Other Platforms
Ford Focus Ecoboost 2.0 Discussion(ECOBOOSTFORUMS.ORG)
> Ford Focus ST Ecoboost - General Discussion
Ford Focus ST Ecoboost - General Discussion Discussion of Ford Ecoboost Engines
Like Tree2Likes
  • 1 Post By rfinkle2
  • 1 Post By SPEED6 KILLAH
 Old 11-28-2012, 01:09 PM   #1
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
Default Disi rods vs ecoboost rods
I have been do some heavy reseacrh on the new ecoboost 2.0 that in the new ford
focusST here is some picture of the ECOBOOST piston rods and compared it with are DISI rod.
Now looking at ecoboost not sure how much boost it a hold up to vs DISI rods which we all know to hold up to 21psi
Ecoboost rod is lighter then are DISI and skinner too.
Here is a picture of both of the rods together.
SPEED6 KILLAH is offline   Reply With Quote
The Following 16 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
atvfreek (11-29-2012), DingoDave (12-01-2012), Easter Bunny (11-29-2012), Elusivellama (12-12-2012), fredricktsang (11-29-2012), ink28 (11-29-2012), Lex (11-29-2012), MS3-a(sore)ASS-rex (11-29-2012), Pointless (11-28-2012), rfinkle2 (11-29-2012), silvapain (11-29-2012), Speed3eak (11-28-2012), TWOptSL0W (11-28-2012), Vader (11-28-2012), Vansquish (11-28-2012), xb2ms3 (12-02-2012)
 Old 11-28-2012, 01:13 PM   #2
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Well they are both powder forged bullshit. Looks like they are using a different mixture of metal on the eb rod though. I bet its stronger than the disi rod with a more dense metal makeup.
 Old 11-29-2012, 07:44 AM   #3
kmac's Avatar
Posts: 1,792   (View Stats)
That's funny because that's not what the showed in there breakdown engine.
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
The Following 4 Users Say Thank You to kmac For This Useful Post:
btstarcher (11-29-2012), Easter Bunny (11-29-2012), rfinkle2 (11-29-2012), SPEED6 KILLAH (11-29-2012)
 Old 11-29-2012, 08:03 AM   #4
Posts: 12,651   (View Stats)
The small end taper is there for reducing friction losses on the non loaded side of the bearing. Can you take measurements of the thickness in both planes? The actual cross sectional area of the beam might be similar since the EB rod looks thicker along one axis and thinner along another.
It also looks like they are using cracked caps on the big end - the metallurgy is probably different in the EB rod. Without knowing anything about the metallurgy in the EB rod we can't assume much of anything.
How many of these rods do you have and are you able to send one out my way? Send me a PM.
atvfreek (11-29-2012), G26 (11-29-2012), kmac (11-29-2012), rfinkle2 (11-29-2012), Snap Off (12-11-2012)
 Old 11-29-2012, 08:23 AM   #5
fredricktsang's Avatar
Posts: 459   (View Stats)
fredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the world
this will get interesting!!!
fredricktsang is offline   Reply With Quote
The Following User Says Thank You to fredricktsang For This Useful Post:
G26 (11-29-2012)
 Old 11-29-2012, 08:33 AM   #6
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
For sure
Sent from my balls via my penis
 Old 11-29-2012, 08:36 AM   #7
are you guys going to run stress tests on the EB rods?
 Old 11-29-2012, 09:12 AM   #8
[/URL]
Here are some more picture with the measurement on both of the rods
The Following 2 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
kmac (11-29-2012), Lex (11-29-2012)
 Old 11-29-2012, 09:18 AM   #9
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I know what Pablo needs for Christmas.
atvfreek likes this.
The Following 8 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (11-29-2012), BigRedSpecial (11-29-2012), Easter Bunny (11-29-2012), exentix (11-29-2012), kmac (11-29-2012), MS3-a(sore)ASS-rex (11-29-2012), Neverlift (11-29-2012), silvapain (11-29-2012)
 Old 11-29-2012, 09:24 AM   #10
Here are some more pictures. Just by look at the rod cap EB look like one solid rod. I know the gen2 rod caps are broken off just like the EB rod.
Not yet I am working on get a custom rod made first for this EB block that I am building.
Last edited by SPEED6 KILLAH; 11-29-2012 at 09:24 AM. Reason: MSF Database - Automerged Doublepost
The Following 5 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
Easter Bunny (11-29-2012), fredricktsang (11-29-2012), kmac (11-29-2012), Lex (11-29-2012), rfinkle2 (11-29-2012)
 Old 11-29-2012, 09:39 AM   #11
Here is some picture if the DISI and EB piston.
kmac (11-29-2012), Lex (11-29-2012), Pointless (11-29-2012), rfinkle2 (11-29-2012), silvapain (11-29-2012)
 Old 11-29-2012, 09:47 AM   #12
kmac's Avatar
Mahle makes the pistons and I'm not sure if it's them or Manley that makes the rods. Also on svt builds for out sources hardware to arp and one other company.
<3 Tokay.
The Following 2 Users Say Thank You to kmac For This Useful Post:
 Old 11-29-2012, 09:55 AM   #13
yeah I seen that just found the info on the rods here is the link
some good info sound like it good to up to 479 lb·ft TQ
Mahle develops ultra-lightweight connecting rod
The Following 3 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
 Old 11-29-2012, 03:17 PM   #14
These rods do seem to be similar in design to the article above - if Mahle is indeed behind them it is good to know that they used the 46MnVS6 material. The wrist pin bushing does seem to employ their oiling design principles (notice no oiling holes in the small end). Also note that they are thicker than our rods in the plane parallel to engine rotation.
That being said, the 3.6L V6 from Chrysler makes only 260 ft lbs, not 479 - they made a mistake there. The rods can't be directly compared as that is a different application.
The take-away number there is 1.2. Essentially that tells you how much above spec OEM rods are tested to. That is 1.2x above peak loads but remember that peak loads on a rod does not mean a 1:1 relationship to peak engine torque. You can increase torque at a higher rate than increasing peak force on the rod.
A total shot from the hip is that these rods are lighter and a better design than the DISI but the overall strength is fairly similar and they are safe (long term) when increasing torque by 1.3-1.5x above stock.
atvfreek (11-29-2012), G26 (11-29-2012), kmac (11-29-2012), rfinkle2 (11-29-2012), SPEED6 KILLAH (11-29-2012)
 Old 11-29-2012, 03:36 PM   #15
ms3rick's Avatar
Posts: 2,959   (View Stats)
damn
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f598/disi-rods-vs-ecoboost-rods-131428/
The ST Turbo Thread - Page 7 This thread Pingback 01-08-2014 06:32 PM
Upgraded Rods & Pistons - Page 6 This thread Pingback 10-30-2013 12:10 PM
The ST Turbo Thread - Page 6 This thread Refback 10-24-2013 02:27 PM
HTML code is On
New Eagle Rods for MZR DISI engines! R.MS3 MazdaSpeed 3 - Engine, Transmission & Driveline 52 01-30-2012 02:13 PM
MZR 2.3 DISI Rods from cp-e™ www.cp-e.com Custom Performance Engineering (cp-e.com) 4 03-22-2011 06:08 PM
MZR 2.3 DISI Rods from cp-e™ www.cp-e.com 2010 MS3 - Engine, Transmission & Driveline 0 03-22-2011 12:29 PM
Pistons and Rods or just Rods ms3-87 MazdaSpeed 3 - Engine, Transmission & Driveline 38 04-14-2010 02:55 PM
FYI: Carrillo Rods vs. Factory Rods JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 45 02-20-2009 10:07 AM
Page generated in 0.44834 seconds with 27 queries
