Like Tree40Likes
 Old 04-05-2012, 10:23 PM   #201
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
So Pennzoil Platinum & Ultra both come in the weights we need with the new spec...
sooooo why is everyone on VR1's dick suddenly?
 Old 04-06-2012, 05:33 AM   #202
Dunno. I'll be trying Pennzoil Platinum with my next oil change.
GLORIFIEDBOZO (04-07-2012)
 Old 04-06-2012, 06:09 AM   #203
Mizzle's Avatar
Groans: 324
Go for Ultra. It's pricey, but it really does clean the way they say it does.
The Following User Says Thank You to Mizzle For This Useful Post:
silvapain (04-06-2012)
 Old 04-07-2012, 10:23 AM   #204
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
How is it any better than the Platinum? Any data on that subject?
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
The Following User Says Thank You to Nataphen For This Useful Post:
SpeedSixxx (04-07-2012)
 Old 04-07-2012, 10:38 AM   #205
Mizzle's Avatar
Groans: 324
I can't remember where, but I saw a data sheet with some of the additive levels and they're higher in the Ultra. My car runs better after more miles on it, too (the idle anyways.)
 Old 04-07-2012, 11:52 AM   #206
Nataphen's Avatar
Groans: 31
Very conclusive.
I'll do some research on it mahself I guess.
EDIT: I did a lot of reading, and the only answer that I've come to is that PU isn't worse than PP, but nothing more. I have run PU before, but I've only done UOAs with PP. I did two different ones on the MS3, one at 6k and one at 7.5k, both came back OK. PP is fine IMO.
The Following 3 Users Say Thank You to Nataphen For This Useful Post:
Ckmazdaspeed3 (04-07-2012), GLORIFIEDBOZO (04-07-2012), silvapain (04-07-2012)
 Old 04-07-2012, 08:39 PM   #207
Mizzle's Avatar
Groans: 324
lol, I try.
I have done a UOA in a while. I'll get one on this latest one after 7k, ok baby?
 Old 04-08-2012, 06:27 AM   #208
Nataphen's Avatar
Groans: 31
Fuck it, I'm switching to Castrol GTX.
I'll get UOAs on both my MS3 and MS6 which are running PP, and we can play show me yours and I'll show you mine. The 6 needs an oil change about every month to two months, the 3 may take a little longer. I'll do both at 6k, would you do the same?
 Old 04-08-2012, 10:08 PM   #209
Mizzle's Avatar
Groans: 324
You mean 6k next time 'round? If I remember, sure.
I don't ham on it, tho, so my results will likely skew better because I rarely WOT.
 Old 04-09-2012, 07:55 AM   #210
Nataphen's Avatar
Groans: 31
The 6 gets almost all highway with very few WOT runs, and the 3 gets mostly city and more WOT, so it should give us both ends of the spectrum. The 3 currently has 59xxx miles and the 6 has 65xxx miles, just to keep things in perspective.
 Old 04-09-2012, 08:46 AM   #211
I pulled my spill valve last night for the first time since going on E50. The valve had a tan/grey film all over it, but it has yet to give me a single problem. I've been on E50 for a couple thousand miles already.
Enki (04-09-2012), GLORIFIEDBOZO (04-10-2012)
 Old 04-09-2012, 10:19 AM   #212
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Sticky film or just a deposit film?
 Old 04-09-2012, 11:39 AM   #213
I didn't check.
 Old 04-10-2012, 07:00 AM   #214
raptorous_g4's Avatar
Posts: 36   (View Stats)
raptorous_g4 has much to be proud ofraptorous_g4 has much to be proud ofraptorous_g4 has much to be proud ofraptorous_g4 has much to be proud ofraptorous_g4 has much to be proud ofraptorous_g4 has much to be proud ofraptorous_g4 has much to be proud ofraptorous_g4 has much to be proud ofraptorous_g4 has much to be proud ofraptorous_g4 has much to be proud of
after 1200 miles the valve stuck again although after warming the car up it went away after a mile or so. Polishing the internal parts did seem to help it was sticking it was happening after 300 miles before doing the dremel polishing and would not go away I would have to limp the car home and clean the coating on the spill valve. I am at 5000 miles on Rotella T6 and am changing the oil either tonight or tomorrow and clean the spill valve. Not sure what I'm going with yet but just read this on a Ferrari Forum about Shell Helix.
Walmart is the distributor for the Pennzoil Ultra, formerly Quaker State Q, and both rebadged Shell Helix Ultra.
Makes me think I may do Pennzoil Ultra... any other recommendations? also what weight are most sticking with?
Damn OIL... Just found this on Mobils site too..
Question:
Which Motor Oil Is Best for Engines Using E85 Fuel
I am using E85 fuel in a converted Honda engine originally not designed for its use. One of the primary concerns of this is the formic acid created in the event of water contamination of the fuel. I have always used Mobil 1 5W-20, but am wondering if Mobil Clean or Extended Performance would be a better choice for me. What Mobil oil has the greatest amount of acid neutralizers in it?
-- Andrew Champion, Frisco, CO
Answer:
We recommend you use a heavy duty diesel product if you want additional acid neutralizer. We recommend you try Mobil 1 Turbo Diesel Truck 5W-40 as it is based on HD diesel technology, which contains additional over-based detergents for acid neutralization.
100% E85 08.5 CWP / COBB AP / CS SRI -INLET / COBB CATLESS DP / AT HPFP / CX RACING FMIC / RACELAND COILOVERS / TRZ DOGBONE MM - TRANS MOUNT / 3" E CUTOUT at DP / MOSSBERG 930SPX IN TRUNK / .40 CAL IN POCKET FORMER 10 SECOND DSM TRANNY KILLER
| Tinkered With K04...
raptorous_g4 is offline   Reply With Quote
The Following 2 Users Say Thank You to raptorous_g4 For This Useful Post:
mazdafreak (04-10-2012), wolly6973 (04-10-2012)
 Old 04-10-2012, 08:32 AM   #215
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
^^good info! I def might try that polishing of the spill valve....idk if I missed it, u have a how-to for it?
I was gonna try the vr1, but I'm thinking 10w30 is too thick....especially being only 40 degrees in the morning to around 50 degrees in afternoon still.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 04-10-2012, 09:26 PM   #216
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
So, finally got over the vomiting and shakes from taking myself off ethanol and was just starting to get my life back on track, and then I thought just 4 gallons what could it hurt, I will swap back right away and I did. But that 4 gal put me right back to the point of shakes. I am weak willed what can I say.... I filled up on E. Oh how I missed the high.
Should be done with the first tank this week, will probably give it a few tanks and then pull the pump and see how it looks, so probably end of next week. I pulled it right before going back and it was pristine clean. So we shall see what happens.
Sent from my DROIDX using Tapatalk
The Following 6 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
Enki (04-10-2012), mazdafreak (04-10-2012), mrmonk7663 (04-10-2012), Nataphen (04-11-2012), silvapain (04-10-2012), wolly6973 (04-11-2012)
 Old 04-10-2012, 09:38 PM   #217
Enki's Avatar
Groans: 189
Rename this forum subsection to AA.
GLORIFIEDBOZO (04-11-2012), Mizzle (04-10-2012), Nataphen (04-11-2012), silvapain (04-10-2012), wolly6973 (04-11-2012)
 Old 04-10-2012, 09:41 PM   #218
Ethanolics Anonymous, where everyone wants to be the designated driver.
Mizzle likes this.
The Following 9 Users Say Thank You to silvapain For This Useful Post:
ASHMS3 (04-30-2012), cld12pk2go (04-11-2012), dot584 (04-18-2012), Easter Bunny (04-12-2012), Enki (04-10-2012), GLORIFIEDBOZO (04-11-2012), Nataphen (04-11-2012), Pseud0logik (04-12-2012), wolly6973 (04-11-2012)
 Old 04-10-2012, 10:07 PM   #219
AzSpeedin's Avatar
Posts: 47   (View Stats)
AzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to beholdAzSpeedin is a splendid one to behold
Hi, I'm Todd and I've been guzzleing this shiz for 8mo and I'm not stopping..thank u
Mfinlay04 likes this.
AzSpeedin is offline   Reply With Quote
The Following 6 Users Say Thank You to AzSpeedin For This Useful Post:
dot584 (04-18-2012), Easter Bunny (04-12-2012), Enki (04-10-2012), GLORIFIEDBOZO (04-11-2012), mazdafreak (04-11-2012), Mfinlay04 (03-08-2013)
 Old 04-12-2012, 07:11 AM   #220
I put in a bottle of sea foam in my oil ran for 5 minutes then drained it. Put in Pennzoil Ultra 5-30.. they did not have 10-30 at my Walmart. Price was $27 for a 5 Quart big bottle. Cleaned the SPV and did notice the O ring looked a bit worn.. I am keeping this in mind as my next test may hunt down some alcohol certified O rings and replace. I've got 100 miles on it since I did this yesterday and will post any problems Id say ill have 300 miles on it by Sunday. With the Rotella T6 I would see sticking after around 300 miles or 2 tanks of E85.
I am including pics of the polishing I did to the internals of the SPV. Pretty simple grab a Dremel some polishing compound (mothers mag and aluminum polish works great) and start polishing the highlighted areas in the pics keep polishing until its a mirror or chrome finish reassemble with a few drops of lubricant. I used CLP gun cleaner.
Before I polished mine after so many miles the valve would stick usually first thing in the morning PSI would stay anywhere from 45-70 car would drive hit normal pressure then buck like fuel cut and drop to the lower PSI range this would continue until I pulled the valve and cleaned. After polishing the PSI would drop as before but if I drove the car for a mile or so it would free itself up and not stick for the rest or the day even a day or 2 after so It does help. I'm hoping for positive results from the oil change over. Hope this helps.
mazdafreak likes this.
mazdafreak (04-12-2012), Nataphen (04-12-2012)
 Old 04-12-2012, 08:09 AM   #221
Mizzle's Avatar
Groans: 324
If polishing helps this much, the makers of the internals should:
a.) Account for polishing in their machine work.
b.) Polish them before we get them, especially for the price paid.
 Old 04-12-2012, 09:16 AM   #222
franz's Avatar
Posts: 1,258   (View Stats)
franz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the world
I think he is only polishing the spill valve so it would only be applicable to whole pumps not internals.
Sent from the ether.
2007 MS3 Black Mica. Stock. 235whp/244wtq Dynojet
FREEKtuned 277/316 Dynojet
Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat
Bilstein B8/Swift Spec-R/ST120s/Nitto 555
JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC
franz is offline   Reply With Quote
The Following 2 Users Say Thank You to franz For This Useful Post:
phate (04-12-2012), wolly6973 (04-12-2012)
 Old 04-12-2012, 09:17 AM   #223
He didn't polish the internals. He polished the part of the pump housing the internals sit in, and the spill valve.
 Old 04-12-2012, 09:34 AM   #224
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
What may also be helpful to polish is the tip of the spill valve plunger. The piece which protrudes through the collar.
Many times when I pulled my spill valve apart, there was slight buildup in there and you could feel it dragging. That's the point which I always thought was the problem.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 04-12-2012, 11:06 AM   #225
Correct.. DO NOT Polish the actual HPFP internals / piston. You will remove the coating and more than likley lose FP or damage it.
 Old 04-12-2012, 12:16 PM   #226
mazdafreak's Avatar
Groans: 124
Anyone think I should run the vr1 10w30 or just run the ultra?
And I'm def gonna polish that spv hopefully this week or next week...since I'm switching to full 85 next week.
713whp/569wtq!
 Old 04-12-2012, 09:12 PM   #227
Mizzle's Avatar
Groans: 324
Do one, UOA.
Do the other, UOA.
 Old 04-12-2012, 09:42 PM   #228
mazdafreak's Avatar
Groans: 124
Do one, UOA.
Do the other, UOA.
Yeah I was, I think its still a lil too cold for the 10w30 here.
713whp/569wtq!
 Old 04-12-2012, 10:09 PM   #229
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
try the sapphire blue VR1...
it costs near the same as the ultra and it's not as easy to get.
Ive used both and honestly they both felt great and looked good after 3000 miles...
I like the VR1 because it's valvoline and they my fav..
DO NOT mix Valvoline VR1 with ANY other oil...
I did my research on VR1, called the tech support on the back and asked questions...
as most other oils conventional and synthetic you shouldn't mix different brands but when it comes to oils such as Ultra and VR1 it's a MUST NOT...
VR1 Racing Oil (VR1)
The #1 selling racing motor oil. High zinc provides race-level protection for any vehicle.
High zinc/phosphorus provides extreme wear protection, including flat tappet applications
Additional friction modfiers to help deliver maximum horsepower
Enhanced anti-foam system protects engine during extreme stress
Compatible with gasoline or alcohol fuels
Available through leading auto parts retailers
Valvoline.com > Products > Racing > Racing Motor Oil Racing > VR1 Racing Oil (VR1)
The Following 2 Users Say Thank You to SpeedSixxx For This Useful Post:
GLORIFIEDBOZO (04-13-2012), mazdafreak (04-12-2012)
 Old 04-12-2012, 10:22 PM   #230
mazdafreak's Avatar
Groans: 124
@SpeedSixxx thanks for the good info! I have heard great things about vr1! But my only concern is that its still ~50-60 degrees here and there...haven't rly had the best weather yet.
You still think ill be good with 10w30? Pretty thick oil for not that warm off weather yet.
713whp/569wtq!
SpeedSixxx (04-12-2012)
 Old 04-12-2012, 10:41 PM   #231
Roddiy's Avatar
Posts: 5,388   (View Stats)
Roddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the world
Groans: 279
Groaned at 58 Times in 47 Posts
So thats what it comes down to? The Oil?
@Enki, do you have any plans to re-do your test with another oil instead of T6?
Penzoil Ultra seems to be a good candidate from what I gathered.
2010 LSM Speed3
Bolted + Corn + Meth + ACT 6-Puck
#BakeryTuned
Roddiy is offline   Reply With Quote
 Old 04-12-2012, 10:42 PM   #232
Enki's Avatar
Groans: 189
I certainly can.
GLORIFIEDBOZO (04-13-2012), silvapain (04-13-2012)
 Old 04-12-2012, 10:43 PM   #233
Roddiy's Avatar
Groans: 279
I think your method is a very valid way of getting a quick answer as to what oils cause the black death.
Also, where did you get that plate from? @jbarone?
2010 LSM Speed3
#BakeryTuned
 Old 04-12-2012, 10:49 PM   #234
SpeedSixxx's Avatar
Groans: 778
is that the only weight they have?
if not 60 degrees really isn't so bad...
how many miles on your engine? I wouldn't be so worried if you have a good amount of mile son the motor as the clearances aren't what they once were...
Not to mention the new recommended oil weight by Mazda is 5w40....10w30 i've used before and I never had an issue.. just let it warm up a bit and don't get on it for the first 10-15 min of driving..
good luck!
anyone recommend an oil testing lab I can send my oil to?
I use different brands of oil every few oil changes just cause...
I'd love to test the differences after 3000 miles on each type...
I use.
Valvoline Syn
Ultra
Rotella T6 Syn
Platinum
AMS oil....
what do I send the oil in? a test tube?...lol
 Old 04-12-2012, 10:59 PM   #235
Enki's Avatar
Groans: 189
The sample plate was from Jet-Hot, the hotplate was from Amazon.
 Old 04-13-2012, 07:29 AM   #236
Shawn it gets into the 40's in the morning here, and no issue's
good luck!
I use.
Valvoline Syn
Ultra
Rotella T6 Syn
Platinum
AMS oil....
VR1 Synthetic comes only in 10w-30 and 20w-50. Mazda recommends 5-30 I believe
Blackstone Labs is where I do mine. They will send you a test kit for free. Just order it well in advance, my first test kit took forever to show up.
The Following User Says Thank You to GLORIFIEDBOZO For This Useful Post:
SpeedSixxx (04-13-2012)
 Old 04-13-2012, 07:51 AM   #237
SpeedSixxx's Avatar
Groans: 778
ty...
I must have used the 10w30 then.
worked great.
 Old 04-13-2012, 07:56 AM   #238
mazdafreak's Avatar
Groans: 124
good luck!
I use.
Valvoline Syn
Ultra
Rotella T6 Syn
Platinum
AMS oil....
Yeah, like jay said, only 20w50 or 10w30......but it looks like my gonna give 10w30 vr1 a try this weekend...then switch to full 85 next week and see what happens! Also need to polish the spv.....and I have 38,5xx miles on my car.
Ahh good to kno! It's also 40 degrees here in the a.m....and around 50-60 in the day...ill def be giving vr1 oil a try then!
713whp/569wtq!
 Old 04-13-2012, 08:38 AM   #239
Damn we get 70-80's in the day, well this week has been a bit chilly
 Old 04-13-2012, 01:31 PM   #240
Roddiy's Avatar
Groans: 279
80 during the day here, and summer is just getting started lol.
2010 LSM Speed3
#BakeryTuned
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f567/resolving-hpfp-corn-woes-black-death-sticking-107141/
/v/ - Vehicles This thread Refback 03-05-2014 09:35 PM
HOW TO: Remove & Disassemble HPFP Spill Valve silvapain MazdaSpeed 3/6 - E85 Fueling 139 04-09-2018 04:02 AM
Spill valve spring mod Enki MazdaSpeed 3/6 - E85 Fueling 15 02-02-2014 11:01 AM
HOWTO: Spill Valve SST Enki MazdaSpeed 3/6 - E85 Fueling 9 02-17-2012 09:07 AM
hpfp woes 37HSSV 2010 MS3 - Engine, Transmission & Driveline 5 11-14-2011 09:00 AM
HPFP Woes 37HSSV 2010 MS3 - Troubleshoot/Diagnostics 9 11-13-2011 03:44 PM
Page generated in 0.59309 seconds with 32 queries
