Mazda Platforms
Ford Ecoboost 1.6,2.0 & 2.3 Discussion(ECOBOOSTFORUMS.ORG)
> Ford Focus ST Ecoboost - General Discussion
Notices
Ford Focus ST Ecoboost - General Discussion Discussion of Ford Ecoboost Engines
  • 1 Post By SPEED6 KILLAH
 Old 08-03-2012, 05:41 AM   #1
DiGi Faggot's Avatar
Posts: 1,082   (View Stats)
DiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the world
Groaned at 86 Times in 49 Posts
Default 2013 Ford Fusion a MazdaSpeed 6 Replacement?
Originally Posted by http://www.ford.com/cars/fusion/2013/features/#page=Feature1
The available new 2.0L EcoBoost in-line four-cylinder engine combines three different technologies – turbocharging, direct injection and twin independent variable cam timing (Ti-VCT) – to optimize both performance and efficiency. Features include:
• All-aluminum construction
• Direct fuel injection
• Single turbocharger
• Piston cooling jets for durability
• Adaptive knock control
Originally Posted by http://www.ford.com/cars/fusion/2013/features/#page=Feature4
Whether the road is filled with gravel, covered with snow or soaked by rain, available AWD helps provide sure-footed traction. Because AWD is fully automatic, it delivers power to the wheels needing it the most when wheelslip is detected.
Originally Posted by http://www.ford.com/cars/fusion/2013/features/#page=Feature5
You don’t have to know how to drive a manual transmission to enjoy the sporty feel of shifting gears. Using race-inspired technology, the available steering wheel-mounted paddles let you easily and quickly go from gear to gear without taking your hands off the wheel.
Originally Posted by http://www.ford.com/cars/fusion/2013/features/#page=Feature6
Standard and available engines include:
• Standard 2.5L Duratec® I-4 engine. Coupled with SelectShift Automatic® six-speed transmission with thumb switch on gear shift knob.
• Available new 1.6L EcoBoost* engine. Coupled with standard SelectShift Automatic® six-speed transmission or optional manual transmission.
• Available new 2.0L EcoBoost engine. Coupled with six-speed automatic transmission with paddle shifters.
• Available hybrid 2.0L I-4 Atkinson-cycle powertrain. Coupled with electronically controlled continuously variable transmission (eCVT).
• Available plug-in hybrid electric 2.0L I-4 Atkinson-cycle engine. Coupled with electronically controlled continuously variable transmission (eCVT) and high-voltage electric motor.
Obviously it doesn't come with a manual transmission in ecoboost form which sucks. But it has the same 2.0L Ecoboost as the Ford Focus which means most parts should be swappable ala Focus ST.
Last edited by DiGi Faggot; 08-03-2012 at 05:41 AM. Reason: MSF Database - Automerged Doublepost
DiGi Faggot is offline   Reply With Quote
 Old 08-03-2012, 05:47 AM   #2
 Old 08-03-2012, 06:00 AM   #3
SPEED PERF6RMANC3
Downmented's Avatar
Posts: 2,104   (View Stats)
Groans: 273
Groaned at 55 Times in 37 Posts
I think im in love
//KILLAH BUILT, SPEED PERF6RMANC3//
Steedspeed T4 Twin Scroll // Precision 6265 Single 44mm Wastegate.
KILLAH BUILT //FREEKPERM // Nuffsaid
His setup is going to be beast. I can't wait til he has fuel and we get her on the dyno.
Oh ya, and his maf volts are 4.7ish so he will need bigger maf housing and a map sensor that can read high enough (3bar is almost maxed at 27psi... Aka spring pressure)
 Old 08-03-2012, 06:02 AM   #4
amoosenamedhank's Avatar
Posts: 1,207   (View Stats)
Groans: 45
Groaned at 27 Times in 20 Posts
The problem is they only offer a manual with the 1.6 EB and FWD. If you want the 2.0 EB and AWD, you're forced to go with an auto..... lame sauce.
Hopefully they change that mid year like they did on the focus.
amoosenamedhank is online now   Reply With Quote
The Following User Says Thank You to amoosenamedhank For This Useful Post:
Juyoung (08-23-2012)
 Old 08-03-2012, 06:03 AM   #5
Colin1337's Avatar
Posts: 1,103   (View Stats)
Colin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the world
Pretty nice, wish it had a manual gearbox though
2006 Mazdaspeed6 - COBB AP| 3' Magnaflow CBE | Autotech FPI | AEM CAI | NGK plugs | RMM | Megan springs | HKS SSQV3
1995 Miata - adjustable Tokiko Illumina shocks | FM springs | HardDog M2 rollbar w/Single diagonal | GV rep front lip | Flyin' Miata rear shock mounts.
Colin1337 is online now   Reply With Quote
 Old 08-03-2012, 06:04 AM   #6
Agreed but there may be a way to swap them. I'm not sure. We'll have to see what happens. If the Auto is a good auto it may not be a immediate problem.
The Following 3 Users Say Thank You to DiGi Faggot For This Useful Post:
ArcticSpeed3 (08-04-2012), Colin1337 (08-03-2012), Juyoung (08-23-2012)
 Old 08-03-2012, 07:18 AM   #7
zkrick's Avatar
Posts: 450   (View Stats)
zkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the worldzkrick is the leader of the world
Groaned at 48 Times in 7 Posts
That interior is boss!
2012 Black Mica MazdaSpeed 3 Tech
. H & R Springs . . Sure Counter weight . . Sure anchors . . Sure Shortcut . . Sure RMM . . Injen CAI . . Cobb TIP . . Cobb Tuning XLE BPV . . JBR Knob .
You mad bro?
Originally Posted by Mazdaspeed_3 View Post
I ain't donating shit.....
YOU AND YOUR PUNK ASS HOMMIES CAN
Kick
Fucking
ROCKS!
zkrick is offline   Reply With Quote
 Old 08-03-2012, 07:21 AM   #8
GoBackToSleep's Avatar
Posts: 870   (View Stats)
GoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the worldGoBackToSleep is the leader of the world
Groaned at 16 Times in 3 Posts
I'd be more interested if a manual transmission was offered in the higher trim levels. I'm waiting to see the direction the redesigned Mazda 6 will take. The current generation is so uninspiring and I very much miss my five-speed '06 iSport that I was able to get with the moonroof/BOSE package.
- Matt
2012 Mazda 3i Touring hatch 6MT in graphite mica (current)
2008 Mazdaspeed 3 Sport CBM (traded)
GoBackToSleep is offline   Reply With Quote
 Old 08-03-2012, 07:27 AM   #9
(Toe-kay)
Tokay444's Avatar
Posts: 9,567   (View Stats)
Groans: 504
I don't understand why anyone wants awd to begin with, but if that's actually what you're dead set on, why not opt for a performance oriented awd system?
Demodded.
Mwho?
Tokay444 is online now   Reply With Quote
 Old 08-03-2012, 07:27 AM   #10
Posts: 10,146   (View Stats)
Groans: 98
any auto is an immediate problem lol
KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust
510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs
WWW.SONICTUNING.COM
Certified RichTune e-Tuner
KILLAH BUILT by SPEED PERF6RMANC3
I could cry right now im so proud of you.
The Following 7 Users Say Thank You to superskaterxes For This Useful Post:
Downmented (08-03-2012), dpolseno41 (08-03-2012), helmetface (08-04-2012), Juyoung (08-23-2012), MicaBlackMS6 (08-03-2012), silvapain (10-19-2012), Stangcobra (10-19-2012)
 Old 08-03-2012, 07:34 AM   #11
I<3Groceries's Avatar
Posts: 1,851   (View Stats)
Groaned at 25 Times in 20 Posts
Your anti awd posts crack me up!
I think it is a pretty nice ride. It isn't really much of an upgrade though. You will compromise some performance overall and lose the exclusivity you have with the MS6...
Why not just have both? Keep the MS6 and supplement it with a nice, more refined car like this new Focus.
The Following User Says Thank You to I<3Groceries For This Useful Post:
4G63 (08-03-2012)
 Old 08-03-2012, 07:35 AM   #12
Unicorn Farts
Deldran's Avatar
Posts: 2,146   (View Stats)
Groans: 96
Groaned at 35 Times in 28 Posts
I love the new fusion, but no manual means no buy to me anyway. Anyone else think that the fusions looks alot like a austin martin from the front
Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms
Deldran is online now   Reply With Quote
The Following 5 Users Say Thank You to Deldran For This Useful Post:
ArcticSpeed3 (08-04-2012), dantes5823 (08-04-2012), dot584 (08-03-2012), imoonpigs (08-31-2012), Juyoung (08-23-2012)
 Old 08-03-2012, 07:41 AM   #13
Hair by Voltron
doubleflusher is the leader of the worlddoubleflusher is the leader of the worlddoubleflusher is the leader of the worlddoubleflusher is the leader of the worlddoubleflusher is the leader of the worlddoubleflusher is the leader of the worlddoubleflusher is the leader of the worlddoubleflusher is the leader of the worlddoubleflusher is the leader of the worlddoubleflusher is the leader of the worlddoubleflusher is the leader of the world
Groans: 1,404
Groaned at 310 Times in 292 Posts
The front and the interior is all that car has going for it.
11.91 @ 122.48 1.85 60' - 12/4/11 - Atco Raceway
11.85 @ 119.69 1.75 60' - 4/15/12 - Mason Dixon Dragway
For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
The Following 3 Users Say Thank You to doubleflusher For This Useful Post:
amggilly305 (08-03-2012), Neverlift (08-03-2012), Tokay444 (08-03-2012)
 Old 08-03-2012, 07:42 AM   #14
SRTie4k's Avatar
Posts: 1,716   (View Stats)
Swap a FWD only manual tranny into an AWD system? I'd love to hear how that works.
The Following User Says Thank You to SRTie4k For This Useful Post:
 Old 08-03-2012, 07:54 AM   #15
Groans: 45
They don't offer the manual with the 2.0 EB in either FWD or AWD. So the bigger problem is settling for the 1.6 engine if you want a manual.
 Old 08-03-2012, 07:56 AM   #16
(Toe-kay)
Tokay444's Avatar
Groans: 504
Don't get one at all.
They all sound like absolute shit to me.
If you can't have what you want, get something else.
Demodded.
Mwho?
CamSpeed360 (10-19-2012)
 Old 08-03-2012, 09:28 AM   #17
I'm waiting to see how good the automatic transmission is and what it holds.
 Old 08-03-2012, 09:38 AM   #18
dale_gribble's Avatar
Posts: 1,054   (View Stats)
Groaned at 7 Times in 4 Posts
Sweet ride. Will need to see how new gen 6 turns out but I would rock this with manual and larger engine option without question. Ford is on their game right now.
dale_gribble is online now   Reply With Quote
 Old 08-03-2012, 10:45 AM   #19
indiscretion
leon78's Avatar
Posts: 1,933   (View Stats)
Groaned at 22 Times in 15 Posts
titanuim huh....id drive it...but its not a car that id want to buy/pay for.
2013 Scion FR-S (Whiteout)
White 17x9 Rota Grids w/ 245's_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP.
leon78 is online now   Reply With Quote
 Old 08-03-2012, 07:53 PM   #20
SPEED6 KILLAH's Avatar
Posts: 1,042   (View Stats)
Dam look good but the 2013 Mazda 6 look way better beside the stupid skyactive motor in it..
Speed3in215 likes this.
SPEED6 KILLAH is offline   Reply With Quote
The Following User Says Thank You to SPEED6 KILLAH For This Useful Post:
 Old 08-03-2012, 08:22 PM   #21
ArtClassShank's Avatar
Posts: 75   (View Stats)
ArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud of
Groaned at 4 Times in 1 Post
What about chassis?
Suspension might be wallowy and bad to drive.
But I guess that doesn't matter to some of you 1/4 mile and dyno people.
2008.5 CWP MS3
Cobb AP, FMIC, Forge BPV V2, Cobb TIP, Cobb SF SRI, JBR 88 RMM, JBR RSB, Ford Transmission fluid, for those magical shifts.
ArtClassShank is offline   Reply With Quote
The Following User Says Thank You to ArtClassShank For This Useful Post:
 Old 08-03-2012, 08:43 PM   #22
greenespeed's Avatar
Posts: 1,314   (View Stats)
greenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the world
Groaned at 6 Times in 3 Posts
That front end looks mean..unlike the rest of the car.
2006 Mazdaspeed6 BCM GT
MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress
Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay.
greenespeed is offline   Reply With Quote
 Old 08-03-2012, 08:46 PM   #23
Mfinlay04's Avatar
Posts: 579   (View Stats)
Mfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the world
Groaned at 9 Times in 6 Posts
If it has the same "auto" that the fiesta has I'd be happy. Dual clutch would be the next best thing. I prefer a 6 speed but a dual clutch auto would be alright.
2006 MS6 Titanium Grey
AP, TP, BSD, AEM CAI, Custom 2.5" Single Exit Exhaust, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, AWR RMM (pending install), Short Shifter
Mfinlay04 is online now   Reply With Quote
 Old 08-04-2012, 12:09 AM   #24
Originally Posted by ArtClassShank View Post
What about chassis?
Supposed to be really good. I know older fusions had a good solid suspentions. This has an independent rear multilink suspension.[/markethype]
The 2.0L 6 Speed Ecoboost uses the ford 6F35 Transmission With PowerShift. I dont think its dual clutch but I can't find anything definitive on it. It seems like a newer better transmission than others, but again theres little on it.
http://www.gearsmagazine.com/view.as...d-2a3f2b8378fc
The Fiesta/Focus transmission is called "PowerShift" and it is a Dual Clutch transmission. But I think it's limited to europe.
Ford_PowerShift_transmission Ford_PowerShift_transmission
 Old 08-04-2012, 05:02 AM   #25
johnnyspeed6's Avatar
Posts: 1,363   (View Stats)
johnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the world
I WILL buy if they ever get the balls to drop the 3.5 TT Eco Boost in that monkey... If buick wont make another Grand National maybe ford will come close .. I know you can get the TT V6 EcoBoost in the taurus but that bastard is heavy and not as sexy .. come on ford ... COME ON.
2008 HG Bullitt Mustang. Long Tube headers, SCT tuner,MGW short throw, FRPP hot rod cams high flow cats, charge motion plate delete
johnnyspeed6 is offline   Reply With Quote
The Following User Says Thank You to johnnyspeed6 For This Useful Post:
speed23 (10-20-2012)
 Old 08-04-2012, 09:01 AM   #26
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,540   (View Stats)
Groans: 68
Groaned at 91 Times in 65 Posts
Yea I might consider trading if they offered a 3.5 TT with manual. The car looks good. Ford is really getting their shit together.
 Old 08-04-2012, 04:47 PM   #27
I doubt it. All options for the Fusion are I4. Plus they dont want to compete with the taurus.
 Old 08-04-2012, 05:03 PM   #28
Mi06Speed6's Avatar
Posts: 105   (View Stats)
Mi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond repute
I believe the car is built off the old Mondeo. The 2013 Ford Mondeo and Fusion will be built on the same platform so there seems to be some hope for the car. And lets be honest, after driving the notchiest and hardest to learn gearbox in this Speed6, I'm almost ready for paddles. I think there is some hope for the 2.0L ecoboost but I don't it'll ever be able to produce what the speeds are capable of. Still a nice saloon though.
'06 Mazdaspeed 6|| Cobb SF & AP Stage 1 | RPM Street Springs | SPC Ball Joints | SU Rear MM | SURE Dread | Whiteline RSB |18x8 Enkei EKM3 w/ 225/40 | JBR SSP & SURE Anchors | Rotora Blanks w/ EBC Red Stuff | 6K HID lights/fogs | V2 Pre-amp |
Mi06Speed6 is offline   Reply With Quote
 Old 08-04-2012, 06:04 PM   #29
Yep, its built off the Mondeo. The Mondeo also has a Dual Clutch Transmission that may be able to be mated up to the Fusion. We'll just have to wait and see.
 Old 08-04-2012, 09:46 PM   #30
Matx's Avatar
Posts: 1,625   (View Stats)
They should get some gas, its really low
Mods: Come find out
"Man, ya'll have those dam scaners! we needs somo thos"
"FYMSN" - Honda
"its not yall its me."
The Following User Says Thank You to Matx For This Useful Post:
DiGi Faggot (08-04-2012)
 Old 10-19-2012, 06:33 AM   #31
ManMan's Avatar
Posts: 35   (View Stats)
ManMan is a jewel in the roughManMan is a jewel in the roughManMan is a jewel in the roughManMan is a jewel in the rough
I'm actually considering looking at the 1.6 MT option. Most of the reviews right now are favoring it's handling over the heavier 2.0 AT. And the MPG would be welcome!
Of course... None of that happens till my MS3 dies!
2007 MS3 - Koni 4040 FSDs, Cobb SRi, Cobb AP Stage 1+, DIY shifter bushings, CorkSport RMM inserts, Hawk HPS, Slotted rotors, SS Lines.
ManMan is offline   Reply With Quote
 Old 10-20-2012, 12:12 PM   #32
CaptObvious75's Avatar
Posts: 394   (View Stats)
Totally off topic but KITTEH!!
 Old 10-20-2012, 04:35 PM   #33
Neverlift's Avatar
Posts: 3,119   (View Stats)
Groans: 542
Groaned at 181 Times in 120 Posts
Same block as the MZR... a MS6 AWD trans and PTO may bolt up.
'04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//OEM Hardtop//Bride Gias II//Autokonexion CF Trunk v2
'06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line//Spin On Oil Filter Conversion
'91 MR2: Planned 1MZ V6 or 3SGTE swap
Driver Mod Level: Focus ST Academy So Cal Champion '12
HTML code is On
Followup: Pricing added to 2013 Ford Fusion configurator Haltech Automotive News 0 05-22-2012 02:30 PM
Official: 2013 Ford Fusion configurator powers up Haltech Automotive News 0 05-08-2012 10:30 AM
Official: 2013 Ford Fusion debuts along with 47-MPG Fusion Hybrid, 100-MPGe Fusion Energi Haltech Automotive News 12 01-09-2012 08:06 PM
Breaking: 2013 Ford Fusion leaks onto web... again Haltech Automotive News 0 01-08-2012 08:20 AM
Detroit: This is the 2013 Ford Fusion Haltech Automotive News 0 01-06-2012 02:30 PM
Page generated in 0.56990 seconds with 44 queries
