So moving that sensor won't affect the IAT as stated earlier correct? |
Why are people thinking the PCM uses the ambient air temperature sensor in it's calculations? It doesn't. I'd loved to be proved wrong though. |
im going to be doing some testing on this to see if i can find any more patterns/correlations |
Pre-turbo meth Quote:
Regretfully, no, I have no data left. I just made a couple or three runs, noted virtually no difference, and gave up on the thought. This was back in May or so when it just started to get warmed up. My tune backs down the boost after 5k or so as well because of the torch like character of the K04. With the DO5 I'm just keeping even with the BATs on the top end. My impression has been that I'm plateau'd as is. |
I think an efficient Intake setup would be to run a full 3" intake WITH a cold air box, that way you get VE and cooler IAT's. |
Sent from my iPhone using Tapatalk |
What is the best pressure drop to have across the I/C core? Too little of a drop and it will not transfer the heat to the aluminum, too much drop and it becomes too much of a restriction. There has to be a a happy median. Also, on an I/C that has the BPV flange on the hot side (like people are going to for the fifth port), do not recirc the air. Heated air from pre I/C will just heat up the inlet, in turn raising IAT'S |
it was really cool how the air filter was tucked up inside the OE duct work. I am tuning a guy with a CS intake...not sure that's the same one or do they make more than one...i'll ax him. he has a 2012 so IDK how that setup looks. |
The CS full FMIC kit which has the stock size MAF housing built into ther piping, or running a big 3"+ MAF SRI? |
The higher the flow, the higher the inlet pressure and the higher the pressure drop given the core stays the same. The size and VE of the motor determine how much air will pass through it at x pressure and x RPM so you have to look at where the motor will be operating most of the time. In summary, you want to have an IC that does not restrict flow unnecessarily through endtank and core design. You also want a core that is large enough for your application in terms of both heat rejection and flow. Most companies quote CFM at x pressure drop. I would shoot for the largest core I can fit on the car since that limitation will come into play first. The placement of the IC is also very important since the amount of heat it can reject from the air passing through it is related to how much heat it can reject TO the air passing over it. Quote:
For what it is worth, this thread finally made me pull the trigger on the CS cold air box for thier SRI. I have been on the fence about this thing for a long time but it doesn't get a lot of love from the MS3 guys. I think you guys have much cooler underhood/IATs to begin with, and peopel always say that the turbo just heats the air anyway so it is pointless. I always thought a little differently and this thread helped to confirm some of those thoughts. As an aside, last night coming home late from the new Batman it was about 70 out and low humidity. The car felt fucking fantastic compared to driving on the way there at about 90 ambient and sunny. I still had IAT and BATs well into the 100's on the way home but could absolutely tell the difference in power at night. |
I actually just switched to a dry flow aem over an oiled kn and did feel a different SOT dyno :) looks like a made a good choice. Also I use a fujita CAI and If i were to just cut the last say foot off and use a reducer coupling to then mate my current 2.75 size to a maybe 3.5 dia size pipe to run a larger diameter filter would that help or hinder cooling and flow? I dont want to scrap the intake, but if more air is needed i need to figure out a way to get it there without going BT and wasting the TIP, and CAI i already have. thanks! |
I just switched from a CP-E CAI to a CP-E Nano SRI and the initial findings are somewhat interesting. Temps are in relation to ambient. CAI: +4-5 Degrees IAT cruising +20 degrees IAT city +40 degrees IAT traffic +18-22 degrees BAT cruising +30 degrees BAT city +35-40 BAT traffic SRI: +10-14 IAT Cruising +18-22 BAT Cruising These are just my initial observations since I just put it on last night. It seems like that even though the intake temps are higher with the SRI that the BATs have stayed the same, which surprises me. Does intake temp matter if my BATs are staying the same? |
4 Attachment(s) I was just looking at the differences of my logs with varied temps. Maybe the 2nd, blue run should be omitted though, I must've done something funky, or.. humidity maybe |
so i put a heat gun right on the AAT sensor and the dash display was super slow to change but it did. the AAT value on the DH did not change however so im not sure what that is referenced by. |
The AAT on the dash is very slow to respond because it is very dampened since large fluctuations are unlikely to happen in contrast to IAT in the MAF. |
Here is my thought on the intake temps: When running the stock intercooler with intake, the intake is all by itself with no heat source nearby. That would explain the similar IAT and ambient temps. With the FMIC, the cold side pipe (well colder pipe) runs directly below the intake. You are now introducing a heat source that heats up the intake. That would also explain why basically all FMIC guys have a much higher difference from ambient and IAT. Anyone think this would seem logical? |
Cool new gauges I came across on Prosports website on the subject of intercooler efficiency and charge density, bat sensor accuracy: Prosport Gauges dual intercooler air temperature gauges with in and out digital display |
Sent from Stratified Mobile Headquarters |
this thread needs more pre turbo meth |
Just thinking out loud here, but me and a few guys were discussing this over the weekend. First off where is the iat measured from? We all assumed the maf sensor. If that's the case, this is my thought on cai vs Sri. Say a cai has about 2 feet worth of piping to go through, and a Sri is say half that (not sure of real measurements, just for reference). The Sri will obviously have higher iat's. But what about the iat by the time it actually gets to the turbo. If the piping takes the same route, its gonna get hot. The air travels through the hot piping, heating the air. So if a cai starts out with colder air, how much is it heated by traveling a longer distance through the intake? The same goes for the Sri. It starts out slightly hotter, but has less distance to get heated before reaching the turbo. I'm sure the difference isn't really that much? I could sound completely retarded (and probably do) but its a thought. |
^ Good thoughts there. The silicone or plastic TIPs are pretty good at preventing the "air" from getting heatsoaked as it travels towards the turbo. However the CAI and SRI will suffer from the same amount of "air heating" from the TIP. The difference here is that the CAI is able to pull in air that is much cooler to begin with compared to the SRI. So let's say for example the air is going to be heated up by 15* by the TIP. By using the SRI you start with 90* and with the CAI you start with 80* then with the SRI you end up with 105* at the turbo and the CAI with 95*. You're still ahead by 10* with the CAI when you get to the turbo. However the design and flow through the intake also has an importance and this is where things get more complicated. CAIs are limited to stock size whereas with SRIs we see them as large as 3.5" which outweighs the temperature difference between the CAI and SRI. |
I don't know how the sensor mounts but this seems to be the best bet @ looking @ intake temps and the effects of changes. Prosport Intake air temperature gauge, instant read air temperature gauge. @Lex, check this out: http://www.designengineering.com/cat...yo2-air-intake |
Is there any repeated observations of intake air actually heating up do to SRI/CAI length and/or material? I remember reading some data years ago from some highly regarded engineers in the industry that basically debunked this belief. Basically the premise was that the intake tract has such minimal surface area in which to transfer heat plus the massive amounts of CFM flowing through the pipe showed little to no additional heating regardless of the temp of the actual tube. The boundary layer inside the pipe helped to insulate the intake air from absorbing any heat from the tube. When I see people wrapping their intake and I/C cooler pipes I always figured that was a worthless mod. Quote:
| All times are GMT -7. The time now is 01:55 AM. |
