| HTP (Hi-Tuned Performance) HTP (Hi-Tuned Performance) is dedicated to providing the automotive community with quality performance products and the highest level of customer service and support. Whether you're local or overseas, we like to approach each customer as though they're sitting right in front of us at the shop. Whether you're a long time customer or if you're new to HTP, we look forward to having the opportunity to prove our commitment to quality and service. |
![]() | | #201 | ![]() |
![]() Join Date: Jul 2010 Location: Rowland Heights, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 121
| Not Ranked : 0 score |
| The Following User Says Thank You to fredricktsang For This Useful Post: | rfinkle2 (01-25-2013) |
![]() | | #202 | ![]() |
Groans: 298
Once you pass the value in the closed loop max load table in the logs, you would use the technique as outlined above to adjust open loop fueling. | |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | SLOWHATCH (01-29-2013), TiGraySpeed6 (01-25-2013) |
![]() | | #203 | ![]() |
![]() Will install and do some testing this weekend when I get time. | |
![]() | | #204 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score My HTP comes in tomorrow. It's too damn cold for me over here (I shouldn't complain, you guys in Canada sun bath in negative temps). I am going to try to install it tomorrow and begin the tuning process. Unfortunately this issue is nothing new to me. My Cobb SRI never was accurate with the Cobb OTS curve. I had to add about about ~9% at WOT so even if there are some inconsistencies I have never minded tuning for it. I'll let you guys know soon how it goes.
__________________ www.tunedbynishan.com Last edited by ms3blackmica; 01-25-2013 at 05:30 PM. |
![]() | | #205 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score I had a small issue with the coolant hose below the TIP. I backed it out a little bit off it's connection so the intake would slide into the coupler a bit better. It was pretty damn cold here today. I'm thinking around 27-30 degrees. I did a lovely custom job of moving my ecu to the fuse box too. I'll take some pics tomorrow morning.
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
![]() | | #206 | ![]() |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
Sent from my XT907 using Tapatalk 2
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC | |
![]() | | #207 | ![]() |
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
![]() | | #208 | ![]() |
![]() Join Date: Oct 2012 Location: Tulsa, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Installed my HTP 3" Today. Have the cut knuckles to prove it. Tight fit but kept the ecu in original location. At the advice of HTP i simply removed the ECU cover which gives an additional 3/8" clearance. So far so good. Justin is in the process of Freekin my tune now.
__________________ 2013 Mazdaspeed 3: Performance: Autotech Internals // COBB AP // COBB TIP // Cobb Intake & Air Box // COBB FMIC // UR Catted DP V1 // UR CBE // UR Testpipe // Go Fast Bits BPV // Stratified ECBS 2-Port Mode // NGK One Step Colder Plugs // JBR Coolant Bypass Kit // Rotella T6 5w-40 // CP-e Stage RMM // Cp-e PMM // CS Shifrer Plate // Sure Shift Anchors // Redline Plus Hood Struts VD: 304hp / 333tq Stage 2 91 Octane Freek Tune |
| The Following User Says Thank You to GreyGhost For This Useful Post: | rfinkle2 (01-26-2013) |
![]() | | #209 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score @Lex; Here is my current MAF Cal. I just multiplied the whole curve by 1.22693 for now. I can't wait to get this intake installed though. I'll post before/after logs either later tonight or tomorrow. The map won't be changing except for the MAF calibration.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() Last edited by Lex; 01-25-2013 at 08:02 PM. |
![]() | | #210 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | TiGraySpeed6 (01-25-2013) |
![]() | | #211 | ![]() |
Groans: 47
On another note, HOW THE FUCK DID YOU GUYS INSTALL THIS? No, but seriously I'm having problems getting the battery back in. Of course it's something stupid like that keeping me from putting it in. I can't get the holes in the battery tray to line up with thw bolt holes and then when I did, there wasn't enough threads on the hold-down to get the nut threaded down far enough... What the fuck. Any tips for making this thing fit better?
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
![]() | | #212 | ![]() |
I'll check
__________________ www.tunedbynishan.com | |
| The Following User Says Thank You to ms3blackmica For This Useful Post: | rfinkle2 (01-26-2013) |
![]() | | #213 | ![]() |
Groans: 731
| Not Ranked : 0 score do what ms3blackmica said in the post above yours or move the ecu like I did to the top of the fuse box.
![]() | | #214 | ![]() |
![]() Join Date: Jan 2012 Location: Pensacola, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score That's where the GA goes, lol. tapawhat
__________________ HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust Beachshoer Intake Manifold P/P /w VTCS Delete Sure Shortcut | Sure Anchors | Sure 1/8 TIG Cobb AP | Cobb FMIC | Cobb Sport Springs ATP GT3071R /w Stratified Boost Dial Stratified Automotive Guardian Angel Go Fast Bits Respons (100% VTA) Autotech Internals I tune myself, bitches |
![]() | | #215 | ![]() |
Groans: 47
ANyways, the MAF Cal. seems to be pretty far off or maybe it's still just learning trims. I haven't driven it at all yet, but it's running kinda rough. There could be a leak too, I'm not 100% sure the clamps seated properly, so I'm going to do a boost leak test soon. I'll post some logs later.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() Last edited by sidekick; 01-26-2013 at 12:05 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #216 | ![]() |
Groans: 47
| Not Ranked : 0 score Well closed loop AFRs are all over the place and LTFTs are very high at idle/low load. WOT AFRs are very close to my target of 11.4 and seem to pretty much hit it with no problem, but I haven't done a full WOT run yet. Another thing I noticed is that I'm able to hold my boost targets much better with this intake. With the stock intake, I could barely hit 16PSI and it would start tapering off to about 15PSI. Without changing the WGDC at all, I'm actually overshooting my peak boost target by about .5PSI, but holding it easily. @Lex; @rfinkle2; Edit: Closed loop AFRs calmed down quite a bit after some driving, but LTFTs were pretty high. +8-14% was the range I saw quite a bit of. I'm working on the MAF Cal. now, but I only got to 55G/s before it transitioned to OL. The MAF Curve doesn't seem to be very smooth after I made the necessary changes. I attached the MAF Cal. logs. There is a very small 3rd gear pull in datalog 6 as well.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() Last edited by sidekick; 01-26-2013 at 03:20 AM. |
| The Following User Says Thank You to sidekick For This Useful Post: | rfinkle2 (01-26-2013) |
![]() | | #217 | ![]() |
![]() Join Date: Nov 2009 Location: Pensacola FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 659
| Not Ranked : 0 score That tray is one of those things that seems like a waste of money till you actually install it. At least to me it was. But holy shit does it give you room and make life easier. After putting it in I have about 2 1/2" between the intake and ECU. I run all my vac lines and occ hoses that way.
__________________ 2010 BM MS3 BNR S3 HTP 3" Intake(Granny Smith Green PC) CS RP Ebay DP Res Delete JBR shift kit Fully JBR mounted Turbosmart BPV DDM 6K Lows 3K fogs H&R Springs CS RSB CXRacing FMIC AT Internals DIY PnP IM w/ VTCS delete. CS OCC Stratified 3port EBCS HTP Batt Tray Bosch 3bar MAP SS brake lines Works emotions cr-kai 18x7.5 ventus v12s for the street TRM C3s 17x9 Hankook RS3s for track days ![]() STRATIFIED TUNED Other Mazdas in my stable 2010 VR MS3 Wifes Ride ETS TMIC JBR RSB JBR SSP JBR knob AT internals 1999 Miata gtx2867 1.9L VVT built like a brick shithouse 2001 Miata LS RB FSB Hawk HP+ pads Dunlop ZII |
| The Following User Says Thank You to beachshoer For This Useful Post: | rfinkle2 (01-26-2013) |
![]() | | #218 | ![]() |
Groans: 47
So I did a 4th gear pull and I lost power and torque... Lol. After looking at my map, it looks like the higher calc. load just put me into an area of the timing advance table that had very low timing advance. I'll have to adjust it to match the timing advance I was hitting before installing the intake. I attached the 4th gear pull log and a log from before I installed the intake running the same map. You can see I'm running almost no timing advance for most of the pull. Here is a virtual dyno comparing the two logs I posted. The red line is with the HTP 3" and the blue line is with a stock intake: ![]() Please note that I did NOT lose power because of HTPs intake. There was almost no timing advance until 5,000RPM in this run. I picked up about 30G/s of airflow over my last logs, which were actually on colder nights than tonight by about 10°f. I'm still hitting my commanded AFR +/-.2., so I don't think the MAF G/s reading is skewed by a bad calibration. My calc. load is higher by about .2, but that could just be from scaling the MAF.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() Last edited by sidekick; 01-26-2013 at 01:59 PM. | |
![]() | | #219 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
| Not Ranked : 0 score When installing my 3" intake I had no problems getting the battery box to fit. I just made sure the coupler was all the way on the turbo, the pipe all the way in the coupler, and the bracket snugged against the engine. But I will double check to make sure it isn't rubbing. Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. |
![]() | | #220 | ![]() |
| Not Ranked : 0 score Boost_addict it's hard to believe you lost power. Please only show results like that after you have completed your tuning with all things be as equal as possible.
![]() | | #221 | ![]() |
| Not Ranked : 0 score Try the MAF Cal I posted in my thread on the Stratified section. Looking at your MAF scale it seemed over scaled in the top end.
![]() | | #222 | ![]() |
Groans: 47
I'll try that, but if it was overscaled, wouldn't I be running rich? I'm hitting my AFR targets almost dead on. I'll give your MAF cal. a shot anyways though.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() Last edited by sidekick; 01-26-2013 at 01:08 PM. | |
![]() | | #223 | ![]() |
| Not Ranked : 0 score Lookie what came in just now ![]() Going to install after I finish my lunch :p |
![]() | | #224 | ![]() |
![]() Join Date: Sep 2011 Location: SCOTLAND
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
| Not Ranked : 0 score There has been alot of guys from the UK buying this intake also, certainly selling very well
__________________ Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft Tuned with by |
![]() | | #225 | ![]() |
Groans: 47
I'm going to adjust my timing tables and hopefully post some legit comparison logs tonight.
![]() | | #226 | ![]() |
| Not Ranked : 0 score Well I just got done taking the car for a spin after installing the HTP 3". I will admit it is a tight fit even with the ECU cover off but I kinda like it..Makes everything nice and snug. First impressions: The engine is extremely responsive. Very snappy. I scaled my curve by 1.14 and that got me within 7% on almost the entire curve. Datalog 3 is 3rd gear part throttle to almost redline. Datalog 4 is a quick 4th gear WOT in FTCL. I dropped boost and richened the AFR as I have some new plans to re-work this map with the new intake. I am extremely pleased so far.
![]() | | #227 | ![]() |
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
![]() | | #228 | ![]() |
I am completely re-working this map so when I get some time to really tune it I will post some legitamite logs with things dialed in.
| The Following User Says Thank You to ms3blackmica For This Useful Post: | rfinkle2 (01-27-2013) |
![]() | | #229 | ![]() |
| Not Ranked : 0 score Just finished installing it. But looks good. Loading up a FTCL map and drive around to get the maf dialed in. |
![]() | | #230 | ![]() |
| Not Ranked : 0 score Good news, using Lex's calibration everything seems to be pretty spot on. At WOT, AFRs are very close to my targeted 11.4. Only have about 10 miles of city driving on the map so LTFT's aren't accurate yet, but seem to be well within +/-8%. I'm going to load up my map with normal boost and wastegate and let her rip! I will most like need to tweak the wastegate and timing to get it as close to my pre HTP 3" runs to have as close of a comparison as possible. I have attached a log if anyone is interested. If anything is out of the ordinary that I missed please let me know. At first my AFRs while idling were into the 20's and the car was running like shit. I was about to flip a bitch thinking I have a leak on the intake, until I realised that i forgot to reconnect brake booster hose... |
![]() | | #231 | ![]() |
| Not Ranked : 0 score Thanks for the feedback. Looks like the MAF table I created is quite spot on - on a number of cars.
| The Following 6 Users Say Thank You to Lex For This Useful Post: | Dmurray06 (01-27-2013), jdmage_mx5 (01-27-2013), KevMS6 (01-27-2013), Pointless (01-27-2013), SLOWHATCH (01-29-2013), TiGraySpeed6 (01-27-2013) |
![]() | | #232 | ![]() |
![]() Join Date: May 2010 Location: Benton, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,028
| Not Ranked : 0 score I will give the numbers a try when my I take comes in on Tuesday and report back.
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with |
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | Lex (01-27-2013) |
![]() | | #233 | ![]() |
Groans: 47
| Not Ranked : 0 score I just loaded the map with your MAF cal. and its going well so far. Mine was off in a few places, but yours seems to be within +/-6% consistently. Thanks for posting it.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() Last edited by sidekick; 01-27-2013 at 06:55 PM. |
| The Following User Says Thank You to sidekick For This Useful Post: | Lex (01-27-2013) |
![]() | | #234 | ![]() |
| Not Ranked : 0 score As a testament to @Lex; number, just ran 16 autox runs. Ended up me 5th and codriver/wife 6th out of 22 in our class. Not spectacular or our best. But the car ran fantastic with the 3" intake.
![]() | | #235 | ![]() |
Groans: 47
| Not Ranked : 0 score Here is a Vdyno after getting some timing advance in there. ![]() Pretty decent gains considering I'm still running a little less timing advance than before. I'm using @Lex;'s MAF Cal. and I picked up 24G/s. There's a nice gain through out the whole power band too. @ms3blackmica; @HTP;
| The Following 3 Users Say Thank You to sidekick For This Useful Post: |
![]() | | #236 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
| Not Ranked : 0 score The maf cal @Lex; made for the 3" was a great starting point for me. Only minimal adjustments to suit my car. The max airflow i've ever seen on my car has been 265 gs with the Corksport full intake. Now its the middle of summer here and yesterday I registered 280 gs in 90 degree heat. Looking forward to some cooler weather so I can do some 4th gear logs and get a new VD record for my car. Easy 300+ Sent from my GT-I9300 using Tapatalk 2
__________________ 2012 Black Mazda 3 MPS ![]() CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC 2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks Versus Eurolace 19 x 8 +45 - Hankook RS3 Built & Tuned by Rob Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18 DBA T3 Rotors - Carbotech XP10 Brake Pads Last edited by ledfootrob; 01-28-2013 at 04:09 AM. |
![]() | | #237 | ![]() |
![]() Join Date: Nov 2011 Location: Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 621
| Not Ranked : 0 score This is all so awesome! I won't be home til April but as soon as I am I'm getting my HTP 3" in and getting my Freektune on! @boost_addict; That's some really good area gained under both curves! Post results again when you've got the tune fully dialed in. I'm really curious to see.
__________________ | 2012 CWP | Cobb AP + AT Internals | HTP 3" Intake | 91oct + DO WMI (D07, 50/50) + 3gal E85 | UR Test Pipe | cp-e TMIC | JBR Trilogy, OCC, EGR Block, SSB | TBC Bypass | Freektuned - 313/351 - Stock DP |
| The Following User Says Thank You to Dr. Speed For This Useful Post: | sidekick (01-28-2013) |
![]() | | #238 | ![]() |
| Not Ranked : 0 score an initial wot run with similar timing on the 3" compared to the old setup on the cobb srt and tip showed about 5-10hp and tq less, but that is with 25-30 degrees higher bats and humidity in the 90's. According to the logs I've picked up around 20g/s of flow. Going to run this map a bit longer and get another log with similar weather condition to the log with the cobb intake, and also allow the maf cal to settle so I can fully dial in the maf. |
![]() | | #239 | ![]() |
| Not Ranked : 0 score Here is a before and after for my car running my most aggressive map. Only difference between tunes is 1 psi xtra boost. Got me over 300hp woo hoo
__________________ 2012 Black Mazda 3 MPS ![]() CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC 2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks Versus Eurolace 19 x 8 +45 - Hankook RS3 Built & Tuned by Rob Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18 DBA T3 Rotors - Carbotech XP10 Brake Pads |
| The Following User Says Thank You to ledfootrob For This Useful Post: | Dr. Speed (01-30-2013) |
![]() | | #240 | ![]() |
| Not Ranked : 0 score Just received my polished 3.5". Looks amazing, hopefully I can get it installed in a couple of days when I have a slow moment.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f579/intakes-now-available-134325/ | ||||
| JBR Wide path VS Cobb SRI+TIP? | This thread | Refback | 01-28-2013 08:55 AM | |
| Out of stock intakes!!!!!! | Toymachinespeed | 2010 MS3 - Turbo Induction | 26 | 07-30-2011 06:34 AM |
| CorkSport SRI Intakes | CorkSport | CorkSport | 3 | 08-04-2010 03:54 PM |
