E-Tuners / Custom Hardparts
View Poll Results: Would you buy the Guardian Angel?
Yes - no more overboost fears! 141 92.16%
No ... 12 7.84%
Voters: 153. You may not vote on this poll
Like Tree33Likes
 Old 02-14-2014, 11:54 AM   #281
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
Originally Posted by hnda etr View Post
I'll be installing the AEM WMI Failsafe that has a 12V out alarm trigger and I want to make sure that will work with the GA.
I just got the Snow Safeinject from my favorite ginger, @gingermike;
I will be wiring this thing up next weekend(hopefully). The safeinject sends out a 12v signal when it detects flow rate drops below a preset point. I have a toggle switch override on the pump so i can simulate a "low flow" event and see how long it takes for the safeinject to react and then the GA to react on top of that and pop the valve.
this should be fun
I think that completes the full safety circle at that point. aaaand next month my motor will just blow for no reason whatsoever.
sidekick likes this.
The Following User Says Thank You to p057 For This Useful Post:
Lex (02-15-2014)
 Old 02-15-2014, 11:46 AM   #282
this should be fun
Which version do you have of the SafeInjection? I was under the impression it triggered a ground instead of a 12V. With a 12V trigger it will definitely set off the GA.
p057 (02-15-2014)
 Old 02-15-2014, 01:44 PM   #283
theurgy's Avatar
Posts: 2,580   (View Stats)
If it has just a ground trigger, can't you put a relay in and convert it to a 12v trigger?
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
theurgy is offline   Reply With Quote
 Old 02-15-2014, 01:46 PM   #284
Yes this is the simplest solution.
 Old 02-15-2014, 07:00 PM   #285
v8 convert
p057's Avatar
Groans: 220
if it has a ground trigger, yeah, i'll do a relay to switch it.
oh how I love relays and more wiring in the car.... :/
Thanks guys.
 Old 02-20-2014, 02:33 PM   #286
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Can anyone outline how to wire a relay to take a +0.5V trigger and convert it into a +12V signal the GA can handle?
 Old 02-20-2014, 02:46 PM   #287
theurgy's Avatar
0.5V or 5V?
The Following User Says Thank You to theurgy For This Useful Post:
hnda etr (02-27-2014)
 Old 02-20-2014, 02:52 PM   #288
theurgy's Avatar
Here's some good info for you:
FAQ: RELAYS; how they work and how to wire it up...
 Old 02-20-2014, 08:56 PM   #289
I will try and do a simple diagram.
You want a single pole, single throw relay.
 Old 02-27-2014, 01:50 AM   #290
hnda etr's Avatar
Groans: 90
0.5V or 5V?
0.5 V
Thanks!
Thanks again!
The Following User Says Thank You to hnda etr For This Useful Post:
Lex (02-27-2014)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f600/gi-guardian-angel-overboost-protection-104486/
Mazda MPS Owners Club • View topic - Overboost protection... This thread Refback 03-25-2012 04:24 AM
The Guardian Angel for your motor Lex Stratified Automotive Controls 158 10-28-2015 12:55 PM
Angel Eyes? Sparky_86 MazdaSpeed 6 - How-To's 26 05-20-2010 04:58 PM
Angel Eyes TXspeed3 MazdaSpeed 3/6 - Appearance 2 06-28-2009 08:36 PM
Angel Eyes Ballast kingpin748 Mazdaspeed3/6 General Discussion 0 04-20-2009 04:53 PM
Page generated in 0.33488 seconds with 25 queries
