| Positive Fabrications Positive Fabrications, Mazda, Mazdaspeed, Mazdaspeed3, Mazdaspeed6, Mazdaspeed 3, Mazdaspeed 6, posifab, |
![]() | | #41 | ![]() |
![]() Join Date: Sep 2009 Location: Skokie, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,080
| Not Ranked : 0 score
You'll be able to tune for 93, it just won't be your balls out map. The higher compression is going to limit how much timing and boost you can safely run on 93. Although in theory it will be making more power with the higher compression anyways so it won't be neutered on 93 either. I plan to go with at least 10.5:1 CR (Still deciding) and I'll have mild/safe street tune made on 93 and then hop on a dyno for my all out E-mix tune. Just thinking about gets me all excited... I can't wait!!! Need complete my MMS requirements this weekend!!!
__________________ 06 LPM MS6: The Essentials | |
| The Following 2 Users Say Thank You to Speed_j23 For This Useful Post: | Clint@posifab.com (10-24-2012), mazdafreak (10-14-2012) |
![]() | | #42 | ![]() |
| fastest 3-cyl MS3 ![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 622 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,710
Groaned at 25 Times in 12 Posts
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, HKS BPV, SSP OCC, JBR TIG's, JBR EGR delete, Cobb AP, Kenne Bell BAS, PTP HPFP internals, Steedspeed turbo manifold, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Cobb RSB, Whiteline Anti Lift Kit, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, PTP BSD Dizzy Tuned by Boost_creep in progress hopefully soon: GTX2867R or GTX3076R | |
| The Following 2 Users Say Thank You to btstarcher For This Useful Post: | Boost_creep (10-14-2012), Clint@posifab.com (10-24-2012) |
![]() | | #43 | ![]() |
![]() Join Date: Jul 2011 Location: Elk Grove Village, IL
Rep Power: 630 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,449
Groaned at 23 Times in 17 Posts
Jay, who is running the 12:1 motor soon?? And what fuel are they going to be running?
__________________ 2.3L Turbo, 20% All around, Candy Purple Evo X Wheels,Tinted tail-lights, Angel eyes, heon endurance fog lights, Step colder plugs (ITV22), TWM Shifter bushings, Cobb SF intake, Cobb turbo inlet, Forge Recirc Bpv, Rally armor mud flaps, cnt catless downpipe, corksport catback, BC coilovers, cp-e motor mount, trz tranny mount, jbr egr block off plate, cp-e fuel pump, Dizzy Tune(Phate)But now.....*FULLY BOLTED* *100% e85 @24lbs on k04(tuned by phate!)* Recently installed: RaceBuilt ex manifold, Cobb Fmic, Driver311 PnP IM, 3 Bar Map sensor, ptp hpfv, ptp intake spacer 11:1 pistons/monlar rods(ORDERED) ((built bottom end)), 38mm wastegate, pte6262 .82--Coming soon! |
| The Following User Says Thank You to mazdafreak For This Useful Post: | Clint@posifab.com (10-24-2012) |
![]() | | #44 | ![]() |
![]() Join Date: May 2009 Location: Kankakee, IL
Rep Power: 8102 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,037
Groans: 121
I have run 93 on my PosiFab pistons, but I did not do any WOT runs and check for KR.
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ |
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | btstarcher (10-14-2012), Clint@posifab.com (10-24-2012), Jay@posifab.com (10-14-2012), Rokusek (10-15-2012), Speed3eak (10-18-2012) |
![]() | | #45 | ![]() |
| Banned ![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| The Following User Says Thank You to Jay@posifab.com For This Useful Post: | Clint@posifab.com (10-24-2012) |
![]() | | #46 | ![]() |
| Not Ranked : 0 score Are you going to be running 100% or 50/50 E mix....I think im just gonna go 11:1, only time ill be on 93 is winter when its stored in the garage, so wouldnt see much driving anyways during that time.
![]() | | #47 | ![]() |
Groans: 121
I have been running E50: 7 gallons E85 to 6 gallons 93 (E10). I'm actually going to switch to 100% E85 today.
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | Clint@posifab.com (10-24-2012), Jay@posifab.com (10-14-2012), mazdafreak (10-14-2012), Speed_j23 (10-14-2012), triplejumper18 (10-14-2012) |
![]() | | #48 | ![]() |
| Lurkers Join Date: Aug 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
As we begin to see more high compression engines up and running, we'll get a feel for how limited they are on 93 or 91. The gas tuning (tuning in general, really) for this car has really improved over the past year or so - my feeling is with slightly raised compression (10.5 or so), you won't lose much power on good 93 compared to the stock 9.5:1. Pure speculation, so take that with a grain of salt for now, lol. Also, with higher compression, there is generally a shift of MBT to the left (faster flame front). Less timing is needed, so starting out conservatively is recommended. The street is not the place to tune for MBT, especially with a new hardware setup like this. Results will be posted with peak timing curves and any observations; good or bad. | ||
| The Following 6 Users Say Thank You to Clint@posifab.com For This Useful Post: | Jay@posifab.com (10-15-2012), mazdafreak (10-15-2012), Realgib3 (10-20-2012), Rokusek (10-15-2012), silvapain (10-15-2012), Speed_j23 (10-15-2012) |
![]() | | #49 | ![]() |
Is there any difference between running the stock wrist pin size ((22.5mm)) than running the 22mm ones?
| The Following 2 Users Say Thank You to mazdafreak For This Useful Post: | Clint@posifab.com (10-24-2012), Jay@posifab.com (10-23-2012) |
![]() | | #50 | ![]() |
Groans: 121
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ | |
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #51 | ![]() |
Ahh gotcha, okay, appreicate the help pain! Im ordering the k1 rods today, since jp just got some in stock! And ill order pistons once i see the dyno results from your car! lol
__________________ 2.3L Turbo, 20% All around, Candy Purple Evo X Wheels,Tinted tail-lights, Angel eyes, heon endurance fog lights, Step colder plugs (ITV22), TWM Shifter bushings, Cobb SF intake, Cobb turbo inlet, Forge Recirc Bpv, Rally armor mud flaps, cnt catless downpipe, corksport catback, BC coilovers, cp-e motor mount, trz tranny mount, jbr egr block off plate, cp-e fuel pump, Dizzy Tune(Phate)But now.....*FULLY BOLTED* *100% e85 @24lbs on k04(tuned by phate!)* Recently installed: RaceBuilt ex manifold, Cobb Fmic, Driver311 PnP IM, 3 Bar Map sensor, ptp hpfv, ptp intake spacer 11:1 pistons/monlar rods(ORDERED) ((built bottom end)), 38mm wastegate, pte6262 .82--Coming soon! | |
![]() | | #52 | ![]() |
Realistically, either will work fine. For the sake of simplicity, we're only offering these pistons with 22.5mm pins. | |
| The Following 2 Users Say Thank You to Clint@posifab.com For This Useful Post: | Jay@posifab.com (10-23-2012), mazdafreak (10-23-2012) |
![]() | | #53 | ![]() |
![]() Join Date: Jun 2010 Location: Ontario, Canada
Rep Power: 505 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 395
Groaned at 7 Times in 6 Posts
Ok, so im thinking of pulling the trigger on these pistons.. Would it be absurd to run 11:1 CR stock bore with GTX3076, Meth, and 5th port on 94 oct fuel?
__________________ ![]() ![]() Engine Build In Progress http://www.mazdaspeedforums.org/forum/f542/snots-rocket-build-129112/ |
| The Following 2 Users Say Thank You to Snotrocket For This Useful Post: | Clint@posifab.com (10-24-2012), Jay@posifab.com (10-24-2012) |
![]() | | #54 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 1985 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,650
Groans: 300
Groaned at 187 Times in 103 Posts
Will our starters turn the crank over at 12:1?
| The Following 5 Users Say Thank You to Mizzle For This Useful Post: | btstarcher (10-23-2012), Clint@posifab.com (10-24-2012), Jay@posifab.com (10-24-2012), Juyoung (10-28-2012), TWOptSL0W (10-28-2012) |
![]() | | #55 | ![]() |
| Unicorn Farts ![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 1098 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,353
Groans: 99
Groaned at 35 Times in 28 Posts
| Not Ranked : 0 score We will find out pretty soon but I don't see y it would not Sent from galaxy Nexus vis CM10
__________________ Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms |
| The Following 2 Users Say Thank You to Deldran For This Useful Post: | Clint@posifab.com (10-24-2012), Jay@posifab.com (10-24-2012) |
![]() | | #56 | ![]() |
Groans: 121
| Not Ranked : 0 score If not, it's easy enough to have a shop rewind the starter motor for more amperage. It's the same process as rewinding alternators to put out more power for big car audio systems. Tapadatass
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | Clint@posifab.com (10-24-2012), Easter Bunny (10-24-2012), Jay@posifab.com (10-24-2012), Mizzle (10-24-2012), ms3blackmica (10-24-2012) |
![]() | | #57 | ![]() |
Groans: 99
__________________ Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms | |
![]() | | #58 | ![]() |
Groans: 121
| The Following 4 Users Say Thank You to silvapain For This Useful Post: | Clint@posifab.com (10-24-2012), Jay@posifab.com (10-24-2012), mazdafreak (10-24-2012), Speed_j23 (10-24-2012) |
![]() | | #59 | ![]() |
My end build will be similar to this, but with eth and a bigger turbo. | |
| The Following 4 Users Say Thank You to Jay@posifab.com For This Useful Post: | Clint@posifab.com (10-24-2012), mazdafreak (10-24-2012), Snotrocket (10-29-2012), Speed_j23 (10-24-2012) |
![]() | | #60 | ![]() |
Just in case you guys don't prowl the forum 23 hours a day like I do (lol), here are the current build threads with these pistons: http://www.mazdaspeedforums.org/foru...-build-115919/ ^^On the dyno this coming weekend (10/27/2012) ![]() http://www.mazdaspeedforums.org/foru...-phate-127713/ |
| The Following 7 Users Say Thank You to Clint@posifab.com For This Useful Post: | atvfreek (10-29-2012), btstarcher (10-24-2012), Easter Bunny (10-28-2012), greenespeed (10-24-2012), Jay@posifab.com (10-24-2012), mazdafreak (10-24-2012), Speed_j23 (10-24-2012) |
![]() | | #61 | ![]() |
Just so everyone knows, Wiseco has been picking up the pace on these. Our latest order is expected to be completed in 2 weeks and 4 days including engineer time. It will be about another 5 days for shipping after that, so just over 3 weeks total. OP updated with who is running what pistons to make it easier to find build threads. Last edited by Jay@posifab.com; 10-24-2012 at 04:15 PM. |
![]() | | #62 | ![]() |
11:1 overbore pistons and molnar rods ordered!!!!!!
| The Following User Says Thank You to mazdafreak For This Useful Post: | Jay@posifab.com (10-28-2012) |
![]() | | #63 | ![]() |
| ZipTie & Duct Tape Master ![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 2491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,799
Groans: 125
Groaned at 83 Times in 49 Posts
is anyone running these with success? better yet, has anyone taken a look at the pistons after they have been used?
__________________ Killah Built SMAC Tuned car went boom...again![]() Penises...you all know who eats them |
| The Following 2 Users Say Thank You to TWOptSL0W For This Useful Post: | Jay@posifab.com (10-28-2012), superskaterxes (10-28-2012) |
![]() | | #64 | ![]() |
Since he is currently the only one up and running, and just started the answer to your second question is no. Since you posted in my build thread I am assuming you noticed that I will be swapping my head shortly after my initial build which should be done this month, and I will be inspecting the pistons at that point though I don't expect to find any issues. | |
![]() | | #65 | ![]() |
Looking forward to the arrival of my 9.5:1 standard bore pistons and molnar rods
| The Following 2 Users Say Thank You to Snotrocket For This Useful Post: | atvfreek (10-29-2012), Jay@posifab.com (10-29-2012) |
![]() | | #66 | ![]() |
Groans: 121
I believe that my blowout at WOT is due to cold temps and 100% E85. I will be testing lower Ethanol content soon to verify.
![]() | | #67 | ![]() |
Groans: 125
| Not Ranked : 0 score i wanna see how bad the lean pocket in the back is. do you have a scope by any chance? how many miles on them?
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | Jay@posifab.com (10-29-2012) |
![]() | | #68 | ![]() |
Groans: 121
| Not Ranked : 0 score No scope unfortunately. I just hit 1,000 miles on the new engine.
| The Following User Says Thank You to silvapain For This Useful Post: | Jay@posifab.com (10-29-2012) |
![]() | | #69 | ![]() |
Groans: 125
| Not Ranked : 0 score damn, im VERY interested in seeing how the exhaust half of the piston looks
![]() | | #70 | ![]() |
![]() | | #71 | ![]() |
| The Following 4 Users Say Thank You to Clint@posifab.com For This Useful Post: | Jay@posifab.com (10-29-2012), silvapain (10-29-2012), Speed_j23 (10-29-2012), TWOptSL0W (10-29-2012) |
![]() | | #72 | ![]() |
Groans: 121
| The Following 2 Users Say Thank You to silvapain For This Useful Post: | Jay@posifab.com (10-29-2012), Speed_j23 (10-29-2012) |
![]() | | #73 | ![]() |
Groans: 300
Go to Harbor Freight Buy video scope Check cylinders Return with receipt ? PROFIT! |
| The Following 3 Users Say Thank You to Mizzle For This Useful Post: |
![]() | | #74 | ![]() |
Thanks fellas!
| The Following 2 Users Say Thank You to btstarcher For This Useful Post: | Jay@posifab.com (11-16-2012), mazdafreak (11-15-2012) |
![]() | | #75 | ![]() |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 1334 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,952
Groans: 85
will these pistons be offered in stock compression ratio ? would be nice to have these .02 over with stock comp. ratio
__________________ 2006 speed6~Cobb AP~COBB custom E-tune~CobbTIP-CobbSRI~CPeHPFP~ATPdp~Magnaflow exhaust~Denzo plugs~Forge bov~Matt Damon's Occ Kit~Treadstone FMIC~PG V1 Ex.Manifold~CPE safe seals~SU EGR block off plate~SURE TIG intake mani gasket~SU lower motor mount~AWR trans. mount/passenger mount~SU shifter bushings~CPE diff mount~H&R springs~Tenzo type M ~235/40/18 Firestone Indy 500 Wide Oval~ipod adapter~HD lip~Prosport boost gauge~ TWM Desert Eagle Shift Knob~JBR shift plate~spin on oil filter~Block8head Vent Pod~ported intake manifold w/ VTCS delete~EBC red pads w/ slotted rotors~4500k HID fogs 2 gal. E85 mix !!! " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
| The Following 3 Users Say Thank You to jracer For This Useful Post: |
![]() | | #76 | ![]() |
| The Following User Says Thank You to Jay@posifab.com For This Useful Post: | mazdafreak (11-16-2012) |
![]() | | #77 | ![]() |
![]() | | #78 | ![]() |
I rly need an update on my pistons/rods jay@posifab.com;
![]() | | #79 | ![]() |
They will come. Mine did. He hasn't boned anyone. TappaFak
| The Following User Says Thank You to Snotrocket For This Useful Post: | mazdafreak (12-28-2012) |
![]() | | #80 | ![]() |
| Not Ranked : 0 score They should have been delivered.. I have personally met jay and is a good guy, let me stay at his house and shit when we have a meet, would just like an update. Jay can clean this up when you get on. Just trying to get in contact with you.
| Methanol Direct Injection | phate | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 285 | 05-29-2013 04:04 AM |
| Direct Injection Systems | mrlilguy157 | MSF KB - Mazdaspeed 3/6 - Fuel | 7 | 09-19-2012 12:51 PM |
| Direct Injection Systems | mrlilguy157 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 6 | 02-18-2012 02:08 AM |
| Direct Port Water Injection | ptperformance | Mazdaspeed3/6 General Discussion | 12 | 08-13-2009 12:32 PM |
| DI FTW: GM unveils new direct-injection 2.4L EcoTec and 3.0L V6 | Haltech | Automotive News | 0 | 12-17-2008 09:50 PM |
