@Lex, should we have gotten a tracking number? |
The shipping time is 4 business days to the US and they are all insured. |
I'm debating ordering... lex hook me up :D lol no shipping just bring it down with you to dyno day. |
woohoo look what i got in the mail today! http://dl.dropbox.com/u/6210299/luls...517_130601.jpg smells like IKEA in there, wtf @Lex? |
^^^ That made my day! |
I LOLed. Nice. Tappin |
Back from Montreal and I have 2 more units to ship immediately before I'm off to San Diego for the dyno day. Any takers? |
saw a prime example of why this would be useful at the dyno day event we just had... *cough* @TRSpeed *cough* |
@Lex - the GA saved me today while doing some "spirited" driving on the highway. When it first activated, I was like wtf?, then I saw the red LED lit up and said "phew, thank you GA!", lol. Thanks for a great product! |
Ill be getting one Lex just that right now funds are somewhere else. But ya the GA would have seriously helped, Dammit. Thanks for coming out btw! Sent from my DROID4 using Tapatalk 2 |
10 Attachment(s) I'm sure most of you guys have already installed it, but for those who havent, or have not yet ordered one, go get it! attached are photos of my install today. took around 1 hour. I work slowly :) Attachment 62659 Attachment 62660 Attachment 62661 Attachment 62662 Attachment 62663 Attachment 62664 Attachment 62665 Attachment 62666 Attachment 62667 Attachment 62668 |
Has anyone hooked up the meth failsafe? Is it compatible with a DO kit with the progressive controller? |
ok, one last question: If the power to this unit were to fail.. for whatever reason, lets just say that there's danger to my intake manifold welds and my bolt holding the ground down just flies off.. Would it just go into a bypass mode or will it leave it "shut"? I tested recently and its working great. Just trying to find the sweet 23psi spot. i really need to get a new map sensor too :( |
If power goes out the unit fails in the normal, non triggered position. If your power lines are flaky you will see it come in and out via the LED blinking. I've built in that self test every time it is powered just for this reason - so that you know all is well every time you start the car. With the GA as a safety net and properly set, you can bypass the stock MAP sensor boost cut if you so desire and run more boost but make sure you also have a gauge going over 22psi to keep an eye on it. In the end if shit really hits the fan the factory boost cut will take too long to respond anyways. |
@Lex I have question. My wife is freaked out to drive my car. Could i effectively use this unit to dial back the boost when she drives it on occasion? Having to flash a map for her to drive it one place and back is annoying (as is her adversion to spool). To pop the hood and dial it back a bit would be great, and make her feel more comfortable with driving the car knowing its not gonna rocket down the road suddenly. |
Thats what i told her. It only makes boost if you want it too. I'd rather her just not drive my car at all really. But there are moments when its necessary. So i was curious. She can drive and prefer's manual and thats what she drives, she just doesn't care for all the POWAH. If i could dial it back we'd both be a little better about it. |
OT but u could alter your APP tables to delay power application until the pedal is mashed down more. It removes the on/off feeling of the throttle. Tappin |
For me, this scenario will be avoided for the most part. But in an instance she does have to drive she wont be thinking, if i push the pedal down to far the car will kill me. This is why i'm buying a 3rd vehicle soon. |
This might make me sound picky but, i'm waiting till the GA is offered in black till I order. |
Lex, I'm interested in another GB..... |
Also looking at your website, how does this effect MPG when change your BOV to VTA over RECIR using the GA? http://www.stratifiedauto.com/index....roducts_id=217 "Another feature of the GA is that it allows the use of vent to atmosphere push-type valves to be run in MAF based vehicles. In MAF based vehicles, releasing a BPV or BOV to atmosphere causes very rich conditions at idle and during shifts. With this feature enabled (see how to enable it in the document below), the GA will stop the BPV from leaking at idle and during shifts allowing you to run the valve in VTA (Vent to Atmosphere) without a loss of driveability. Check out the video below of a MazdaSpeed3 running in full VTA" |
I'd be down for group buy |
On the serious side, what's the max V that the external trigger can accept? Your instructions say 5V or higher, but not the max...? I'll be installing the AEM WMI Failsafe that has a 12V out alarm trigger and I want to make sure that will work with the GA. |
group buy yes yes yex |
We're going to have a little something for Black Friday ... |
Might pick one up over BF. Genuine question, is this like a Go Fast Bits Turbo Fuse? Or what is the differance between the two? |
| All times are GMT -7. The time now is 01:58 AM. |
