-   -   GI: Guardian Angel (Overboost Protection) (http://www.mazdaspeedforums.org/forum/f600/gi-guardian-angel-overboost-protection-104486/)
Lex 11-26-2013 03:52 AM
Originally Posted by cletusb (Post 2355835)
Might pick one up over BF.
Genuine question, is this like a Go Fast Bits Turbo Fuse? Or what is the differance between the two?
Their device is a mechanical device (ours is electronic) that doesn't have a precise trigger setpoint, external trigger, driver warning, or VTA feature for the BPV.
p057 02-14-2014 11:54 AM
Originally Posted by hnda etr (Post 2355306)
I'll be installing the AEM WMI Failsafe that has a 12V out alarm trigger and I want to make sure that will work with the GA.
I just got the Snow Safeinject from my favorite ginger, @gingermike;
I will be wiring this thing up next weekend(hopefully). The safeinject sends out a 12v signal when it detects flow rate drops below a preset point. I have a toggle switch override on the pump so i can simulate a "low flow" event and see how long it takes for the safeinject to react and then the GA to react on top of that and pop the valve.
this should be fun :)
I think that completes the full safety circle at that point. aaaand next month my motor will just blow for no reason whatsoever.
Lex 02-15-2014 11:46 AM
Which version do you have of the SafeInjection? I was under the impression it triggered a ground instead of a 12V. With a 12V trigger it will definitely set off the GA.
theurgy 02-15-2014 01:44 PM
If it has just a ground trigger, can't you put a relay in and convert it to a 12v trigger?
Lex 02-15-2014 01:46 PM
Yes this is the simplest solution.
p057 02-15-2014 07:00 PM
if it has a ground trigger, yeah, i'll do a relay to switch it.
oh how I love relays and more wiring in the car.... :/
Thanks guys. :)
hnda etr 02-20-2014 02:33 PM
Can anyone outline how to wire a relay to take a +0.5V trigger and convert it into a +12V signal the GA can handle?
theurgy 02-20-2014 02:46 PM
0.5V or 5V?
theurgy 02-20-2014 02:52 PM
Here's some good info for you:
FAQ: RELAYS; how they work and how to wire it up...
Lex 02-20-2014 08:56 PM
I will try and do a simple diagram.
You want a single pole, single throw relay.
http://www.mazdaspeedforums.org/foru...1&d=1392954947
hnda etr 02-27-2014 01:50 AM
Originally Posted by theurgy (Post 2461974)
0.5V or 5V?
0.5 V
Originally Posted by theurgy (Post 2461985)
Thanks!
Thanks again!
Page generated in 0.18958 seconds with 11 queries
