> 2010 MS3 - Appearance > Exterior
Like Tree3Likes
 Old 06-03-2011, 06:28 PM   #41
Yeldarb's Avatar
Posts: 24   (View Stats)
Yeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the worldYeldarb is the leader of the world
Would be good too see a photo of them on? Are they the same bulb as the w5w I've noted above, or is it more like actual LEDs in the Nargare pattern. I know you've mentioned the Nagare IS the DRL, but I have that pattern too!
GENII 2009 VR MPS LUX
Best Mufflers DP | 200 Cell CAT by 2XS | 3" Custom OPEN System with MAGNAFLOW Muffler & 4" tips | Speedy Lite Fin 18" Alloys with Sumitomo HTR ZIII
CORKSPORT SRI-TIP-Airbox | DGR Coilovers
OPTICOAT by ZAS | 2XS LED Fogs | 68 SMD LED (in the post) Parkers | Rear LED Reflectors | EYELIDS by MPS | Visual Garage Shark Fin Antenna
Hollandia 700 Sunroof
Yeldarb is offline   Reply With Quote
 Old 06-04-2011, 07:46 AM   #42
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I don't have a pu. Someone else will have to fill in. So, at what point do your nagare's come on? When you switch your dash lights on?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 06-04-2011, 06:01 PM   #43
Yeldarb's Avatar
For our cars, it's the Parker light. Not sure if you call it the same thing over there.
That's the bulb (Ive changed it again), I've unplugged it to show it's location in the back of the headlight.
While I'm there, thought I show of the Philips Silver, turn signal bulbs.
 Old 06-04-2011, 07:24 PM   #44
Tokay444's Avatar
Groans: 793
Yeah, parking lights is a term we use.
Demodded.
The Seals
 Old 06-05-2011, 07:30 AM   #45
jscape83's Avatar
Posts: 14   (View Stats)
jscape83 is a jewel in the roughjscape83 is a jewel in the roughjscape83 is a jewel in the rough
Corksport - DRL
CORKSPORT LED DRL Kit
jscape83 is offline   Reply With Quote
 Old 06-05-2011, 08:40 AM   #46
Tokay444's Avatar
Groans: 793
What I wish is that my drls didn't turn off when my headlights are on. More lights the better.
Demodded.
The Seals
 Old 06-05-2011, 02:26 PM   #47
Yeldarb's Avatar
Originally Posted by jscape83 View Post
Corksport - DRL
I have these already, just the non-branded version. CS are ok, but the mine are 68 LED, much brighter.
 Old 06-05-2011, 04:29 PM   #48
jscape83's Avatar
I'll second that!
Does that mean you have had the CS bulbs? If so, that sucks. I bought ebay led's for the interior of my car from a seller I have always bought from and felt they weren't that bright. It seems like everyone raves about their CS interior bulbs, I was hoping to hear something more positve about the DRL's and place an order for both.
Love your wheels btw!
 Old 07-28-2011, 01:47 AM   #49
Yeldarb's Avatar
So I've been searching for for thes bulb type for the Canadian DRL. Seriously, can't an owner open up the fcking manual and just tell us...???
Anyway on another forum i dare not mention, someone wrote that it's a H8 bulb like below...
That would make a serious DRL if that wwas true, not the shitty parker W5W T10 bulbs that are fitted to Aus/US cars.
So I took the W5W (T10) fitting out of the headlight below...
and noticed that the parker buld is mounted on this grey body (labeled 1). Could it be that you could remove the grey body from the black base (label -2) and fit a H8 bulb??
At the base of the grey body looks like it could be a larger bulb fitting... Just need to find a H8 bulb to try...
 Old 07-28-2011, 08:17 AM   #50
Yeldarb's Avatar
Seemingly no one else spotted this, so check out this pic...
Inside that red box, the top word is "Canada H8", underneath, "Other W5W".
So there you go. Mystery solved. I'm off to buy H8 35w 6000k HID bulbs and my Nagare wedges are going to glow like a MF!
 Old 07-30-2011, 07:30 PM   #51
mtran's Avatar
Posts: 195   (View Stats)
mtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond repute
So the tabs that the bulb holder locks into, is the same as an H8 bulb? If so, that saves me some money.. I have a ton of H8 bulbs laying around work that I can use if it ever burns out.
2010 Black Mica MS3
mtran is offline   Reply With Quote
 Old 07-30-2011, 11:41 PM   #52
Scoobs's Avatar
Posts: 750   (View Stats)
Scoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the world
In the owners manual the answer you seek lol H8 bulbs DRL, H11 in the fogs.
I haven't found a LED H8 yet but Piaa makes a Ion yellow H8 and H11. That will be my bulbs when I have a few bucks to waste. Bulbs won't make me faster so AP, SRI/TIP.....you get the picture.
Sold
2010 Speed3 Black Mica tech pack, JBR RMM 80 duro, Cobb SRI, stupid horn fixed with low tone add on.
New
2012 Mazda2 GS Aluminum Metallic Mica, Corksport rear torsion bar, Corksport H11 Led fog bulbs, Piaa H4 x-treme white bulbs, AWR rmm 70duro....more to come
Wife's car
2011 Mazda2 True Red GS (Touring in the US), wifes car, no mods so far but she want a Corksport CBE, Corksport SRI and a drop in the futur. <-----
Scoobs is offline   Reply With Quote
 Old 07-31-2011, 06:38 AM   #53
Yeldarb's Avatar
Originally Posted by vonG View Post
thanks, but you didn't read the post.
I have CANADIAN DRL (daytime running lights)
the headlights are HID, but the DRL's are halogen and suck.
so what bulbs are the DRL?
the sylvania bulb guide leads me to think they are 9006.
can someone confirm for sure?
just to be crystal clear, the Canadian cars have DRL's in the headlights, they are not DRL Fogs.
Mate, you suck for not opening your manual. Luckily you live at home and your parents wipe your arse. .
Anyway, I'm glad we've helped you work out your problem. Let us know how go...
 Old 07-31-2011, 06:57 PM   #54
Scoobs's Avatar
It's the first thing I looked into when I got the car, I hate the standard bulb in the DRL. For 2010 all Canadian MS3's came with the tech package with HID's and LED tail lamps.
The manual is your friend, grab a highlighter and mark all the important info. Oil capacity, oil type, bulbs, jacking point..... anything that may be usefull in the futur.
Sold
New
Wife's car
 Old 09-15-2011, 12:05 PM   #55
ttchanusa's Avatar
Posts: 8   (View Stats)
ttchanusa will become famous soon enough
Has anyone try to install a H8 bulb by removing the grey adapter for us who don't have DRL? Does it work with a standard H8 bulb?
ttchanusa is offline   Reply With Quote
 Old 09-15-2011, 11:40 PM   #56
Paul's Avatar
Posts: 822   (View Stats)
Paul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the worldPaul is the leader of the world
Groaned at 20 Times in 5 Posts
Im looking for a Orange LED DRL to match the ones in the 2011 MS3. ( the ones on the ends of the headlight tips)
Anyone have any ideas?
Edit. Ideas on how to achieve a different color other than the bright blue on the 68s that will say intact with driving etc.
http://www.v-leds.com/Exterior-LED/D...33643-1-2.html
^^^ These should work for FOGs/ Replace the Orange.Amber DRLs in the outside edges of the headlights?
2011 MS3 || Tech Pkg || Shark fin ||
|| HTP 3.5 Intake || || BNR4 || CS TMIC || CS CBE ||
|| CS Boost & BpV Tubes || DENSO IVT22 || FORGE BPV v2 ||
|| AT Internals || COBB APV3 || CNT DP || Koni Yellows || H&R Springs ||
|| JBR Shift Knob || JBR Stage 2 SSP || JBR SSBushings ||
|| JBR 88 RMM || JBR 80 TMM || JBR 80 PMM || JBR RSB || JBR RCAs || JBR EGR Block/Delete - OCC - Small Battery box ||
\\|// AJ 91 & E85/91 Mix Tunes by A.J \\|//
|| Window Tints, Lamine-x Headlights/Fogs, Tinted Tails, JDM Rain Guards ||
Paul is offline   Reply With Quote
 Old 09-16-2011, 10:06 AM   #57
dr_banano's Avatar
Posts: 502   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
2 V-LEDS AMBER 68 M-SMT DRL/FOG BULBS HB4 9006
for the fog light it migh work but for the orange amber edges one i dont think since that one is double contact since it also for turn sings
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front
ptp studs/seals pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
 Old 09-30-2011, 06:13 PM   #58
dhsieh911018's Avatar
Posts: 530   (View Stats)
dhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the world
Groaned at 55 Times in 35 Posts
guys i know this might sound silly 'cause im new to mods... ive managed to find the place for the nagare light(US 2011 mazdaspeed 3 with tech pkg). How do u get the bulb out of the grey housing? Do you rip the grey body off or do u just get the bulb out of the grey thing?
dhsieh911018 is offline   Reply With Quote
 Old 10-08-2011, 07:20 AM   #59
Yeldarb's Avatar
Just pull the bulb out of the grey housing...
Then you can install something like this...
looks like this...
 Old 10-09-2011, 09:24 PM   #60
Jhornbrook's Avatar
Posts: 708   (View Stats)
Groaned at 6 Times in 4 Posts
Originally Posted by EvilMonkey View Post
headlights are H11. Fogs are also H11 and high beams are 9005. Go HID in your headlights. I got 55W 6000K and they are plenty bright..plenty! I got the H11 LED fog lights from Corksport and they match my headlights very very very close and they are bright as shit.
i installed my led drl's from corksport today it took 1o minutes. so easy especially when you have an oil pit to stand in. anyways, i want to ask if anyone has removed that stupid plastic piece that is in the light housing. it seriously drains light output and itst ugly. anyone got any advice on getting it out.
 Old 11-21-2011, 05:17 AM   #61
2010_MS3's Avatar
Posts: 263   (View Stats)
2010_MS3 is the leader of the world2010_MS3 is the leader of the world2010_MS3 is the leader of the world2010_MS3 is the leader of the world2010_MS3 is the leader of the world2010_MS3 is the leader of the world2010_MS3 is the leader of the world2010_MS3 is the leader of the world2010_MS3 is the leader of the world2010_MS3 is the leader of the world2010_MS3 is the leader of the world
So anyone else have problems with only one LED coming on when they ate both in? I know it's not the bulbs or the connectors because if I swap them around and only test one at a time they work. I purchased ones that had been linked in a previous post so I figured they would work. Anyone have any ideas on how I can fix this?
File Type: jpg ImageUploadedByTapatalk1321877826.873570.jpg (1.60 MB, 65 views)
2010_MS3 is offline   Reply With Quote
 Old 11-28-2011, 07:01 PM   #62
Jhornbrook's Avatar
has anyone pulled the stupid fucking fog light cap things out of a 2010 speed3. i have the led's but thecaps made it look retarded. so i got one side out but it took me 45 minutes of fucking with it to pull the caps out. they are metal and dont fit through the hole the lights go into. i just broke it off and bent it till it fit. there has to be an easier way to do this. let me know because im a bout to tear into the other half after dinner.the side thats done looks sick though.
 Old 11-29-2011, 07:51 PM   #63
2010_MS3's Avatar
Pics?
 Old 11-30-2011, 06:02 AM   #64
Yeldarb's Avatar
Caps? I've bought a few sets of these things. One set didn't fit, it had a huge heatsink end, like you call it a cap. Is that what you mean? You shouldn't need to bend anything. Changing the fogs only takes a few minutes.
 Old 11-30-2011, 06:14 AM   #65
Macedawg's Avatar
Posts: 1,168   (View Stats)
Macedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the world
i think he means the glare cap/shield inside the foglight housing..i assume most people would have to remove it when installing the longer LED's or HID's in them so they would fit
Macedawg is offline   Reply With Quote
 Old 12-01-2011, 12:46 AM   #66
Yeldarb's Avatar
Does he mean the glare cap on the bulb? There aren't flare caps in the fog light housing in Oz.
 Old 07-13-2012, 03:48 AM   #67
Yeldarb's Avatar
Haven't posted in here for a while. Recently installed these Chinese copy's while bored one weekend.
 Old 10-12-2015, 05:26 AM   #68
g.ciotta21's Avatar
Posts: 12   (View Stats)
g.ciotta21 is a jewel in the roughg.ciotta21 is a jewel in the roughg.ciotta21 is a jewel in the rough
This might be a dumb question but...... Is it possible to put the tech pckg headlights in a base model speed? I love the look and want DRL's
g.ciotta21 is offline   Reply With Quote
 Old 01-13-2020, 08:04 PM   #69
madman55's Avatar
Posts: 2   (View Stats)
madman55 is an unknown quantity at this point
I am in the middle of trying to install tech package HIDS on a non tech ms3. Will report back if successful.
madman55 is offline   Reply With Quote
Page generated in 0.48664 seconds with 33 queries
