> VersaTune
VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting.
Like Tree2Likes
 Old 03-24-2016, 07:50 AM   #1
Eth Fiend
phate's Avatar
Posts: 6,935   (View Stats)
Default SWAS issues
It happens, almost without fail, in big left handed turns where I'm straightening out and going full throttle. The 'Disable Torque Limiter' toggle is checked. I've attached logs, but here's a couple screenshots of the issue.
I've attached my tune file and 3 logs. The particular ranges I'm looking at in each of the logs:
1_31_57: 142-144s
1_38_58: 712-715
1_55_31: 732-754
@Steve@VersaTune;
@Ugnius@VersaTune;
I don't see anything in the tune that would cause it, so I'm curious what you guys think. Thanks for all your help!
-06 MS6
-Corn fed 07 MS3 - Sold
dsb_chicago (05-02-2016), Enki (03-24-2016), Mazdazilla6 (03-24-2016), MS3Shadow (03-24-2016), SofaKingAwesome (03-24-2016), Vansquish (03-24-2016), xfeejayx (03-24-2016)
 Old 03-24-2016, 02:32 PM   #2
Polish_Eagle's Avatar
Posts: 403   (View Stats)
Polish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the world
I've experienced this too, and I'm pretty sure I've mentioned before as well. Since the SWAS disable doesn't 100% work I still use the SWAS disable switch unfortunately.
Here's the link and also, when I was testing I had semi slick track tires which didn't slip: 2011 SWAS Issue
Oh, I also think you need to push the "DSC Off" button in the car so DSC isn't interfering. Try pushing that button and then taking logs to see if that helps. I know for me it didn't as I had my AFR's dip into the 9's and you can feel SWAS affecting things.
2011 MAZDASPEED3 Hypnotic Tuned - Rob
CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) -
Polish_Eagle is offline   Reply With Quote
The Following 2 Users Say Thank You to Polish_Eagle For This Useful Post:
Gnostic1 (05-03-2016), phate (03-24-2016)
 Old 03-24-2016, 02:49 PM   #3
Eth Fiend
phate's Avatar
DSC is most definitely always off, so not a worry about that. The SWAS sensor in ms6's controls part of the awd system. Unhooking it disables awd, so that's out of the question.
-06 MS6
Enki (03-24-2016), TiGraySpeed6 (03-24-2016)
 Old 03-25-2016, 04:26 PM   #4
Steve@VersaTune's Avatar
Posts: 431   (View Stats)
Steve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the world
The ECU is definitely pissed off. It fuel cut at 142.626s in 1_31_57. RPMs are up and down. Were you spinning an inside wheel?
edit: same thing in 1_38_58. Sharp rpm rise then fuel cut.
Could also be a lateral G force limit induced torque reduction by the DSC module that the button doesn't mask.
Steve
Lead Tuner
Steve@VersaTune is offline   Reply With Quote
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Gnostic1 (05-03-2016), phate (03-25-2016)
 Old 03-25-2016, 05:25 PM   #5
Eth Fiend
phate's Avatar
We may have occasionally spun an inside tire, but not every time. Sometimes I'll just wait until the wheel is nearly straight to apply more throttle, and it will still cut with throttle application.
We pull over 1g lateral, and it only happens after sustained cornering, not after quick maneuvers. All of my videos from Saturday were corrupt, so I don't have a good example (you can hear the car pop and stutter when it happens). If it is g-force induced, is there any hope of it getting tuned out?
-06 MS6
 Old 03-25-2016, 05:51 PM   #6
I'm looking at it. I have an idea that I need to do some testing with.
Steve
Lead Tuner
The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (03-25-2016), phate (03-25-2016), Tomas (03-30-2016), xfeejayx (03-28-2016)
 Old 03-25-2016, 06:15 PM   #7
Eth Fiend
phate's Avatar
Awesome, thanks. We autocross every 2 weeks or so during the season, so if you need testing done I can help with whatever you need.
-06 MS6
Enki (03-25-2016)
 Old 03-28-2016, 05:54 AM   #8
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Leave it to phate to find a lateral G force limit.
In for testing if you need/want/would like a second car.
-Wetz
QFT
The Following 4 Users Say Thank You to xfeejayx For This Useful Post:
Enki (03-28-2016), MS3Shadow (03-28-2016), phate (03-28-2016), WetzMS3 (03-28-2016)
 Old 03-28-2016, 06:27 AM   #9
Eth Fiend
phate's Avatar
-06 MS6
Enki (03-28-2016), Hargarbl (04-03-2016), WetzMS3 (03-28-2016), xfeejayx (03-28-2016)
 Old 03-30-2016, 10:05 AM   #10
Eth Fiend
phate's Avatar
We're autocrossing on Sunday, again. Steve, if you would like us to try anything or capture anything specific in the data, let us know and we'll do it! I'll have my accelerometer logging this time around, so that data should be available, too.
-06 MS6
 Old 03-30-2016, 10:20 AM   #11
Working on a new build for you with some new tables.
Steve
Lead Tuner
The Following 9 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (03-30-2016), mazdakaps (03-31-2016), meicalnissyen (08-28-2016), MS3Shadow (04-01-2016), phate (03-30-2016), Polish_Eagle (03-30-2016), SofaKingAwesome (03-30-2016), WetzMS3 (03-30-2016), xfeejayx (03-30-2016)
 Old 04-01-2016, 05:17 AM   #12
Sent you a link to a new VT to test. Check your spam folder if you don't see it.
Steve
Lead Tuner
The Following 6 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (04-01-2016), MS3Shadow (04-01-2016), phate (04-01-2016), SofaKingAwesome (04-01-2016), WetzMS3 (04-01-2016), xfeejayx (04-01-2016)
 Old 04-03-2016, 09:15 PM   #13
Any improvement?
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
phate (04-04-2016)
 Old 04-04-2016, 06:42 AM   #14
Eth Fiend
phate's Avatar
Any improvement?
No, still cutting after long left handers. I'll send (or post) data logs and the tune file for you guys to check out. Long day yesterday, still went fast enough to take the class
-06 MS6
Enki (04-04-2016), SofaKingAwesome (04-05-2016)
 Old 04-04-2016, 08:22 PM   #15
Eth Fiend
phate's Avatar
Any improvement?
I've attached all of the logs from Sunday. Here's the summary (included in the .rar):
Essentially, I took anything and everything that might be causing an issue out of the tune. Tune file included, please let me know if I missed any tables that you were thinking of.
You can see and hear in this video around 32s where it happens after the big left hander:
-06 MS6
Enki (04-04-2016), kolosok17 (04-08-2016), SofaKingAwesome (04-05-2016)
 Old 04-04-2016, 08:34 PM   #16
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Christ almighty.
kolosok17 (04-08-2016), phate (04-04-2016)
 Old 04-05-2016, 03:26 AM   #17
KCi
KCi's Avatar
Posts: 93   (View Stats)
KCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond reputeKCi has a reputation beyond repute
Off topic: The video log looks cool. What software / hardware is this?
KCi is offline   Reply With Quote
The Following User Says Thank You to KCi For This Useful Post:
phate (04-05-2016)
 Old 04-05-2016, 06:13 AM   #18
Eth Fiend
phate's Avatar
Race Render 3 is the video software. It can handle time based data, so data logs are perfect to overlay. In my case, I have a GoPro taking video, VT logs exported to CSV format, and a GCDC 3-axis 2g accelerometer for the G-G plot (smoothed from 128Hz sample rate in this case).
-06 MS6
KCi (04-05-2016)
 Old 04-05-2016, 01:48 PM   #19
Eth Fiend
phate's Avatar
@mazdakaps you might need to download it again
WetzMS3 likes this.
-06 MS6
Enki (04-05-2016), mazdakaps (04-05-2016), MS3Shadow (04-06-2016), SofaKingAwesome (04-05-2016), WetzMS3 (04-05-2016)
 Old 04-05-2016, 11:52 PM   #20
mazdakaps's Avatar
Posts: 133   (View Stats)
mazdakaps has a reputation beyond reputemazdakaps has a reputation beyond reputemazdakaps has a reputation beyond reputemazdakaps has a reputation beyond reputemazdakaps has a reputation beyond reputemazdakaps has a reputation beyond reputemazdakaps has a reputation beyond reputemazdakaps has a reputation beyond reputemazdakaps has a reputation beyond reputemazdakaps has a reputation beyond reputemazdakaps has a reputation beyond repute
Lol how did this happen? I only download it once. Oh well!!!
mazdaspeed3 Gen1: Manley pistons, eagle rods, L19 studs, 3.5" intake, FMIC AMS, map 3.5 bar, Cobb accessport, Cobb solenoid valve, 3" catless DP, HKS exhaust, EFR 7163
mazdakaps is offline   Reply With Quote
The Following User Says Thank You to mazdakaps For This Useful Post:
phate (04-06-2016)
 Old 04-06-2016, 08:05 AM   #21
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 283
If the downloader uses multi-threading to increase downloads, it'll appears as a another download for each connection.
sent from my Nexus 6P
The Following 2 Users Say Thank You to MS3Shadow For This Useful Post:
Enki (04-06-2016), mazdakaps (04-06-2016)
 Old 04-08-2016, 12:56 PM   #22
xfeejayx's Avatar
Groans: 78
@Steve@VersaTune;
Weather depending, racing this weekend. Anything specific you want to see? Will attempt phate type log, but...slower.
-Wetz
QFT
The Following User Says Thank You to xfeejayx For This Useful Post:
phate (04-08-2016)
 Old 04-08-2016, 01:27 PM   #23
Nothing right now. I am still looking. Thanks for the offer.
Sent from my SM-G900V using Tapatalk
Steve
Lead Tuner
phate (04-08-2016), xfeejayx (04-08-2016)
 Old 04-11-2016, 09:24 PM   #24
Eth Fiend
phate's Avatar
@xfeejayx, have you gotten any cuts in either of the 6's?
@Steve@VersaTune, I'll be autocrossing again this coming Sunday, do you want me to test any tables or grab different fields in the data logs?
-06 MS6
 Old 04-12-2016, 03:59 AM   #25
xfeejayx's Avatar
Groans: 78
Hadn't been looking. Was going to look specifically for it this past weekend, but got rained out.
Have an ax Saturday, and potentially one Sunday.
Sent from my Nexus 5 using Tapatalk
-Wetz
QFT
phate (04-12-2016)
 Old 04-12-2016, 11:57 PM   #26
A beta is in the works. Should have something to you shortly.
Steve
Lead Tuner
mazdakaps (04-13-2016), mituc (04-14-2016), phate (04-13-2016), Polish_Eagle (04-13-2016), WetzMS3 (04-13-2016), xfeejayx (04-13-2016)
 Old 04-19-2016, 09:10 AM   #27
Eth Fiend
phate's Avatar
May have found the culprit and might owe the VT guys some beers for creating extra work. I popped a P2088 code a few weeks ago, but cleared it because it was pretty random. It came back after the car was cutting especially hard this weekend, so thought I better check it out...
I'll repin tonight and see how it goes.
-06 MS6
The Following 8 Users Say Thank You to phate For This Useful Post:
broda (04-19-2016), Code Monkey (04-19-2016), Enki (04-19-2016), mazdakaps (04-20-2016), Nliiitend1 (04-19-2016), SofaKingAwesome (05-03-2016), Ugnius@VersaTune (04-22-2016), WetzMS3 (04-19-2016)
 Old 04-19-2016, 10:13 AM   #28
xfeejayx's Avatar
Groans: 78
Just checked our logs from the weekend. No RTP reduction below 6k; slaloms, sweepers, whatever. I imagine this will address your issue.
-Wetz
QFT
nindoja (04-20-2016), Nliiitend1 (04-19-2016), phate (04-19-2016), SofaKingAwesome (05-03-2016)
 Old 04-20-2016, 04:12 PM   #29
Eth Fiend
phate's Avatar
I reworked that connector and the car is pulling cleanly now in straight lines. Dragon this weekend, then another autocross the weekend after. I'm going to revert back to the current public release of VT and my old tune to test things out. Hopefully everything is fixed!
-06 MS6
Enki (04-20-2016), Nliiitend1 (04-22-2016), Ugnius@VersaTune (04-22-2016)
 Old 05-02-2016, 11:24 AM   #30
Eth Fiend
phate's Avatar
I won't call yesterday's event conclusive, because there weren't any long left handers. But, the car pulled cleanly every time we asked for it
Next event in 2 weeks.
-06 MS6
Enki (05-02-2016), SofaKingAwesome (05-03-2016)
 Old 05-03-2016, 12:49 PM   #31
MSP6's Avatar
Posts: 1,246   (View Stats)
MSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the worldMSP6 is the leader of the world
Shouldn't you be Skyping with Fiat right now??
Speed 6 Gone for 3+ years and still not happy about it
2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP
Enki - "High mixes of corn = all the wastegate all the time for great justice."
MSP6 is offline   Reply With Quote
The Following User Says Thank You to MSP6 For This Useful Post:
phate (05-03-2016)
 Old 05-03-2016, 12:56 PM   #32
c_bye's Avatar
Posts: 67   (View Stats)
c_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to beholdc_bye is a splendid one to behold
I get this cut-off on sweeping turns on power as well.
I haven't done this, but I've heard you have to completely disable the SWAS sensor which is under the steering column but you need to remove all the shrouding to get to it.
What I've done is on startup hold the DSC button and that will disable both DSC and Traction Control. I've gotten good results this way, but you have to be careful of lift-off oversteer!
2008 Cosmic Blue MS3 GT // CS TD05-18G Turbo // Freektuned //Denso ITV22 // CS DP // CS 3.5" Full Intake // CS 3.5 Bar Map // CNT Catback // CS HPFP // JBR FMIC Piping // Treadstone TR8 FMIC // CS OCC // CS Heat Sheilds // CS boost hoses // CS ECU relocation // Cobb AP3 // Cobb RMM // HKS SSQV 4 // CS Short Shifter // CS Short Shift plate // Fifteen52 18x9 Tarmacs // Hankook RS3 235/40 // Koni Yellows // GC Coilovers // CS F&R Sway Bars // CS front Endlinks // Whiteline rear Endlinks // GC bump stops // CS mid chassis brace // Megan front H brace // CS rear strut tower bar // Stoptech rotors/pads/ss lines // DG carbon spoiler // DG carbon bumper cover // V2 Side Skirts // STi Lip // CS Antenna // CS Lisence plate relocator // CS LED Fogs // PIAA yellow high beams // Pioneer NEX-7100 // Prosport Premium gauges (Boost/OP/OT) // CP-E Gauge Pod // TWM Shift Knob // Sparco Pedals // Royal Purple 5w/30
c_bye is offline   Reply With Quote
The Following User Says NO Thank You to c_bye For This Un-useful Post:
 Old 05-03-2016, 01:12 PM   #33
xfeejayx's Avatar
Groans: 78
You're likely just getting traction/stability control action mid corner when DSC is on. Most people probably don't even know what SWAS cut feels like. It's like turbo lag more than cut.
Don't have to hold button on MS6, just tap it. It does NOT disable SWAS cut.
Disabling that sensor does more than just disable SWAS, I think.
-Wetz
QFT
phate (05-03-2016)
 Old 05-03-2016, 02:29 PM   #34
Eth Fiend
phate's Avatar
Done!
Check here. MS6 is a little different.
-06 MS6
 Old 05-03-2016, 03:42 PM   #35
c_bye's Avatar
Done!
Ah I see, disregard what I said before then. I can only speak for the MS3.
The Following User Says Thank You to c_bye For This Useful Post:
phate (05-03-2016)
 Old 05-03-2016, 03:54 PM   #36
My 2011 MS3 suffers from powerless mid corner (rich AFR's and little power), once I straighten the wheel out I feel full power. I then disable my SWAS with the switch I wired in and the powerloss no longer happens.
 Old 05-03-2016, 04:33 PM   #37
Enki's Avatar
Groans: 189
From what I remember, holding the button only turns on the lights for testing and doesn't actually fully disable anything. I've had my light come on simply because I hit the button too fast after starting it, no holding needed. Car didn't behave any differently either.
 Old 05-03-2016, 05:00 PM   #38
c_bye's Avatar
Right, like I said you have to physically unplug it under the dash for it to actually disable.
It was probably just me, but I did notice the back end stepping out a bit more on track than with both DSC off and traction control light on.
 Old 05-24-2016, 08:49 AM   #39
Eth Fiend
phate's Avatar
No dice on the connector being the culprit. I flashed back to the pre-beta tune and autocrossed yesterday with a HUGE nascar style left handed oval. After straightening out into the next section, the car cut out just like it used to.
I'll work back through to see if I can find a fix. I'll start with the tables that became available in 1.10.11, then move to the tables available in 1.10.13.
Video of the course. Too much wind noise to hear the cut, this time.
-06 MS6
Code Monkey (05-24-2016), Enki (05-24-2016)
 Old 05-25-2016, 05:18 AM   #40
xfeejayx's Avatar
Groans: 78
http://youtu.be/MuFV8qb6Ohk
I briefly looked at the logs from our last ax, didn't see any cut after the left sweeper. Will go through them in more detail.
-Wetz
QFT
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 06:23 PM
SWAS question. JSmith Gen2 MS3 General Discussion 3 12-22-2012 12:13 PM
WTF is happening? SWAS? jordan11b 2010 MS3 - ECU Computer Tuning 31 05-01-2012 07:39 PM
Going over ~19psi, SWAS issues adlpb 2010 MS3 - ECU Computer Tuning 15 11-22-2011 03:04 PM
Page generated in 0.60825 seconds with 30 queries
