E-Tuners / Custom Hardparts
View Poll Results: Would you buy the Guardian Angel?
Yes - no more overboost fears! 141 92.16%
No ... 12 7.84%
Voters: 153. You may not vote on this poll
Like Tree33Likes
 Old 03-09-2012, 02:28 PM   #121
ScottyP's Avatar
Posts: 209   (View Stats)
ScottyP has a reputation beyond reputeScottyP has a reputation beyond reputeScottyP has a reputation beyond reputeScottyP has a reputation beyond reputeScottyP has a reputation beyond reputeScottyP has a reputation beyond reputeScottyP has a reputation beyond reputeScottyP has a reputation beyond reputeScottyP has a reputation beyond reputeScottyP has a reputation beyond reputeScottyP has a reputation beyond repute
1. starscream
2. mtlms3
3. mrmonk7663
4. Gringo East
5. Sid3wayS
6. speed_freak91
7. ryno077
8. fooqr
9. obijack
10. Sleeperhatch
11. EL F00LI0
12.mroclimbr
13. MS3kid08
14. p057
15. Ckmazdaspeed3
16. blendedej8
17. JTMS3
18. Angr-E1
19. QwkEVO
20. skeurton
21. Dizzydtrain
22. ScottyP
I am all about this. this is legit
Last edited by ScottyP; 03-09-2012 at 02:30 PM. Reason: didn't see the "add yourself" :P
ScottyP is offline   Reply With Quote
The Following User Says Thank You to ScottyP For This Useful Post:
Lex (03-09-2012)
 Old 03-09-2012, 03:01 PM   #122
Derek wrote a great review with videos and logs: http://www.mazdaspeedforums.org/foru...3/#post1302377
charlesfist (03-14-2012), Dano (03-12-2012), djuosnteisn (03-12-2012), ScottyP (03-15-2012)
 Old 03-09-2012, 03:02 PM   #123
QwkEVO's Avatar
Posts: 484   (View Stats)
QwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the world
I see Lex lurking.....better get to work and make up another batch! lol
08 MS3 //PTP Injector seals & stud kit //CP-E RMM //Corksport Sway Bar // Koni Yellow Sports // Eibach Pro Kit Springs // Enkei 18" PF01's //
QwkEVO is offline   Reply With Quote
The Following User Says Thank You to QwkEVO For This Useful Post:
Lex (03-09-2012)
 Old 03-09-2012, 04:58 PM   #124
HPFPUPGRADE's Avatar
Posts: 403   (View Stats)
HPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the worldHPFPUPGRADE is the leader of the world
Groaned at 22 Times in 17 Posts
Install is very simple and I will post it here shortly. Basically, you need power and ground (add a fuse in the stock fuse panel and use the ground on fender where the battery grounds).
You also remove the BPV vacuum line, plug this line into the Guardian, and then plug the second port from the Guardian into the BPV.
The LED you can route into the the cabin without any modifications through the hood release cable passthrough.
So there are no modifications that are not reversible and it should take no more than 1 hour to install.
Any worries about potential over spinning the turbo with the BOV open while the turbo is still trying to target XX boost?
This also got me thinking about being on PCM controlled boost. If there is a leak and the system cannot see it, will the adaptive in the PCM continue to adjust to reach that target?
HPFPUPGRADE is offline   Reply With Quote
 Old 03-09-2012, 04:59 PM   #125
708
Erich's Avatar
Posts: 4,274   (View Stats)
Warning is already stated that it is not to be used as a boost controller.
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
Erich is offline   Reply With Quote
The Following 2 Users Say Thank You to Erich For This Useful Post:
Lex (03-09-2012), rfinkle2 (03-13-2012)
 Old 03-09-2012, 05:03 PM   #126
This depends on how it is setup. If you are in load tuning mode and recirculating then it will still target load based on what the MAF sees regardless of whether the BPV is open or closed.
The ECU will always try and reach targets. This device is meant to save the motor from a catastrophic condition, not to be ridden on every day as a means to control boost.
The other thing to note is that once you're building less boost, you're generating less exhaust, and are naturally not going to spin the turbine as fast.
86AmishMs3 (03-18-2012)
 Old 03-09-2012, 05:03 PM   #127
Thanks, so this would simply be for boost cut if over boost happened?
I only ask because I made something very similar to this for the SRT4 market and it killed several turbo's in a very short period of time, product never made it to market because of this.
 Old 03-09-2012, 05:04 PM   #128
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
If you see the logs you'll notice the charge air pipes are still pressurized even when the BPV opens. IM pressure remains at about 7-10 psi. I.e. there is still back pressure holding the compressor from overspining.
The engagement feels really gentle.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
charlesfist (03-14-2012), Dano (03-12-2012), jracer (03-10-2012), Lex (03-09-2012)
 Old 03-09-2012, 05:07 PM   #129
Sorry to hear that John, I've had my little K04 under this condition many times and I haven't seen a single issue.
It would also mean that every time someone blew a coupler off a charge pipe the turbo would be sacked.
 Old 03-09-2012, 05:07 PM   #130
In boost tuning mode this could become a problem?
I am only commenting on this because you stated, "- It is a much gentler cut than the fuel cut. The car will feel like it lost power, but you will still be able to keep your foot in it if you choose. This is NOT a fuel cut or ignition cut."
Keeping your foot into the throttle with the BOV open could be catastrophic to the turbo, RPM's could potentially kill the turbo.
Other than that, its a great idea!
 Old 03-09-2012, 05:10 PM   #131
Could potentially kill a turbo and actually kill a turbo are very different things. If you're in the middle passing someone and you have oncoming traffic I think I would rather have the option to keep my foot in it instead of hitting a fuel cut.
 Old 03-09-2012, 05:10 PM   #132
708
Erich's Avatar
If the driver is dumb enough (or actually REALLY needs) to keep their foot in it, better the turbo then the engine.
The Following 3 Users Say Thank You to Erich For This Useful Post:
jracer (03-10-2012), Lex (03-09-2012), p057 (03-21-2012)
 Old 03-09-2012, 05:13 PM   #133
Again, it is meant to be a failsafe that is ECU and wastegate independent. It's another layer of safety for the vehicle while tuning and modifying.
 Old 03-09-2012, 05:14 PM   #134
The K04 might be stronger than it looks then.
Not really because when you blow off a coupler or charge pipe the turbo its a spike in RPM then you lift off the throttle (for obvious reasons). If the BOV is being held open then the turbo is allowed to increase RPM over time, thus the WGDC tables will continue to climb putting additional RPM in the turbo until a different cap is hit inside the PCM (boost tuning only I assume).
Have you verified turbo RPM with the BOV open?
The Following User Says NO Thank You to HPFPUPGRADE For This Un-useful Post:
Easter Bunny (06-10-2012)
 Old 03-09-2012, 05:19 PM   #135
When you see the RED led turn ON, unless you have a good reason not to, you should also probably lift off the throttle and analyze why you overboosted and triggered the device.
You will not hit a "cap" inside the ECU because even with the WG closed and the device triggered, your boost won't continue climbing. So you can stop assuming. You should know this already from having designed a similar device, right?
charlesfist (03-14-2012), djuosnteisn (03-12-2012), Easter Bunny (06-10-2012)
 Old 03-09-2012, 05:20 PM   #136
Bob Ross Fanclub
Tomas's Avatar
That's not how it works.
Once you lose charge air pressure there is also less air flow / pressure on the turbine. It's almost instantaneous. The air resistance against the compressor, even when boosting into empty space, overcomes the inertia of the rotor.
charlesfist (03-14-2012), djuosnteisn (03-12-2012), Lex (03-09-2012)
 Old 03-09-2012, 06:01 PM   #137
It looks like a great device, I was just wondering about turbo RPM and if there were any concerns.
Very good idea and a great price!
 Old 03-12-2012, 01:46 PM   #138
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Jesus john.... can't you just let someone else have a good idea for once?
86AmishMs3 likes this.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 11 Users Say Thank You to djuosnteisn For This Useful Post:
86AmishMs3 (03-18-2012), charlesfist (03-14-2012), Ckmazdaspeed3 (03-12-2012), daafisch (03-12-2012), Dano (03-12-2012), dereeek (03-12-2012), Easter Bunny (06-10-2012), Lex (03-12-2012), p057 (06-03-2012), SleeperHatch (03-20-2012), superskaterxes (03-12-2012)
 Old 03-12-2012, 01:59 PM   #139
Posts: 9,484   (View Stats)
Received my GA late last week and hope to tinker with it sometime this week and will post up a thread when completed.
BTW...John, its ok for someone else to develop products for our market.
The Following 6 Users Say Thank You to Dano For This Useful Post:
charlesfist (03-14-2012), djuosnteisn (03-12-2012), Easter Bunny (06-10-2012), Lex (03-12-2012), p057 (06-03-2012), SleeperHatch (03-20-2012)
 Old 03-12-2012, 02:24 PM   #140
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
So @Lex not rushing or anything just curious do you have a ruff estimate of when you will have these up for sale?
TEAM LUXURY
Sid3wayS is offline   Reply With Quote
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
Lex (03-12-2012), ScottyP (03-12-2012)
 Old 03-12-2012, 08:57 PM   #141
Estimates are hard right now just because I am still working 2 jobs. That will change in a week and things will be moving much faster.
QwkEVO (03-12-2012), rfinkle2 (03-13-2012), Sid3wayS (03-12-2012), skeurton (03-13-2012), SleeperHatch (03-20-2012)
 Old 03-13-2012, 10:06 AM   #142
I want to see more reviews! Everyone should have gotten theirs by now from the first batch.
Dano (03-13-2012)
 Old 03-13-2012, 10:33 AM   #143
Lol. Now the impatience is coming from the other side.
I have mine mounted and the wiring almost done but still need to plumb it and tidy up
Maybe tonight.
Tappin
Lex (03-13-2012)
 Old 03-13-2012, 10:37 AM   #144
bigriver's Avatar
Posts: 1,123   (View Stats)
Lol! I need to pick up an Add a fuse and find a wire coat hanger. Mine will be on soon.
The Following User Says Thank You to bigriver For This Useful Post:
Lex (03-13-2012)
 Old 03-13-2012, 11:17 AM   #145
event's Avatar
Posts: 521   (View Stats)
event is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the world
I'll definitely buy one when I turbo my miata.
***sold*** 06 MS6 Cobb SRI 3.5" ETS TMIC Cobb AP Sure RMM JBR SSP EBay Catless DP Autotech HPFP Magnaflow
2013 Scion FR-S 6MT
1993 Mazda Miata with shocks, springs, fsb, GT2560r, Megasquirt
event is offline   Reply With Quote
The Following User Says Thank You to event For This Useful Post:
Lex (03-13-2012)
 Old 03-16-2012, 10:26 PM   #146
speed_freak91's Avatar
Posts: 1,189   (View Stats)
speed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the world
Groans: 34
Update? Still interested in picking one of these up when the next batch arrives.
speed_freak91 is offline   Reply With Quote
The Following User Says Thank You to speed_freak91 For This Useful Post:
Lex (03-16-2012)
 Old 03-18-2012, 04:21 AM   #147
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Hahaha at John.
Hardly seeing this as being bad for the turbo....and chances are it should never be used. Just a failsafe against fail.
Anyways put me down for the 3rd batch... alittle low on skrilla.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
Lex (03-18-2012)
 Old 03-19-2012, 03:25 PM   #148
Wondering if you guys installed the unit and how it went ... reviews, impressions ...
@rfinkle2
@Dano
@the_rolex_guy
@bigriver
@starscream
 Old 03-19-2012, 03:38 PM   #149
bigriver's Avatar
I finally have all the things I need for the install. The vacuum tube I plan to use has 7/32" ID. This fits really snug on the bpv out nipple on the GA as well as the inlet on the oem bpv.
Lex (03-19-2012)
 Old 03-19-2012, 06:34 PM   #150
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Lex, my apologies.
I have every intention of installing this weekend.
Lex (03-19-2012), p057 (03-23-2012)
 Old 03-20-2012, 02:08 PM   #151
Day job is relentless with my time. I have it installed and just need to get time to collect data and put a thread together.
Tappin
Lex (03-20-2012), p057 (03-23-2012)
 Old 03-21-2012, 02:10 PM   #152
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
i can haz?
'08 CWP MS3 w/ T3 3071r
The Following User Says Thank You to 802MS3 For This Useful Post:
Lex (03-21-2012)
 Old 03-21-2012, 02:14 PM   #153
Originally Posted by 802MS3 View Post
i can haz?
You can haz! I iz buzy placing orderz and getting theze madez!
The Following 8 Users Say Thank You to Lex For This Useful Post:
802MS3 (03-21-2012), Dano (03-23-2012), djuosnteisn (03-21-2012), Gringo East (03-21-2012), mtlms3 (03-21-2012), p057 (03-23-2012), speed_freak91 (03-21-2012), Tomas (03-24-2012)
 Old 03-21-2012, 05:07 PM   #154
Apparently it's monsoon season down here so no logging yet.
Tappin
Lex (03-21-2012), p057 (03-23-2012)
 Old 03-21-2012, 07:27 PM   #155
rfinkle2's Avatar
Groans: 298
Tappin
That was a better excuse than I had for Lex.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
Dano (03-21-2012), Lex (03-21-2012), p057 (03-23-2012)
 Old 03-21-2012, 11:24 PM   #156
Lol
I've been making excuses since before you were born.
Tappin
p057 (03-23-2012)
 Old 03-23-2012, 06:28 AM   #157
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
i couldn't make excuses.
Florida's seeing decent weather lately, i don't care about my job, and i've got a legitimate need for one and will install same day I get it.
Will drive my car until either the unit breaks or i get arrested.
The Following User Says Thank You to p057 For This Useful Post:
Lex (03-23-2012)
 Old 03-23-2012, 09:02 AM   #158
Sorry for the delays folks but getting something truly production ready takes time to do right but fear not - the 30 enclosures are in, PCB is being sent out for manufacturing today, electronic parts are bought and the harness supplier will be on board next week.
The details matter since this has been designed and built from the ground up including the electronics, software, enclosure, harness, and plumbing so validation is important - *cough* this is why I want these things to be running out there as much as possible so any issues come out of the woodwork.
Anyways, here's a little shot of what's under the skin:
The Following 7 Users Say Thank You to Lex For This Useful Post:
daafisch (03-23-2012), Dano (03-25-2012), djuosnteisn (03-23-2012), Gringo East (03-23-2012), mtlms3 (03-23-2012), Sid3wayS (03-23-2012), skeurton (03-23-2012)
 Old 03-23-2012, 10:52 PM   #159
Sid3wayS's Avatar
Groans: 97
@Lex I was woundering does the GA need a dedicated vac line? What I mean is Im planning on installing a boost gauge and the bpv line is the one that I have always seen beeing tapped, if I add a tee there and have one side go to my gauge and the other to the GA will it affect how it works?
TEAM LUXURY
 Old 03-24-2012, 05:04 PM   #160
bigriver's Avatar
Just finished install and took a quick drive. Set the dial at lowest setting. In third gear stepped on it an boost psi went to 11 psi then dropped to 8 psi and held. I need to use my AP though as i think the SG psi is wrong. LED also lit up. Cutoff was nice and smooth. I just had my scangauge so no logs. If I wasnt watching the SG, i wouldnt have felt the drop in boost. It was that smooth. I'm off to Vegas but will make some logs tomorrow.
Here are some pics. My LED is ghetto rigged on my dash for now, haha.
Just glad I'm not the last to install, lol
@Lex
@rfinkle2
Lex (03-25-2012)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f600/gi-guardian-angel-overboost-protection-104486/
Mazda MPS Owners Club • View topic - Overboost protection... This thread Refback 03-25-2012 04:24 AM
The Guardian Angel for your motor Lex Stratified Automotive Controls 158 10-28-2015 12:55 PM
Angel Eyes? Sparky_86 MazdaSpeed 6 - How-To's 26 05-20-2010 04:58 PM
Angel Eyes TXspeed3 MazdaSpeed 3/6 - Appearance 2 06-28-2009 08:36 PM
Angel Eyes Ballast kingpin748 Mazdaspeed3/6 General Discussion 0 04-20-2009 04:53 PM
Page generated in 0.61526 seconds with 37 queries
