, 12:34 PM   #356
NCspecV81's Avatar
Hdpe should lend itself very well to alcohol and acid resistance.
The Following User Says Thank You to NCspecV81 For This Useful Post:
littleloogy (11-17-2013)
 Old 11-17-2013, 01:08 PM   #357
Phenolics are also carcinogens, so I wouldn't recommend just cutting some up.
Enki (11-17-2013), timjs (11-17-2013)
 Old 11-17-2013, 10:05 PM   #358
Enki's Avatar
Groans: 189
Now you tell me; I've been smoking this shit for over a month now.
Roddiy likes this.
Constantin (11-17-2013), El_Diablo (11-18-2013), phate (11-17-2013), silvapain (11-18-2013)
 Old 11-18-2013, 07:41 PM   #359
tokoam's Avatar
Posts: 199   (View Stats)
tokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant future
Groaned at 17 Times in 4 Posts
what about 335i HPFP ? my cousin runs K in his car 80% of the time and he never has any issues.Looking at his logs they look to be rather consistent pressure without any loss in pressure even between shifts.Although we have never taken it apart to inspect he has been running E for almost 2 years on JB3 tune.
tokoam is offline   Reply With Quote
The Following User Says Thank You to tokoam For This Useful Post:
Enki (11-18-2013)
 Old 11-18-2013, 07:54 PM   #360
Enki's Avatar
Groans: 189
The more the merrier, IMO.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/kings-corn-hpfp-oil-122082/
2014 Ford Fiesta ST project - Page 9 This thread Refback 08-03-2014 08:28 AM
What happened to the e85 blend thread? - Page 4 This thread Refback 02-15-2014 09:29 PM
What happened to the e85 blend thread? - Page 3 This thread Refback 01-08-2014 09:42 PM
BNR Stage 3 Turbo Upgrade - Page 7 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-01-2013 03:06 PM
Resolving HPFP corn woes (black death/sticking spill valve) Enki MazdaSpeed 3/6 - E85 Fueling 467 10-26-2014 03:50 AM
Another Corn Fed PU trf5000 2010 MS3 - ECU Computer Tuning 73 08-12-2012 09:07 AM
2 gal's of corn + chinacharger dooderek MazdaSpeed 3/6 - ECU Computer Tuning 15 01-10-2012 01:52 AM
Make hate part 10ish. - negative camber kings check in IshiKage MazdaSpeed 3/6 - Suspension & Brakes 30 05-02-2010 11:08 PM
Dale Earnhardt lives on... as 305-foot roller coaster at Kings Dominion?! [w/VIDEO] Haltech Automotive News 0 08-21-2009 09:20 AM
Page generated in 0.60870 seconds with 34 queries
