-   -   VTA ... (http://www.mazdaspeedforums.org/forum/f600/vta-115811/)
himurax13 06-22-2012 04:47 PM
I can't wait to try out my TS Dual Port on this. :shhh:
Ziggo 06-22-2012 06:42 PM
Originally Posted by Dano (Post 1475575)
ahem..
gotta keep up with the Jones' [me]
I do believe you forgot who is wearing the crown :banana:
dantes5823 06-22-2012 07:14 PM
What do you mean? Does it not work vta as is?
Dano 06-22-2012 10:08 PM
Bitch. Just knew that would come up. Or you'd say " who already has a 5th port"
Lol
My eyes r on you. Your bases will belong to me!
HahahaahH
Prab not but it's fun to say.
Keep up the good work brotha!
Tappin
Lex 06-22-2012 11:35 PM
Originally Posted by Ziggo (Post 1475563)
Arregghh.
I relocated my XLE BPV in prep for 5th port, and my fears were correct, COBB says the XLE can function as a BOV, but they lie. You just can't get enough preload on it to keep it closed at idle.
I just spent $70 on a samco superflex hose to recirculate from its current position, that money could have put me that much closer to a GA instead. What is the timeline on this?
Zigatapatalka
Release of the feature likely next week.
Dano 06-23-2012 12:00 AM
I don't care about being a ricer...nor do I hate the ricers...but even in recirc if my chit is leaking boost I don't want that...so please allow the early GA adopters to get the updated FW.
I run blue 2 shims....hahahah.....anything more than that an I get surge.
help me pls :)
Dash08 06-23-2012 11:50 AM
help me pls :)
LOL @ blue 2 shims.
I wish I had a dollar for every time somebody used this as a response to a stupid question.
I'd be filthy rich.
m249saw 06-23-2012 12:17 PM
Originally Posted by Dash08 (Post 1476350)
LOL @ blue 2 shims.
I'd be filthy rich.
Which is weird because I use blue and no shims. Even 1 and a get comp surge
Sent from my DROID RAZR using Tapatalk 2
Lex 06-23-2012 12:58 PM
help me pls :)
The BPV is kept closed at idle and low load with this feature - under boost you will have the same situation as with a normally functioning BPV.
The Forge I just tested worked best with blue - 2 shims :)
Mistersix 06-25-2012 09:04 PM
I just finished up a custom FMIC with treadstone tr-8 and had to run the oem bpv vta because i had no hose for recirc. I love the sound, but hate the pops and back fires, the 9.xx afr at idle and the bucking at part throttle low speed.
@Lex I've been following this thread from the begining without interest in vta but rather the boost protection. ( i hate the brick wall effect of fuel cut) but with this current serving of rice i want more.
So, does your device only help with the rich idle condition? What about the richness in between shifts and the pops and backfires? My car seems to recover from its rich condition by going lean for a moment as shown in the log below. This log is lift shifted at about 5k. The just getting on it kinda driving not WOT FFS.
I'm targeting 11.4afrs. CL exit @ 1.0 20psi taper to 17psi. This is the same map i was using with TMIC so i've not got to tuning it just yet. But other than idle, ltft's are spot on.
Lex 06-25-2012 09:27 PM
The device helps between shifts as well. As you get off the throttle, the device will close the valve since keeping it open while you're in vacuum and driving will cause the same rich situation as at idle. So I've done some fine tuning such that the device will allow as little air as possible to escape before closing the BPV between shifts while also keeping things surge free (right on the edge of it). This resulted in the smoothest results and shifts. I do get a pop here and there, mostly at partial throttle but it happens 1-2 times during an entire drive.
I drove with the OEM BPV in VTA without the GA and it was terrible in terms of hesitation after a shift and gas economy. I can't imagine doing that with the OEM BPV, without the GA it leaks all the time unless you're in boost.
EDIT: I should mention - the OEM BPV is a diaphragm type. If it breaks or starts to leak, it will start to close on its own more and more. This is bad because it will also leak under boost. My BPV holds vacuum perfectly from the top port and this is a good test for the BPV itself. If it doesn't hold vacuum, it will leak under boost and it will improve how running it VTA feels since it will close under vacuum.
Mistersix 06-26-2012 05:48 AM
Ya it sits open about a 1/4" when at idle. And yes it sucks to drive. I've always like the stock valve. Mine has always worked great and it sound decent to.
I have noticed that it sounds like it stays open for a long time. Say you rev the engine to get it to go woosh, it doesn't just go:
Psssh!
It goes:
Psssssssssssssssssssssssssssssssssssssshhhhhh!
In a near comical fashion.
So the GA closes the valve after a shift before your back on the gas and the valve closes itself under vacuum/boost? As if to eliminate the lazyness of the oem valve? Interesting.
I'm curious to see you test more valves with this and develop it further. I'm sold on it for the over boost protection already. I'm currently over boosting because haven't tuned my new set up.
Will this new feature be adjustable?
Lex 06-26-2012 11:22 AM
Psssh!
It goes:
I have already tested non OEM valves and they work better than OEM in VTA ... simply because of how fast and stiff the OEM is. The OEM is worlds better than without the GA in VTA but others are even better. The OEM also has twin chambers making it like I said a very fast and unique valve.
The feature is not adjustable - it's just an add on to the failsafe device. You will be able to turn it on and off however.
himurax13 06-26-2012 12:40 PM
So if I use the feature with say a TS BOV and then turn it off when I drop in a Forge V2 BPV, will I need to make any adjustments to my tune?
BlueDmnSpeed 06-26-2012 01:23 PM
i need something to plug the recirc part of my Cobb TIP so i can do this. i have the HKS SSQV3 and want to do this. who knows maybe it'll fix my too lean after cat CEL lol
m249saw 06-26-2012 02:45 PM
I think @eric@edgeautosport has something. Billet recirc plug
Lex 06-26-2012 05:29 PM
If you run any of those valves (TS or Forge) in VTA you should have this feature enabled. If you recirculate them, you can disable it.
dooderek 06-26-2012 05:31 PM
alex unloading knowledge onto my dry erase board
himurax13 06-26-2012 05:38 PM
I haz video with explanation
<div style="display: none;" id="ame_noshow_post_1340753363_2">
<a href="" title="MazdaSpeed Forums Presents: YouTube" target="_blank">MazdaSpeed Forums Presents: YouTube</a>
</div>
<div style="display: inline;" id="ame_doshow_post_1340753363_2">
<div align="center">
<table class="tborder" cellpadding="6" cellspacing="1" width="640" style="margin:10px 0">
<thead>
<tr>
<td class="tcat" colspan="2" style="text-align:center">
</td>
</tr>
</thead>
<tbody>
<tr>
<td class="panelsurround" align="center">
<object width="640" height="480">
<param name="movie" value="http://www.youtube.com/v/hHdgf48EOSo&start="></param>
<param name="allowFullScreen" value="true"></param>
<embed src="http://www.youtube.com/v/hHdgf48EOSo&start=" type="application/x-shockwave-flash" allowfullscreen="true" width="640" height="480" wmode="transparent"></embed></object>
</td>
</tr>
</tbody>
</table></div>
</div>
LOL, so the answer is I can run VTA with this feature on and Recirc with the feature off and I don't need to adjust my tune? :naughty:
Lex 06-26-2012 05:39 PM
Since the above link was screwed up with Automerge ... I haz video with explanation
dooderek 06-26-2012 05:46 PM
i want royalties for this idea
Lex 06-26-2012 05:48 PM
I give you love :)
himurax13 06-26-2012 05:57 PM
So will you just have a Red Toggle switch that has a label of a bowl of rice on all of the NEW GA's?
Lex 06-26-2012 06:11 PM
No, it will be smarter than that. The change is software only.
xxdjfate76xx 06-26-2012 06:26 PM
So does that mean its out? Need to order one by Friday
Lex 06-26-2012 06:31 PM
Not quite, my plan is to have final software release by the end of this week. I will post announcement here.
Dmurray06 06-26-2012 06:31 PM
I wantz some rice
Mistersix 06-26-2012 08:49 PM
Awesomeness!!! I want one. I'm loving the sound of my OEM VTA but the car sucks to drive.
I've never had VTA before and that big woosh of air in between shifts completes the experience of driving a turbocharged car, rice or not.
What valve was that in that video? Forge? Which one?
Lex 06-26-2012 08:55 PM
Forge V1.
Mistersix 06-26-2012 09:09 PM
Originally Posted by Lex (Post 1481622)
Forge V1.
Oh!!?? I've had that valve before. It didn't sound so.....clangy vta. Maybe i should watch the vid again.
IMASA 06-26-2012 09:26 PM
I assume we have to send the units back to get its firmware update, but can we disable/enable this VTA feature ourselves?
dantes5823 06-26-2012 09:43 PM
Damn that sounds nice in vta. Should gotten an in car clip. In before forges get all bought up.
Lex 06-26-2012 11:41 PM
Yes and yes. The firmware update for existing customers will need to be done by me so the units will have to come in. For you it's nice and easy since you're local :) The feature the user will be able to disable and enable themselves as they wish once the firmware is updated.
With my camera all you hear in-car is the exhaust rumble - I tried. Also as it's noted in the captions, the GA works with ANY of the push type BPVs in VTA. It doesn't have to be a Forge. Actually the Turbosmart I tested as well was a little smoother of a valve.
mrtheandrew 06-27-2012 10:59 AM
Sweet, 'UNCLBEN' is available for a personalized plate in my state.
m249saw 06-27-2012 03:55 PM
Gonna get one to go with my Tial QR as soon as you give the word
dantes5823 06-27-2012 03:57 PM
Good idea. I gave in to peer pressure and bought and hks
dooderek 06-28-2012 12:37 AM
im drunk
Mistersix 06-28-2012 08:56 PM
@Lex give me a mention when you announce this is ready.
Thanks.
m249saw 06-29-2012 06:50 AM
Thanks.
Same as above. Im ready to buy as well
XerocX 06-29-2012 10:14 PM
So will there be ninjas fighting in the forge v1 when it's in vta??
Page generated in 0.24129 seconds with 11 queries
