Yes, you can disconnect the sensor or do the 1 click on the MS6. That being said, not sure how much drag even an electronically decoupled rear would generate on the drivetrain. |
Letting you guys know, my cousin owns Tuning Technology in Colton. Lex, if you want call them and speak to Alfred or Jennifer and see what they can do. The have a AWD dyno. If you want I can talk to them unless you have everything under control. Let me know and I'll talk to my cousins. |
1. @dale_gribble (If AWD dyno available) 2. @Boosten Ya(josh) (FWD) (Saturday or Sunday) 3. @himurax13 4. @TheDeebs (FWD, either day) 5. @lilred (FWD)(Saturday) 6. @Zoomspeed(FWD)(Saturday) 7. @Ruination (If AWD dyno available) 8. @insomniacucr (FWD) (Saturday or Sunday) 9. @Sp33dyGT 100% if a sunday 10. @bmfms3 (FWD) 11. @11cruzito11(FWD) 12. @Koke382 (FWD) (Saturday) 13. @Oliverms3 (FWD) 14. @Whiteboy (FWD) (Saturday) 15. @povee (FWD) (Saturday or Sunday) 16. @<32eatV8 (FWD) (Saturday) 17. @ms3rick (FWD) (SUNDAY trying hard to get day off) 18. 19. B) Dyno tuning where we spend some time tweaking on the dyno. I recommend this only for BT cars/E85 cars. This is in the $175 per hour rate ballpark. 1. Ruben - BMW 335i 2. @radioflyer (FWD) 3. @BPASPEED if BT is installed and tune has begun. (FWD) 4. @v8killer (FWD) Saturday or Sunday 5. @Todd98SE (FWD) Assuming BT installed and E85 tune has begun. 6. @krazycoble (FWD) Late Saturday or Sunday 7. @002hex (FWD) (Sat or Sun) Unable to get sat off, changed to sunday for me. (unless late sat is good i get off at 3pm in Hemet.) |
1. @dale_gribble (If AWD dyno available) 2. @Boosten Ya(josh) (FWD) (Saturday or Sunday) 3. @himurax13 (FWD) (Saturday or Sunday) 4. @TheDeebs (FWD, either day) 5. @lilred (FWD)(Saturday) 6. @Zoomspeed(FWD)(Saturday) 7. @Ruination (If AWD dyno available) 8. @insomniacucr (FWD) (Saturday or Sunday) 9. @Sp33dyGT 100% if a sunday 10. @bmfms3 (FWD) 11. @11cruzito11(FWD) 12. @Koke382 (FWD) (Saturday) 13. @Oliverms3 (FWD) 14. @Whiteboy (FWD) (Saturday) 15. @povee (FWD) (Saturday or Sunday) 16. @<32eatV8 (FWD) (Saturday) 17. @ms3rick (FWD) (Sunday) 18. 19. (cuz ^ missed my edit) B) Dyno tuning where we spend some time tweaking on the dyno. I recommend this only for BT cars/E85 cars. This is in the $175 per hour rate ballpark. 1. Ruben - BMW 335i 2. @radioflyer (FWD) 3. @BPASPEED if BT is installed and tune has begun. (FWD) 4. @v8killer (FWD) Saturday or Sunday 5. @Todd98SE (FWD) Assuming BT installed and E85 tune has begun. 6. @krazycoble (FWD) Late Saturday or Sunday 7. @002hex (FWD) (Sat or Sun) |
Fail hahaha/\/\ @ms3rick |
AWD guys don't despair yet. I am looking at several other possibilities but not 100% it's feasible yet. |
Lex, did you talk to them yet? |
I currently have a mazdaspeed CAI 2.75". I was thinking of picking up an aeros 3" system. My ?'s are, do you think there would be any noticeable power increase, and do I need a MAFCAL immediately, would i be able to drive around for a week or so, and how would that affect tuning? Will I need both maps tweaked? Thanks |
For the MAF cal, yes it needs to be done immediately and I have posted MAF cals for different size intakes here: http://www.mazdaspeedforums.org/foru...ntakes-124734/ Any other info you need, just contact me here: https://www.stratifiedauto.com/index...age=contact_us |
Any updates on the location/dyno? |
I say Church Auto cause DynaPacks rule! But I'll go anywhere |
Sent from my DROID4 using Tapatalk 2 |
@Lex, since my 91 tune is done do you have time to street tune an e85 map before this dyno? Sent from my dizzLe using RaWr powers! |
Alright, after a bunch of back and forth here are the details: It's still on for the Oct 20-21 weekend Address: The address is here: 17336 FOOTHILL BLVD, Fontana, CA. The 2WD dyno is very flexible and we can do Sat, Sun, or both. Between the full tunes and dyno day 3 pulls we will probably be there for both days. For 3 pulls we're still looking at $55/car for FWD IF I can get 15 people to sign up. We can maybe do a map swap in between there but this is mostly for people just wanting to get pulls in. Don't expect to get much actual tuning done. This should be fine if I tuned you already on the street and you don't have a BT or E85 tune. For the AWD guys, I found another shop and they are quite a bit more expensive. We're looking at close to doubling the prince since they want 1 hour per car. If you AWD guys really want an AWD dyno and not do the hand brake trick then we have to be looking into this other shop but it will be more. The good thing is that they are right next door (Tuning Technologies) So I need to know from you AWD people but my suggestion is to just for a pull in fwd mode. @dale_gribble, @Ruination) For actual tuning, this will have to be purchased by the hour and it will be $150 per hour. The cars that fall into this category will probably show up the second day and we can have as long as we need on the dyno to fine tune your setup. I recommend this for E85 cars, BT cars, people that really want their stuff fine tuned on the dyno where they can see the numbers. There will be a 1 hour minimum charge. So here's what I need to pre-purchase the time from the shop. The shop is the same as in the OP. 1. I need the people that are FOR SURE doing 3 pulls to paypal me the $55USD and this guarantees your spot. In the paypal e-mail I need the following information: 1. Your name 2. Your screen name 3. Contact phone 4. If there is a day (Sat or Sun) where you CAN'T make it. This is important. 2. For the guys that want to get full tunes and have a MazdaSpeed I will need $150USD deposit for a guaranteed 1 hour. Paypal me this and the following information: 1. Your name 2. Your screen name 3. Contact phone 4. Your setup and goals for the dyno. I want to know if we're fine tuning boost, E85, etc. 5. If there is a day (Sat or Sun) where you CAN'T make it. This is important. If you DO NOT have an MS3/MS6 then you will need to have your ducks in a row and bring all the software and hardware that is needed to tune your ride. Contact me beforehand for this. Paypal is paypal at stratifiedauto com Below I am making a list of the people that have paid and reserved a spot: 3 Pulls: 1. 2. 3. Dyno time: 1. 2. 3. See you in October! And here's a mention for everyone that is tentative: 1. @dale_gribble (If AWD dyno available) 2. @Boosten Ya(josh) (FWD) (Saturday or Sunday) 3. @himurax13 (FWD) (Saturday or Sunday) 4. @TheDeebs (FWD, either day) 5. @lilred (FWD)(Saturday) 6. @Zoomspeed(FWD)(Saturday) 7. @Ruination (If AWD dyno available) 8. @insomniacucr (FWD) (Saturday or Sunday) 9. @Sp33dyGT 100% if a sunday 10. @bmfms3 (FWD) 11. @11cruzito11(FWD) 12. @Koke382 (FWD) (Saturday) 13. @Oliverms3 (FWD) 14. @Whiteboy (FWD) (Saturday) 15. @povee (FWD) (Saturday or Sunday) 16. @<32eatV8 (FWD) (Saturday) 17. @ms3rick (FWD) (Sunday) 18. 19. (cuz ^ missed my edit) B) Dyno tuning where we spend some time tweaking on the dyno. I recommend this only for BT cars/E85 cars. This is in the $175 per hour rate ballpark. 1. Ruben - BMW 335i 2. @radioflyer (FWD) 3. @BPASPEED if BT is installed and tune has begun. (FWD) 4. @v8killer (FWD) Saturday or Sunday 5. @Todd98SE (FWD) Assuming BT installed and E85 tune has begun. 6. @krazycoble (FWD) Late Saturday or Sunday 7. @002hex (FWD) (Sat or Sun) |
Paid! :D @Lex How did everything go with my cousin? Let me know if you got the payment. |
I tried paypal. I need an email address or phone # to send payment. Or is there another way to send payment? Going thru paypal site right now. Thanks |
Mine and @11cruzito11 are paid but I fucked up. Instead of the day we can't make it I put the one we could. I fucked up Lex. We are on for Saturday only Saturday only. :sad6: I'm all :trink26::hypnotized::hypnotized: on meds right now. @Lex |
Is it $150 total for tuning? or 150 + dyno fee? |
Nevermind. It worked. |
Ouch. So that's 100+ for standard AWD dyno pulls? |
So far guaranteed spots and paid (Thank you!) we have: Below I am making a list of the people that have paid and reserved a spot: 3 Pulls: 1. povee (both days) 2. bmfms3 (can't on Sun) 3. 11cruzito11 (can't on Sun) Dyno tuning time 1. 2. 3. Quote:
So far guaranteed spots and paid (Thank you!) we have: Below I am making a list of the people that have paid and reserved a spot: 3 Pulls: 1. povee (both days) 2. bmfms3 (can't on Sun) 3. 11cruzito11 (can't on Sun) 4. UnknownSuperhero / TheDeebs Dyno tuning time 1. 2. |
Paid for dyno, and tune. Can't wait! |
@povee get on that shit brah. |
@Lex are you near your magic making laptop machine? Its my only day off in the next 6 days I could push logs out instantly for u :X <3 |
I will talk to my cousin tonight. |
@Lex, just paid my fee. Can I just start a direct deposit with you? ;) Anywhoo, do I need to do the 1 hour tune? |
Moved the post with who has paid to OP and I will update there. Quote:
Also just put in an order with COBB for AccessTuner Pro. So we won't need to run around resaving map on individual laptops anymore. :) |
I just sent my money too for tuning on the 21st. And I should get you my logs again tonight so we can get started |
Sent from my dizzLe using RaWr powers! Quote:
Just paid for the hour of dyno time, Saturday only. Thanks, |
| All times are GMT -7. The time now is 01:55 AM. |
