Well, I'm running the HKS VTA right now and haven't had any issues. I guess the HKS and Greddy are the only two you can run like that? |
2nd day of mixed driving on my greddy vta, had a few little pops in the exhaust but it dosnt seem to be going rich inbetween shifts |
I need condom and ga with this feature ! |
Check the storage aisle at the hardware store. The little bastards are used on wire shelving. |
2 Attachment(s) mine. |
Thanks lex for this thread, I need to get myself a GA. |
Hmm, I wonder how a 1g dsm crushed would do. |
turbo spool from the front and through the exhaust sounds mean |
So, I was told about the thread and how Lex found you can run the Stocker VTA. Well, I tried it since I was swaping TIPs (Broke the stupid nipple). At idle if you put your hand in front its just puffin out air like crazy, at least mine was. So I drove it up the block. Seemed ok at first but then during cruising (not accelerating, just PT or enginebreaking) it was at -25. Shifts had horrid response. But the blow off was very non-dramatic and gave me a boner that spit white rice. Quote:
just tried this out, with my only mod being a CS intake/tip. only thing i noticed was idle was a little lower and had an occasional studder while idling w/o defrost or AC on. the rest of the time it drove like normal, the shifting being a little different, but not much. |
Again. People are missing the point of this thread. It's not "hey vta the stocker" it's "ga allows you to vta the stocker and any bpv" |
the point is if you are only having problems at idle and decel, then the GA could be a solution for those who want to serve some rice. but then if you can run a bpv vta with the GA, then why not just run a BOV thats designed to stay shut at idle and decel? |
The POINT was that I can run VTA because of a new feature I am adding to the GA. If you guys think the car runs well VTA on the stock valve, wait until you see how well it runs with the GA. |
:) how is the ga progress mr lex!!!!!! Can't wait! Is there going to be fine tuning needed per vehicle? |
That GA is freakin cool. definitely on my list of what to do next. |
Basically, if this ends up being a feature you include in the GA you will allow people to run VTA possibly on nearly the same exact tune with the included feature of safety. Specially since the GA is cheaper then a new HKS. |
going back to recirc until I pick up this hks, you can hear the bpv leak at idle |
For those still not making the GA connection, please see below references: http://www.mazdaspeedforums.org/foru...ection-104486/ http://www.mazdaspeedforums.org/foru...-angel-109466/ http://www.mazdaspeedforums.org/foru...-angel-109331/ .. |
if I were running an OE type BPV and wanted to go VTA...it would be a no brainer to get a GA instead of upgrading to an HKS type BOV. two birds one stone |
That's my thinking here. |
I'm gonna prob pick this up next paycheck or the following |
The change to add the VTA feature to the GA is a software change so the implementation will be quick but I will have to do more testing with aftermarket BPVs before release. I am picking some up tomorrow. The OEM works well but we'll see how different springs affect things. I am also going to investigate how running the feature AND recirculating will affect spool (ie by keeping the valve close, can I improve spool)? In the end the feature will be something the customer can turn on and off as they desire. |
glad to hear the stock bpv works well with this new feature, as it sounded pretty nice vented. loud too. starting rice fund now. |
Funny how more people are interested in the VTA (rice :)) feature than the failsafe aspect. |
ricers |
how much for GA? |
gay |
On off switch? Sound like calm weekday driver & Friday Night Rice :D Quote:
Sent from my Galaxy Nexus using Tapatalk 2 |
| All times are GMT -7. The time now is 01:57 AM. |
