E-Tuners / Custom Hardparts
Like Tree17Likes
 Old 07-03-2013, 02:22 PM   #121
Originally Posted by iammike View Post
@Lex; So timing is the only difference between the 93 and 91?
Just for the sake of it, I loaded the Stage 2 93 map yesterday and took 6 logs and in every one of them saw KR over 1.5...and a couple of times over 2.5.
Today I loaded up the Stage 2 91 map and did 8 logs and think I only saw over .5 for a couple of cells. Overall much more time spent at 0.0 KR and a few runs never had any KR at all.
As much as it annoys me (because I'm like this) to run a 91 map for 93 fuel, it's obviously the quality of fuel in this area since I've tried two stations and two different brands with virtually the same results.
91 and 93 fuels are catered to the specific fuels mainly through timing changes. Stage 1 and 2 add another level of difference in that they have different load targets as well.
 Old 07-03-2013, 03:46 PM   #122
Spawn's Avatar
Posts: 47   (View Stats)
Spawn is a splendid one to beholdSpawn is a splendid one to beholdSpawn is a splendid one to beholdSpawn is a splendid one to beholdSpawn is a splendid one to beholdSpawn is a splendid one to beholdSpawn is a splendid one to behold
here is a 3rd gear log I did today with stage 2 loaded up. There are 2 cells right when I went WOT where my FP dropped below 1600 (not sure if I should be worried, I have internals installed), also boost only hit 16psi.
Black 2012 Speed3, cobb AP, autotech internals, JBR dogbone, JBR SRI/TIP, JBR SSP, UR testpipe, CP-E triton, JBR knob, JBR OCC
Spawn is offline   Reply With Quote
 Old 07-03-2013, 06:30 PM   #123
Are you at higher altitude?
Also go WOT at 3000 RPM instead of so early in the RPM band. You will get a better boost response.
 Old 07-03-2013, 06:47 PM   #124
Spawn's Avatar
I would say no to higher altitude, I'd say I am pretty close to sea level.
 Old 07-04-2013, 07:09 PM   #125
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Agent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the world
Groans: 665
Groaned at 76 Times in 40 Posts
Hey @Lex; Just took some logs running the S-OTS Stage 1 93 map, all the numbers look great to me, just wondering what you think.
Agent_Orange is offline   Reply With Quote
 Old 07-11-2013, 07:04 PM   #126
Looks just fine.
For those people enjoying the S-OTS maps, if you have a spare moment, we'd really appreciate if you wrote a short review of the maps/product on our site at the link below.
Login : Stratified Automotive Controls
L3THAL6 (07-13-2013)
 Old 07-13-2013, 07:28 AM   #127
L3THAL6's Avatar
Posts: 168   (View Stats)
L3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the worldL3THAL6 is the leader of the world
Groaned at 6 Times in 1 Post
Did some logs last night, this one was with 3 people in the car. I made everyone weigh themselves on a scale when we got back
Originally Posted by shadow102 View Post
Finally got my accessport and flashed in the stage 1 map yesterday and plan on going to the stage 2 map when my internals get here (autotech backorder fail). Anyway i like the option of being able to use the FFS and LC options with the Cobb maps is there any way to add this into the stratified maps as they are locked?
I've used the Cobb Map Conversion Utility to add FFS and LC into my Stratified tune. Find it here: Map Conversion Utilities
Also, since I have an upgraded HPFP I am thinking about trying out the Stage 2 map this morning (:
L3THAL6 is offline   Reply With Quote
 Old 07-13-2013, 10:11 AM   #128
L3THAL6's Avatar
Tried out the Stage II maps, best run was 256WHP/297WTQ, got a little knock higher up and since I don't have a test pipe yet I didn't hit the boost targets in this map. I flashed back to Stage I but as soon as I get my race pipe I'll be flashing back to this map and expecting 280/320
 Old 07-13-2013, 11:25 AM   #129
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
What boost are you hitting?I have a jbr stage 2 and loaded a stage 1 91 Oct map and hit 18.1 psi
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 07-13-2013, 04:39 PM   #130
L3THAL6's Avatar
Highest I saw on that tune was 17, my stage 1 tune spikes to 19. Of course I did the stage 1 logs at night and the stage 2 logs on the morning so weather may have caused the change.
Sent from my PI39100 using Tapatalk
 Old 07-14-2013, 03:01 PM   #131
Speed3_BigV's Avatar
Posts: 23   (View Stats)
Speed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to beholdSpeed3_BigV is a splendid one to behold
Hmm, I have a Sure SRI with TIP and the OTS stage 2 tune hits target boost for me (17.5-18 psi) Stock downpipe and test pipe gives me 245hp/288tq in VD 4th gear at 3572 lbs vehicle weight.
One thing to note, do your pulls in 4th gear and not in 3rd like your sheet shows. Boost is still slightly lower in 3rd than 4th that may be why you dont see 17-18 psi.
I'm wondering tho why your vehicle weight is so high, the stock weight is 3272, you are carrying 600 pounds of stuff in your car? That weight affects the numbers alot and you will see you are far from 256 hp if you input the correct weight and you wont see 280 with a mere test pipe. If I input the same weight as you I get 263hp/310tq and I know I'm not even close to hitting that kind of power yet.
VD is only meant for before/after comparisons, it's probably close to a real dyno but the smallest input mistake can make a world of difference.
| 2010 Mazdaspeed with Tech Pkg / 18x8.5" Enkei T6S w/ Nitto NT05 245/40
| Cobb AccessPORT / Self Tuned
| Ultimate Racing Turboback Exhaust (Catted, Non-resonated) / Ultimate Racing FMIC
| Grimmspeed EBCS / Turbosmart Dual Port BPV / Denso ITV22 / Autotech Internals / JBR EGR Delete / Corksport OCC
| JBR Chrome-Moly 88A RMM / Corksport TMM Insert / Corksport Shifter Bushings
| Prosport Halo Boost Gauge / Corksport LED DRL and Foglight Bulbs / Rally Armor Mudflaps
Speed3_BigV is offline   Reply With Quote
 Old 07-14-2013, 07:48 PM   #132
Playaj's Avatar
Shouldn't we be around 230-240 bone stock with no tune? I could have sworn I've read that plenty of times on here
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
 Old 07-14-2013, 10:35 PM   #133
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
There are a few factors if you are using VDyno.
If you are using a Stage 0 map as a baseline, it is just COBB's interpretation of the stock MAP.
Then there is the usual temperature, elevation, humidity, etc.
Then there is the health of the motor.
I have seen some people make 215 or less on a stage 0 map.
Sent via blown passenger side speakers.
Pickles Tune in progress
 Old 07-14-2013, 10:38 PM   #134
L3THAL6's Avatar
Myself and two friends were in the car, our weights combined were 600 Lbs. I did some pulls with just myself (200 Lbs) today and got the same numbers.
 Old 07-20-2013, 10:21 AM   #135
iammike's Avatar
Posts: 1,415   (View Stats)
iammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the worldiammike is the leader of the world
The Shell gas I get here in Missouri must be better than the Shell gas I get in Maryland. Both are rated 93 octane but I can run the S2 93 map here in Missouri with less than 1 knock while I regularly hit over 2 in MD. Not to mention, it's crazy hot in MO right now while temps were more normal in MD. My intake temps were around 100 degrees and I had been driving down the interstate for over 10 miles.
Anyway, linked are the shared Google Sheets and attached are the .csv's for your reviewing pleasure.
https://docs.google.com/spreadsheet/...EE&usp=sharing
https://docs.google.com/spreadsheet/...Hc&usp=sharing
https://docs.google.com/spreadsheet/...1E&usp=sharing
Mike
iammike is offline   Reply With Quote
The Following User Says Thank You to iammike For This Useful Post:
Lex (07-20-2013)
 Old 07-20-2013, 01:22 PM   #136
Looks like she's running strong!
 Old 07-21-2013, 04:22 PM   #137
Enter the 36 Chambers
NoRegrets's Avatar
Posts: 612   (View Stats)
NoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the worldNoRegrets is the leader of the world
i'm curious if there is a way to disable my cel that i get for the egr delete while using your s-ots2 93oct map.
i downloaded it, but couldn't get into the map itself to disable the cel. maybe i was doing something wrong...
i keep hearing good things about it over the cobb ots maps, but if i can't block the cel then it will just pull power from me.
i would like to get a custom tune form you guys. but at the moment, i still have some things to change around before i'm ready for that.
if anyone can help, it would be greatly appreciated. thanks.
Originally Posted by wassup61 View Post
Blood is good, it feeds your gremlin so your motor doesn't blow. A week without flesh and it will start consuming rods
Tuned by Nishan
GTX3071r : Tial MV-S 38mm ewg : COBB AP : Stratified ebc : CP-E HPFP : CP-E Safe seals : COBB fmic v2 : HKS bov : HTP 4" intake w/battery tray : DNP turbo mani : ATP catless dp : Mazdaspeed cbe : JBR trilogy : TWM sts : MattDamond occ v2 : NGK6510's : Eibach Prokit : Koni Yellow's : Corksport front endlinks : Corksport RSB : JBR EGR Delete : Kozmic Motorsports Primary EGR Delete : TB coolant bypass : Relentless Customs PnP intake mani : Bosch 3 Bar Map Sensor : Bitwise Motorsports Bosch MAP Sensor Connector : South Bend stg3 endurance clutch : 17x8 Enkei TSP5 : Hankook v12 245/45
SP63 Longblock
Head= Mild bowl work as well as mild porting on intake/exhaust.
Bottom end= SP63 Weisco 9.5:1 - 87.5mm : Head Studs 10mm L19 : Manley H-Beam : Rod Bolts ARP Custom Age 625 : Coated Clevite Main & Rod Bearings
NoRegrets is offline   Reply With Quote
The Following User Says Thank You to NoRegrets For This Useful Post:
Lex (07-21-2013)
 Old 07-21-2013, 10:14 PM   #138
The S-OTS maps are locked. I am not sure that you will lose any power from that CEL but it is a nuisance. A custom map definitely removes it and I am playing with some ideas to help people that need slight modifications to these maps.
aromig likes this.
aromig (02-11-2014), NoRegrets (07-21-2013)
 Old 07-22-2013, 12:44 PM   #139
NoRegrets's Avatar
in my experience, the p0401 cel robbed me of some serious power.
i've had my car dynoed 3 times on a dynojet.
1st: 297whp, slightly different mods than in my sig. using a hypertech programer.
2nd: 266whp, same mods in sig but using the hypertech and throwing the p0401 cel due to egr delete. i lost 31whp.
3rd: 286whp, current mods in sig. i gained 20whp back when i was able to block the p0401 code with the cobb ap.
i'm not sure if this will help you in anyway, or if it was just a freaky situation with just me.
thank you for your timely response.
Tuned by Nishan
SP63 Longblock
Lex (07-22-2013)
 Old 07-22-2013, 01:45 PM   #140
deekspeed's Avatar
Posts: 342   (View Stats)
deekspeed is the leader of the worlddeekspeed is the leader of the worlddeekspeed is the leader of the worlddeekspeed is the leader of the worlddeekspeed is the leader of the worlddeekspeed is the leader of the worlddeekspeed is the leader of the worlddeekspeed is the leader of the worlddeekspeed is the leader of the worlddeekspeed is the leader of the worlddeekspeed is the leader of the world
Groaned at 12 Times in 3 Posts
Lex I just ordered the free S-OTS map for my car. How do I go about getting it? Is it a download?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Corksport Race Pipe, M2 Catless Downpipe, CX Racing Piping with TR8 FMIC, Sure ID300 Aeros 3 inch intake, Forge V1 BPV, AccessPORT, FREEKTune 93 with 50/50 meth FTW!, Autotech HPFP Internals, BC Coilovers, JBR Rear Sway Bar, TC Performance Front Traction Bar, Custom Aluminum Shifter Bushings, SURE Short Shift Plate, SNOW Performance Meth Kit with Devils Own D07 nozzle, CP-E Stage 2 Flex RMM, BBS Wheels.
deekspeed is offline   Reply With Quote
 Old 07-22-2013, 01:58 PM   #141
You simply right click an save as on the correct map on the S-OTS maps page.
deekspeed (07-22-2013)
 Old 07-23-2013, 12:21 PM   #142
deekspeed's Avatar
Lex. I have been running the applicable Cobb map for some time and couldnt really tell much difference from a base map. But the Stratified map, WOW. Things just got a little more fun! I need that intercooler then its time for a REAL tune. Thanks!
The Following User Says Thank You to deekspeed For This Useful Post:
Lex (07-23-2013)
 Old 07-23-2013, 12:42 PM   #143
Yatta's Avatar
Posts: 1,862   (View Stats)
Lex, as you know I have been running the S-OTS stage2 91 map for a while and have to say I am impressed, using Dashcommand (I hate the AP as a display, the v3 will fix this but money, whats that?) on my iPhone I see calculated HP/TQ over 300/350, my question is about the 93 map and altitude, the highest available pump gas here is typically 91 octane because in theory altitude makes knock less likely, would if be foolish to try the 93 map with 91 octane at altitude? I understand that heading to the lowlands would require a reflash due to knock or staying out of the throttle until possible but my car is seldom below 5600 ft and spends a good amount of time well above that.
If I haven't said it enough, thanks for these maps, night and day difference from the Cobb OTS.
The Following User Says Thank You to Yatta For This Useful Post:
Lex (07-23-2013)
 Old 07-23-2013, 01:35 PM   #144
Awesome to hear you're enjoying these and looking forward to working with you on the custom tune. It gets even better
Octane rating at the pump is a little hit and miss. Some areas advertise 91 that is better than 93 in other areas. So if you're diligent about monitoring you can see if the 93 tune is too much for your local fuel.
If you're looking to get an AP V3 and a tune from us, we have a little promotion going on:
GI/GB: AP V3.0 + Custom Tune Group Deal
 Old 07-27-2013, 08:46 AM   #145
undercover's Avatar
Posts: 2   (View Stats)
undercover will become famous soon enough
im changing from cobb stage 1+ map to s-ots stage 2 91octane map today. im holding very high boost with that map. a little higher than what im expecting. feel strong.
but it came with alot of KR. - till im abit worried looking at the KR, i short shifted while logging.
immediately after that, i change it back to the cobb stage 1+ 98 octane map.
mods- downpipe, hpfp internal, catback, k&N sri.
i would love if some 1 can tell me what i need to do to run this map with 0 KR .
below is the comparison of both map log. same tank of fuel.
i havent try out s-ots stage 1 map tho, if recommended i will do so.
undercover is offline   Reply With Quote
 Old 07-27-2013, 09:09 AM   #146
A few things are going on here.
First of all you have a K&N intake which is not the same as the JBR intake the map is made for. So the load calculations are off and it's causing the car to target higher boost.
Secondly, KR is related to fuel quality, boost, and temperature. You have to either increase the fuel quality or lower one (or both) the other 2.
It sounds like a custom map for your exact setup and fuel will serve you best.
himurax13 (01-22-2014)
 Old 07-27-2013, 09:37 AM   #147
undercover's Avatar
i got u lex. can u pm me to discuss about custom tune? im from asia. malaysia
The Following User Says Thank You to undercover For This Useful Post:
Lex (07-27-2013)
 Old 07-27-2013, 09:57 AM   #148
PM sent. This is not a problem, we tune international customer all the time.
 Old 09-08-2013, 05:22 PM   #149
sebms6's Avatar
Posts: 3   (View Stats)
sebms6 will become famous soon enough
i juste istalled the stage 2 s-ots map for 91 oct
its seem like i have some kr
i have drive 60 miles before do this datalog
i have datalog with my ap3
i will post my log
my mod are
jbr stage 2 intake
autotech hpfp
test pipe
can you tell me if all is ok
or i need a custum tune
sebms6 is offline   Reply With Quote
 Old 09-19-2013, 12:07 PM   #150
PokeyHokie's Avatar
Posts: 56   (View Stats)
PokeyHokie has a reputation beyond reputePokeyHokie has a reputation beyond reputePokeyHokie has a reputation beyond reputePokeyHokie has a reputation beyond reputePokeyHokie has a reputation beyond reputePokeyHokie has a reputation beyond reputePokeyHokie has a reputation beyond reputePokeyHokie has a reputation beyond reputePokeyHokie has a reputation beyond reputePokeyHokie has a reputation beyond reputePokeyHokie has a reputation beyond repute
@Lex; Any reason I couldn't run the Stage 1 91/93 map on a stock intake since the MAF size is the same?
Or is the stock intake restrictive enough that I'm going to see too much boost trying to hit the load targets that this map calls for?
2012 LSM w/ Tech
JBR 88duro RMM | JBR SSB
PokeyHokie is offline   Reply With Quote
 Old 09-19-2013, 12:18 PM   #151
The OEM intake diameter is actually smaller than the JBR intake. So your targets will be "lower" than the map intends.
himurax13 (01-22-2014), PokeyHokie (09-19-2013)
 Old 09-22-2013, 09:15 PM   #152
Lancer-AM's Avatar
Posts: 306   (View Stats)
Lancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the world
Thank you Lex for these map, I really do appreciate it. I know these are free off the shelf maps but if you have a moment to have a look over my log I would appreciate it. This file has two 4 gear pulls in it. I have the Power Path Stage 3 intake. I am running your Stage 2 93 map. My AFR does not seem to smooth out like everyone else's and according to VD my HP is in the toilet. It feels like it too.
2010 Mazdaspeed 3 Tech
Stocking out
If a person says they 'work smart, not hard,' odds are they are lazy and stupid.
Lancer-AM is offline   Reply With Quote
 Old 09-23-2013, 10:28 AM   #153
The two logs above are not the same. In one you are making a lot more boost than in the other.
The inconsistent AFRs - try removing the CAI section of the intake and see if that makes the AFRs smoother.
 Old 09-23-2013, 10:47 AM   #154
Lancer-AM's Avatar
Yes sorry the VD file is just a trimmed version of one of the pulls that was used for that VD graph. The first file has both pulls inside it that were done one right after the other. The time stamp is retained in the VD file so you can see it in the original. I'll pull the pipe and give it another go.
Stocking out
 Old 11-14-2013, 09:53 AM   #155
Raider YOLO'd my mom
spdandpwr's Avatar
Posts: 965   (View Stats)
spdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the worldspdandpwr is the leader of the world
Groaned at 20 Times in 7 Posts
I just want to give a huge shout-out to @jbarone; & @Lex;. I have the powerpath stage 2 with the accompanying s-ots map and my logs have been reviewed by several individuals for the MAF calibration and they're saying that the cal is spot on! Seriously, good work guys on dialing in the ots tune.
JBR likes this.
Sold: 2013 Mazdaspeed 3 Tech
JBR PowerPath Stage 2 Intake // JBR "Trilogoy" 70a Mounts // Autotech Fuel Pump Internals // Magnaflow 3" Cat-back Exhaust // Cobb AccessPort v3 // Ultimate Racing Catless DP // Ultimate Racing Catless Testpipe // RichTune
Current: 2015 Ford Focus ST
When in fear, drop a gear and disappear
spdandpwr is offline   Reply With Quote
The Following 2 Users Say Thank You to spdandpwr For This Useful Post:
JBR (11-15-2013), Lex (11-14-2013)
 Old 12-31-2013, 11:56 AM   #156
Danfriscia3's Avatar
Posts: 199   (View Stats)
Danfriscia3 has much to be proud ofDanfriscia3 has much to be proud ofDanfriscia3 has much to be proud ofDanfriscia3 has much to be proud ofDanfriscia3 has much to be proud ofDanfriscia3 has much to be proud ofDanfriscia3 has much to be proud ofDanfriscia3 has much to be proud ofDanfriscia3 has much to be proud of
Im new to the mazdaspeed platform and also new to any type of tuning. I have a 13 speed3 with jbr stage 2 sri and autotech internals along with AP and jbr rmm. I downloaded the s-ots maps, and did a couple logs, looking on some input from anyone.
First log is datalog4 which is the stage 2 93 map. I uploaded it drove two days almost a total of 45 miles and then did a log. it was 28 degrees out at time of log and I ran out of room at the end to hit redline.
second log is datalog5 which is the stage 2 91 map. Flashed it and only drove about 2-3 miles before doing a log. it was 34 degrees out and also ran out of room to hit redline.
Like I said im new to the tuning, but I know of some of the key things to monitor ie kr, fuel pressure, ltft's and boost. that being ssaid does anyone have any input? Thanks in advanced
Danfriscia3 is offline   Reply With Quote
 Old 12-31-2013, 01:14 PM   #157
himurax13's Avatar
Groans: 255
Well you need to add Accelerator position and Injector Duty Cycle to the logs.
 Old 12-31-2013, 01:37 PM   #158
I will go back and add those for my next logs
 Old 12-31-2013, 03:57 PM   #159
Logs look good and the tune is doing what it's supposed to. The boost is lower than you'd see when temperatures warm up. We can definitely do more with a custom tune on your car but currently there are no issues running on the S-OTS maps.
btstarcher (12-31-2013), Danfriscia3 (01-01-2014)
 Old 01-21-2014, 02:40 PM   #160
speedaholic's Avatar
Posts: 154   (View Stats)
speedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the world
Here are my first three, 4th gear pulls with the S-OTS 91 stage 1 map. This is on a "false flat" stretch of road. Two pulls on the incline (NW), one down (SE).
They all look good to me but any input is appreciated.
- Ambient temp: -2°F
- Wind: NW/6mph
- Atm. Pressure: 101.6kpa
- Rel. Humidity: 53%
I now know my tach is off by 250rpm as the log shows I started the pulls at 2.7/2.8k to end at 6.2/6.3k instead of 3k to redline. From now on I’ll rely on the AP’s tach.
I'm getting internals, a test pipe and an upgraded top mount in a couple of months so I’m eager to get tuned by Stratified! @Lex;
2015 Black Mustang GT
RIP 2015-06-27
2013 Liquid Silver MS3
speedaholic is offline   Reply With Quote
The Following User Says Thank You to speedaholic For This Useful Post:
Lex (01-21-2014)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f600/stratified-s-ots-maps-jbr-power-path-135125/
Flat foot shift - Mazda 3 Quebec This thread Refback 07-28-2013 06:23 PM
Forum Mazda Performance Series - Zobacz temat - Stratified OTS Maps This thread Refback 03-23-2013 05:44 AM
Intakes Now Available! HTP HTP (Hi-Tuned Performance) 354 10-14-2014 08:21 AM
Mod path for me eksces Mazdaspeed3/6 General Discussion 19 07-31-2012 03:26 PM
Ignition tables in the OTS 1.02 Gen 1 boost maps, hugely different from the Load maps FreeFlyFreak MazdaSpeed 3/6 - ECU Computer Tuning 11 08-18-2011 11:03 PM
Any input from Stage 2 ONLY maps (not + SF, MSCAI maps) steven88
Cobb Access Port/Maps
8 10-15-2008 06:48 AM
Page generated in 0.59955 seconds with 38 queries
