E-Tuners / Custom Hardparts
Like Tree38Likes
 Old 12-19-2014, 03:52 PM   #281
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I have run both the 3" SURE FULL AEROS and the HTP 3.5. I am not going to lie, the 3.5" idle is pretty crappy even when well MAF cal'd. Once my MAF sensor gets below 1V it is no mans land. The HTP 3.5" sits around .95v-1v at idle (I think ~850rpm) and I just end up with kind of a crappy idle that is always kind of hunting (STFTs never settle down) and I get a P2188 rich at idle often. I often see MAF g/s bounce around a few g/s as well even though the voltage is holding steady.
Literally as soon as I go off idle, everything straightens out perfect and the intake is perfect from then on.
I originally suspected a part issue; I checked/rechecked everything from filter to downpipe multiple times. I checked/tested purge valve and did a bunch of other tests. It was when I swapped in another maf sensor and let it learn for a while that I realized this issue has to do with the MAF reading. The 2nd sensor learned and LTFTs got around -3 or so at idle even though STFTs were still bouncing around. With the 2nd sensor at idle, the idle stumbled around and AFRs were biasing leaner this time at around the same voltage. I changed the condition just by changing the MAF sensor. Why? My two MAF sensors are having a hard time reading good flow with the 3.5" intake below and around 1V.
I hypothesize that the MAF sensor curve is probably not linear below 1v and it's kind of a crap shoot down there. So, it's either up the idle to get the MAF reading out of the weeds or go back to the 3" intake.
MINI H1 6.0 - CAR LED TAILS
 Old 12-20-2014, 09:58 AM   #282
You're not the only one to experience these symptoms with the larger intakes. I have seen people complain about the 4" intakes quite a bit in coasting and idle conditions. Intake design does also play a factor in how the sensor reads at very low airflow levels.
snailD (05-25-2015)
 Old 12-23-2014, 12:49 PM   #283
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world
Raise the idle rpm and you shouldn't have a problem. i DD on a 4" HTP (also have tuned a bunch of these intake now) have now for 8 months. My idle rpm is 950.
2.0t03speed is offline   Reply With Quote
 Old 12-23-2014, 06:09 PM   #284
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Groans: 29
I have a htp 3.5" intake and my car idles great. I just have freeks base map. No maf cal yet. Idle is stock 700rpm.
 Old 12-23-2014, 10:33 PM   #285
What turbo do you have cheapspeed. Also, I think the vcts delete didn't help me.
 Old 12-24-2014, 04:06 AM   #286
Cheapspeed's Avatar
Groans: 29
Still k04 with a 3076 waiting to go in.
 Old 01-07-2015, 03:57 PM   #287
Arnie1229's Avatar
Posts: 45   (View Stats)
Arnie1229 is a name known to allArnie1229 is a name known to allArnie1229 is a name known to allArnie1229 is a name known to allArnie1229 is a name known to allArnie1229 is a name known to all
Groaned at 12 Times in 2 Posts
Neutral  -2 score
subbed
'11 speed3 non tech | Turbosmart Hybrid BOV | AP v3 | Corksport Power series stage II intake and TIP | Cp-E X-Flex RMM | Autotech Internals | Speed Daddy Catback | Manzo Race Pipe | Denso ITV20's | Freek OTS+ | 33% E85 |
Arnie1229 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to Arnie1229 For This Un-useful Post:
g00s3y (01-28-2015), ms6mil (01-07-2015), thehead (01-08-2015)
 Old 02-24-2015, 02:01 PM   #288
sporkbomb's Avatar
Posts: 295   (View Stats)
sporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the world
It's threads like this that remind me why I donated. Thank you, @Lex;.
Sleepin6 likes this.
2007 MS3 GT
Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks
2006 MS6 GT (ZZB Rebirth)
Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts
1990 Miata
I like it raw
sporkbomb is offline   Reply With Quote
The Following User Says Thank You to sporkbomb For This Useful Post:
Lex (02-24-2015)
 Old 03-10-2015, 10:29 PM   #289
Cheese5.0's Avatar
Posts: 170   (View Stats)
Cheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the worldCheese5.0 is the leader of the world
I just used the HTP 4" data on mine and it works great. I'm running a stock k04 and idle and driveability is good so far. Stft is all over the place, but it got me very close all things considered.
2006 WWP Mazdaspeed 6 #00694 Built 09/05
Stock K04
50/50 E85 mix
304/349 Central Florida Turbo Mustang Dyno
4/18/15
Tuned by NISHAN
Cheese5.0 is offline   Reply With Quote
The Following User Says Thank You to Cheese5.0 For This Useful Post:
Lex (03-11-2015)
 Old 03-11-2015, 12:33 PM   #290
Glad it helped out!
 Old 03-16-2015, 05:03 PM   #291
Cheese5.0's Avatar
Glad it helped out!
I've since had some issue dialing in the maf cal. Idle is a bit choppy initially then smoothes out. STFT at idle likes to start our somewhere deep into the negative, then slowly work its way up to +24.8. I cleaned up a bunch of boost leaks and I'm looking at a bad pcv as another potential culprit. I'll post up some logs once I get that sorted.
Stock K04
50/50 E85 mix
4/18/15
Tuned by NISHAN
 Old 03-16-2015, 07:14 PM   #292
The 4" intakes at low airflow values like idle and coasting can be tricky to dial in. Try raising your idle to 900 or 950 RPM.
Cheese5.0 (03-21-2015), Vansquish (03-16-2015)
 Old 04-23-2015, 07:27 AM   #293
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
I was working with @sleeveless; who was attempting to copy and paste Lex's values into ATR so he can get a base MAF curve for his new 3" intake. He was doing everything correctly as far as I could tell (I even saw a video he took of him doing it), but for some reason it just wouldn't work for him. The only thing I could think of is that I have ATR installed on Windows XP and Windows 7, and he has Windows 8.1.
Even when I was trying to copy and paste them into Openoffice just now (that's all I have installed on my laptop), for some reason they wouldn't paste correctly and I had to paste them into ATR, then copy them into the spreadsheet. Really odd.
Therefore, I have copied all of the curves from the OP into spreadsheets which I have attached in .ods and .xls format for your convenience.
edit: The ods wouldn't upload. I zipped it and it's in the .zip file.
File Type: xls MAF Calibrations for bigger intakes.xls (19.5 KB, 17 views)
File Type: zip MAF Calibrations for bigger intakes.zip (17.6 KB, 6 views)
2007 Mazdaspeed3 GT
The Following 3 Users Say Thank You to MD1032 For This Useful Post:
Awal (05-22-2015), phate (05-23-2015), sleeveless (04-23-2015)
 Old 04-23-2015, 09:52 AM   #294
sleeveless's Avatar
Posts: 462   (View Stats)
sleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the world
I ended up doing it by hand but yea it was extremely weird .
2012 black Mica MS3
sold
06 Mazdaspeed 6
LED turns, front switchbacks, 7000 lumen fogs, fancy boost gauge, dipped ms3 wheels
sleeveless is offline   Reply With Quote
 Old 04-24-2015, 10:56 AM   #295
This is a formatting issues - from the web browser to ATR and or excel. If it doesn't work I always attempt going through another software or medium first. Notepad is sometimes an option.
Awal (05-22-2015)
 Old 05-22-2015, 10:57 PM   #296
Awal's Avatar
Posts: 645   (View Stats)
Awal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the world
Posting as a reminder to update the OP's Corksport's section to include their '3.5" Mazdaspeed 3 Power Series Intake System'. I'm going to measure the MAF ID with calipers before install to double check, but according the CS's site:
"True 3.5" MAF: The Power Series 3.5" system is a true 3.5" inner diameter for maximum flow to get the most out of you performance mods"
Also, for the MS3 they list a few different SRI/MAF housing or SRI to stock TIP. Here's what they are selling as of today:
-CORKSPORT Stage I Power Series Short Ram Intake/stock TIP for Mazdaspeed 3 (after checking all reviews, I eventually found the ID @ 68mm [2.68"] for the MAF housing, but it runs fine without MAF adjustments/tune)
-CORKSPORT Stage II Power Series Short Ram Intake for Mazdaspeed 3 (same results as the Stage I for actual MAF ID size [68mm/2.68"], just an added TIP @ the same time)
-CORKSPORT 3" Power Series 2007-2013 Mazdaspeed 3 Intake (true ID of 3" for MAF, Cobb AP MAF re-calibration needed)
Okay, so those are just CS's offerings in terms of SRI or SRI/TIP kits at this point in time for MS3, both gens. There are some CS CAI systems that use the same CNCed MAF housings as the SRI kits as far as I can tell.
No rush on any of this, just thought it would be good to fill in any blanks.
All Go, No Show
2013 LSM W/ Tech
CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames
COBBAP v3 w/ Window Mount
AUTOTECHHPFP INTERNALS
ToBeInstalled:
CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5")
dbaDBA42962S Front and Rear Rotors
StopTechRear Braided SS brake lines
JBROCC & VTA OCC kit, EGR BO, Boost Tubes
Cooling MistWMI kit
StratifiedCustom Tune (as soon as TBE is on)
On Deck
wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines)
Hawk PerformanceHB478F.605 or HB478Z.605 rear pads
BilsteinB16s
Awal is offline   Reply With Quote
The Following User Says Thank You to Awal For This Useful Post:
Lex (05-23-2015)
 Old 05-24-2015, 11:56 PM   #297
Awal's Avatar
Well, after a nightmarish Corksport 3.5" SRI/TIP install with a basic craftsman socket/ratchet set (the one I carry in my trunk) and an assortment of really shitty and short pliers/screwdrivers in my GF's driveway, she dropped my phone into the fender well.. I few pop-clips and some fecking around later I retrieved my phone and cleaned up the tools/parts etc. I had ealier reflashed my car with Cobb's OTS "safe 91 oct" map and i was blocking her car in, so I tried to fire it up... It started, and died, which is what I expected, but it was enough to move the car to let her out.
I took my AP to my PC, used the 3.5" tru flow JBR MAF calibration values from Alex's OP, loaded them into my ATR on top of the same OTS map I used earlier, renamed it "safe 91 oct + 3.5 SRI", loaded it to the AP, flashed it to the car, and Boom, fired right up.
Let it warm up to a regular idle, and it settled down nicely, took it for a rip (sooo glad to have that familiar turbo whine back) and it's running quite well. TC came on in 3rd and 4th many o times, and I wasn't even pushing her.. I love the cool night air up here
Thanks again Alex and Stratified!
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
Lex (05-25-2015)
 Old 05-25-2015, 08:53 AM   #298
Now we have to get you tuned up!
Awal likes this.
Awal (05-25-2015)
 Old 05-25-2015, 11:31 AM   #299
Awal's Avatar
Indeed we do, internals and TBE 1st though! I know there's a bunch of power lurking in my mods so far, especially on 94 octane, but best to get everything installed 1st.
All Go, No Show
2013 LSM W/ Tech
ToBeInstalled:
Cooling MistWMI kit
On Deck
BilsteinB16s
Lex (05-25-2015)
 Old 09-28-2015, 12:48 PM   #300
Caldazar's Avatar
Posts: 293   (View Stats)
Caldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond repute
question about the Corksport maf cal table posted in the first post. Those numbers look quite a bit larger than the Corksport numbers in Cobbs Corksport cal included in thier maps. These numbers look bigger than the ones for the other 3" systems listed as well.
is this done on purpose or is it a typo or is it for a different intake system?
thank you.
JBR likes this.
06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver
91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's
Caldazar is offline   Reply With Quote
 Old 11-16-2015, 11:12 AM   #301
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Back from the dead. Im currently running a 3.5 Jrb wide. im using versa tuner. I started to change the MAF settings, but I got to the point where it wouldnt go past 105.8. So what do I do?
Project_dog is offline   Reply With Quote
 Old 11-16-2015, 01:04 PM   #302
kidlifecrisis's Avatar
Posts: 672   (View Stats)
kidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the world
Holy shit 105 POUNDS of air per minute? Lol check your units homie
kidlifecrisis is offline   Reply With Quote
The Following 2 Users Say Thank You to kidlifecrisis For This Useful Post:
phate (11-16-2015), Vansquish (01-27-2016)
 Old 11-16-2015, 01:29 PM   #303
Hey Guys and Gals, here are good starting points for the larger MAF calibrations. This is just so you guys are not stuck until a tune happens if you need to drive away with a bigger than stock intake.
JBR
Tru-3.5 Wide Path (3.5" ID MAF)
Code:
0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	2.56	2.91	3.28	3.67	4.11	4.59	5.16	5.99	6.81	7.69	8.58	9.45	10.25	11.54	12.43	13.39	14.5	15.71	16.95	18.35	19.49	21.01	22.65	24.86	26.3	28.6	30.28	32.46	34.64	36.47	38.31	40.83	44.01	47.19	50.16	53.23	56.41	59.7	63.14	66.7	70.38	74.22	78.19	82.32	85.23	88.15	91.07	95.5	99.99	104.58	109.28	114.11	119.07	124.16	129.43	141.67	147.59	156.21	164.84	171.45	178.17	185.02	191.93	199.04	206.32	213.76	221.37	229.21	237.26	245.5	254.08	262.95	272.06	281.4	290.96	300.75	310.78	321.03	331.54	342.25	353.17	364.27	375.65	387.28	399.12	411.23	423.61	436.24	449.14	462.33	475.79	489.52	503.53	517.82	532.39	547.28	562.42	577.89	593.65	609.7	626.06	642.76	659.74	677.06
I was just copying what he has.
 Old 11-16-2015, 02:22 PM   #304
So do i have to go from lb/min to grams/lb
 Old 11-16-2015, 03:18 PM   #305
MD1032's Avatar
Groans: 143
Sent from my A0001 using Tapatalk
2007 Mazdaspeed3 GT
 Old 11-16-2015, 03:30 PM   #306
And multiply by 60, the guideline numbers are for grams/sec
 Old 11-16-2015, 05:11 PM   #307
I changed my settings in my tuner. Now I'm able to see grams/sec
Sent from my SAMSUNG-SGH-I337 using Tapatalk
kidlifecrisis likes this.
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
 Old 01-26-2016, 12:54 PM   #308
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
Lex, I have to thank you for the 4" HTP MAF cal. I have to say it's quite perfect for a generalized MAF cal. Besides first start up after Intake and a BT install, the car has not stumbled or felt hesitant at all.
Here in Portland, OR with 40-50F temps.
The Following User Says Thank You to breakfstincluded For This Useful Post:
Lex (01-27-2016)
 Old 01-27-2016, 09:34 AM   #309
Glad it has helped! Thanks for the kind words.
breakfstincluded (02-01-2016)
 Old 05-17-2016, 05:16 PM   #310
nell's Avatar
Posts: 6   (View Stats)
nell is an unknown quantity at this point
Default locked map
Hi all,
Ive recently copied the table for a htp 3" intake onto my map. However, now when i go to reflash the ecu via my APA V3 it says the map is locked (grey in colour). How do i unlock the map??
nell is offline   Reply With Quote
 Old 05-17-2016, 05:25 PM   #311
Police - Grammarhead
Vansquish's Avatar
Groans: 1,911
Originally Posted by nell View Post
Hi all,
You need to update your AP to the latest firmware, update ATR to the latest revision, open the relevant map in ATR, save it, load it on the AP, and then flash the map.
 Old 05-17-2016, 06:10 PM   #312
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I'm not sure ATR can be updated at this time.
Also, just wanted to say thank you @Lex;! Used your template for my 4" intake on my new setup and fuel trims at idle are within 3%. I'll get around to doing some maf cals after my exhaust isn't scraping the ground.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
Lex (05-20-2016), Micha (05-18-2016), Vansquish (05-17-2016)
 Old 05-17-2016, 06:14 PM   #313
nell's Avatar
So i did update ATR and it still didnt work. Maybe theres an uapdate for the AP im not to sure. Ill check it out later tonight. Thanks for all your help.
 Old 05-17-2016, 08:56 PM   #314
nell's Avatar
Hi all, ive update the atr software and the AP itself and it still wont work. Ive just realised that the serial number for the map (when about to save) doesnt match the serial number on my AP. Does anyone know how to change the S/N as i think thats why the map gets locked and i cant reflash the ecu
 Old 05-17-2016, 09:54 PM   #315
blackms3_71's Avatar
Posts: 2,250   (View Stats)
blackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the worldblackms3_71 is the leader of the world
Resave the map
COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned
blackms3_71 is offline   Reply With Quote
 Old 05-17-2016, 09:56 PM   #316
nell's Avatar
Ive been trying to, but when i go to save the map it doesnt give me the option to change the serial number??
 Old 05-18-2016, 06:23 AM   #317
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
When you request a copy of ATR from Cobb you need to supply the serial number for your AP as part of the request. Cobb sets the serial number as part of the working key in ATR then provides you the special download link. Every time you save a map it links to that serial number.
If the serial number was incorrect as part of that initial request, or if you're using ATR from any other source than directly from Cobb, it's most likely that the serial number that is saved to the map is not one that matches your AP. That means saving or resaving the map in ATR will not match the serial to your AP, and when you try to flash the map to your ECU it will appear grayed out and you will get the message that the map is "Locked to Serial XXXXXX"
The only way to correct that would be to make a new request to Cobb with the correct serial number. Currently Cobb is "retooling" ATR and it is not available via the website. You can call them directly and let them know what's up- they may hook you up.
blackms3_71 likes this.
340hp / 371tq
 Old 05-20-2016, 01:08 PM   #318
Also keep in mind that if this is an OTS map or a map you made you will be able to save and modify it. If it was built by a tuner using ATP, you won't be able to open or modify it using ATR.
 Old 06-02-2016, 11:38 AM   #319
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
If you need a 2010-2013 version of ATR I can help you out. PM me with your email and I'll send you over the ATR install file.
 Old 06-02-2016, 11:46 AM   #320
MD1032's Avatar
Groans: 143
Yeah but the problem is that your ATR has your serial number locked to it. He still won't be able to flash any maps using it.
2007 Mazdaspeed3 GT
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f600/maf-calibrations-bigger-intakes-124734/
VersaTune - View topic - DTC P2178, P2188 This thread Refback 12-19-2015 07:06 PM
VersaTune - View topic - Share your MAF Calibration This thread Refback 11-23-2015 12:53 AM
VersaTune - View topic - Hello This thread Refback 11-17-2015 02:20 AM
VersaTune - View topic - New to Versatuner/Tuning This thread Refback 06-29-2015 07:49 PM
Sorry gents, MAF CAL ? Mazda MPS Owners Club This thread Refback 12-24-2014 06:37 AM
For Sale: JBR 3" Intake, JBR Heavy Knob, Other assorted parts This thread Refback 07-26-2014 07:51 PM
4th Gear WOT log This thread Pingback 07-05-2014 04:12 AM
Stratified MazdaSpeed / Mazda MPS S-OTS+ Tune This thread Pingback 06-04-2014 11:50 PM
Cobb ap logs help This thread Refback 05-21-2014 04:56 PM
Emew's Tune - Page 23 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-18-2014 08:40 AM
Newbie COBB User This thread Refback 01-17-2014 01:58 PM
New custom made 3.75" Aluminum MAF Housings - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-19-2013 07:09 PM
cobb sure map thats been maf corrected ? Mazda MPS Owners Club This thread Refback 12-08-2013 02:17 PM
Intake Tuning Question? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-03-2013 10:37 AM
Cobb Ap and dash hawk ? Mazda MPS Owners Club This thread Refback 10-04-2013 08:24 AM
Sure Full3 Aeros ID300 Mazdaspeed3 - Mazda 3 Quebec This thread Refback 09-15-2013 08:06 PM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 09-09-2013 10:10 AM
Sure Full3 Aeros ID300 Mazdaspeed3 This thread Refback 08-29-2013 05:03 AM
Mrdouble99 Part out :( - Mazda 3 Quebec This thread Refback 07-28-2013 03:27 AM
Mrdouble99 Part out :( This thread Refback 07-27-2013 05:52 PM
HELP! Advice requested please on SRI and TIP with CobbAP - Page 2 This thread Pingback 05-16-2013 07:07 PM
Solid 14.2 AFR killing my vibe man! - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 03-22-2013 09:45 AM
Nouveauté : HTP 3" Intake Kit - Mazda 3 Quebec This thread Refback 01-28-2013 05:37 PM
HTP 3" full intake - top quality ? Mazda MPS Owners Club This thread Refback 01-27-2013 02:22 PM
HTP 3" Intake - Page 2 This thread Refback 01-24-2013 11:19 PM
AccessTUNER and Stage2 Calibrations Available for 2010 MAZDASPEED3! Travis@Cobb 2010 MS3 - ECU Computer Tuning 173 03-25-2011 08:31 AM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Copying MAF calibrations between maps smakdown61
Cobb ATR Support
3 04-21-2009 02:52 PM
V1.03 Calibrations Now Available for Mazdaspeed3 AccessPORT Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 5 01-09-2009 05:54 PM
Spy Shots: Next Pagani Zonda packing big engine, bigger intakes Haltech Automotive News 1 05-14-2008 05:02 PM
Page generated in 0.62257 seconds with 40 queries
