![]() | | #1 | ![]() |
![]() Join Date: Feb 2009 Location: Flanders, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 224
(Thread Starter) | Neutral : +1 score Right now my fuel gravity is .7520 and Scalar is set to 1.11 I put 4 gallons of Eth along with 8 gallons of 93 for every fill up. Are my settings off? I've looked at several threads about this but can't find a definitive answer on what to do.
__________________ 2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40// |
![]() Join Date: Jan 2009 Location: Parma, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 75
| Not Ranked : 0 score Not that it really matters...but back when I had my Cobalt on E85...the fuel trims would go crazy in the winter. Anything from +12 to -12...could never seem to get it consistent no matter what...that was when I had Vince at Trifecta tuning it to. Ran fine with no knock or any lean/rich spikes...but would occasionally take 2 tries to start up in the morning. I Tapped that
__________________ '08 Cobalt SS - 334whp- SOLD '09 WRX - Stage 1 - SOLD '12 Mazdaspeed3 |
Groans: 189
| Not Ranked : 0 score A reduction in E content in the fuel leads to a richening of the fueling; all else being equal. I'd start checking for leaks/cracks/etc.
__________________ |
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Boost_creep (10-08-2012), phate (10-08-2012) |
![]() | | #4 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well for comparison, I switched to my prior map which was tuned for 93, I'd like to add that this map was made during the winter months when it was cold. Filled it up with 93 and drove for a while that way. Trims stayed within spec which makes me think there aren't any leaks. At about 1/4 tank I put in 4 gallons of E85. At that point I started to notice the fuel trims going back up. Since then I've switched back to the E85 map just so that I'm not effing anything up. I guess I should have mentioned that info in the OP.
![]() | | #5 | ![]() |
Groans: 189
| Not Ranked : 0 score Are your maps scalar adjusted or maf adjusted for the E content?
![]() | | #6 | ![]() |
(Thread Starter) | Not Ranked : 0 score Scalar is set to 1.11
![]() | | #7 | ![]() |
Groans: 189
| Not Ranked : 0 score And you changed the specific gravity too right?
![]() | | #8 | ![]() |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score I would try .754, and a 1.12 scaler. I think this closer matches your mix, and might help. That is of course, if you are absolutely positive that you have no boost/vacuum leaks. Tuning around a mechanical issue will only cause much more aggrevation down the road
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning |
| The Following User Says Thank You to Boost_creep For This Useful Post: | phate (10-08-2012) |
![]() | | #9 | ![]() |
(Thread Starter) | Not Ranked : 0 score yeah, .752
![]() | | #10 | ![]() |
Groans: 189
| Not Ranked : 0 score If your E map scalar/FSG numbers are off, changes in airflow density could conceivably alter trims. You sure those numbers are right for the blend of E you're on right now?
![]() | | #11 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'll try that and see what happens. Obviously if the trims keep going up there is a leak, but as stated on the regular 93 map they stayed the same for 50 miles. thanks.
![]() | | #12 | ![]() |
| Not Ranked : 0 score 50 miles generally is not really enough time to fully settle. A tankful is more like it. Lol.
![]() | | #13 | ![]() |
| Not Ranked : 0 score Winter blend. E85 is usually more like E70 in the winter, as too much Ethanol leads to cold start issues. Conversely, pump gas has a higher Ethanol content in winter to reduce emissions. Tapadatass
| The Following User Says Thank You to silvapain For This Useful Post: | helmetface (11-09-2012) |
![]() | | #14 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score funny that you posted this up... after leaving gerry's house the other night, i noticed my trims at idle were about +6% when i had them dialed in at about 0.8% I did nothing to the car. Gotta check for leaks now !!But i am seriously considering testing my local 93 to see if the ethanol content is higher now.
__________________ www.tunedbynishan.com |
| The Following User Says Thank You to ms3blackmica For This Useful Post: | rfinkle2 (10-09-2012) |
![]() | | #15 | ![]() |
| Not Ranked : 0 score In the winter, ethanol content is decreased in some places. This will shift your actual fueling RICHER, meaning your trims and AFR's have gone the wrong way to consider it a tuning issue. Definitely sounds like a leak to me. Edit: OR, you put in too much e85 at your last fillup Since you're gas tune didn't change, this is a likely culprit.
![]() | | #16 | ![]() |
Groans: 189
| Not Ranked : 0 score Trims at idle are out the window. I've long since given up trying to get them perfect on ANY fuel, as it seems it will adjust based on ambient temp, engine coolant temp and boost temps (yes, even at idle).
| The Following User Says Thank You to Enki For This Useful Post: | rfinkle2 (10-09-2012) |
![]() | | #17 | ![]() |
(Thread Starter) | Not Ranked : 0 score All good points. I think I need to get a leak test done just for peice of mind. Would a place like midas be able to do something like that? No good "race shops" around here
![]() | | #18 | ![]() |
__________________ | |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Going to try and get under the hood tonight and check for leaks. Would this leak be pre-turbo? I was always told post-turbo leaks would cause a rich condition since air is escaping, not being drawn in. Someone please correct me if I'm wrong.
![]() | | #20 | ![]() |
Groans: 189
| Not Ranked : 0 score That sounds about right, yeah; somewhere between the MAF and the turbo. If any portion of your intake is made from silicone, you should probably pull it completely out and check for tears/rubbing; a while back my CPE inlet had some issues which I was able to easily patch with RTV.
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay, so a month later I'm finally going to get my car checked out. Shop I'm taking it to has a "smoke machine" which after doing some research seems like a good way to detect any leaks in my system. I've also been getting the infamous P0401 code for my EGR over the last couple of months. I know sometimes the EGR can get stuck open, could that be causing positive fuel trims?
![]() | | #22 | ![]() |
I do believe we are now running on a winter blend of fuel. I remember years ago winter blend fuels had oxygen based compounds in the fuel to help with combustion in the winter such as methyl tertiary butyl ether (MTBE) and Ethyl tertiary butyl ether (ETBE) which bring oxygen into the combustion chamber through the fuel, however I believe it is no longer used..I am not certain what is used currently for winter blends of fuel but it has thrown my trims positive by a significant amount. I thought it was funny that we both live in North Jersey and saw the same symptons at the same time. Regardless I have boost leak tested my car and my entire system holds pressure. I re-did my MAF calibration and all is well (although technically it was not necessary, I think i just had ADD lol). But i am certain I was not tuning aroud any leaks.
__________________ www.tunedbynishan.com Last edited by ms3blackmica; 11-08-2012 at 10:14 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 2 Users Say Thank You to ms3blackmica For This Useful Post: | CWP_MS3 (02-28-2013), sallyspeed3 (11-09-2012) |
![]() | | #23 | ![]() |
Still a question for anyone out there, could the infamous P0401 have anything to do with my problem?
__________________ 2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40// | |
![]() | | #24 | ![]() |
Deff just make sure you don't have any leaks both on the intake side and the exhaust side (before the primary 02 sensor). If either side has a leak it will throw it off. Fuel trims will always be changing throughout the year, but for me, it was all of a sudden +7-8% right after getting a fresh tank of gas so I knew something was up
__________________ www.tunedbynishan.com | |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well Midas smoked my intake and inter cooler pipes. Found a leak at the bpv and a leak at the coupler coming off my fmic. Going to disconnect the battery to allow ecu to reset and see what happens. Hopefully they'll come back down.
![]() | | #26 | ![]() |
Because now you can fix it !
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well fuel trims are better while driving. I'm now at 9,7, and 5 opposed to 14,12, and 7 from before. But still 19 at idle so obviously they missed something. Car smells like shit when it idles. I told them to check everything before and after the turbo plus exhaust leaks. I have a feeling they found those leaks and then called it quits. Will be taking it back, so aggravating.
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay, Im hoping some of the guru's on here can start chiming in here cause now I'm freaking stumped. Please read this and see if you can figure this shit out. Unplugged the battery yesterday before a long drive to east rutherford and back, between that and driving my wife to work tonight I put about 150 miles on the odometer. Plenty of mileage for things to settle. During that time my trims did not change from what I posted last other than the idle trims staying at about +15. I knew before the trip that I needed some more e85 so I brought along my containers and filled them up at Power Gas in east orange. Figured while I was there I should put some in the tank as well but I wasn't on empty. I put in 2 gallons of E85 and 4 gallons of regular. For reference when my gas light comes on I put in 4 gallons of E85 and 8 gallons of regular, so the ratio is the same. Not even 1 minute down the road I noticed my trims starting to come back down. By the time I got home my LTFT's are close to zero except for one breakpoint that barely gets used so it's still high. Idle trims are also down to +7 and staying steady. Does this mean that I've been getting bad gas for the last 2 months? WTF?
![]() | | #29 | ![]() |
| Not Ranked : 0 score Try to reproduce it by going back to the original station next time. If you get consistent results, it could definitely be the fuel source. But, when crazy things happen after a fillup, I usually think evap pump or purge valve going bad.
| The Following User Says Thank You to phate For This Useful Post: | sallyspeed3 (11-13-2012) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Buy an Ethanol test kit and check the fuel at the station you usually use. Tapadatass
| The Following 2 Users Say Thank You to silvapain For This Useful Post: | ms3blackmica (11-12-2012), sallyspeed3 (11-13-2012) |
![]() | | #31 | ![]() |
![]() Join Date: Aug 2009 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score I actually had something very similar just happen to me. Got E85 from a different gas station than I usually do, and it affected my fuel trims. I dunno whether I've been getting bad gas all along, or whether one station is on summer E85 while the other has switched over to the winter blend.
__________________ 08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
![]() | | #32 | ![]() |
will do, thanks. If it is in fact due to winter blends would lowering my E85 content by a gallon or two during the winter help?
| The Following User Says Thank You to sallyspeed3 For This Useful Post: | phate (11-12-2012) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score If station variance or winter/summer blends are affecting your car, you can offset this by modifying your E85/pump gas filling ratio, based on testing the Ethanol content in the E85. Tapadatass
| The Following 2 Users Say Thank You to silvapain For This Useful Post: | ms3blackmica (11-13-2012), phate (11-13-2012) |
| Need Cooler Air Temps? | Stealth01 | Mazdaspeed3/6 General Discussion | 0 | 05-04-2011 09:46 PM |
| 5W-30 and 95* Temps...? | AutoXRacer | MazdaSpeed 6 - Engine, Transmission & Driveline | 15 | 08-04-2010 01:16 PM |
| Want cooler boost temps? Check this out! | Eazy | Mazdaspeed3/6 General Discussion | 39 | 02-09-2010 03:00 PM |
| Winter Temps and higher LTFT | Speed3FTW | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 01-28-2010 05:51 PM |
| Cooler intake temps, look at the link. | ptperformance | MazdaSpeed 3/6 - Turbo Induction | 6 | 10-05-2009 02:22 PM |
