Coal Rolling is better http://static.neatorama.com/images/2...-repellent.jpg |
So.. @Mike@Stratified; @Lex; and @jbmazda6; We should be seeing a dyno comparison with tuned stock dp vs tuned cpe catted dp yes? |
@jbmazda6; did you guys do any before and after dyno comparisons? |
We will also have to look at differences in temperature and humidity. Even though the dyno "corrects" for that, the car still runs differently in different weather (not a boost based tune) so that will have to come into consideration. Thank you everyone (who is interested) for being patient.. the time has almost come. |
Does the stock dp in this conparison have a race pipe? |
So both the cats then? I think it would make more sense to have a racepipe/nator midpipe installed since that is the easier/cheaper option than a full downpipe install. Not to mention you should remove a cat in order to use a stage 2 OTS tune. |
But effectively tp with oem cat is comparable to long catted dp stage 2 ots should be attainable |
Cpe replaces both oem cats with 1 high flow cat. |
The title of this thread is "does a downpipe make a difference", all but ONE of the options for the speed6 is a long downpipe so replacing the downpipe generally means replacing both cats. Its not saying whether a test pipe or downpipe is better. I have an opinion on that but dont feel like even touching on it until I see the numbers saturday. |
Well downpipes usually eliminate both cats or replaces one of them with a high flow cat. So if the purpose of this test is to compare a stock downpipe and midpipe to an aftermarket downpipe with no cats or one high flow cat, I suspect that a 15 HP difference will be seen and I doubt anyone will disagree with that. Most of the arguements I have had involves a stock downpipe + race pipe/NATOR midpipe vs any aftermarket downpipe, catted or not on a stock turbo. Seriously, who is going to tune with both stock cats in the car? |
They are buried in old threads, though, and I'm not going to search for them. |
So... What happened to all these test results. |
With so many people going to mid turbos, I can offer some data that won't mean much to the K04 crowd. Better than nothing I spose... Same dyno, similar mid ~70F temps for all pulls. The E85 K04 setup was 68mm intake and test pipe only. The BNR S3 pulls were Gutted UPPER DP and stock test pipe vs ATP long catless. The results were impressive - so I would use the same train of thought we typically use for intakes - if you might go bigger later, you may as well go full 3" out the hiney now, unless you're concerned about expediting K04 seal failure. http://i.imgur.com/9SKFPSSh.png |
I'm stuck around 320whp on my 3076. High flow cat, resonated testpipe, and stock catback. Also, low compression in cylinder 3. But I'm definitely leaning towards opening up the catback now. I keep reading that I'm leaving about 15hp on the table, which seems to line up with your numbers. |
Thats it... I am selling my brand new Corksport Downpipe I got coated with ceramic... just gotta get to 150 posts! |
Hoping a DP has some utility on the new CS turbo as I just dropped in a Cobb DP with it when my K04 decided that it deserved a line in my budget named oil consumption, but if nothing else it makes the car sound cool... : / |
Food for thought: Vdyno from 09 juan- Both oem cats OEM tmic 4" htp intake E25-E30 AFR line has lb/min data in it. |
It seems most of the people claiming a 3" downpipe produces no gains on the K04 are running E25 or other higher ethanol fuel and ethanol specific tunes. That data may not translate to the same conclusion for those of us who do not have ready access to ethanol blends and are running pump gas 93 octane. On pump 93 I experienced significant gains with a 3" catless dp/rp, a CAI intake and a modest tune, reaching 300/300. That's about all you can squeeze out of the stock turbo without adding more ethanol. My datalogs support a significant gain from increased exhaust side flow upstream (3" dp and rp) when limited to pump gas and the stock turbo. |
On pump gas, we can use the extra exhaust side flow to increase lower - not as well as higher ethanol, but better than with stock dp/rp. |
But you talked about how you saw gains by going to 3" DP/TP together, which, well...obviously. The discussion at the heart of this thread is how much additional gain was it versus just a 3" catless TP. I'd also be curious to see a 93 comparo in addition to the E mixes, I'm just taking umbrage with the way you're relating it to your jump from stock exhaust to a 3" long DP, having skipped the step in between of running only the TP. |
I think what @Lex; has said earlier in the thread supports this idea: Quote:
In short- I'm suggesting that due to the smaller size of the housing and turbine wheel, the K04 doesn't necessarily need a much larger hotside pressure differential created by replacing or removing OEM exhaust components. I think that there's some evidence too with @JgamB;s post with the BNR which has a larger turbine wheel- and maybe a K04 based hotside, depending on which version it is. He saw substantial gains not seen in this thread's K04 comparison from upgrading to aftermarket catless DP, particularly at the top end of the rev range. Perhaps the larger turbine wheel needs a larger hotside pressure differential to maintain wheel velocity at the top end? With my work on the modified K04- which is using a ported hotside and a larger turbine wheel, I'm beginning to believe that I may have to uncork the exhaust a bit (a larger hotside pressure differential) to get maximum speed/flow from the turbine wheel at the top end of the rev range. |
There are 2 things to consider. 1. Pumping losses. The easier it is to get exhaust out, the less power you lose doing so. This is a bit of a moot point on turbo cars as the turbo acts as a really big restriction. 2. Pressure differential across the turbine. The higher the differential the more energy you can put into spinning the turbo. This means higher turbo speeds and response times. This is where most see gains - with a catless setup the pressure differential across the downpipe increases and allows you to put more energy into the turbo. |
So on the topic of this thread. I have all mods that are in my sig and feel that my little K04 pulls really good. Self tuned to 19.5 tapering to 17 @6k I typical Via AP show peak about 20.2 with 308g/s, Now from reading this thread it seems like I'm flowing really good?, NO? Anywho I was debating on getting DP, but doesnt seem it is worth it. Going to get A CNT CBE cause I want it for sound, but My question is IF I upped my Intake to 3-3.5 MAF It seems I would pick up more power g/s Per second but would that also drop my WGDC since it would be flowing more g/s making Boost Achieved more Easily? Does that sound about right? Also trying to find a local e85 but having trouble finding one. since that seems to be some very easy power made Thanks |
so confused as to why people buy such expensive downpipes. i got mine for 125 and it does the same thing :/ |
Because not all downpipes are the same. Different flange designs, different fitment, different ease of install. |
Could be wrong, but I believe the Corksport DP is the only one that offers a 'divorced' design; so if that's someone's preference, they have to pay a bit more for it than an ebay special. |
| All times are GMT -7. The time now is 01:46 AM. |
