IIRC meth is WAY more corrosive than eth, so if you're running 100% meth and the pump can handle it, it *may* work with e85 as well. Probably best to contact the MFG. |
E85 will be just fine in these tanks. There will be a limited number of these tanks available configured as a surge tank. These tanks will be on sale the first of the year. Thanks Matt |
Any pics of the tank? |
Consider mine preordered! |
Gotcha, sounds good. Marks setup works really well as evident by his numbers. You'll like that method. |
I don't need mine until May, but yea I really hope this doesn't turn into the CPE manifold. Lol |
Two weeks, tops....:popworm: |
@HTP; any word on the tanks? |
I think @HTP died in the "Polar Vortex" |
I need meth Sent from my SCH-I535 using Tapatalk |
may get better luck calling them |
You mean using a forum that a vendor doesn't visit everyday isn't better than calling them at their offices where they work every day? now with three times the hate |
Any updates? |
Any updates in regards to tanks? Not to throw a wrench in, but any idea if they will fit the Speed 6? |
Two more weeks. |
I think they're making sure it's compatible with the CP-E Manifold. |
subbing for any new info, this will probably be my next mod, im running out of things to do. |
well I am out, I had one made for me to fit in a stock location |
Pictures? |
http://i.imgur.com/OZ8ABGF.jpg http://i.imgur.com/r2WlIcY.jpg http://i.imgur.com/gn2yMRC.jpg http://i.imgur.com/a6vrkiO.jpg http://i.imgur.com/1POPeqD.jpg http://i.imgur.com/PPAZO4u.jpg http://i.imgur.com/6Yyz7vo.jpg http://i.imgur.com/B9FcGsI.jpg http://i.imgur.com/cNgfCQS.jpg |
Looks good! Location and fill neck wise this is very close to our design. Ours is much larger volume and incorporates a pump mount. (make sure you keep anti-seize on those threads or you will find that lid impossible to remove) Stainless isn't necessary. We were very gung-ho about releasing these tanks until we talked to every meth injection manufacturer and they were very adamant about corrosion. It will corrode over night they said. Well it doesn't. I will go into more detail as we set to finally release these. We will have an initial number of these available and if the interest is there, we will do a nice group buy. Matt |
What gauge aluminum are you using? No fear of the pump jolting around on hard launches screwing up the tank? That's the only reason a mount wasn't incorporated into this one. Did not want the that stress from hanging the pump off the side of it. |
I'll take one. That tank looks aces man. I'm currently utilizing my WW reservoir as my meth tank. Is there truth to tanks having to be vented? Is that tank vented? |
http://i.imgur.com/YN5Feos.jpg |
Subbed Sent from my iPhone using Tapatalk |
3 quarts is not going to be enough for me so I'm very interested in this. Glad I finally found the subsection Matt haha. |
Just to add a little more info on our methanol testing and its corrosive effects. It is true that 100% methanol is corrosive to aluminum, but for it to take effect, it takes a very, very long time. We have conducted a long term test because this face value claim pops up immediately when discussing it. We have tested this on cast alum, 3003 alum, 5352 alum (what we use for tanks), 6061 alum, & anodized alum (5352 & 6061). Due to the protective oxide layer that forms on the surface of alum when exposed to air, it is protected from corrosion for the most part. Where we saw any type of corrosion was on cast, and over the length of 2 years, it was very minimal. All types of alum did surprisingly well over this period, the only spots that we saw signs of any type of etching is where we had put a scratch through the oxide layer and the HAZ area around a weld. Even this was very minimal and would have no effect on a methanol injection system. Anodized alum had zero effects. This was all tested with 99.999% meth. Keep in mind that Methanol is hydrophilic, meaning that it attracts water and will absorb it, self diluting. So fresh methanol was constantly changed to keep the purity levels up. As I have studied these results and researched findings from corrosion engineers, I'm a little let down by this claim that everyone spouts so freely. Just as little as a couple percent of dilution of water, and the corrosive effects are gone. What does this all mean? Maybe its time to finally release these tanks. Got Meth? |
2 weeks? Seriously though, using the stock WWF tank is getting pretty old. I'm ready for this release. |
My body is ready. |
Bump :( |
I will be looking out for the release. I'm in the market to get another tank. |
I needs this right meow |
Bump @Matt@HTP; I need this! Preorder??? :) |
@Matt@HTP; I'd be in. |
@Matt@HTP; any update? I'm ready to spend money. |
Same! I need this and your hot pipe. |
I know of a few locals that would want in on this as well. |
@Matt@HTP; any news??!!!?! |
All I'm gonna say is it IS in the lineup to release real soon. We have received a lot of support lately, and we would like to support your meth habit in return. |
Finally!!! Been waiting for this! |
I could use more HTP sexiness in my car! This included. |
Any Update? |
Sigh........bump @Matt@HTP; |
I’ve had a devils own kit waiting for install mostly because I wanted to upgrade the stock WWF tank to Canadian spec before doing so... this would eliminate that requirement and it has been more than 2 weeks... ;) |
I cannot wait to get my hands on this and see what HTP has come up with. Sounds like the mad scientist will want my new meth setup active this week, so soon I'll need that extra capacity and sexy welds behind my bumper. |
@Matt@HTP; yup.. I'm back. This time I'm here to bug you until you release this meth tank. I have two options right now. I either run your tank or I run trunk-mount. Now since I own a MS3, that would put the methanol right in the cabin. Imagine if I were to get in a roll-over crash and I'm smoking. I'd be lit up in invisible flames and the firefighters wouldn't even know that i'm burning alive. Would you want that on your conscience?! WOULD YOU?! I hope you can sleep at night knowing that there's the possibility that somebody out there could be risking their lives right now running a trunk-mount meth tank when they could be running your meth tank instead. Think of the children when they come home to find out that their parents died in a horrific crash that they could have survived had they not used an in-trunk meth tank. Then they'll look at you with tears in their eyes and ask "Why Matt, why didn't you release the meth tank soon enough? My mommy and daddy would still be alive." You heartless bastard.. http://savvysuburban.com/wp-content/...Favim.com_.jpg Think of the children.. I love your under-route piping by the way. ;) |
However, I am a red blooded American, who fears the same fate. Please help Matt!!! |
Mines already in the hatch....it's a ticking time bomb! :) |
Will Vodka work in lieu of meth? having that in cabin, no, wrong... |
I'n for a MS6 version in the same location! |
Sheesh @Putin 2.3T; I'm all teary-eyed now. That was heart felt. The meth tank will be making an appearance at ENM.......for the children. |
fap fap fap fap fap fap |
Do you have a price on it? Are you going to sell them at ENM or it's just being shown? |
in for a ms6 version also |
Bump for MS6 |
Matt is honeydickin us for sure. |
Not at all. It will be at ENM and available shortly after. And yes, a MS6 one as well. |
After buying an HTP intake, I'm a belieber in HTP products, quality, fit and finish was excellent, the packaging alone (EVERYTHING bubble wrapped) was better than competitors that I've had intakes from. I'll believe you this time Matt.. |
How much meth capacity are we talking bout Willis? |
I believe it was mentioned already in this thread. 7 qts. |
I was relieved, until I realized I was talking to a bird. |
@Matt@HTP; did you show the meth tank at ENM? |
I don't recall HTP being at ENM. |
No HTP @ ENM. I AM DISAPPOINT. (unless the reason is you were busy making a fuck ton of meth tanks.) |
This thread is full of broken promises... I've had to reduce nozzle size because Canadian/MZ5 washer fluid tank isn't big enough to make it through an entire session at the track. Let's see some love... finally! |
1 Attachment(s) The tank did not make it to ENM due to some time constraints (not related to the tank). I apologize to those that were looking forward to seeing it there, but here's a peek. |
This makes me think about that song about jizzing in one's own pants. |
Talk about customer service. That's exactly the sort of love I was asking for, and quick as shit! (Just coincidence I'm sure) So... Just need a link to click and buy. |
I don't know just how much @Matt@HTP; wants me to reveal but I want to let you guys that Matt's design for this meth-tank is INCREDIBLY versatile and expandable. At the moment Matt is working on a meth tank/fuel cell for me that will accommodate auxiliary pumps for my port-injection setup. This should slipstream the PI system and make it damn near plug-n-play. 8800ccs of methanol here I come! |
those welds in that teaser pic are absolutely redonkulous. I think matt@htp is a robot |
Only reason I went to enm was to see this tank..... Not really but bummed it wasn't there. I need it! |
@Matt@HTP; where you at? Check your email. :) |
Have you looked into alternatives yet? I'm going to start looking myself, need more volume ASAP! |
I was going to get a 2 gal auquamist, but shit if youre making a 3 gal in trunk im definately in! |
Matt isn't making an in trunk. It fits inside of the fender well. The whole point about my earlier message, you know the one about the children, was to reiterate the importance of keeping methanol outside of the cabin for safety. |
Can you confirm the release date of the meth tank? |
bump. ETA? a few weeks away from getting a local shop to build one. been wanting something ready to just bolt on, but im running out of time. |
Anything? |
1 Attachment(s) Real |
2 weeks? |
I'll believe it when I can click the add to cart button. I'll then proceed to add all of them in stock to my cart so no one else can have them and then I'll upload a video of me showering my naked body with said meth tanks. |
I just want to give you $!!!!! :) I guess I'll order this with my Cpe intake manifold.....trollololol But for real @Matt@HTP; eta? Price point? Something? I'm 100% in. |
Comes with the float switch installed, low level LED, integrated pump mounting. It really doesn't get any easier. |
| All times are GMT -7. The time now is 01:19 AM. |
