E-Tuners / Custom Hardparts
Like Tree10Likes
 Old 02-23-2013, 01:10 PM   #121
Originally Posted by mps6dave View Post
its becoming hesitant/juddery up top when fueling gets to about 95%idc,im usually running 265kpa,9.5-10* up top , i can can run 2.38load up to 5k then tapers down to 2.15at 6900rpm if fueling allows it.
i may get a better in tank pump to help with fuel demand
I honestly don't think you have a fueling issues. I have tuned many cars on the stock fuel system with higher loads. If you're getting hesitations up top it's either spark blowout (tighten down the gap to 0.026) or knock.
 Old 02-23-2013, 01:15 PM   #122
mps6dave's Avatar
Posts: 45   (View Stats)
mps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud ofmps6dave has much to be proud of
its closing the throttle but acc pedal still 100%, wgdc drops then about a second later throttle plate.ill post a log hang on sir
mps6,cs tmic,versatuner,one step cooler plugs ngk,jetex 3"cbe,3" catless long pipe,kmd hpfp internals.coolant bypass.bnr3 turbo.3.25 sure maf.egr delete,mani flap delete.injector seals.devils own meth,htp 3" tip,stratified boost dial,cs cab,ported intake,h&r springs,floor braces all round,soon to be forged to get the most out of the turbo
mps6dave is offline   Reply With Quote
 Old 02-23-2013, 01:18 PM   #123
mps6dave's Avatar
here ya go bud
 Old 02-23-2013, 01:21 PM   #124
here ya go bud
I don't see any throttle closure in that log but let's keep this thread on topic.
 Old 02-23-2013, 01:24 PM   #125
mps6dave's Avatar
my bad sorry,back on topic tho,the valve definatly works and works very well
Last edited by mps6dave; 02-23-2013 at 01:24 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-04-2013, 09:18 AM   #126
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
I've started testing my hybrid MBC/EBCS/Stratified Boost Dial approach. http://www.mazdaspeedforums.org/foru...7/#post1928386
The Following 3 Users Say Thank You to RichieRichness For This Useful Post:
BobtailedSnail (03-04-2013), Lex (03-04-2013), TiGraySpeed6 (03-04-2013)
 Old 03-04-2013, 12:41 PM   #127
Sample logs and curves added to OP to better illustrate how to set the Boost Dial.
 Old 03-04-2013, 01:50 PM   #128
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
Looks solid Lex! Nice work man!
The Following User Says Thank You to Alpha For This Useful Post:
Lex (03-04-2013)
 Old 03-09-2013, 05:59 PM   #129
Smelson's Avatar
Posts: 2,237   (View Stats)
Smelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the world
Where should I be getting the boost source from on a k04 with stock EBCS?
Sent while losing to TheFlash
FreekTune
GT2871r- 402/402
Smelson is offline   Reply With Quote
 Old 03-09-2013, 06:03 PM   #130
The manifold OR the compressor housing. Be aware that the compressor housing has a restrictor built in.
 Old 03-09-2013, 06:12 PM   #131
Smelson's Avatar
At the moment I have it coming from the BPV line. I have the knob a quarter turn away from being maxed out and I'm still getting WGDC at 100% in the upper RPM's. I'm tapering to 17lbs at redline so I don't think I'm asking too much of the turbo. I'm waiting on a bigger intake and then I will be getting in touch with you for a tune. I would like to have this sorted out before that though.
FreekTune
GT2871r- 402/402
 Old 03-09-2013, 08:46 PM   #132
Are you spiking during spool? What happens if you go further into the + region? Be careful if you go fully to + your WG will see no boost and you will overboost for sure. Port up a log.
 Old 03-09-2013, 09:00 PM   #133
Smelson's Avatar
I do have a spike and have been working with the WG duty cycle down low to combat that. In the latest revision I have a small spike to 23, I am targeting 22. I have some more work to do because I now have a dip after the spike. I think that log I had the dial a half turn from max, I now have it a quarter turn and will try to get some logs tomorrow. I do have a 3bar MAP sensor so I know what I'm hitting when I do over boost. Here is the most recent log.
FreekTune
GT2871r- 402/402
 Old 03-10-2013, 01:56 AM   #134
Based on your log you may be able to get more boost up top. Target to get 22 psi spool at around 45wgdc and you will need to lower both the wgdc and lec coarse table to start. Turn the dial up as you control your spool to avoid spikes. Also keep in mind that more boost up top may not mean more power.
atvfreek (03-10-2013)
 Old 05-09-2013, 12:59 PM   #135
agentgordon27's Avatar
Posts: 560   (View Stats)
agentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the worldagentgordon27 is the leader of the world
Bought this boost dial, now I know how poor Canadians feel when they order stuff from here and get kicked in the nuts with shipping.
Also, I got my shipping confirmation and am SO used to seeing Canadian pharmacy emails that I almost deleted it. Gathering grains of sand that will be the mountain that is a BT speed.
Stock as fook.
agentgordon27 is offline   Reply With Quote
The Following 3 Users Say Thank You to agentgordon27 For This Useful Post:
Lex (05-09-2013), magicka (05-09-2013), SarcasticOne (05-09-2013)
 Old 05-13-2013, 06:30 PM   #136
blkspeed307's Avatar
Posts: 509   (View Stats)
blkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the world
Received my Strat boost dial last week & definitely a quality piece. Thanks Lex can't wait 2 get it installed along with BT & other parts.
Next custom Strat BT tune.
blkspeed307 is offline   Reply With Quote
The Following User Says Thank You to blkspeed307 For This Useful Post:
Lex (05-13-2013)
 Old 05-16-2013, 02:01 PM   #137
So I have both this and a grimmspeed ebcs, should I just use the boost dial with the stock bcs and change it out later if the stocker takes a crap? I figure I can do a top up tune later if that happens, unless I should just install it for the piece of mind.
Stock as fook.
 Old 05-16-2013, 03:06 PM   #138
Once the boost dial is ... dialed in ... the EBCS will have a fairly small effect. So essentially you can swap from the GS to the OEM and vice versa with minimal to no effect.
agentgordon27 (05-16-2013), blkspeed307 (05-16-2013)
 Old 05-16-2013, 03:53 PM   #139
Thanks, that is great to know, don't hate me cause I didn't get the stratified EBCV, it was sold out
Stock as fook.
 Old 05-16-2013, 04:50 PM   #140
Absolutely not Thank you for getting the Boost Dial, I think you will be quite happy with the tuning results.
atvfreek (05-16-2013)
 Old 06-16-2013, 11:02 AM   #141
Just tuning an EWG GT3071 speed3 using the Boost Dial and OEM boost control solenoid. Look at the perfectly flat boost control with a quick spool and no spiking. You can have your cake and eat it too.
File Type: jpg Stratified GT3071 V1.40 93 octane 100F IAT.jpg (103.6 KB, 397 views)
Dano (06-16-2013), Nliiitend1 (06-16-2013), SpeedRebirth (06-16-2013)
 Old 07-06-2013, 08:43 AM   #142
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
Groaned at 10 Times in 7 Posts
I've just ordered one of these boost dials and now I'm wondering how to configure my (boost based) software correctly.
Up to now I ran a GS ebcs in 3 port mode with a maximum required wgdc of 63-70 (depending on the temps/weather) in order to reach my desired target boost level of 22 psi, so over all I have a wgdc range from ~55-70 at wot.
Of course I also adujsted boost dynamics and load correction tables (besides some others) to meet the requirements.
Now I have a few questions about the correct start settings of the boost dial, in order to get the best "boost window":
- I intend to start with the blue ring, or shall I start with the red one?
- Do I have to reduce any values (wgdc/bd) or can I just leave everything as it is for the first try / test runs?
- How is the further processing? Which components (boost dial, wgdc, bd, boost targets...) have to be adjusted, what is the recommended order and step size for these adjustments to come to a solution without spending too much time? Is it sufficient to adjust only the boost dial little by little or will I also have to experiment a lot with all contributing (software) parameters?
- What is the actual aim - to reach the same wgdc level (and stable boost) as before?
In principle it should be possible to reach the same boost targets using different boost dial windows (but significant different wdgc levels), so what is the "best" setup?
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 07-07-2013, 02:41 AM   #143
I would start with the boost dial in the position that it is currently.
The aim is to get maximum desired boost in the upper RPM around the 90% wgdc point in warm weather.
During spool you should also not be getting spikes.
Take a look at the example tables posted in the first page here and the instructions document.
EmPeEs6 (07-07-2013)
 Old 07-07-2013, 05:47 AM   #144
EmPeEs6's Avatar
Thank's Lex, I just wasn't sure if I should try to keep wgdc quite low (using a red or even golden boost dial setup) or to target something around 90% (using a "softer" setting) in order to achieve my boost targets. You know, there are always several ways to reach the same target state.
So I will probably have to increase my wgdc table significantly. Nevertheless, the main goal will be to have a stable, non oscillating/non spiking boost curve.
 Old 07-07-2013, 11:31 AM   #145
So I will probbaly have to increse my wgdc table significantly. Nevertheless, the main goal will be to have a stable, non oscillating/non spiking boost curve.
You will find a sweet spot in the tuning window of the boost dial where boost ramps up quickly without overshooting targets. If you have it set too far in the + side you will see boost spikes when it spools. If you set it too low (-) you will see slow spool and your WGDC go to 100% without reaching boost targets.
Once you found the correct sweet spot, you leave it and use the ECU to control boost. The setting it comes at is a good setting to start from and you will need minimal changes in most cases.
 Old 07-12-2013, 04:16 PM   #146
If anyone has any questions regarding this boost control method give me a shout. I know it's not the conventional "way" but the results are excellent.
atvfreek (07-13-2013), Funkster777 (07-15-2013)
 Old 07-23-2013, 01:42 PM   #147
EmPeEs6's Avatar
After a few weeks of waiting (especially for the German customs) I finally got my boost dial and now I have an installation question:
The 3rd ("middle") port of my GS is not connected to the wastegate, but to the boost source.
So, shall I "deactivate" the port which is now connected to the wastegate or the port "3" in your diagram, which (in my case) goes to the boost source? Actually I would plug the boost dial in the current connection line from the GS to the boost source and connect the tool to the wastegate, leaving the intake line as it is.
I'm a little bit confused...
 Old 07-23-2013, 01:43 PM   #148
So, shall I "deactivate" the port which is now connected to the wastegate or the port "3" in your diagram, which (in my case) goes to the boost source? Actually I would plug the boost dial in between the current connection line from the GS to the boost source and connect the tool to the wastegate, leaving the intake line as it is.
Check out our 3 port setup diagram:
http://www.stratifiedauto.com/images...203%20Port.png
 Old 07-23-2013, 02:02 PM   #149
EmPeEs6's Avatar
I already studied this diagram - there is also a Grimmspeed example in this thread where the installation seems to be different from mine, too.
The basic question is: should I change/adjust my connections so that they are equal to the ones in your diagram or shall I leave everything as it is (because it works and cannot be totally wrong) and just put the boost dial in the boost source connection line and connect it to the wastegate afterwards, deactivating my current wg port? In principle this is what your diagram shows, although you are using other ebcs ports/port numbers.
 Old 07-24-2013, 02:03 PM   #150
EmPeEs6's Avatar
This evening I wanted to test the boost dial, and...this was the "funniest" test drive ever!
Although I adjusted the boost dial to the red setting (at least for my last run), commanding up to 22 psi at wot (wgdc 60-80), I just reached ~14 psi maximum boost pressure!
Since there are no boost leaks, I was obviously wrong and have to correct my port settings...
But, can anyone explain why (in my case) in 3 port mode the port connections were ok and everything worked fine, but when switching to 2 port mode, I have to change them - probably to the ones on the boost dial diagram?!?
 Old 07-24-2013, 02:32 PM   #151
Although I adjusted the boost dial to the red setting (at least for my last run), commanding up to 22 psi at wot (wgdc 60-80), I just reached 15-16 psi maximum boost pressure!
The connections should be as per the diagram whether it's a GS solenoid or a Stratified one. The port numbers are the same. Basically the 3 port is setup in "2 port mode" and it bleeds boost pressure away from the WG actuator line.
EmPeEs6 (07-24-2013)
 Old 07-24-2013, 03:14 PM   #152
EmPeEs6's Avatar
Finally I've found the reason for my confusion:
If you have a look at the "official" GS installation guide: https://www.grimmspeed.com/install_g...MazdaSpeed.pdf
you can see that the connections for the GS running in 2 port mode are totally different from those for the 3 port mode!
In any case, the boost dial diagram shows the correct settings, which I will test tomorrow ;-)
BTW: The diagram from SarcasticOne on page 3 of this thread shows the correct settings for a GS using the boost dial.
The Following User Says Thank You to EmPeEs6 For This Useful Post:
Lex (07-24-2013)
 Old 07-24-2013, 10:34 PM   #153
This is why I made those diagrams, to remove any confusion. The port numbers for our solenoid, COBB, GS, are all the same so just follow our diagram and the same port numbers if you have a different solenoid.
EmPeEs6 (07-26-2013)
 Old 07-26-2013, 03:59 AM   #154
EmPeEs6's Avatar
Here is my personal impression after the first test runs using the (now correctly installed) boost dial :
First of all I chose the "blue + 1" setting, meaning "almost blue".
The best thing is that boost is much more smooth and stable now, without the "huge" oscillations which I had before, especially for high revs and high boost.
The driving feels so much more comfortable now, and knock tendency also seems to be reduced.
I got some overboosting during spool up, but this was due to the fact that my start wgdc values were much too hight (commanded: 60-65, required: 40-50).
Boost builds up a little bit later but faster now (at exactly 3k) and reaches the target boost level of 21.5-22 psi for high revs with max. observed wgdc values of 75-80. Before the installation, when using the GS in 3 port mode, I needed 65-70, so this is less than expected (which leaves a lot of headroom :-)
@Lex: I intend to keep this setting and focus on adjusting the wgdc table accordingly, or should I try to find an even better boost dial setup?
In any case, it's a very nice tool and absolutely recommendable!
The Following 3 Users Say Thank You to EmPeEs6 For This Useful Post:
kish89 (07-26-2013), Lex (07-26-2013), Nliiitend1 (07-26-2013)
 Old 07-26-2013, 10:06 AM   #155
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Dizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the world
I'm a little confused. You say boost builds a little later, but faster? Am I reading that wrong lol
Dizzy Turbo is offline   Reply With Quote
 Old 07-26-2013, 12:36 PM   #156
EmPeEs6's Avatar
It's just an impression: I command noticeable boost not before 3k. Before, I had already boost at 2.8-2.9k - now it looks like the rise at 3k is sharper, meaning a faster build up. But 100 revs are a negligible difference, moreover boost below 3k is not the best for our engines ;-)
 Old 07-26-2013, 02:49 PM   #157
The majority of the tuning still happens in the tune but the boost dial makes the tuning much easier and smoother. The key is to setup the boost dial correctly and then move to the electronic tuning.
What WGDC do you have at redline and what boost are you running and what is your target? If you are not reaching targets and WGDC is 100% and the turbo can get you those targets you need to move it more towards + slowly. If you are fighting spool spikes with relatively low WGDC values then you need to move it towards -.
Say my target is 25psi on the BNR S3.
I set the boost dial such that between 95 - 100% WGDC in hot weather I am reaching that 25psi at redline
Dano (07-26-2013)
 Old 07-26-2013, 05:58 PM   #158
aldekei's Avatar
Posts: 831   (View Stats)
aldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the world
The idea here is to shape your wgdc table such that you spool quickly without spiking while running 75-85% up top. This leaves room for really hot days AND really cold days while providing for plenty of precision for your tune to manage boost.
Hope I didn't step on any toes @Lex;!
tapawhat
HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke
CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust
Beachshoer Intake Manifold P/P /w VTCS Delete
Sure Shortcut | Sure Anchors | Sure 1/8 TIG
Cobb AP | Cobb FMIC | Cobb Sport Springs
ATP GT3071R /w Stratified Boost Dial
Stratified Automotive Guardian Angel
Go Fast Bits Respons (100% VTA)
Autotech Internals
I tune myself, bitches
aldekei is offline   Reply With Quote
 Old 07-27-2013, 03:05 AM   #159
EmPeEs6's Avatar
That's what I've thought, too.
- I have no big boost spikes or oscillations during spool up
- nevertheless fast boost buildup
- I reach my boost targets (22 psi) up top at wgdc ~80
- The boost curve is smooth and stable
So, why should I change the boost dial setup further - just to reach wgdc values of 90-95 at redline?
At the moment I have no major issues and enough headroom it I want to increase my target boost further (even for hotter weather conditions)...
The boost fluctuations I had around 3k were just because of much too high wgdc start values (which is absolutely consistent, since when I still used the 2-port oem ebcs, I also had to reduce wgdc at 3k-4k and ramp it up afterwards).
So, is it really required to "target" a maximum wgdc of ~95 when adjusting the boost dial???
I dont want to restrict my boost curve too much, so that there's enough room to run different maps without having to adjust the boost dial each time.
Now I have all advantages that I expected:
- no more huge spikes possible
- smoother, more stable boost curve (especially up top)
- comparing to oem reduced wgdc (something between 3-port mode and oem)
- no more need to play around with all kind of boost/wgdc correction tables
- faster boost buildup (although that was not so important for me)
That's absolutely enough for me and I'm very satisfied!
Lex (07-27-2013)
 Old 07-27-2013, 09:15 AM   #160
That's excellent, it sounds like you have the boost dial setup correctly. Happy to hear you're enjoying the smooth boost control.
As much as 3 port is preferred by a lot of people, 2 port boost control is not only easier to dial in but smoother as well and with the Boost Dial it can be applied to ANY turbo.
With a large wastegate such as an EWG it is even more of a breeze.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f600/product-release-stratified-boost-dial-136768/
Limestone Street Scene - View topic - My Speed3 is faster than yours....lol This thread Refback 02-08-2013 12:10 PM
Instead of a 3 port boost solenoid.... ? Mazda MPS Owners Club This thread Refback 02-01-2013 03:19 AM
Product Release! ? CorkSport Adds Mazdaspeed 6 Rear Sway Bar to Product Line-Up CorkSport CorkSport 47 04-22-2014 11:53 PM
Product Release! CorkSport Oil Catch Can Development and Release Notes CorkSport CorkSport 118 03-25-2014 05:20 PM
Product Release! CorkSport LED Underhood Lighting Kit CorkSport CorkSport 12 11-30-2013 04:29 AM
New Product release. Speed 6 rear mount medieval MazdaSpeed 6 - Engine, Transmission & Driveline 22 04-24-2009 09:12 PM
Page generated in 0.60516 seconds with 30 queries
