> 2010 MS3 - Appearance > Exterior
 Old 08-10-2019, 12:30 PM   #1
Rklamb2008's Avatar
Posts: 5   (View Stats)
Rklamb2008 will become famous soon enough
Default Mazdaspeed 3 door vs Mazda 3
Hello I am a new member here and I recently bought a Mazdaspeed 3 that I'm restoring and I have a question about doors. My passenger side door was punctured by a folk lift when they attempted to load it on my trailer. So it would be cheaper to just replace the door than to fix it. In my area I cant find any Mazdaspeed 3 but I have found a few 2010 to 2012 Mazda 3s the exact same color. So my question is will a Mazda 3 sedan or hatchback front door fit a speed 3. Are there any differences and would the body lines match up?
Thanks in advance.
Rklamb2008 is offline   Reply With Quote
 Old 08-10-2019, 01:36 PM   #2
SSinstaller's Avatar
Posts: 3,984   (View Stats)
Groans: 60
You need a hatch door, all the accessories can be swapped from your original door.
Double Product Release! CorkSport Mazdaspeed 3/Mazda 3 and Mazdaspeed 6 Rear Motor Mount CorkSport CorkSport 30 04-19-2013 06:44 PM
Mazdaspeed 6 door skspeed Mazdaspeed3/6 General Discussion 7 06-24-2012 02:54 PM
mazdaspeed 6 door skspeed Mazdaspeed3/6 General Discussion 2 06-23-2012 10:15 PM
Page generated in 0.23050 seconds with 21 queries
