I completely agree with you about the reliability and service being a big note to take when shopping around, but I was under the impression though that all aftermarket bpv's needed to be lubed? |
The truth is that tuning pressure systems mechanically is a bit of an art. Component responses will affect what works and what doesn't and that includes the turbo, piping, WG, etc. I experienced some pretty bad SWAS interaction once I swapped out the OEM BPV and installed the BNR. The spool and airflow rates of the BNR, the response of the BPV and the DSC/SWAS systems were not well in tune/calibrated with each other. Even when SWAS was not involved I felt the response was sluggish when transitioning on and off the throttle. Before cutting the wire to SWAS which many people opt for I wanted to give it another shot with a faster BPV and it worked well. |
Lex i recently installed a BNR S3 and started getting SWAS intervention. I thought at the time my GFB Response might have something to do with it so i put the stock BPV back on which didn't change anything. Now i have to long press the DSC button everytime i drive my car so i dont get SWAS'd and dont get a CEL (Rich Condition Bank 1). Did you test the OEM BPV with the BNR and still get SWAS'd Looking at swapping to a Synapse now if you think it'll solve my issue. |
good read, never had a bpv in a car before so more info is always welcome! :D |
Regarding the synapse in push or pull mode. I thought I remembered reading that the push mode was only good to, I'm guessing here, 20psi and after that they recommended the pull set up |
This is not meant to be a product advert, it's meant to be informative. I haven't tested all the valves on the market and combinations of parts. I wanted to draw attention to the BPV as being a culprit to some of the driveability issues we experience. |
I only get a CEL after the SWAS makes my car run rich a few times. I definently dont have a boost leak, been tested multiple times. Sent from my GT-I9300 using Tapatalk 2 |
what good info most people just go for the swoosh sound and dont even think twice before rice hahah |
Well I have been driving around for a week on my Forge V1 with a green spring and one shim instead of blue with 1 shim on 20 lbs of boost. The Forge reacts much faster than before and I can hear the sword clash more clearly. The bucking in third gear near redline in the corners has also been reduced. I might try removing the shim and take some 4th gear logs to see if I am still holding boost. |
It is funny hearing the sword clash almost immediately after throttle lift. |
Got some shit from Haltech and others about it, but I think they've more than proven themselves as legit: http://www.mazdaspeedforums.org/foru...r-valve-66575/ Edit: Now I need to make sure I'm running in Push mode and not Pull... Edit 2: Yup, running in Pull mode... Maybe this explains the issues I have been having with the stuttering/cutting, especially around corners lol. Cld12pk2go told me to disconnect the SWAS so I'll be doing that too Saturday... |
1.It was quick when clean other wise the change over from OEM was seamless. 2. Required moly lube at oil change intervals (4000 miles of 70/30 highway driving). 3. Insides contained a push type aluminum cap with one O-ring. One spring and washer attachment for adjustment screw. 4. Adjustable via Allen key and 10 mm wrench. To much spring pressure can lead to mild surge when releasing throttle at mild boost. 5. Typical Cobb quality. Overbuilt, works fabulous in recirc, didn't want to mess with it much in VTA. I liked it but I decided to go a different route. That being said I have been SWAS delete for 2 years. |
Also make sure the cuts are not spark related. The car commands very rich mixtures under SWAS conditions and those alone can cause blowout. With the OEM turbo, 2 port, and OEM valve SWAS does not interfere much with the driving experience. As you change these parts the calibration of the DSC system is off from the hardware installed and it becomes more of a problem. The 3 parts I mentioned above play a big role. |
I reinstalled the valve in push mode and left the SWAS connected so I can see if there's any change. Spark blow out is probably not an issue with me - I'm running a 0.026" gap along with the HKS twin fire. Plugs have around 12k miles on them so i will probably change them next weekend. I did raise the starting threshold on my DO wmi controller though a while back, to start at around 7 psi and go full blast at 10 psi. I was thinking that blowout might be happening because I was starting to airway around 5 psi... didn't help though. Edit: as for the lube interval, synapse says they put the DV through a 1 million cycle test with no issues... I doubt I did 1/4 of that in the last 1.5 years lol https://www.youtube.com/watch?v=Q2dw...e_gdata_player |
Quick update.. Called Synapse today and they're gonna send me a loaner to use so I can send them my DV to have the seized bolts removed... No problem at all from them! |
Ended up unplugging the SWAS yesterday, and putting a switch in today, and what a difference! Definitely more performance when disabled and that f'ing cutting out is gone when disabled! |
1 Attachment(s) Proof the Synapse guys have a sense of humor... notice the hand drawn stripper pole, disco ball, flood light and the "made it rain" bills on the floor lol. Fyi - they sent me a loaner DV, removed the stripped bolts from my DV, serviced it and returned it to me - they also paid all the shipping both ways! I paid exactly $0 to have my DV repaired. Nice! @Lex; you get my PM? Or you just ignoring it? ;) |
the synapse dv is awesome, it fixed all my response/bucking surge issues and the support from the synapse guys was awesome when a bolt snapped and serviced my valve when I could have just used thread seal tape on the top 2 ports ( leaked very little at 20psi when leak tested) |
i got the synapse DV recently too. I wanted a new BPV that wasnt loud and annoying like the forge, responds quickly, and doesnt need maintenance. so far I'm really happy with it! it's extremely quiet and reacts fast! However, i left the preload at whatever the hell level it is out of the box. is that considered zero? should I unscrew the nut more? I think it's running fine as-is and probably should leave it alone. Push mode, A+B, stock spring preload. |
been fine like that. |
http://www.mazdaspeedforums.org/foru...r-valve-66575/ |
Zero preload is out of the box. A+B in push mode works very well. |
ALex, I thought you were happy with your Forge. So do you really like the Synapse that much better? Fuck I've tried Turbosmart, HKS, and greddy and don't like any of them. Part throttle response is horrible. On all of them. Stock is the only one with good part throtle response but at 25 psi it leaks like hell. |
That Vibrant Performance DV looks awfully the same as the Synapse DV. Is it a picture mistake? Edit: no picture mistake. Wonder who is the manufacturer?!?!?! One or the other or neither of them lol? There is about a $20 difference between them. Either way, I'm gonna get one. Synapse: http://cdn1.bigcommerce.com/server30....1280.1280.jpg Vibrant: http://cdn1.bigcommerce.com/server30....1280.1280.jpg |
The important bits are what's on the inside. With just a $20 difference I would stick with the original. |
this might explain that? EvoXForums.com - Mitsubishi Lancer Evolution X Forums - View Single Post - Synapse DV vs Vibrant DV? |
Yeah I always thought the vibrant ones were just rebadged or mislabled |
Lex, what are you opinions on the CorkSport BPV? I'm interested in hearing your thoughts. |
1 Attachment(s) Another important and quick note about bypass/blow off valves. In general they don't add too much to power unless you're running 20+psi on the MazdaSpeeds. At that point pretty much all OEM valves start to open and bleed pressure. On a big turbo car this can be a little hard to detect. The car will still hold boost but airflow (g/s) values will seem low as will power. On the car below we are in the middle of a pump gas tune on a BNR S3. The motor has a lot of miles on it and is knock prone but you can see what replacing the OEM BPV did here. So for above 20psi applications and all big turbo ones, it's wise to run an aftermarket bypass valve. http://www.mazdaspeedforums.org/foru...1&d=1410805043 |
@Lex; any experience tuning with the corksport bpv? I just want to know that it'll hold boost on a gtx3076 at a low 380hp. It's definitely priced well, but I haven't found specs on what kind of pressure it will hold. |
Boost pressure is what it has to hold, not crack open regardless of turbo used and I haven't heard or seen issues with it holding pressure. If it leaks you will see an unreasonable drop in power and no airflow rise in the upper RPM as boost goes up. |
| All times are GMT -7. The time now is 01:58 AM. |
