> Start Here
Start Here This will all be renamed once we compile everything
  • 1 Post By Haltech
 Old 11-05-2012, 06:27 PM   #1
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Default How to mention someone in a post...
Well im happy this bug popped up, but it did cause some issues. So, from here on out, if you want to mention someone in a thread, you will need to place a semicolon after each screen name.
Old way: Haltech
New way: Haltech;
the @ will no longer show as its caused an issue. To tag / mention another forum member, simply type @ member name ; (semicolon) without any spaces.
thebigtizzle likes this.
Haltech is offline
jabeel00 (12-10-2015)
 Old 11-05-2012, 06:30 PM   #2
Posts: 20,650   (View Stats)
Groans: 1,443
Blame me
Beanfab / Tuned by Nishan
doubleflusher is offline
 Old 11-05-2012, 06:34 PM   #3
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
/me blames @doubleflusher;
______________________
Built By NATOR
Tons of Ricer Mods
09Speed3Z is offline
 Old 11-05-2012, 06:35 PM   #4
Groans: 1,443
Originally Posted by 09Speed3Z View Post
/me blames doubleflusher;
wtf?
Always getting blamed.
 Old 11-05-2012, 06:42 PM   #5
nindoja's Avatar
Posts: 2,378   (View Stats)
Hmm. Every time I try to fix the mention list, I get spaces added after each @ and before the member's name.
See http://www.mazdaspeedforums.org/foru...r-list-122948/ for what I'm talking about. When you copy-paste the names from the list, it doesn't recognize it since there is an additional space there.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
nindoja is offline
 Old 11-06-2012, 07:37 AM   #6
lilred's Avatar
Posts: 5,792   (View Stats)
Bump for less confusion
Ok just to be clear you still use the "@" but now adding ";" at the end
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
lilred is offline
 Old 11-06-2012, 07:42 AM   #7
Like this: @lilred; is a foggot.
silvapain is offline
 Old 11-06-2012, 07:43 AM   #8
ANITIX87's Avatar
Posts: 1,387   (View Stats)
ANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the world
Groans: 92
Groaned at 27 Times in 16 Posts
Maybe my computer's wonky, but the "old way" worked better for me. I never saw the @, and my grammar-Nazi self is bothered by the semi-colon. Oh well, if it makes the site less glitchy and is convenient for users who do multi-mentions, then I'm all for it!
TIS
TOTS
2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5
alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml"
ANITIX87 is offline
 Old 11-06-2012, 07:47 AM   #9
lilred's Avatar
Faggot*
tapafuck
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
lilred is offline
 Old 11-06-2012, 08:37 AM   #10
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
@lilred;
just testing
tddvrrn is offline
 Old 11-06-2012, 08:41 AM   #11
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
What was the actual issue?
NATOR PA
MS3-a(sore)ASS-rex is offline
 Old 11-06-2012, 08:47 AM   #12
EdgeAutosport.com's Avatar
Posts: 6,207   (View Stats)
@MS3-a(sore)ASS-rex; you're the problem
EdgeAutosport.com is offline
 Old 11-06-2012, 09:01 AM   #13
Groans: 1,443
I was trying to post a code box last night and teabagged the DB a few times.
The code started with @
Kevin disabled the @ for mentions so I couldn't kill MSF again.
 Old 11-06-2012, 09:08 AM   #14
ms3rick's Avatar
Posts: 2,959   (View Stats)
fucking @doubleflusher;
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
ms3rick is offline
 Old 11-06-2012, 09:08 AM   #15
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
@Stangcobra; is still gai.
700HP CLUB
11.479@124mph
#DIX
Downmented is offline
 Old 11-06-2012, 09:09 AM   #16
Groans: 1,443
@Downmented; can't tag
 Old 11-06-2012, 09:11 AM   #17
Downmented's Avatar
Groans: 493
I was hoping noone caught that
700HP CLUB
11.479@124mph
#DIX
 Old 11-06-2012, 09:11 AM   #18
load's Avatar
Posts: 410   (View Stats)
load is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the worldload is the leader of the world
Groaned at 9 Times in 3 Posts
@Haltech;
Assuming it doesn't work for me because brownie post count fail.
Edit: hm looks like it does work.
load is offline
 Old 11-06-2012, 09:16 AM   #19
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Originally Posted by load View Post
@Haltech;
Open wide brownie, I gotta load for your mouf
Haltech is offline
 Old 11-06-2012, 10:33 AM   #20
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
motherfucking @doubleflusher; goddamit fuck
www.tunedbynishan.com
ms3blackmica is offline
 Old 11-06-2012, 10:39 AM   #21
KusteLokal's Avatar
Posts: 2,664   (View Stats)
Groans: 124
@doubleflusher; wtf
1995 Miata 1.8
2006 MS6 Sold
KusteLokal is offline
 Old 11-09-2012, 04:39 PM   #22
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Am I the only one having trouble with this new system? Im doing something wrong but cant figure it out. Haltech;
FREEKTUNE
Boost Addict is offline
 Old 11-09-2012, 04:40 PM   #23
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
You still need the @ symbol, followed by the screen name,followed by a semi colon ;
Haltech is offline
 Old 11-09-2012, 04:41 PM   #24
lilred's Avatar
"@" haltech ";" will tag him
tapafuck
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
lilred is offline
 Old 11-09-2012, 04:41 PM   #25
Ahh now i see, @Haltech;
Thank you!
FREEKTUNE
 Old 11-09-2012, 04:45 PM   #26
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
There you go
Haltech is offline
 Old 11-09-2012, 04:49 PM   #27
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Man, there are some dumb mthrfckrs on here. If I understood it, you guys shouldn't be having problems with it.
I still blame double pumper though.
@doubleflusher;
What a lovable bunch we are!!
predapio is offline
 Old 11-09-2012, 04:50 PM   #28
@doubleflusher;
My college degree has gotten me so far in life
FREEKTUNE
 Old 11-13-2012, 10:42 PM   #29
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
People are fail at reading...
Haltech is offline
Notorious AMA (01-08-2014)
 Old 11-14-2012, 12:15 PM   #30
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
@lilred;
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline
HTML code is On
Not Getting Mention Notifications maisonvi Website Help/Feedback 18 06-18-2013 08:21 AM
Toyota gets dishonorable mention in Oscars opening Haltech Automotive News 0 03-08-2010 06:10 AM
Page generated in 0.48032 seconds with 37 queries
