The importance of the BPV I have been investigating SWAS response recently and have found some interesting facts. The ECU uses the throttle, WGDC, AFRs to limit power/wheelspin when turning and this is more aggressive in lower gears since wheelspin is more prominent - yes we know this. I was having bucking/poor performance with SWAS active in corners to the point that it was dangerous in the low gears. I then drove a closer to stock speed3 and the system was not nearly as intrusive. Felt pretty decent actually. I could chalk this up to BT and heavier modifications but something wasn't adding up as I also wasn't remembering it being this bad in the past and I realized something many people overlook. When the ECU changes throttle (abruptly) mid corner as the turbo spools this affects the manifold/charge pipe pressure ratio. This in turn triggers/opens the BPV. The OEM BPV is a twin chamber design with a very stiff spring that is very quick acting. A lot of the aftermarket ones (I run a Forge V1 since the OEM leaked at high boost) do not share the response of the OEM BPV. The forge is notorious for this as it loses lubrication on the sealing o-rings. This causes the response time of the valve to be significantly affected and causes/exacerbates the bucking/sputtering phenomenon and it affects how SWAS interacts. Overall this mismatch between the ESP software and BPV can make you hate SWAS/ESP more than you should. For those of you where SWAS interferes violently, consider the BPV and that it is an important part of the overall system and it should be tuned to work well with it. Holding boost/pressure is important but so is response time and tunability the multi chamber designs with fast reaction times are better than the older designs with lots of internal friction and slow response. This will affect spool, lag between gears, shifting smoothness, and SWAS. Poor valve response can even cause bucking on throttle tip in or acceleration in a straight line. I recommend pressure testing your system to the boost level you want to run and stick with the OEM BPV unless you go over 20-21psi (ie bigger turbo). If you need to swap out the BPV, choose a multi chamber design with a fast response and low friction parts where you can adjust the spring/preload. It will make the car drive better in all conditions. |
Great read, awesome info fuckin yo couch |
@Lex; forgive my amatuer question, but I thought your GA when paired with the proper BPV would help eliminate leaks associated with loose spring tension. Wouldn't your GA help in keeping the system functioning quickly and properly in addition to the overboost protection? |
Heh, this is why I'm happy my stock BPV holds fine at 20psi... although I'm in line to pick up a friends Forge V2 soon when he parts out - I won't be using it until there is a need. Anyhow, does anybody have a complete link or a list of all the quick reacting two chamber designs currently available? Most reviews seem simply focused on the "sound" and ignore the performance of the unit. |
If you try several BPVs (with or without the GA) you will notice changes in driving characteristics during these throttle transitions |
Yes that's the one thing this forum cannot seem to teach me, what a good BPV is to go with. I could give two shits about how it sounds. Great read though Lex, interesting stuff. |
Indeed, thank you Lex! |
We treat it like it plays no part in engine operation whatsoever. Like it's some bullshit accessory that doesn't do anything. Lex has overlooked this and delved into the inner workings of them and how they affect our engine's performance on a multitude of levels. On top of what Lex has discovered here with SWAS and ESP, BPV's have a relatively profound effect on fuel trims as well. So, BPV's affect driveability, throttle response, SWAS/ESP operation, and fuel trims... That's not fucking rice, that's important shit. I think we need a more serious approach to BPV's from now on. |
I suppose Ill be the one to ask, which of the BPVs on the market are dual chambered, if any? |
Sooooooo what BOV should I get?! I kid I kid I don't need one but, seriously. |
So many people were haphazardly replacing oem bpvs without them leaking. Now we see that not only is it often a waste of money on the ko4 it may actually be a detriment to engine operation. Great thread. Sent from my DROID RAZR using Tapatalk 2 |
So you're saying... Stratified Tuning will be releasing a BPV next week? (: |
What about valves like the HKS? I freely admit I know nothing about them; I don't even remember what factored into my decision when I purchased mine. |
A BPV should be evaluated on several performance criteria: - First, do you need to replace the OEM and how do you know? What I found with the BNRS3 is that once boost pushed past the 21psi mark or so; although boost continued to climb, the airflow did not increase. This is because the BPV had cracked open and instead of the turbo drawing in more air, it was simply recirculating what it had already compressed. So the symptom was not a lack of boost, but rather it was a stall in the increase of airflow. Once the BPV was swapped, it was in line with what the turbo should have been flowing at that boost level and RPM. Boost remained the same, airflow increased. Most aftermarket BPVs are able to seal well under boost but there is more to it than this. - Controlling compressor surge in all conditions. A BPV should allow minimal to no surge under both heavy and light throttle lift. The HKS seals great under boost since it is a pull type valve but allows for compressor surge under part throttle. The TS valve with the heavy 20psi spring is terrible for surge although it is a push valve. The valve should also flow enough to control compressor surge under high boost and high airflow conditions as well. - Response time. How quickly a valve is able to open and close with varying pressure differentials is important. Not only does is effectively allow fast throttle modulation without surging or bucking but it works well with drive by wire systems where the ECU modulates the throttle on top of what the driver is doing. Fast valves close under boost quickly promoting spool as well. Fast response time is about low friction lightweight parts, smart construction, multi chamber construction, and high airflow rates out of the valve. - Ability to tune the valve. This is important for improving driveability and making the valve work well with the electronic control in the car, your turbo, your boost levels. Some of the multi chamber valves allow you to use one or more of the chambers. The ability to replace spring is nice but I prefer a dial where the same spring can be put under more or less pressure as well. - Construction, fitment, servicing. The valve should not require a lot of attention or servicing because if it does it means that the performance deteriorates as you get closer to the service period. I want the valve to work the same all the time. I've seen plenty of aftermarket valves leak, have poor seals, etc. You want a high quality piece that will last a long time. - Sounds and VTA. Yes you want a pleasing sound and we all do. It's not a performance feature but it's something to consider since after all we must enjoy driving the car. Some people like VTA and they can use the Guardian Angel to limit the VTA effects on engine operation or use a 50/50 valve. The GA closes the valve much sooner after a shift so if you run the GA in VTA mode you can get some response improvements but the valve should be tunable somehow so that you can soften the spring and walk the fine line between surge and fast response. You can also use the VTA feature on the GA to increase response time of a fully recirculating valve. |
Thanks, now I remember. I liked that there are no springs to replace and no maintenance. That and I thought that it works for any boost level. Or any reasonable boost level anyway. Dumb question: would running it as a BOV eliminate compressor surge? Or is my understanding of compressor surge incorrect? And yes, I understand that I can't use the HKS with the GA....it was the main reason I almost didn't get it. |
Just so I understand this right.... STOCK BPV = Good for K04 up to 20psi (basically =<20psi) AFTERMARKET BPV = Good for K04 beyond 20psi (basically >20psi), BNRS3, Big Turbo (GT30/35...etc) That would be a good way to look at it? Seems like the stock valve is the way to go if you want function for up to 20psi, yes? |
@Lex; I love your brain and articulation. That is all. |
I can confirm @Lex; 's findings, though not related to swas. I was getting a strange bucking when in stop and go traffic. It would happen when trying to hold a low rpm in 1st and secong gear, and also when going from deceleration to accleleration (lighlty). I dont want to go through all the details of what i was seeing in logs (trying to diagnose it) because i am on my phone right now, but long story short, i cleaned and lubed my forge v1, and voila! Gone! |
I went with the GFB Respons and I think it fits all of your criteria. I just don't know if it is multi-chambered though. I know a lot of other people run this bpv as well and like it. It has the dial up top for the spring and it has a knob you turn to control how much you vta so you can crack it like 10%vta and get the sound without causing problems to how to the car runs. Go Fast Bits Blowoff Valve Dual Port Mazdaspeed 3 6 MS3 MS6 |
you have done it again lex, good work |
So @Lex; will you be removing your Forge and going back to stock or are you tuning around it? P.S. blue spring one shim? :p |
NEWB comment: with the above explanation from Lex explain why i have never had an issue with my SWAS pissing me off mid turn or any issues like that? I will say that i did have an issue with my OEM BPV giving up on life on a stage 1 OTS map. I would get a bad boost leak and the car would buck constantly under heavy acceleration (not even WOT). I replaced with the Cobb valve, and issues were gone. Obviously now i'm on the synapse valve, and this thing responds fast as fuck, and like i said, i don't have any issues with SWAS. |
Mine never leaked, but I'll be pushing the limits of the K04.... |
1 Attachment(s) I mentioned the importance of the BPV earlier this year and finally got to do some testing with one of the fastest valves on the market. The results were great. SWAS and stability control no longer got in the way. No more bucking, loss of boost, jerkiness when taking a hard corner in a lower gear. So if you want SWAS and the stability control to work with you and not against you, get a BPV that is as fast as possible. A fast valve also helps response and spool. |
Lex = faster than me. |
Lex, this is the BPV I am running currently; if you have run and logged this, can you quantify the effects of it leaking while not under boost (it does this by design, essentially bypassing the turbo and IC while under vacuum) I can hear it leaking while in this state, if you take the throttle right to the threshold at atm (no vacuum, no boost) you can hear the transition from it being opened to it being closed. Given that it uses the bypass outlet as a intake inlet while under vacuum I have wondered if a TIP that brings the BPV inlet closer to the MAF would make sense. Synapse has claimed positive effects and I believe throttle response is better but it would be interesting to see real test data on this. The sound is definitely like no other BPV I have run (stock, Greddy Type S and a Turbosmart ) |
At the same time the charge piping is at a higher pressure level than the intake itself. By allowing air to bleed in front of the turbo by keeping the BPV open when not under boost there is less load on the compressor which results in less load on the turbine and this decreases pumping losses. Less pumping loss should marginally improve economy. |
I'm interested to see if Corksport is taking any of the data into consideration with their new bpv that's coming out |
Anyhow, thanks for the analysis, I have been quite happy with mine, it just works and it didn't need any adjustments, just bolted it on and forgot about it until your post. |
What is your port setup on the Synapse? Also are you running it in push or pull mode? |
Tried push and pull; with the stock turbo I think anyone running pull will experience/hear part throttle fluttering on the valve (I did), so I configured it like stock (push), running single port (b used, a VTA) no additional preload. |
@Lex; how would you say the synapse DV compares to the cobb bpv? I understand the configuration on the synapse can change from push to pull, but I mean in a apples to apples set up, how is the response and stability between the two? Just curious as I was sold on the cobb unit for my future upgrade list. |
1. Valve speed 2. Does it need to be serviced or lubricated. I am not a fan of these types of valves as they "lose" performance as the lube wears. 3. Reliability - are there wear or breakable items like diaphragms? 3. Adjustability 4. Fit and quality 5. I prefer push design for least surge |
I completely agree with you about the reliability and service being a big note to take when shopping around, but I was under the impression though that all aftermarket bpv's needed to be lubed? |
The truth is that tuning pressure systems mechanically is a bit of an art. Component responses will affect what works and what doesn't and that includes the turbo, piping, WG, etc. I experienced some pretty bad SWAS interaction once I swapped out the OEM BPV and installed the BNR. The spool and airflow rates of the BNR, the response of the BPV and the DSC/SWAS systems were not well in tune/calibrated with each other. Even when SWAS was not involved I felt the response was sluggish when transitioning on and off the throttle. Before cutting the wire to SWAS which many people opt for I wanted to give it another shot with a faster BPV and it worked well. |
Lex i recently installed a BNR S3 and started getting SWAS intervention. I thought at the time my GFB Response might have something to do with it so i put the stock BPV back on which didn't change anything. Now i have to long press the DSC button everytime i drive my car so i dont get SWAS'd and dont get a CEL (Rich Condition Bank 1). Did you test the OEM BPV with the BNR and still get SWAS'd Looking at swapping to a Synapse now if you think it'll solve my issue. |
good read, never had a bpv in a car before so more info is always welcome! :D |
Regarding the synapse in push or pull mode. I thought I remembered reading that the push mode was only good to, I'm guessing here, 20psi and after that they recommended the pull set up |
This is not meant to be a product advert, it's meant to be informative. I haven't tested all the valves on the market and combinations of parts. I wanted to draw attention to the BPV as being a culprit to some of the driveability issues we experience. |
I only get a CEL after the SWAS makes my car run rich a few times. I definently dont have a boost leak, been tested multiple times. Sent from my GT-I9300 using Tapatalk 2 |
what good info most people just go for the swoosh sound and dont even think twice before rice hahah |
Well I have been driving around for a week on my Forge V1 with a green spring and one shim instead of blue with 1 shim on 20 lbs of boost. The Forge reacts much faster than before and I can hear the sword clash more clearly. The bucking in third gear near redline in the corners has also been reduced. I might try removing the shim and take some 4th gear logs to see if I am still holding boost. |
It is funny hearing the sword clash almost immediately after throttle lift. |
Got some shit from Haltech and others about it, but I think they've more than proven themselves as legit: http://www.mazdaspeedforums.org/foru...r-valve-66575/ Edit: Now I need to make sure I'm running in Push mode and not Pull... Edit 2: Yup, running in Pull mode... Maybe this explains the issues I have been having with the stuttering/cutting, especially around corners lol. Cld12pk2go told me to disconnect the SWAS so I'll be doing that too Saturday... |
1.It was quick when clean other wise the change over from OEM was seamless. 2. Required moly lube at oil change intervals (4000 miles of 70/30 highway driving). 3. Insides contained a push type aluminum cap with one O-ring. One spring and washer attachment for adjustment screw. 4. Adjustable via Allen key and 10 mm wrench. To much spring pressure can lead to mild surge when releasing throttle at mild boost. 5. Typical Cobb quality. Overbuilt, works fabulous in recirc, didn't want to mess with it much in VTA. I liked it but I decided to go a different route. That being said I have been SWAS delete for 2 years. |
Also make sure the cuts are not spark related. The car commands very rich mixtures under SWAS conditions and those alone can cause blowout. With the OEM turbo, 2 port, and OEM valve SWAS does not interfere much with the driving experience. As you change these parts the calibration of the DSC system is off from the hardware installed and it becomes more of a problem. The 3 parts I mentioned above play a big role. |
I reinstalled the valve in push mode and left the SWAS connected so I can see if there's any change. Spark blow out is probably not an issue with me - I'm running a 0.026" gap along with the HKS twin fire. Plugs have around 12k miles on them so i will probably change them next weekend. I did raise the starting threshold on my DO wmi controller though a while back, to start at around 7 psi and go full blast at 10 psi. I was thinking that blowout might be happening because I was starting to airway around 5 psi... didn't help though. Edit: as for the lube interval, synapse says they put the DV through a 1 million cycle test with no issues... I doubt I did 1/4 of that in the last 1.5 years lol https://www.youtube.com/watch?v=Q2dw...e_gdata_player |
Quick update.. Called Synapse today and they're gonna send me a loaner to use so I can send them my DV to have the seized bolts removed... No problem at all from them! |
Ended up unplugging the SWAS yesterday, and putting a switch in today, and what a difference! Definitely more performance when disabled and that f'ing cutting out is gone when disabled! |
1 Attachment(s) Proof the Synapse guys have a sense of humor... notice the hand drawn stripper pole, disco ball, flood light and the "made it rain" bills on the floor lol. Fyi - they sent me a loaner DV, removed the stripped bolts from my DV, serviced it and returned it to me - they also paid all the shipping both ways! I paid exactly $0 to have my DV repaired. Nice! @Lex; you get my PM? Or you just ignoring it? ;) |
the synapse dv is awesome, it fixed all my response/bucking surge issues and the support from the synapse guys was awesome when a bolt snapped and serviced my valve when I could have just used thread seal tape on the top 2 ports ( leaked very little at 20psi when leak tested) |
i got the synapse DV recently too. I wanted a new BPV that wasnt loud and annoying like the forge, responds quickly, and doesnt need maintenance. so far I'm really happy with it! it's extremely quiet and reacts fast! However, i left the preload at whatever the hell level it is out of the box. is that considered zero? should I unscrew the nut more? I think it's running fine as-is and probably should leave it alone. Push mode, A+B, stock spring preload. |
been fine like that. |
http://www.mazdaspeedforums.org/foru...r-valve-66575/ |
Zero preload is out of the box. A+B in push mode works very well. |
ALex, I thought you were happy with your Forge. So do you really like the Synapse that much better? Fuck I've tried Turbosmart, HKS, and greddy and don't like any of them. Part throttle response is horrible. On all of them. Stock is the only one with good part throtle response but at 25 psi it leaks like hell. |
That Vibrant Performance DV looks awfully the same as the Synapse DV. Is it a picture mistake? Edit: no picture mistake. Wonder who is the manufacturer?!?!?! One or the other or neither of them lol? There is about a $20 difference between them. Either way, I'm gonna get one. Synapse: http://cdn1.bigcommerce.com/server30....1280.1280.jpg Vibrant: http://cdn1.bigcommerce.com/server30....1280.1280.jpg |
The important bits are what's on the inside. With just a $20 difference I would stick with the original. |
this might explain that? EvoXForums.com - Mitsubishi Lancer Evolution X Forums - View Single Post - Synapse DV vs Vibrant DV? |
Yeah I always thought the vibrant ones were just rebadged or mislabled |
Lex, what are you opinions on the CorkSport BPV? I'm interested in hearing your thoughts. |
1 Attachment(s) Another important and quick note about bypass/blow off valves. In general they don't add too much to power unless you're running 20+psi on the MazdaSpeeds. At that point pretty much all OEM valves start to open and bleed pressure. On a big turbo car this can be a little hard to detect. The car will still hold boost but airflow (g/s) values will seem low as will power. On the car below we are in the middle of a pump gas tune on a BNR S3. The motor has a lot of miles on it and is knock prone but you can see what replacing the OEM BPV did here. So for above 20psi applications and all big turbo ones, it's wise to run an aftermarket bypass valve. http://www.mazdaspeedforums.org/foru...1&d=1410805043 |
@Lex; any experience tuning with the corksport bpv? I just want to know that it'll hold boost on a gtx3076 at a low 380hp. It's definitely priced well, but I haven't found specs on what kind of pressure it will hold. |
Boost pressure is what it has to hold, not crack open regardless of turbo used and I haven't heard or seen issues with it holding pressure. If it leaks you will see an unreasonable drop in power and no airflow rise in the upper RPM as boost goes up. |
| All times are GMT -7. The time now is 01:58 AM. |
