E-Tuners / Custom Hardparts
Notices
 Old 03-24-2012, 09:02 AM   #1
the_rolex_guy's Avatar
Posts: 59   (View Stats)
the_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant futurethe_rolex_guy has a brilliant future
Groaned at 8 Times in 1 Post
Default Guardian Angel Install
Hey guys,
I have been fortunate enough to receive a Guardian Angel unit from Lex of Stratified. After doing a big turbo build with a GTX 3076 I wanted something that would give me a piece of mind from the famous zoom zoom boom.
When I received the unit I was very impressed about the detail of work that went into it and was more than pleased to install it into my speed 3.
The unit was installed on the fuse box cover right beside my meth controller since I knew it would be the best place for the install since Ive had good success with my meth controller being installed in that location for the past year.
It was very to install the power to the unit since there was only three wires for the actual install. The power was tapped into #12 of the fuse panel and the ground wire was connected to the chassis. Since I am not running safe injection monitor unit for the meth controller. The blue wire for the unit was not used but stored in a safe location. As for the installation of the warning indicator I decided to mount it on the right side if the steering wheel right beside the dsc control button. The vacum line was then installed from the engine into to the GA and then out from the GA to the Forge bpv.
After the installation, it was time to take the speed for a drive and test the unit out. Prior to the drive I set the boost detection to 10 psi. During the test drive, I did three consecutive wot pulls and each time the GA turned to cut the boost making the car to lose some power in a soothing way.
On the way back home after the testing of the unit I noticed the warning light turn on while on partial throttle and while off the throttle. I sent Lex an email to let him know what was happening with the unit and Lex told me that the problem might be a possible loose connection. After exmamining the wires, I noticed the connector for the ground wire was loose and I decided to replace it with a new one and that solved the power problem.
If you want a piece of mind for safety for your ride. I highly recommend the Guardian Angel.
the_rolex_guy is offline   Reply With Quote
The Following 5 Users Say Thank You to the_rolex_guy For This Useful Post:
helmetface (03-24-2012), Lex (03-24-2012), Naaman (03-24-2012), SleeperHatch (03-24-2012), uncorked11 (03-25-2012)
 Old 03-24-2012, 10:26 AM   #2
Able
helmetface's Avatar
Posts: 4,431   (View Stats)
Groans: 126
One LED for Meth and the other for the guardian? However, does the LED just stay solid when the car is on.?
helmetface is online now   Reply With Quote
The Following User Says Thank You to helmetface For This Useful Post:
Lex (03-24-2012)
 Old 03-24-2012, 10:34 AM   #3
Posts: 9,619   (View Stats)
The GA LED comes on for 2 seconds when it powers on to let you know it's still alive (when you turn on the car). It will only come on when the GA is tripped otherwise.
Lex is online now   Reply With Quote
 Old 03-24-2012, 11:00 AM   #4
crazyp's Avatar
Posts: 1,045   (View Stats)
crazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the world
Groans: 64
Groaned at 22 Times in 9 Posts
nice! can you also set this up as a meth failsafe?
2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RMM and RDM, Turbine tech FDM and FMM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC
crazyp is offline   Reply With Quote
The Following User Says Thank You to crazyp For This Useful Post:
Lex (03-24-2012)
 Old 03-24-2012, 11:07 AM   #5
Yes, as long as your meth controller outputs a signal when the meth runs out.
 Old 03-24-2012, 10:58 PM   #6
Novej's Avatar
Posts: 261   (View Stats)
Novej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the world
So Lex the guy recommends that we should get one..... Oh how I WISH I could take his advice, but when will that be???? As soon as you say "GO" money will be sent as I refuse to install a DP with this Hypertech tune without my Guardian Angel watching over me
2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex
Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN
Novej is offline   Reply With Quote
The Following User Says Thank You to Novej For This Useful Post:
Lex (03-25-2012)
 Old 03-25-2012, 12:52 AM   #7
I expect 2-3 weeks before units from next batch are ready for delivery.
dizzydtrain (03-25-2012), mrmonk7663 (03-25-2012), Novej (03-25-2012), uncorked11 (03-25-2012)
 Old 03-25-2012, 05:03 AM   #8
memin's Avatar
Posts: 821   (View Stats)
Groaned at 29 Times in 17 Posts
Common dude i know you can do a better review than that, with maybe a video etc,
The Following User Says Thank You to memin For This Useful Post:
Lex (03-28-2012)
GI: Guardian Angel (Overboost Protection) Lex Stratified Automotive Controls 269 07-02-2012 07:31 PM
Guardian Angel Installed and Reviewed Joe Isuzu Stratified Automotive Controls 21 06-17-2012 09:27 PM
The Guardian Angel for your motor Lex Stratified Automotive Controls 157 02-27-2012 02:49 PM
Angel Eyes? Sparky_86 MazdaSpeed 6 - How-To's 26 05-20-2010 03:58 PM
Page generated in 0.31993 seconds with 25 queries
