E-Tuners / Custom Hardparts
View Poll Results: Would you buy the Guardian Angel?
Yes - no more overboost fears! 141 92.16%
No ... 12 7.84%
Voters: 153. You may not vote on this poll
Like Tree33Likes
 Old 03-24-2012, 09:37 PM   #161
Gringo East's Avatar
Posts: 198   (View Stats)
Gringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the world
Seriously, can't wait to get my hands on one of these. Not only an awesome motor savior, but some serious eye candy for under the hood! No doubt this is definitely going to save some speeds (and probably other turbos) in the north during winter months.
Side note: is it sad I already know where it's going?
Can't wait to have one! Getting stoked about the next batches progress.
Gringo East is offline   Reply With Quote
The Following User Says Thank You to Gringo East For This Useful Post:
Lex (03-25-2012)
 Old 03-25-2012, 01:58 AM   #162
@bigriver Thanks a lot for posting this review. Looking forward to those logs.
How long did it take you to set it to the appropriate level?
Have fun in Vegas!
 Old 03-25-2012, 03:29 AM   #163
bigriver's Avatar
Posts: 1,123   (View Stats)
Have fun in Vegas!
Hi Lex
Just got back. Gonna get some sleep then do some logs.
I didnt have my AP for the short test run so I havent set the GA yet.
The Following User Says Thank You to bigriver For This Useful Post:
Lex (03-26-2012)
 Old 03-25-2012, 06:36 AM   #164
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Bump for new page:
@Lex I was woundering does the GA need a dedicated vac line? What I mean is Im planning on installing a boost gauge and the bpv line is the one that I have always seen beeing tapped, if I add a tee there and have one side go to my gauge and the other to the GA will it affect how it works?
Share
TEAM LUXURY
Sid3wayS is offline   Reply With Quote
The Following User Says Thank You to Sid3wayS For This Useful Post:
Lex (03-26-2012)
 Old 03-26-2012, 11:13 AM   #165
bigriver's Avatar
Have fun in Vegas!
Tried logging yesterday but it rained all day. When it cleared up I went out, but then it started raining. Arrgh. Got in one log but the road was kind of dicey. Will try again tonight.
I had the dial set at about 10 o'clock and the GA cutoff boost just under 15 psi. I wasn't able to finish setting the GA.
File Type: xls bigriver_datalog47 3-26-12 guardian.xls (33.0 KB, 2 views)
The Following 2 Users Say Thank You to bigriver For This Useful Post:
Lex (03-26-2012), rfinkle2 (03-26-2012)
 Old 03-26-2012, 11:36 AM   #166
Originally Posted by Sid3wayS View Post
Bump for new page:
Share
You will have no issues with sharing the line with a boost gauge. Really, the GA is not a T in the line to the BPV, it interrupts the line. So as long as the GA sits in line with the BPV it doesn't matter if there is anything upstream from it.
Awesome thanks for the log! How did the activation feel? Also are you on the stock BPV?
Last edited by Lex; 03-26-2012 at 11:36 AM. Reason: MSF Database - Automerged Doublepost
rfinkle2 (03-26-2012), Sid3wayS (03-26-2012)
 Old 03-26-2012, 11:53 AM   #167
bigriver's Avatar
@Lex - Activation is silky smooth. There is no noticeable cut. It is really nice! The only challenge I have is figuring out where to permanently mount the LED so I can easily see it when its activated and it is clean looking. Right now its dangling on my dash lol.
Lex (03-26-2012)
 Old 03-26-2012, 11:57 AM   #168
Yes, it does look at little "limp" there. I know it's a little ghetto but I ran mine from the top of the steering column and simply taped it to the top of the column with a small piece of electrical tape. You can always drill some plastic piece and mount it there but this all depends on what you prefer.
 Old 03-26-2012, 12:10 PM   #169
bigriver's Avatar
@Lex - more notes for ya--
Yes-I'm on stock bpv. 7/32" tubing works well from bpv out on GA to the bpv nipple. 5/32" tubing works well from manifold tubing (using an adapter connection) to the bpv in on the GA.
Other install notes:
1. Used mini add a circuit and tapped into the "ENG BAR" 15A fuse. But needed to also buy a 15A mini fuse to plug into the add a circuit since the oem uses a low profile mini fuse. I also make sure when I start the car, that the LED lights up momentarily to confirm ready state.
2. Removed battery box so I could see the hole in the fire wall for the hood release cable. Not necessary to do this if you already know where to look. Used stiff coat hanger to push out the rubber grommet in the firewall where the hood release cable passes through. Then this opened up enough room to pass the LED wire through the hole in the fire wall. I didnt want to just force it through and risk damaging the LED.
Lex (03-26-2012)
 Old 03-26-2012, 12:13 PM   #170
2. Removed battery box so I could see the hole in the fire wall for the hood release cable. Used stiff coat hanger to push out the rubber grommet in the firewall where the hood release cable passes through. Then this opened up enough room to pass the LED wire through the hole in the fire wall. I didnt want to just force it through and risk damaging the LED.
Thanks for the notes! Just to add, the current draw from the unit is very low - a 5A fuse is plenty.
Also, I was able to actually put the hood release cable grommet back on once I passed the LED wire through. Not sure if you put it back on there or just left it.
 Old 03-26-2012, 12:29 PM   #171
bigriver's Avatar
Oh, the add a circuit has two fuse slots. The lower one for the original fuse (15A) and the upper one for the accessory (3A fuse used).
Ya I just left it. Dude you must have lobster claws or something cause I cant get my fat hands up in that space up there. Plus with all the blood going to my head from being upside down its hard to focus, lol!
Lex (03-26-2012)
 Old 03-26-2012, 12:39 PM   #172
My wife and I in Mexico
p057 likes this.
bigriver (03-26-2012), djuosnteisn (03-27-2012), kgb (03-27-2012), p057 (03-27-2012)
 Old 03-26-2012, 12:48 PM   #173
bigriver's Avatar
LOL!!
Nice arms! In 4 more pics of your wife, haha.
 Old 03-26-2012, 03:34 PM   #174
mayer's Avatar
Posts: 154   (View Stats)
mayer is the leader of the worldmayer is the leader of the worldmayer is the leader of the worldmayer is the leader of the worldmayer is the leader of the worldmayer is the leader of the worldmayer is the leader of the worldmayer is the leader of the worldmayer is the leader of the worldmayer is the leader of the worldmayer is the leader of the world
Great stuff. Me wants one of these. GA > Software boost cuts
GT3071R 23psi
Tuned with Versatuner by Stratified Auto
mayer is offline   Reply With Quote
The Following User Says Thank You to mayer For This Useful Post:
Lex (03-26-2012)
 Old 03-26-2012, 04:52 PM   #175
bigriver's Avatar
Found a better spot. There is a small gap under the dash gauges. So I tucked the wire under there and the LED itself is in a nice dark corner so it wont be in direct sunlight.
LED is in the center of the pic below in the dark recess.
Lex (03-26-2012)
 Old 03-27-2012, 10:35 PM   #176
bigriver's Avatar
@Lex - So here is an interesting question for you, and it may seem dumb but this really happened. Does the same boost protection setting apply to all gears, in particular 3rd and 4th? The reason why I am asking is I did a third gear log (see attachment) and while watching the AP, the GA activated at 20.2 psi. Then after just a few minutes, I went on to the freeway to go home. Just for kicks I decided to try and go wot in 4th. When I did this in 4th gear, the GA activated at 17.9 psi. I did not change the psi setting on the GA. Sorry, I didn't take a log for this 4th gear wot run.
Here is a pic of my AP
File Type: xls bigriver_datalog53 3-27-12 Guardian.xls (46.5 KB, 2 views)
Lex (03-28-2012), mrmonk7663 (03-28-2012)
 Old 03-28-2012, 05:51 AM   #177
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
I"m gonna say that is not how it should work. It is a boost sensing source...it should cut the same for all gears...perhaps its the response speed of the unit that is the problem here??? @Lex?
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
The Following User Says Thank You to mrmonk7663 For This Useful Post:
Lex (03-28-2012)
 Old 03-28-2012, 08:54 AM   #178
Novej's Avatar
Posts: 354   (View Stats)
Novej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the world
1. starscream
2. mtlms3
3. mrmonk7663
4. Gringo East
5. Sid3wayS
6. speed_freak91
7. ryno077
8. fooqr
9. obijack
10. Sleeperhatch
11. EL F00LI0
12.mroclimbr
13. MS3kid08
14. p057
15. Ckmazdaspeed3
16. blendedej8
17. JTMS3
18. Angr-E1
19. QwkEVO
20. skeurton
21. Dizzydtrain
22. ScottyP
23. Novej
2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex
Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN
Novej is offline   Reply With Quote
The Following User Says Thank You to Novej For This Useful Post:
Lex (03-28-2012)
 Old 03-28-2012, 09:37 AM   #179
What you're dealing with here is response time of the turbo and logging rates. The same setting applies to all gears but in 4th gear boost increased at a much higher rate than walking it up in 3rd.
The AP log versus AP display may also have a different rates of update - you should always use the same logging/observation method for consistency.
The GA cut at the same boost pressure setting (has no idea about gears) but since the boost ramp time in 4th was faster the AP display likely didn't catch the boost rise to the same value it did in 3rd.
Did you try and do the same thing again in 4th to verify?
 Old 03-28-2012, 09:47 AM   #180
bigriver's Avatar
@Lex - I will try another log in 4th tonight.
The 3rd gear data log shows boost cut off at 20.2 psi which is what I also saw on the AP display as the max value.
Hey, where are all the other "guinea pigs"? Lol! They should be doing this too.
Lex (03-28-2012)
 Old 03-28-2012, 10:14 PM   #181
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
So where are we in terms of availability? I can haz, or not yet? It is either this or a new rear o2 sensor... fucking $130!!! It sucks cuz I want teh fun parts, but probably a good idea to protect mah infestment.
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
rfinkle2 (03-30-2012)
 Old 03-28-2012, 10:49 PM   #182
2-3 weeks out from having 30 ready to ship. If those are gone in a couple of weeks, next batch will be 100.
Gringo East (03-29-2012), skeurton (03-30-2012)
 Old 03-28-2012, 10:52 PM   #183
bigriver's Avatar
@Lex Here is a 4th gear log. Same GA setting as last night. Activation occurred at 19.9 psi (both the datalog and my AP display showed max psi at 19.9). Last night in 3rd gear, activation occurred at 20.2 psi. Better results tonight.
File Type: xls bigriver_datalog55 3-28-12 Guardian.xls (77.0 KB, 4 views)
Lex (03-29-2012), rfinkle2 (03-30-2012)
 Old 03-29-2012, 05:39 PM   #184
bigriver's Avatar
Ok so I'm pretty much dialed in and "think" I have it set to 1 psi above my boost target since I turned it another 10 degrees above the last setting where it was activating at 20 psi (my boost target). Gonna do a third gear log tonight for @rfinkle2 for my etune.
@Lex let me know if there is anything else you want me to try.
Just curious, would it be feasible to have a digital boost protection feature so we could be more precise in setting the activation threshold? I may need reading glasses soon so its hard to see that tiny arrow on the white dial, lol, assuming there is an arrow, haha. I just see the notch.
 Old 03-29-2012, 08:40 PM   #185
Posts: 9,484   (View Stats)
fine tip sharpie to mark the end of the pot adjustment.
bigriver (03-29-2012), rfinkle2 (03-30-2012)
 Old 03-29-2012, 09:02 PM   #186
bigriver's Avatar
Haha! Good one!!
 Old 03-29-2012, 10:11 PM   #187
I appreciate all the leg work you've done - thanks a lot for that! To have a digital "feature" would mean adding a display of sorts to the unit, buttons, etc ... I wanted to avoid this due to cost and complexity.
Since the unit is programmable, I can always program a set value but that won't work for most people. Remember that if your target is 20 psi and you trip it at 22 instead of 21 it's not a big deal.
Derek wrote a how-to and shot of video about setting the GA: http://www.mazdaspeedforums.org/foru...-angel-109332/
bigriver (04-03-2012), mayer (03-29-2012), mrmonk7663 (03-29-2012), p057 (03-30-2012), rfinkle2 (03-30-2012)
 Old 04-03-2012, 05:03 PM   #188
bigriver's Avatar
bump -- so far so good. GA working just fine.
Lex (04-04-2012)
 Old 04-04-2012, 12:26 PM   #189
Better be! It's a got a year warranty
bigriver (04-04-2012), kgb (04-04-2012)
 Old 04-04-2012, 01:18 PM   #190
m4tic's Avatar
Posts: 4,928   (View Stats)
My dad wants to swap his 8-71 blown alki small block chevy to a TT setup. Would he need two GAs or just a single GA and tee from turbos to the unit then tee out to two BPVs?
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following User Says Thank You to m4tic For This Useful Post:
Lex (04-04-2012)
 Old 04-04-2012, 01:27 PM   #191
How is he planning to run the BPVs? From the same vacuum source? If it's from the same vacuum source and the flow in that single tubing does not slow down BPV response he would need just 1 into the single source, and then place the T to the two BPVs AFTER the GA (between the GA and BPVs).
m4tic (04-04-2012)
 Old 04-04-2012, 01:37 PM   #192
m4tic's Avatar
Yes a single vac source.
I might be in for one unit myself.
Thanks.
2017 Daytona 392
2007 MS6 w/ Cheez
Lex (04-04-2012)
 Old 04-04-2012, 03:13 PM   #193
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
i'm definitely in. just waiting for them to be prepared to ship. I'm also just about 1k away from this car being paid off.
i have the weirdest boner right now.
The Following User Says Thank You to p057 For This Useful Post:
Lex (04-04-2012)
 Old 04-20-2012, 01:23 PM   #194
Sid3wayS's Avatar
Groans: 97
Bumpity bump bump... I can haz angel now?
TEAM LUXURY
Lex (04-20-2012)
 Old 04-20-2012, 01:25 PM   #195
F*ck ... I have everything in terms of parts except the PCBs!!! The manufacturer screwed up so I'm out another 8 business days . My deepest apologies to everyone waiting.
djuosnteisn (04-20-2012), Gringo East (04-20-2012), kgb (04-21-2012), Sid3wayS (04-20-2012), skeurton (04-20-2012)
 Old 04-20-2012, 01:53 PM   #196
Sid3wayS's Avatar
Groans: 97
If I knew what PCBs were I would say it's ok....... Since I don't, this is unexceptable!!! Lol honestly thou when they are ready are you going to be selling them thru your website and just post it up here or will you make a group buy using the list from this thread? Just curious.
TEAM LUXURY
The Following 3 Users Say Thank You to Sid3wayS For This Useful Post:
kgb (04-21-2012), Lex (04-20-2012), Novej (04-20-2012)
 Old 04-20-2012, 02:01 PM   #197
v8 convert
p057's Avatar
Groans: 220
printed circuit boards...the brains of this whole product!
I'm glad you're testing them instead of just slapping a stupid "QC cheked!" sticker on it and shipping it anyway, like another country starting with a C. we all know.........
The Following 2 Users Say Thank You to p057 For This Useful Post:
Lex (04-20-2012), Sid3wayS (04-20-2012)
 Old 04-20-2012, 07:14 PM   #198
Novej's Avatar
LOLROFLLMAO!!!
The Following 2 Users Say Thank You to Novej For This Useful Post:
 Old 04-20-2012, 07:39 PM   #199
speed_freak91's Avatar
Posts: 1,189   (View Stats)
speed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the world
Groans: 34
I keep forgeting to check on this thread for updates. Let us know when they are ready. Im still up for purchasing one of these!
speed_freak91 is offline   Reply With Quote
The Following User Says Thank You to speed_freak91 For This Useful Post:
Lex (04-20-2012)
 Old 04-20-2012, 10:58 PM   #200
I will mention everyone in this thread who is on the list but the purchasing will likely happen through my webstore since I can track things better that way. These should be the final growing pains as after this batch - they should no longer be available in batches but be ready to purchase anytime.
charlesfist (04-21-2012), dereeek (04-20-2012), Gringo East (04-21-2012), kgb (04-21-2012), Sid3wayS (04-20-2012)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f600/gi-guardian-angel-overboost-protection-104486/
Mazda MPS Owners Club • View topic - Overboost protection... This thread Refback 03-25-2012 04:24 AM
The Guardian Angel for your motor Lex Stratified Automotive Controls 158 10-28-2015 12:55 PM
Angel Eyes? Sparky_86 MazdaSpeed 6 - How-To's 26 05-20-2010 04:58 PM
Angel Eyes TXspeed3 MazdaSpeed 3/6 - Appearance 2 06-28-2009 08:36 PM
Angel Eyes Ballast kingpin748 Mazdaspeed3/6 General Discussion 0 04-20-2009 04:53 PM
Page generated in 0.63250 seconds with 33 queries
