> HTP (Hi-Tuned Performance)
HTP (Hi-Tuned Performance) HTP (Hi-Tuned Performance) is dedicated to providing the automotive community with quality performance products and the highest level of customer service and support. Whether you're local or overseas, we like to approach each customer as though they're sitting right in front of us at the shop. Whether you're a long time customer or if you're new to HTP, we look forward to having the opportunity to prove our commitment to quality and service.
Like Tree47Likes
 Old 01-24-2013, 09:12 AM   #121
JDW1's Avatar
Posts: 486   (View Stats)
JDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the world
Obviously something seems off but my logs are super clean except for unusually high g/s
07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out.
11 Mustang GT current.
JDW1 is offline   Reply With Quote
 Old 01-24-2013, 09:16 AM   #122
Yup something is off and the strange thing is that different cars are off by different amounts. What is worse is that the higher the airflow the more off the curve becomes. Ugh. Sorry for the guys chasing boost leaks. We'll get this sorted.
GODspeed7 (01-24-2013), rfinkle2 (01-24-2013)
 Old 01-24-2013, 09:18 AM   #123
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
+1 ^^^ LOL.
 Old 01-24-2013, 09:23 AM   #124
Voltwings's Avatar
Posts: 3,713   (View Stats)
I find it odd that at 20 psi and 93 octane alone you're running a Higher IDC than i was at 23 psi on 4 gallons of E85... i was barely in the Mid 80's at a 12.4 AFR, but you're seeing over 90 at an 11.8 on 93. I hate to come in here and sound like i'm the one that figured everything out because lex pretty much already nailed it :/ off MAF curve, or more ethanol in the fuel than we're lead to believe. Interesting.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following User Says Thank You to Voltwings For This Useful Post:
 Old 01-24-2013, 09:25 AM   #125
GODspeed7's Avatar
Posts: 3,456   (View Stats)
I just chocked it up to finkle being over worked and under paid just like me. He says boost leak on high side, I said impossible! Lol unless those stock DP bolts are backing themselves out which I doubt since they are hard as hell to break loose, has to be another problem! Can't wait to be a test dummy as long as my car doesn't blow up!
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
 Old 01-24-2013, 09:26 AM   #126
rfinkle2's Avatar
Groans: 298
Not on my watch!
ricknm (01-24-2013)
 Old 01-24-2013, 09:37 AM   #127
aldekei's Avatar
Posts: 831   (View Stats)
aldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the world
I'm having my car smoked right now to definitively rule out a leak and will report back when I pick up my ride.
On the 2 piece bikini model, I'm measuring 2.846" ID.
tapawhat
HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke
CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust
Beachshoer Intake Manifold P/P /w VTCS Delete
Sure Shortcut | Sure Anchors | Sure 1/8 TIG
Cobb AP | Cobb FMIC | Cobb Sport Springs
ATP GT3071R /w Stratified Boost Dial
Stratified Automotive Guardian Angel
Go Fast Bits Respons (100% VTA)
Autotech Internals
I tune myself, bitches
aldekei is offline   Reply With Quote
The Following 3 Users Say Thank You to aldekei For This Useful Post:
Lex (01-24-2013), Pointless (01-25-2013), rfinkle2 (01-24-2013)
 Old 01-24-2013, 09:52 AM   #128
JDW1's Avatar
Something is definitely weird and I know i'm no pro but i'm no noob either. If my MAF curve was so of then how am I at a most of a .2 variance of my commanded WOT AFR? My cruising LTFT's were pulling ~9 with the 3" Sure cal from @Lex; so I made a revision last night and scaled it back a tad. Every adjustment I've made to the WOT range the AFR's have responded accordingly so does that still mean on over scaled, I feel like I'd be super lean if I went with that assumption and kept scailing back the curve.
As for a boost leak, again AFR in spec, WGD barely working to hold my 20 and decreasing through the range. I'll do a test this weekend and report back.
 Old 01-24-2013, 09:57 AM   #129
Voltwings's Avatar
well the 390 g/s log was pig rich, almost 10.5, which would mean an off MAF cal, however your other log was running more consitant high 11's and making about ~370 g/s which seems much more reasonable... still a tad high i feel but much better. Granted i believe you're on a speed6 and i've never tuned one, maybe you guys just generate that much more load which reflects in your maf cal.
Past:
-Sold-
-Sold-
Current:
 Old 01-24-2013, 10:02 AM   #130
JDW1's Avatar
That 390 in the mid high 10's was the 3"Sure cal untouched. I've since made 2 revisions to the WOT range. My loads have been as high as 2.7 tapering to maybe 2.2/2.3 by redline. I can do another log tonight and post, I'm very curious about this.
 Old 01-24-2013, 10:08 AM   #131
Voltwings's Avatar
Yeah just checked my last set of logs and again, 25 psi im only hitting max 2.65 load. The awd must have something to do with it im guessing.
Past:
-Sold-
-Sold-
Current:
JDW1 (01-24-2013)
 Old 01-24-2013, 10:22 AM   #132
There is an inconsistency that bothers me. I have an MS6 that the following MAF cal works well for for the HTP 3"
Code:
0	0	0	0	0	0	0	0	0	0.02288	0.0572	0.08008	0.13728	0.19448	0.27456	0.35464	0.4576	0.56056	0.69784	0.84656	1.00672	1.16688	1.36136	1.56728	1.80752	2.0592	2.33376	2.6312	2.95152	3.30616	3.69512	4.15272	4.62176	5.0908	5.74288	6.267386	6.791893	7.316399	8.233679	8.867039	9.554999	10.34124	11.20392	12.08844	13.09308	14.18508	15.288	16.4892	18.10536	19.14276	20.16924	21.19572	22.23312	23.76192	25.389	27.0816	28.8834	30.75072	32.71632	34.76928	36.89868	39.10452	41.3868	43.76736	46.23528	48.79055	51.44412	54.19596	57.057	59.08812	61.10831	63.13943	66.19703	69.30923	72.48695	75.75204	79.09355	82.53336	86.06051	89.71872	98.20355	102.3095	106.5246	110.838	115.2824	119.8033	124.4006	129.0635	133.8355	138.7277	143.729	148.8614	151.1225	153.3836	155.6446	161.0809	166.7025	172.4683	178.3988	184.4631	190.6716	197.0242	203.5313	210.1825	216.9779	223.8968	230.9496	238.1568	245.5184	253.0242	260.705	268.5506	276.5608	284.7462	293.1065	301.6316	310.342	319.2172	328.2777	334.1381	343.4851	352.9951	362.6888	372.5862	382.6671	392.9315	403.4099	414.0719	424.9377
At the same time, one of the MS3s is almost getting MAF cut (4.85V) at 22psi on the BNR which essentially means the intake up top acts like a COBB SRI.
I am asking these guys if the have the straightener and if both intakes are powdercoated.
 Old 01-24-2013, 10:27 AM   #133
CorkSport's Avatar
Posts: 3,416   (View Stats)
CorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the world
Originally Posted by beachshoer View Post
Just installed my Granny Smith Green 3" intake and it looks fantastic.
Also......Tootsie Pops Katie? Nice Touch! Ryan was jealous.
That green is awesome!
-Derrick
WWW.CORKSPORT.COM
CorkSport is offline   Reply With Quote
The Following User Says Thank You to CorkSport For This Useful Post:
HTP (01-24-2013)
 Old 01-24-2013, 10:28 AM   #134
Voltwings's Avatar
Code:
i plugged that curve into my old 3" maf tune, and that MAF curve is substantially less than the 3" curve i was running. Do you really think the powdercoating would take up THAT much of the ID?
Past:
-Sold-
-Sold-
Current:
 Old 01-24-2013, 10:29 AM   #135
Can one of you guys with the intake take a picture straight on looking into the intake to have a good look at this straightener?
 Old 01-24-2013, 10:29 AM   #136
JDW1's Avatar
Code:
I'll have to wait till I get home tonight and see how that compares to how I've scaled mine so far. I'd be glad to send it to you if you wanted another example.
 Old 01-24-2013, 10:30 AM   #137
No, the pipe is smaller to begin with, and the straightener is probably adding to the problem.
Voltwings (01-24-2013)
 Old 01-24-2013, 10:34 AM   #138
Voltwings's Avatar
like it would be diverting air away from the MAF at high load so it reads less? or just the fact its taking up space?
Past:
-Sold-
-Sold-
Current:
 Old 01-24-2013, 10:42 AM   #139
JDW1's Avatar
The honeycome style is def taking up space.
The Following User Says Thank You to JDW1 For This Useful Post:
 Old 01-24-2013, 10:45 AM   #140
Voltwings's Avatar
Duh, brain fart i forgot they use honeycombs. i was thinking it was like the Sure, corksport... ones that have like a crosshairs design. Was thinking if it wasnt pointing exactly straight it could push air away from the sensor but that apparently isnt the case.
Past:
-Sold-
-Sold-
Current:
 Old 01-24-2013, 10:49 AM   #141
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
Just throwing this out there. Lex and finkle are going to be the experts here, but I have seen a few mentions of OL trimming in here and references to Gen2 vs Gen1 vs MS6 differences. Obvioulsy @Lex; has tuned a ton more cars than I, but I know for a fact my MS6 does at least some OL trimming.
Been running a 3/10 E85/93 mix since summer, now it is dead of winter in MN so we are surely on E70. I have also gone to 2.5/10.5 recently and no matter what, my WOT OL trims are always spot on my 12.0 target. Even when I first started running E way back, I think I started by dumping 2gal in a full tank and made no adjustments to the tune. Still was hitting WOT targets like a boss.
Just wondering if this could be contributing to some of the discrepencies, especially with JDW1 and his high flow numbers
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
The Following 3 Users Say Thank You to BigjohnB20 For This Useful Post:
Lex (01-24-2013), rfinkle2 (01-24-2013), Voltwings (01-24-2013)
 Old 01-24-2013, 10:53 AM   #142
Cyclops's Avatar
Posts: 290   (View Stats)
Cyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the worldCyclops is the leader of the world
@Lex; Here is the picture you asked for. It's not the clearest but hopefully this will help.
2008.5 Mazdaspeed 3 GT True Red
BNR S3. HTP Full 3.5" Intake. Self Ported Intake Mani. CorkSport Catless DP. UR Test Pipe. CXRacing Piping w/ TR8. GFB Respons BPV. Autotech HPFP. Stratified 3 Port EBCS. Stratified Guardian Angel. 3 Bar MAP Sensor w/ PnP Harness.
Cyclops is offline   Reply With Quote
The Following 2 Users Say Thank You to Cyclops For This Useful Post:
Lex (01-24-2013), Voltwings (01-24-2013)
 Old 01-24-2013, 10:55 AM   #143
Gen2s adjust at WOT for sure right after a flash. Gen1 MS3s take a while but also appear to adjust after some time. MS6s seem to adjust as well but after a bit of time.
Overall none of them seem to adjust more than 10-12% above or below the MAF curve.
As I get more data I will post but I must say I'm a little miffed by this issue. Inserting a honeycomb, not having a 3" ID as implied by the name really affects the fluid dynamics of the pipe and MAF curve and not in a nice way.
How is that mesh held in there and how deep is it? Is there a lip holding it in??
Last edited by Lex; 01-24-2013 at 10:55 AM. Reason: MSF Database - Automerged Doublepost
BigjohnB20 (01-24-2013)
 Old 01-24-2013, 10:59 AM   #144
Cyclops's Avatar
An inch deep and looks like glue and a lip right behind the straightner hold it in.
The Following User Says Thank You to Cyclops For This Useful Post:
Lex (01-24-2013)
 Old 01-24-2013, 11:00 AM   #145
The honeycombs look crushed. It should look like shown below. Also that lip and glue are further affecting the MAF reading which may explain the inconsistency.
 Old 01-24-2013, 11:06 AM   #146
Cyclops's Avatar
It definitely is on the outside..
 Old 01-24-2013, 11:16 AM   #147
I digress, @HTP; if you have a MAF cal developed for the intakes please post it or provide some information. It will be very helpful is putting the data we have together and getting a solid MAF cal for these intakes.
sidekick (01-24-2013)
 Old 01-24-2013, 11:52 AM   #148
HTP
HTP's Avatar
Posts: 210   (View Stats)
HTP is the leader of the worldHTP is the leader of the worldHTP is the leader of the worldHTP is the leader of the worldHTP is the leader of the worldHTP is the leader of the worldHTP is the leader of the worldHTP is the leader of the worldHTP is the leader of the worldHTP is the leader of the worldHTP is the leader of the world
The local that you are tuning was in yesterday and had 3 very bad boost leaks.
When Jarod comes in he will post up a calibration.
Matt
Made in the USA by really ridiculously good looking people.
HTP is offline   Reply With Quote
The Following 3 Users Say Thank You to HTP For This Useful Post:
Lex (01-24-2013), ms3blackmica (01-25-2013), rfinkle2 (01-24-2013)
 Old 01-24-2013, 12:06 PM   #149
GODspeed7's Avatar
Matt
Where were the boost leaks? Because I am also having problems and have not touched the hot side of the turbo. Stock DP, stock intercooler.
 Old 01-24-2013, 12:08 PM   #150
Which local is that? PM me if you like please.
 Old 01-24-2013, 12:17 PM   #151
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
FWIW, @JDW1; I'd suggest waiting to see what core MAF Cal numbers are posted by HTP later, and if the talented ones here like lex don't rip them to shreds, then you should use those numbers and simply re-do your MAF Cal from scratch just to see where you end up.
Couldn't hurt and is easy enough to do.
And, of course, the usual old stand-by's of being sure that you've got no leaks, either pre or post turbo (ninja edit: intake & exhaust) and the MAF is good etc.
If it stays funky you might want to take an afternoon and reinstall your old intake set-up and map just to be sure everything returns to known good values, verify the mechanical end of things, then reinstall the HTP taking the opportunity to be doubly sure of the install being good.
340hp / 371tq
 Old 01-24-2013, 12:24 PM   #152
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
http://i1142.photobucket.com/albums/n610/BadNoodle2011/honeycomb.jpg[/IMG]
I think the MAF Cal. problems are caused more by the slightly smaller ID than anything else. I think the problems you're having with top-end MAF cals may be caused by the honeycomb though. I wouldn't be surprised at all if the honeycomb style air straighter hindered flow slightly in the top end vs the "cross hair" style air straightener. Although, despite these "problems", it seems like people are still getting decent gains with these intakes.
2006 Mazdaspeed6
 Old 01-24-2013, 01:01 PM   #153
GODspeed7's Avatar
I have one of these intakes. And although I am I more asked with the build quality for the most part, the gain I THOUGHT I noticed might be subjective. We will see what everything looks like when we get stuff dialed in.
 Old 01-24-2013, 01:06 PM   #154
sidekick's Avatar
Groans: 47
It may be that we aren't picking up as many G/s as we originally thought, but quite a few have picked up at least 10WHP. So that has nothing to do with whether or not the mass airflow numbers are correct.
2006 Mazdaspeed6
 Old 01-24-2013, 01:26 PM   #155
10whp is definitely the ballpark that I have seen with larger intakes 3"+ on the K04 and this is what I posted a long time ago. 30whp on the other hand is a little optimistic.
 Old 01-24-2013, 01:33 PM   #156
beachshoer's Avatar
Posts: 2,039   (View Stats)
beachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the worldbeachshoer is the leader of the world
So basically after reading all this:
I've been chasing leaks in two cars for nothing
I'm about to cut holes in my honeycomb straightner
3" doesn't really mean 3"
And all this ridiculous extra HP is coming from this lex tuned BNR and not from my ALMOST 3" intake.
WOW what a day.
2010 BM MS3
BNR S3
HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs
H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines
Works emotions cr-kai 18x7.5 ventus v12s for the street
TRM C3s 17x9 Hankook RS3s for track days
STRATIFIED TUNED
Other Mazdas in my stable
2010 VR MS3 Wifes Ride
ETS TMIC JBR RSB JBR SSP JBR knob AT internals
1999 Miata
gtx2867 1.9L VVT built like a brick shithouse
2001 Miata LS
RB FSB Hawk HP+ pads Dunlop ZII
beachshoer is offline   Reply With Quote
 Old 01-24-2013, 01:43 PM   #157
Dr. Speed's Avatar
Posts: 610   (View Stats)
~2.8" isn't even that much bigger than the stock MAF housing is it? I know this is kind of the general trend (doesn't the JBR 3.5" have an ACTUAL ID of 3.3-something?)... but it still is a bit disappointing. Intake diameter should definitely be advertised using ID numbers.
The Following User Says Thank You to Dr. Speed For This Useful Post:
DamagedGoods (01-24-2013)
 Old 01-24-2013, 01:48 PM   #158
KevMS6's Avatar
Posts: 316   (View Stats)
KevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the world
I'll measure my Cpe intake tomorrow to check also
Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft
Tuned with by
KevMS6 is offline   Reply With Quote
 Old 01-24-2013, 02:00 PM   #159
HTP
HTP's Avatar
Our intake MAF ID's are as follows:
3.0" - 2.87"
3.5" - 3.37"
4.0" - 3.83"
The original post and our website will updated.
Matt
The Following 9 Users Say Thank You to HTP For This Useful Post:
BigjohnB20 (01-24-2013), Dr. Speed (01-24-2013), El_Diablo (01-24-2013), KevMS6 (01-24-2013), Lex (01-24-2013), magicka (01-24-2013), Micha (11-03-2013), SLOWHATCH (01-24-2013), Voltwings (01-24-2013)
 Old 01-24-2013, 02:15 PM   #160
aldekei's Avatar
Boost leak test done. 0 leaks found.
tapawhat
Autotech Internals
Lex (01-24-2013), Mike@Stratified (01-24-2013), rfinkle2 (01-24-2013)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f579/intakes-now-available-134325/
JBR Wide path VS Cobb SRI+TIP? This thread Refback 01-28-2013 08:55 AM
Out of stock intakes!!!!!! Toymachinespeed 2010 MS3 - Turbo Induction 26 07-30-2011 06:34 AM
CorkSport SRI Intakes CorkSport CorkSport 3 08-04-2010 03:54 PM
Page generated in 0.59783 seconds with 35 queries
